HCM1A0703-220-R
HCM1A0703-220-R
    EATON(伊顿)
    IND_7.1X6.8MM_SM
    功率电感 22µH ±20% IND_7.1X6.8MM_SM 3.00mm 7.10 x 6.80mm 149mΩ 2A
HCM1A0703-220-R 数据手册
Technical Data 10548 Effective August 2016 HCM1A0703 Automotive grade High current power inductors Applications • • Body electronics • Central body control module • Vehicle access control system • Headlamps, tail lamps and interior lighting • Heating ventilation and air conditioning controllers (HVAC) • Doors, window lift and seat control Advanced driver assistance systems • 77 GHz radar system • Adaptive cruise control (ACC) • Automatic parking control • Collision avoidance system/Car black box system Product features • AEC-Q200 Grade 1 qualified • High current carrying capacity Infotainment and cluster electronics • Active noise cancellation (ANC) • Magnetically shielded, low EMI • Audio subsystem: head unit and trunk amp • Frequency range up to 1 MHz • Digital instrument cluster • Inductance range from 0.1 μH to 33 μH • In-vehicle infotainment (IVI) and navigation • Current range from 1.6 A to 36 A • • 7.4 mm x 7.0 mm footprint surface mount package in a 3.0 mm height Port power/USB HUB for front and rear passengers • Alloy powder core material • Moisture Sensitivity Level (MSL): 1 • Halogen free, lead free, RoHS compliant • • Chassis and safety electronics • Airbag control unit • • Electronic stability control system (ESC) Engine and Powertrain Systems • Electric pumps, motor control and auxiliaries • Powertrain control module (PCU)/Engine Control unit (ECU) • Transmission Control Unit (TCU) Environmental Data • Storage temperature range (Component): -55 °C to +155 °C • Operating temperature range: -55 °C to +155 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant HALOGEN Pb HF FREE HCM1A0703 Automotive grade high current power inductors Technical Data 10548 Effective August 2016 Product Specifications Part Number6 OCL1 (μH) ± 20% FLL2 (μH) minimum Irms3 (A) Isat4 (A) DCR (mΩ) typical @ +20 °C DCR (mΩ) maximum @ +20 °C K-factor5 HCM1A0703-R10-R 0.10 0.06 22 28 1.2 1.4 2737 HCM1A0703-R15-R 0.15 0.09 18.5 36 1.5 1.8 1358 HCM1A0703-R22-R 0.22 0.13 17 24 2.3 2.7 1386 HCM1A0703-R33-R 0.33 0.21 14 19 3.5 4.0 907 HCM1A0703-R47-R 0.47 0.30 12 17 3.7 4.2 818 HCM1A0703-R56-R 0.56 0.35 10.3 14 4.7 5.2 740 HCM1A0703-R68-R 0.68 0.43 10 15 5.0 5.5 574 HCM1A0703-R82-R 0.82 0.52 8.5 14 6.7 8.0 482 HCM1A0703-1R0-R 1.0 0.64 7.9 13 9.0 10 450 HCM1A0703-1R2-R 1.2 0.76 7.8 11 9.3 10.2 446 HCM1A0703-1R5- R 1.5 1.0 6.6 11 14 15.5 353 HCM1A0703-2R2-R 2.2 1.4 5.7 10 18 20 309 HCM1A0703-3R3-R 3.3 2.1 4.9 9.0 28 30 262 HCM1A0703-4R7-R 4.7 3.0 4.1 8.8 37 40 235 HCM1A0703-6R8-R 6.8 4.3 3.5 6.4 54 60 177 HCM1A0703-8R2-R 8.2 5.2 3.1 5.6 64 68 159 HCM1A0703-100-R 10 6.4 3.0 4.4 71 77.6 153 HCM1A0703-150-R 15 9.6 2.2 4.0 118 127 127 HCM1A0703-220-R 22 14.1 2.0 3.4 135 149 121 HCM1A0703-330-R 33 19.8 1.6 2.3 220 242 81 1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, +25 °C 2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, Isat, +25 °C 3. Irms: DC current for an approximate temperature rise of 30 °C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed 155 °C under worst case operating conditions verified in the end application. 4. Isat: Peak current for approximately 20% rolloff @ +25 °C 5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (Gauss), K: (K-factor from table), L: (Inductance in μH), ΔI (Peak to peak ripple current in Amps). 6. Part Number Definition: HCM1A0703-xxx-R HCM1A0703 = Product code and size xxx= inductance value in μH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant xxxx Dimensions (mm) Part marking: 1AXXX=automotive grade, XXX=inductance value in uH, R=decimal point. If no R is present then last character equals number of zeros. xxxx= Lot code All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.3 millimeters unless stated otherwise DCR measured from point “a” to point “b” Color: Grey Do not route traces or vias underneath the inductor 2 www.eaton.com/electronics ctronics HCM1A0703 Automotive grade high current power inductors Technical Data 10548 Effective August 2016 Packaging information (mm) Drawing not to scale xxxx Supplied in tape and reel packaging, 2,000 parts per 13” diameter reel Core loss vs Bp-p HCM1A0703-R10-R 100 1 MHz HCM1A0703-R15-R 1000 500 kHz 300 kHz 1 MHz 25 kHz 1 300 kHz 100 kHz 50 kHz 10 25 kHz 1 0.1 0.01 500 kHz 50 kHz Core Loss (mW) Core Loss (mW) 100 100 kHz 10 0.1 100 1000 Bp-p (Gauss) 10000 100 1000 10000 Bp-p (Gauss) www.eaton.com/electronics ctronics 3 HCM1A0703 Automotive grade high current power inductors Technical Data 10548 Effective August 2016 Core loss vs Bp-p HCM1A0703-R22-R 100 1 MHz 500 kHz 300 kHz 100 kHz 50 kHz 10 25 kHz 100 kHz 25 kHz 1 0.1 100 1000 10000 Bp-p (Gauss) 1 MHz 100 500 kHz Core Loss (mW) 100 kHz 25 kHz 1 0.1 300 kHz 50 kHz 10 25 kHz 1 100 1000 0.1 10000 1 MHz 1 MHz 500 kHz Core Loss (mW) 50 kHz 25 kHz 1 0.1 10000 500 kHz 300 kHz 100 100 kHz 10 1000 HCM1A0703-R82-R 1000 300 kHz 100 100 Bp-p (Gauss) HCM1A0703-R68-R 1000 Core Loss (mW) 500 kHz 100 kHz Bp-p (Gauss) 4 10000 1 MHz 100 50 kHz 1000 HCM1A0703-R56-R 1000 300 kHz 10 100 Bp-p (Gauss) HCM1A0703-R47-R 1000 Core Loss (mW) 50 kHz 10 1 0.1 500 kHz 300 kHz 100 Core Loss (mW) Core Loss (mW) 1 MHz HCM1A0703-R33-R 1000 1000 100 kHz 50 kHz 10 25 kHz 1 100 1000 Bp-p (Gauss) www.eaton.com/electronics ctronics 10000 0.1 100 1000 Bp-p (Gauss) 10000 HCM1A0703 Automotive grade high current power inductors Technical Data 10548 Effective August 2016 Core loss vs Bp-p HCM1A0703-1R0-R 1000 1 MHz Core Loss (mW) Core Loss (mW) 50 kHz 25 kHz 100 kHz 50 kHz 10 0.1 100 1000 10000 Bp-p (Gauss) 500 kHz 1 MHz 300 kHz 500 kHz 300 kHz 100 Core Loss (mW) 100 kHz 50 kHz 25 kHz 10 1 100 kHz 50 kHz 10 25 kHz 1 100 1000 0.1 10000 Bp-p (Gauss) 100 HCM1A0703-3R3-R 1 MHz 500 kHz 1 MHz 300 kHz 500 kHz 100 Core Loss (mW) 100 kHz 50 kHz 10 10000 HCM1A0703-4R7-R 1000 100 1000 Bp-p (Gauss) 1000 Core Loss (mW) 10000 HCM1A0703-2R2-R 100 25 kHz 1 0.1 1000 Bp-p (Gauss) 1000 1 MHz 0.1 100 HCM1A0703-1R5-R 1000 Core Loss (mW) 25 kHz 1 1 0.1 300 kHz 100 100 kHz 10 500 kHz 1 MHz 500 kHz 300 kHz 100 HCM1A0703-1R2-R 1000 300 kHz 100 kHz 50 kHz 10 25 kHz 1 100 1000 Bp-p (Gauss) 10000 0.1 100 1000 Bp-p (Gauss) www.eaton.com/electronics ctronics 10000 5 HCM1A0703 Automotive grade high current power inductors Technical Data 10548 Effective August 2016 Core loss vs Bp-p HCM1A0703-6R8-R 1000 1 MHz 500 kHz 100 kHz 50 kHz 10 25 kHz 1 100 1000 100 kHz 50 kHz 10 0.1 10000 HCM1A0703-100-R 25 kHz 1 MHz 100 1000 1 MHz 300 kHz 100 100 kHz 25 kHz 1 100 1000 300 kHz 100 kHz 50 kHz 10 0.1 10000 Bp-p (Gauss) HCM1A0703-220-R 25 kHz 100 1000 HCM1A0703-330-R 1000 100 500 kHz 100 300 kHz Core Loss (mW) 1 MHz 100 kHz 50 kHz 10 25 kHz 500 kHz 300 kHz 100 kHz 50 kHz 10 25 kHz 1 1 0.1 10000 Bp-p (Gauss) 1 MHz Core Loss (mW) 500 kHz 1 1000 0.1 100 1000 Bp-p (Gauss) 6 10000 Bp-p (Gauss) HCM1A0703-150-R 500 kHz 50 kHz 10 100 1000 Core Loss (mW) 1000 Core Loss (mW) 300 kHz 1 Bp-p (Gauss) 0.1 500 kHz 100 Core Loss (mW) Core Loss (mW) 1 MHz 300 kHz 100 0.1 HCM1A0703-8R2-R 1000 www.eaton.com/electronics ctronics 10000 100 1000 Bp-p (Gauss) 10000 HCM1A0703 Automotive grade high current power inductors Technical Data 10548 Effective August 2016 Inductance and temperature rise vs. current HCM1A0703-R15-R HCM1A0703-R10-R 100 0.16 90 80 0.08 60 0.06 50 40 0.04 30 10 15 20 25 30 35 40 45 50 40 0.06 30 20 0 0.00 10 0 5 10 15 20 Idc (A) 60 50 0.12 40 0.08 30 0.04 25 30 35 40 45 50 100 90 80 70 0.25 60 0.20 50 40 0.15 30 20 0.05 10 20 0.00 0 10 0 5 10 15 20 25 30 35 40 HCM1A0703-R47-R HCM1A0703-R56-R 0.45 100 0.40 90 0.70 60 0.25 50 0.20 40 0.15 30 0.10 0.50 Inductance (µH) 70 0.30 90 80 Temperature Rise(°C) 0.35 100 0.60 80 70 60 0.40 50 0.30 40 30 0.20 20 0.05 10 0.00 0 0 5 10 15 20 Idc (A) 0 Idc (A) Idc (A) Inductance (µH) 0 0.10 20 15 50 0.30 Inductance (µH) 70 0.16 10 45 0.35 Temperature Rise (°C) Inductance (µH) 80 5 40 0.40 90 0 35 HCM1A0703-R33-R 100 0.20 0.00 30 Idc (A) HCM1A0703-R22-R 0.24 25 Temperature Rise (°C) 5 50 25 30 35 40 Temperature Rise (°C) 0 60 0.08 0.02 10 0.00 70 0.10 0.04 20 0.02 80 0.12 Inductance (µH) 70 90 0.14 Temperature Rise (°C) Inductance (µH) 0.10 100 Temperature Rise (°C) 0.12 20 0.10 0.00 10 0 5 10 15 20 25 30 0 Idc (A) www.eaton.com/electronics ctronics 7 HCM1A0703 Automotive grade high current power inductors Technical Data 10548 Effective August 2016 Inductance and temperature rise vs. current HCM1A0703-R82-R 100 90 0.80 90 80 0.70 60 50 0.40 40 0.30 30 0.20 20 0.10 5 10 15 20 25 50 0.40 40 0.30 30 0.20 20 0.00 0 10 0 5 10 HCM1A0703-1R0-R 100 90 1.2 80 80 0.8 60 0.6 50 40 0.4 30 1.0 Inductance (µH) 70 Temperature Rise (°C) Inductance (µH) 1.0 5 10 15 20 25 60 0.8 50 0.6 40 30 20 0.2 10 0 70 0.4 20 0.2 0.0 0 10 0 2 4 6 8 HCM1A0703-1R5-R 1.6 10 12 14 16 18 20 HCM1A0703-2R2-R 2.8 100 90 1.4 100 90 2.4 80 70 1.0 60 0.8 50 40 0.6 30 0.4 2.0 Inductance (µH) 1.2 Temperature Rise (°C) 80 70 60 1.6 50 1.2 40 30 0.8 20 0.2 10 0 2 4 6 8 Idc (A) www.eaton.com/electronics ctronics 0 Idc (A) Idc (A) Inductance (µH) 0 HCM1A0703-1R2-R 90 8 25 1.4 100 1.2 0.0 20 Idc (A) Idc (A) 0.0 15 Temperature Rise (°C) 0 60 0.50 0.10 10 0.00 70 0.60 Temperature Rise (°C) 70 0.50 80 10 12 14 0 20 0.4 0.0 10 0 2 4 6 8 Idc (A) 10 12 14 16 0 Temperature Rise (°C) Inductance (µH) 0.60 0.90 Inductance (µH) 0.70 100 Temperature Rise (°C) HCM1A0703-R68-R 0.80 HCM1A0703 Automotive grade high current power inductors Technical Data 10548 Effective August 2016 Inductance and temperature rise vs. current 90 4.5 90 80 4.0 80 3.5 70 3.0 60 2.5 50 2.0 40 70 2.5 60 2.0 50 40 1.5 1.5 30 20 1.0 20 10 0.5 10 0 0.0 30 1.0 0.5 2 4 6 8 10 12 14 16 0 2 4 6 8 7 100 90 8 90 60 4 50 40 3 30 2 20 1 3 4 5 6 7 8 9 10 80 7 Inductance (µH) 5 Temperature Rise (°C) Inductance (µH) 9 70 2 70 6 60 5 50 4 40 3 30 2 10 1 0 0 20 10 0 1 2 3 4 Idc (A) HCM1A0703-100-R 90 80 60 6 50 40 4 30 20 2 10 3 4 Idc (A) 8 9 0 5 6 7 8 0 100 90 80 12 Inductance (µH) 70 8 2 7 14 Temperature Rise (°C) Inductance (µH) 10 1 6 HCM1A0703-150-R 16 100 0 5 Idc (A) 12 0 0 100 80 6 1 14 HCM1A0703-8R2-R HCM1A0703-6R8-R 8 0 12 Idc (A) Idc (A) 0 10 Temperature Rise (°C) 0 70 10 60 8 50 40 6 30 4 20 2 0 Temperature Rise (°C) 0.0 100 Inductance (µH) Inductance (µH) 3.0 5.0 Temperature Rise (°C) 3.5 100 Temperature Rise (°C) HCM1A0703-4R7-R HCM1A0703-3R3-R 4.0 10 0 1 2 3 4 5 6 7 0 Idc (A) www.eaton.com/electronics ctronics 9 HCM1A0703 Automotive grade high current power inductors Technical Data 10548 Effective August 2016 Inductance and temperature rise vs. current HCM1A0703-330-R 40 90 35 80 60 12 50 40 8 30 20 4 10 0 0 0.5 1 1.5 2 2.5 Idc (A) 10 www.eaton.com/electronics ctronics 3 3.5 4 4.5 5 0 100 90 80 30 Inductance (µH) 70 16 Temperature Rise (°C) Inductance (µH) 20 100 70 25 60 20 50 40 15 30 10 20 5 0 10 0 0.5 1 1.5 2 Idc (A) 2.5 3 3.5 4 0 Temperature Rise (°C) HCM1A0703-220-R 24 HCM1A0703 Automotive grade high current power inductors Technical Data 10548 Effective August 2016 Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb Solder (Tc) Package Thickness Volume mm3
HCM1A0703-220-R
物料型号:HCM1A0703
器件简介:这是Eaton公司生产的汽车级高电流功率电感器,符合AEC-Q200 Grade 1标准,具有高电流承载能力,磁屏蔽低电磁干扰,频率范围高达1MHz,电感范围从0.1μH到33μH,电流范围从1.6A到36A。
引脚分配:7.4 mm x 7.0 mm的表面贴装封装,高度为3.0 mm。
参数特性: - 合金粉末芯材料 - 湿度敏感等级(MSL):1 - 无卤素,无铅,符合RoHS标准
功能详解: - 适用于多种汽车电子应用,包括车身电子、中央车身控制模块、车辆进入控制系统、前大灯、尾灯和室内照明、暖通空调控制器、门窗升降和座椅控制、高级驾驶辅助系统、77 GHz雷达系统、自适应巡航控制、自动停车控制、碰撞避免系统/汽车黑匣子系统、信息娱乐和集群电子、主动降噪、音频子系统、数字仪表盘、车载信息娱乐和导航、底盘和安全电子、气囊控制单元、电子稳定控制系统、发动机和动力传动系统、电动泵、电机控制和辅助设备、传动控制单元。
应用信息:适用于汽车电子的多个领域,包括车身电子、照明、高级驾驶辅助系统、信息娱乐系统、底盘和安全电子等。
封装信息:提供2000个元件每卷的胶带和卷轴包装。
环境数据: - 存储温度范围:-55°C至+155°C - 工作温度范围:-55°C至+155°C(环境温度加上自身温度升高) - 焊接回流温度:符合J-STD-020(最新修订版)
技术数据:提供了不同型号的电感器的详细规格,包括开路电感(OCL)、满载电感(FLL)、直流电阻(DCR)、K因子等参数。
HCM1A0703-220-R 价格&库存
很抱歉,暂时无法提供与“HCM1A0703-220-R”相匹配的价格&库存,您可以联系我们找货
HCM1A0703-220-R
  • 1+11.09378
库存:1716
HCM1A0703-220-R
  • 2000+5.567162000+0.71861
  • 4000+5.250594000+0.67775
  • 6000+5.074016000+0.65496
  • 10000+4.8602810000+0.62737
  • 14000+4.8108614000+0.62099
库存:2308
HCM1A0703-220-R
  • 2000+6.87978
库存:4394
HCM1A0703-220-R
  • 1+10.613131+1.36995
  • 10+8.7237410+1.12607
  • 25+8.0724025+1.04199
  • 50+7.6123550+0.98261
  • 100+7.17627100+0.92632
  • 250+6.63958250+0.85704
  • 500+6.26036500+0.80809
  • 1000+5.903361000+0.76201
库存:2308
HCM1A0703-220-R
