MCL1608V1-2R7-R
MCL1608V1-2R7-R
    EATON(伊顿)
    固定电感器 0603 2.7µH ±20% 100mA 600mΩ 45MHz
MCL1608V1-2R7-R 数据手册
Technical Data 10926 Effective June 2019 MCL1608V1 Multilayer chip inductor Applications Product features • Industrial connectivity (IoT) • Wireless communiations • Bluetooth • WiFi • Antenna • Machine-to-machine (M2M) • Mobile phones • Wearable devices • Wireless LAN • Computing/gaming consoles • 0603 (1608 metric) package • Low DC resistance, high current Broadband components • • Multilayer monolithic construction yields high reliability RF transciever modules • • Suitable for wave and reflow soldering • Inductance range from 0.047 uH to 12 uH Environmental data • Moisture sensitivity level (MSL): 1 • Operating temperature range: -40 °C to +85 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant HALOGEN Pb HF FREE MCL1608V1 Multilayer chip inductor  Technical Data 10926 Effective June 2019 Product specifications Part number OCL (uH) ±20% I Rated (mA) maximum DCR (Ω) maximum @ +25°C SRF (MHz) minimum Test frequency (MHz) Test voltage (mV) MCL1608V1-R047-R 0.047 150 0.12 260 1.0 50 MCL1608V1-R056-R 0.056 150 0.12 260 1.0 50 MCL1608V1-R068-R 0.068 150 0.12 250 1.0 50 MCL1608V1-R082-R 0.082 150 0.12 245 1.0 50 MCL1608V1-R10-R 0.100 150 0.15 240 1.0 50 MCL1608V1-R12-R 0.120 150 0.20 205 1.0 50 MCL1608V1-R15-R 0.150 150 0.20 180 1.0 50 MCL1608V1-R18-R 0.180 150 0.20 165 1.0 50 MCL1608V1-R22-R 0.220 150 0.25 150 1.0 50 MCL1608V1-R27-R 0.270 100 0.30 136 1.0 50 MCL1608V1-R33-R 0.330 100 0.30 125 1.0 50 MCL1608V1-R39-R 0.390 100 0.35 110 1.0 50 MCL1608V1-R47-R 0.470 100 0.45 105 1.0 50 MCL1608V1-R56-R 0.560 100 0.45 95 1.0 50 MCL1608V1-R68-R 0.680 100 0.55 90 1.0 50 MCL1608V1-R82-R 0.820 100 0.60 85 1.0 50 MCL1608V1-1R0-R 1.0 150 0.30 75 1.0 50 MCL1608V1-1R2-R 1.2 150 0.30 65 1.0 50 MCL1608V1-1R5-R 1.5 120 0.35 60 1.0 50 MCL1608V1-1R8-R 1.8 120 0.40 55 1.0 50 MCL1608V1-2R2-R 2.2 120 0.50 50 1.0 50 MCL1608V1-2R7-R 2.7 100 0.60 45 1.0 50 MCL1608V1-3R3-R 3.3 100 0.65 40 1.0 50 MCL1608V1-3R9-R 3.9 80 0.70 35 1.0 50 MCL1608V1-4R7-R 4.7 80 0.75 33 1.0 50 MCL1608V1-5R6-R 5.6 60 0.90 22 1.0 50 MCL1608V1-6R8-R 6.8 60 0.90 20 1.0 50 MCL1608V1-8R2-R 8.2 60 1.05 18 1.0 50 MCL1608V1-100-R 10 60 1.15 17 1.0 50 MCL1608V1-120-R 12 60 1.25 15 1.0 50 1. Test frequency and voltage at +25 °C 2. Resistance to soldering heat: +260 ±5 °C for 10 ± 1 second 3. At low temperature (-40 ±2°C) the inductance change is within ±10% 4. At high temperature (+85 ±2°C) the inductance change is within ±10% 2 www.eaton.com/electronics 5. Rated I: When rated I is applied to the product, self-temperature rise will be 40 °C or less. 6. Part Number Definition: MCL1608V1-xxx-R MCL1608 = Product code and size V1= Version indicator xxx= inductance value in uH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant Technical Data 10926 MCL1608V1 Multilayer chip inductor Effective June 2019  Dimensions (mm) Schematic Recommended pad layout B L C Part Number L W T a A B C MCL1608V1-xxx-R 1.6 ±0.20 0.80 ±0.20 0.80 ±0.20 0.30 ±0.20 1.2 ±0.10 0.9 ±0.10 040 ±0.10 No part marking All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.2 millimeters unless stated otherwise Pad layout tolerances are ±0.1 millimeters unless stated otherwise Do not route traces or vias underneath the inductor Packaging information (mm) Drawing not to scale Supplied in tape and reel packaging, 4000 parts per 7” diameter reel W ±0.3 F±0.05 E1±0.10 E2 Min P0±0.10 P1±0.20 P2±0.1 D0+0.10/-0 A0 B0 T Max T1 Max 8.00 3.50 1.75 6.25 4.00 4.00 2.00 1.50 1.1±0.20 1.9±0.20 1.10 na www.eaton.com/electronics 3 MCL1608V1 Multilayer chip inductor  Technical Data 10926 Effective June 2019 Inductance vs frequency Q vs frequency 60 10 50 40 8 6 MCL1608V1-2R2-R MCL1606V1-R39-R MCL1608V1-100-R 4 2 0 Q value Inductance [uH] 12 MCL1608V1-R39-R 20 MCL1608V1-100-R 10 0     Frequency [MHz] MCL1608V1-2R2-R 30    Inductance vs current 10,000 Inductance (nH) 1,000 100 10 1    Current (mAdc) MCL1608V1-100-R MCL1608V1-R39-R MCL1608V1-2R2-R Temperature rise vs current Temperature rise (°C) 90 80 70 60 50 40 30 20 10 0 0 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 Current (Adc) MCL1608V1-100-R MCL1608V1-2R2-R MCL1608V1-R39-R 4 www.eaton.com/electronics 1 1.1 1.2 1.3 1.4 1.5   Frequency [MHz]  Technical Data 10926 MCL1608V1 Multilayer chip inductor Effective June 2019  Solder reflow profile TP TC -5 °C tP Max. ramp up rate = 3° C/s Max. ramp down rate = 6 °C/s Temperature TL Preheat A T smax Package Thickness Volume mm3
MCL1608V1-2R7-R 价格&库存
很抱歉,暂时无法提供与“MCL1608V1-2R7-R”相匹配的价格&库存,您可以联系我们找货
