Technical Data 10903
Effective April 2019
HCM1A1104V2
Automotive grade high current power inductors
Applications
Product features
AEC-Q200 qualified
High current carrying capacity
Magnetically shielded, low EMI
DC-DC converter applications up to 1 MHz
Filtering applications up to Self Resonant
Frequency (SRF) [See product specification
table]
Body electronics
• Central body control module
Vehicle access control system
Headlamps, tail lamps and interior lighting and
LED lighting
Heating ventilation and air conditioning
controllers (HVAC)
Doors, window lift and seat control
Advanced driver assistance systems
• Adaptive cruise control (ACC)
Automatic parking control
Collision avoidance system/ Car black
box system
Infotainment and cluster electronics
• Audio subsystem: head unit and trunk amp
Digital instrument cluster
In-vehicle infotainment (IVI) and navigation
Port power/USB HUB for front and rear
passengers
Inductance range from 0.20 μH to 68 μH
Chassis and safety electronics
• Airbag control unit
Current range from 2.2 A to 60 A
Electronic stability control system (ESC)
11.2 mm x 10.3 mm footprint surface mount
package in a 4.0 mm height
Electric parking brake
Moisture Sensitivity Level (MSL): 1
Engine and Powertrain Systems
• Electric pumps, motor control and auxiliaries
Alloy powder core material
Powertrain control module (PCU)/
Engine Control unit (ECU)
Transmission Control Unit (TCU)
Environmental data
Storage temperature range (Component):
-55 °C to +155 °C
Operating temperature range: -55 °C to +155 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
HCM1A1104V2
Product specifications
Part number6
OCL1
(μH) ± 20%
FLL2 (μH)
minimum
Irms3
(A)
Isat4
(A)
DCR (mΩ)
typical @ +20 °C
DCR (mΩ)
maximum @ +20 °C
SRF (MHz)
typical
K-factor5
HCM1A1104V2-R20-R
0.20
0.13
43
60
0.63
0.72
150
726
HCM1A1104V2-R36-R
0.36
0.23
26
33
1.04
1.20
80
493
HCM1A1104V2-R45-R
0.45
0.29
25
40
1.07
1.23
85
450
HCM1A1104V2-R47-R
0.47
0.30
25
35
1.10
1.27
73
450
HCM1A1104V2-R56-R
0.56
0.36
22.5
24
1.56
1.80
62
469
HCM1A1104V2-R90-R
0.90
0.58
2.17
2.5
49
361
HCM1A1104V2-1R0-R
1.0
0.64
19
25
2.7
3.1
38
303
HCM1A1104V2-1R5-R
1.5
0.96
14
22
3.8
4.2
33
281
HCM1A1104V2-2R2-R
2.2
1.41
10.5
16
6.0
7.0
25
432
HCM1A1104V2-3R3-R
3.3
2.11
8.2
11.5
9.9
11.4
19
215
HCM1A1104V2-4R7-R
4.7
3.01
8.0
10.8
13.2
15
15
309
HCM1A1104V2-5R6-R
5.6
3.58
7.5
9.0
14
17
14
160
HCM1A1104V2-6R8-R
6.8
4.35
6.4
9.0
16
19
12
149
HCM1A1104V2-100-R
10
6.40
6.0
6.0
27
30
10
131
HCM1A1104V2-150-R
15
9.60
4.7
4.6
40
45
6.8
132
HCM1A1104V2-220-R
22
14.1
3.8
4.6
58
65
6.5
77
HCM1A1104V2-330-R
33
21.1
3.3
4.6
89
102
5.0
55
HCM1A1104V2-470-R
47
30.1
2.7
3.6
147
165
3.9
63
HCM1A1104V2-680-R
68
43.5
2.2
3.0
190
210
3.1
39
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, +25 °C
2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, Isat, , +25 °C
3. Irms: DC current for an approximate temperature rise of 30 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed +155 °C under worst case operating
conditions verified in the end application.
4. Isat: Peak current for approximately 20% rolloff @ +25 °C
5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (Gauss), K: (K-factor from table),
L: (Inductance in μH), ΔI (Peak to peak ripple current in Amps).
6. Part Number Definition: HCM1A1104V2-xxx-R
HCM1A1104V2 = Product code and size
xxx= inductance value in μH, R= decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
Dimensions (mm)
Schematic
1
2
Part marking: 1AxxxV2, xxx=inductance value in uH, R=decimal point. If no R is present then last character equals number of zeros. xxxx=Lot code
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.3 millimeters unless stated otherwise
Pad layout tolerances are ±0.1 millimeters unless stated otherwise
DCR measured from point “a” to point “b”
Do not route traces or vias underneath the inductor
2
www.eaton.com/electronics
HCM1A1104V2
Packaging information (mm)
Drawing not to scale
Supplied in tape and reel packaging, 500 parts per 13” diameter reel
Core loss vs Bp-p
HCM1A1104V2-R20-R
HCM1A1104V2-R36-R
700 kHz
500 kHz
300 kHz
1000
700 kHz
500 kHz
300 kHz
100
100 kHz
50 kHz
100
100 kHz
50 kHz
Core Loss (mW)
Core Loss (mW)
1000
10
1
0.1
0.01
10
1
0.1
100
0.01
1000
Bp-p (Gauss)
HCM1A1104V2-R47-R
HCM1A1104V2-R45-R
1000
700 kHz
500 kHz
300 kHz
1000
700 kHz
500 kHz
300 kHz
100
100 kHz
100
100 kHz
50 kHz
50 kHz
Core Loss (mW)
Core Loss (mW)
1000
100
Bp-p (Gauss)
10
1
1
0.1
0.1
0.01
10
0.01
100
1000
Bp-p (Gauss)
100
1000
Bp-p (Gauss)
3
HCM1A1104V2
Core loss vs Bp-p
HCM1A1104V2-R56-R
HCM1A1104V2-R90-R
1000
1000
700 kHz
500 kHz
300 kHz
100
100 kHz
700 kHz
500 kHz
300 kHz
100
100 kHz
10
1
0.1
0.01
50 kHz
Core Loss (mW)
Core Loss (mW)
50 kHz
10
1
0.1
100
0.01
1000
1000
100
Bp-p (Gauss)
Bp-p (Gauss)
HCM1A1104V2-1R0-R
HCM1A1104V2-1R5-R
1000
700 kHz
500 kHz
300 kHz
1000
100
100 kHz
100
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
Core Loss (mW)
Core Loss (mW)
50 kHz
10
1
0.1
0.01
10
1
0.1
100
0.01
1000
100
Bp-p (Gauss)
HCM1A1104V2-3R3-R
HCM1A1104V2-2R2-R
1000
1000
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
10
1
100 kHz
50 kHz
10
1
0.1
0.1
0.01
100
1000
Bp-p (Gauss)
4
700 kHz
500 kHz
300 kHz
100
Core Loss (mW)
Core Loss (mW)
100
0.01
1000
Bp-p (Gauss)
1000
100
Bp-p (Gauss)
HCM1A1104V2
Core loss vs Bp-p
HCM1A1104V2-4R7-R
HCM1A1104V2-5R6-R
1000
1000
700 kHz
500 kHz
300 kHz
Core Loss (mW)
100 kHz
50 kHz
10
1
0.1
0.01
100
Core Loss (mW)
100
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
10
1
0.1
100
0.01
1000
1000
100
Bp-p (Gauss)
Bp-p (Gauss)
HCM1A1104V2-100-R
HCM1A1104V2-6R8-R
1000
1000
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
10
1
100
Core Loss (mW)
Core Loss (mW)
100
100 kHz
50 kHz
10
1
0.1
0.1
0.01
700 kHz
500 kHz
300 kHz
0.01
100
1000
Bp-p (Gauss)
HCM1A1104V2-150-R
HCM1A1104V2-220-R
1000
1000
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
10
1
0.1
700 kHz
500 kHz
300 kHz
100
Core Loss (mW)
Core Loss (mW)
100
0.01
1000
100
Bp-p (Gauss)
100 kHz
50 kHz
10
1
0.1
100
1000
Bp-p (Gauss)
0.01
1000
100
Bp-p (Gauss)
5
HCM1A1104V2
Core loss vs Bp-p
HC1A1104V2-330-R
HCM1A1104V2-470-R
1000
100
700 kHz
500 kHz
300 kHz
1000
100 kHz
100
700 kHz
500 kHz
300 kHz
100 kHz
Core Loss (mW)
Core Loss (mW)
50 kHz
10
1
0.1
0.01
100
0.01
1000
1000
700 kHz
500 kHz
300 kHz
100
100 kHz
50 kHz
10
1
0.1
0.01
100
1000
Bp-p (Gauss)
1000
100
Bp-p (Gauss)
HCM1A1104V2-680-R
Core Loss (mW)
1
0.1
Bp-p (Gauss)
6
50 kHz
10
HCM1A1104V2
Inductance and impedance vs. frequency
HCM1A1104V2-R36-R
HCM1A1104V2-R20-R
0.9
1000
0.35
0.8
0.3
10
0.15
0.1
Impedance
100
0.5
Inductance
0.4
0.3
10
0.2
1
Impedance
0.1
0.05
0.1
1
10
100
0.1
1
10
100
1
Frequency (MHz)
Frequency (MHz)
HCM1A1104V2-R47-R
HCM1A1104V2-R45-R
1.2
1000
1
0.9
1000
1
100
10
0.5
Inductance
0.4
0.3
0.6
10
Inductance
0.4
1
1
Impedance
0.2
0.8
OCL (uH)
0.6
Impedance (Ω)
100
0.7
Impedance (Ω)
0.8
OCL (uH)
Impedance (Ω)
0.2
OCL (uH)
0.6
Inductance
Impedance (Ω)
OCL (uH)
0.7
100
0.25
Impedance
0.2
0.1
0.1
1
10
100
0.1
1
HCM1A1104V2-R56-R
3.5
1.6
1000
100
1
0.8
10
Inductance
0.6
OCL (uH)
2.5
Impedance (Ω)
OCL (uH)
10000
3
1000
1.2
2
100
Impedance
1.5
10
1
0.4
0.1
Inductance
1
Impedance
0.2
HCM1A1104V2-R90-R
10000
1.4
100
Frequency (MHz)
Frequency (MHz)
1.8
10
Impedance (Ω)
0.5
1
10
Frequency (MHz)
100
0.1
1
10
100
0.1
Frequency (MHz)
7
HCM1A1104V2
HCM1A1104V2-1R5-R
HCM1A1104V2-1R0-R
4.5
9
10000
8
4
1000
100
Impedance
2
10
1.5
1
Inductance
5
100
4
Impedance
3
10
2
1
Inductance
1
0.5
0.1
1
10
100
0.1
1
10
HCM1A1104V2-3R3-R
HCM1A1104V2-2R2-R
14
30
10000
12
8
100
Impedance
6
4
OCL (uH)
10
10
10
5
2
Inductance
0.1
1
Inductance
10
100
0.1
1
1
100
HCM1A1104V2-5R6-R
HCM1A1104V2-4R7-R
35
40
10000
10000
35
30
100
Impedance
15
10
10
5
Impedance
10
Frequency (MHz)
100
1
100
15
10
10
5
Inductance
0.1
1000
25
OCL (uH)
Impedance (Ω)
1000
25
Inductance
0.1
1
10
Frequency (MHz)
100
1
Impedance (Ω)
30
Frequency (MHz)
Frequency (MHz)
OCL (uH)
100
Impedance
Impedance (Ω)
1000
1000
Impedance (Ω)
OCL (uH)
10000
25
10
8
1
100
Frequency (MHz)
Frequency (MHz)
Impedance (Ω)
2.5
1000
6
OCL (uH)
OCL (uH)
3
7
Impedance (Ω)
3.5
HCM1A1104V2
HCM1A1104V2-100-R
HCM1A1104V2-6R8-R
60
100000
100
10000
90
50
Impedance
40
10
10
10
100
Inductance
0.1
1
10
Frequency (MHz)
Frequency (MHz)
HCM1A1104V2-220-R
HCM1A1104V2-150-R
140
250
100000
120
1000
60
Impedance
100
OCL (uH)
80
Impedance (Ω)
OCL (uH)
100
100000
200
10000
40
1
100
10000
150
1000
100
Impedance
Impedance (Ω)
1
100
Inductance
0.1
50
30
10
60
Impedance (Ω)
100
OCL (uH)
Impedance
30
70
Impedance (Ω)
OCL (uH)
40
10000
80
1000
100
50
Inductance
0.1
1
10
100
Inductance
0.1
10
100
10
Frequency (MHz)
Frequency (MHz)
HCM1A1104V2-470-R
HCM1A1104V2-330-R
300
350
100000
100000
300
250
10000
1000
Impedance
100
OCL (uH)
150
10000
250
Impedance (Ω)
200
OCL (uH)
1
200
1000
150
Impedance
100
100
100
50
50
Inductance
1
10
Frequency (MHz)
100
10
Impedance (Ω)
Inductance
0.1
1
10
100
10
Frequency (MHz)
9
HCM1A1104V2
HCM1A1104V2-680-R
700
100000
600
OCL (uH)
400
1000
300
Impedance
200
Impedance (Ω)
10000
500
100
100
Inductance
1
10
100
10
Frequency (MHz)
Inductance and temperature rise vs. current
HCM1A1104V2-R20-R
HCM1A1104V2-R36-R
100
0.40
90
0.15
60
50
0.10
40
30
Temperature rise
0.05
40
Idc (A)
10
50
60
80
90
80
0.30
70
0.25
OCL (uH)
OCL (uH)
70
0.00
0.35
80
Inductance
Temperature rise (°C)
0.20
100
Inductance
60
0.20
50
40
0.15
30
0.10
10
0.05
Temperature rise
Idc (A)
40
50
Temperature Rise (°C)
0.25
HCM1A1104V2
HCM1A1104V2-R47-R
100
Inductance
70
0.30
60
0.25
50
0.20
40
Temperature rise
30
0.10
10
0.00
40
50
60
0.40
80
0.35
70
0.30
60
0.25
50
0.20
40
0.15
30
Temperature rise
0.10
90
0.00
10
Inductance
60
0.3
50
40
0.2
30
Temperture rise
15
30
35
40
OCL (uH)
70
0.4
OCL (uH)
80
10
0.8
80
0.7
70
0.6
60
0.5
50
0.4
40
Temperature rise
0.3
10
10
15
1.4
70
1.2
60
0.6
50
40
0.4
30
Temperature rise
10
15
Idc (A)
25
30
35
OCL (uH)
80
OCL (uH)
0.8
10
35
90
1.6
90
Inductance
5
30
1.8
100
HCM1A1104V2-1R5-R
1.2
0.0
Idc (A)
HCM1A1104V2-1R0-R
0.2
30
0.2
0.0
Inductance
Idc (A)
1.0
0.9
90
0.5
5
60
1.0
100
HCM1A1104V2-R90-R
HCM1A1104V2-R56-R
0.6
0.0
40
Isat (A)
Idc (A)
0.1
0.15
OCL (uH)
80
0.35
OCL (uH)
0.45
90
0.40
100
Inductance
Inductance
80
70
60
1.0
50
0.8
40
0.6
30
Temperature rise
0.4
0.0
0.45
0.50
HCM1A1104V2-R45-R
10
10
15
30
35
Idc (A)
11
HCM1A1104V2
HCM1A1104V2-3R3-R
Inductance
4.0
90
3.5
80
1.5
60
50
1.0
40
30
60
2.0
50
40
1.5
30
1.0
10
15
4
6
Idc (A)
3.0
60
2.5
50
2.0
40
1.5
30
Temperature rise
90
80
70
60
3.0
50
40
2.0
30
Temperature rise
10
10
4
6
8
10
12
14
0.0
4
6
HCM1A1104V2-6R8-R
8
5
60
4
50
40
3
30
Temperature rise
10
6
8
90
Inductance
80
70
60
6
50
40
4
30
Idc (A)
OCL (uH)
70
6
4
14
100
10
80
2
12
12
90
Inductance
HCM1A1104V2-100-R
100
2
8
Idc (A)
Idc (A)
7
4.0
OCL (uH)
70
OCL (uH)
16
5.0
OCL (uH)
3.5
0.5
12
14
Inductance
90
80
6.0
100
Inductance
4.0
0.0
10
HCM1A1104V2-5R6-R
5.0
1.0
8
Idc (A)
HCM1A1104V2-4R7-R
4.5
Temperature rise
5
70
2.5
0.5
10
Temperature rise
0.0
90
Inductance
10
12
Temperature rise
2
10
Idc (A)
0.5
100
3.0
OCL (uH)
OCL (uH)
70
2.0
100
Temperature Rise (eC)
HCM1A1104V2-2R2-R
2.5
HCM1A1104V2
HCM1A1104V2-150-R
100
16
90
Inductance
50
8
40
6
30
4
15
50
10
40
5
1
2
3
4
5
6
7
8
10
15
40
30
10
Temperature rise
2
3
5
6
7
6
90
Inductance
40
80
35
70
30
60
25
50
15
30
10
Temperature rise
5
10
4
OCL (uH)
70
80
1
4
100
45
90
Inductance
50
100
25
HCM1A1104V2-470-R
35
5
1
Idc (A)
HCM1A1104V2-330-R
30
Temperature rise
10
Idc (A)
OCL (uH)
60
30
Temperature rise
2
80
70
OCL (uH)
OCL (uH)
60
10
90
12
100
Inductance
80
14
HCM1A1104V2-220-R
25
18
10
2
3
4
5
Idc (A)
HCM1A1104V2-680-R
80
100
90
Inductance
80
60
70
OCL (uH)
50
60
40
50
40
30
30
70
Temperature rise
1
1.5
2
2.5
10
3
3.5
4
Idc (A)
13
HCM1A1104V2
Solder reflow profile
TP
TC -5 °C
tP
Max. ramp up rate = 3 °C/s
Max. ramp down rate = 6 °C/s
Temperature
TL
Preheat
A
T smax
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“HCM1A1104V2-1R0-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+13.193891+1.70601
- 国内价格 香港价格
- 1+13.242441+1.71228
- 国内价格
- 500+5.45305
- 15000+4.54622
