Technical Data 10978
Effective November 2019
MCLA3216V1
Automotive grade multilayer inductor
Applications
Product features
AEC-Q200 qualified
1206 (3216 metric) package
Multilayer monolithic construction yields high
reliability
Inductance range from 0.047 uH to 12 uH
Moisture sensitivity level (MSL): 1
ADAS
Infotainment
Wireless communications
Wifi, bluetooth, satellite
Antenna tuning
On board computer
Environmental data
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
HALOGEN
Pb HF
FREE
MCLA3216V1
Product specifications
Part number
OCL
Tolerance
OCL (µH)
Q minimum
DCR@ (Ω)
@ +25 °C
maximum
Test
frequency
(MHz)
Test
voltage (mV)
SRF (MHz)
minimum
I Rated (mA)
MCLA3216V1-R047-R
±10
0.047
30
0.15
50
50
320
300
MCLA3216V1-R056-R
±10
0.056
30
0.2
50
50
320
300
MCLA3216V1-R068-R
±10
0.068
30
0.25
50
50
280
300
MCLA3216V1-R082-R
±10
0.082
30
0.25
50
50
280
300
MCLA3216V1-R100-R
±10
0.1
25
0.25
25
50
235
250
MCLA3216V1-R120-R
±10
0.12
25
0.25
25
50
220
250
MCLA3216V1-R150-R
±10
0.15
25
0.25
25
50
200
250
MCLA3216V1-R180-R
±10
0.18
25
0.3
25
50
185
250
MCLA3216V1-R220-R
±10
0.22
25
0.3
25
50
170
250
MCLA3216V1-R270-R
±10
0.27
25
0.3
25
50
150
250
MCLA3216V1-R330-R
±10
0.33
25
0.3
25
50
145
250
MCLA3216V1-R390-R
±10
0.39
30
0.5
25
50
135
200
MCLA3216V1-R470-R
±10
0.47
30
0.5
25
50
125
200
MCLA3216V1-R560-R
±10
0.56
30
0.5
25
50
115
150
MCLA3216V1-R680-R
±10
0.68
30
0.5
25
50
105
150
MCLA3216V1-R820-R
±10
0.82
30
0.6
25
50
100
150
MCLA3216V1-1R0-R
±10
1.0
35
0.3
10
50
75
100
MCLA3216V1-1R2-R
±10
1.2
35
0.4
10
50
65
100
MCLA3216V1-1R5-R
±10
1.5
35
0.4
10
50
60
50
MCLA3216V1-1R8-R
±10
1.8
35
0.4
10
50
55
50
MCLA3216V1-2R2-R
±10
2.2
35
0.5
10
50
50
50
MCLA3216V1-2R7-R
±10
2.7
35
0.5
10
50
45
50
MCLA3216V1-3R3-R
±10
3.3
35
0.5
10
50
41
50
MCLA3216V1-3R9-R
±10
3.9
35
0.6
10
50
38
50
MCLA3216V1-4R7-R
±10
4.7
35
0.65
10
50
35
25
MCLA3216V1-5R6-R
±10
5.6
35
0.8
4
50
32
25
MCLA3216V1-6R8-R
±10
6.8
35
0.8
4
50
29
25
MCLA3216V1-8R2-R
±10
8.2
35
0.8
4
50
26
25
MCLA3216V1-100-R
±10
10
35
0.8
2
50
24
25
MCLA3216V1-120-R
±10
12
35
0.9
2
50
22
15
1. Test frequency and voltage is for open circuit inductance (OCL) and Q at +25 °C
2. Rated I: When rated I is applied to the product, self-temperature rise will be 40 °C or less.
2
www.eaton.com/electronics
3. Part Number Definition: MCLA3216V1-xxx-R
MCLA32162V1 = Product code and size
xxx= inductance value in µH, R= decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
MCLA3216V1
Mechanical parameters, schematic, pad layout (mm)
Recommended pad layout
Schematic
Part Number
L
W
T
a
F
G
H
MCLA3216V1-xxx-R
3.20±0.20
1.60±0.20
0.90±0.20
0.50±0.30
2.00 ref
1.40 ref
1.20 ref
Part marking: No marking
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.1 millimeters unless stated otherwise
Pad layout dimensions are reference only
Traces or vias underneath the inductor is not recommended
Packaging information (mm)
Drawing not to scale
Supplied in tape and reel packaging, 4000 parts per 7” diameter reel
Boom cover tape
Top cover tape
Center lines of cavity
Boom cover tape
Top cover tape
Direcon of feed
W±0.2
8.00
F±0.1
3.50
E1±0.2
1.75
E2 Min
na
P0±0.2
4.00
P1±0.2
4.00
P2±0.1
2.00
D0±0.1
1.55
A0
1.9±0.2
B0
3.5±0.2
T
0.95±0.1
T1 Max
na
3
MCLA3216V1
Inductance vs frequency
Inductance (nH)
MCLA3216V1-R047-R
Frequency (MHz)
Inductance (nH)
MCLA3216V1-1R0-R
Frequency (MHz)
Inductance (nH)
MCLA3216V1-120-R
Frequency (MHz)
4
MCLA3216V1
Q vs frequency
Q
MCLA3216V1-R047-R
Frequency (MHz)
Q
MCLA3216V1-1R0-R
Frequency (MHz)
Q
MCLA3216V1-120-R
Frequency (MHz)
5
MCLA3216V1
Solder reflow profile
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used
in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com/electronics
© 2019 Eaton
All Rights Reserved
Printed in USA
Publication No. 10978 BU-MC19106
November 2019
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“MCLA3216V1-R056-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4000+0.516814000+0.06439
