Technical Data 10907
Effective April 2019
HCM1A2213V2
Automotive grade high current power inductors
Applications
Product features
AEC-Q200 qualified
High current carrying capacity
Magnetically shielded, low EMI
DC-DC converter applications up to 1 MHz
Filtering applications up to Self Resonant
Frequency (SRF) [See product specification
table]
Inductance range from 0.47 μH to 100 μH
Current range from 6.4 A to 100 A
22.78 mm x 22.30 mm footprint surface mount
package in a 13.0 mm height
Moisture Sensitivity Level (MSL): 1
Alloy powder core material
Body electronics
• Central body control module
Headlamps, tail lamps and interior lighting and
LED lighting
Heating ventilation and air conditioning
controllers (HVAC)
Doors, window lift and seat control
Advanced driver assistance systems
• Adaptive cruise control (ACC)
Automatic parking control
Collision avoidance system/ Car black
box system
Infotainment and cluster electronics
• Audio subsystem: head unit and trunk amp
Digital instrument cluster
In-vehicle infotainment (IVI) and navigation
Chassis and safety electronics
• Airbag control unit
Electronic stability control system (ESC)
Electric parking brake
Electronic power steering (EPS)/
Anti-locking braking system (ABS)
Engine and Powertrain Systems
• Electric pumps, motor control and auxiliaries
Powertrain control module (PCU)/
Engine Control unit (ECU)
Transmission Control Unit (TCU)
Environmental data
Storage temperature range (Component):
-55 °C to +155 °C
Operating temperature range: -55 °C to +155 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
HCM1A2213V2
Product specifications
Part number6
OCL1
(μH) ± 20%
FLL2 (μH)
minimum
Irms3
(A)
Isat4
(A)
DCR (mΩ)
typical @ +20 °C
DCR (mΩ)
maximum @ +20 °C
SRF (MHz)
typical
K-factor5
HCM1A2213V2-R47-R
0.47
0.30
66
100
0.40
0.50
52
111
HCM1A2213V2-1R0-R
1.0
0.64
50
71
0.67
0.84
34
53
HCM1A2213V2-2R2-R
2.2
1.41
42.5
48
1.05
1.25
17
33
HCM1A2213V2-3R3-R
3.3
2.11
34
41
1.6
1.77
12
26
HCM1A2213V2-4R7-R
4.7
3.0
33
37
1.68
1.85
10
28
HCM1A2213V2-6R8-R
6.8
4.35
26.5
36
2.5
3.0
9
HCM1A2213V2-100-R
10
6.4
3.7
4.1
7
17
HCM1A2213V2-150-R
15
9.6
17
24
4.92
6.0
5
15
HCM1A2213V2-220-R
22
14.1
13.5
16
8.1
10
4
12
HCM1A2213V2-330-R
33
21.1
11
16
13.2
15.5
3
9
HCM1A2213V2-470-R
47
30.1
10
15
15.2
17.7
2
9
HCM1A2213V2-750-R
75
48.0
7.5
10
27.6
32.5
2
6
HCM1A2213V2-820-R
82
52.5
7.0
9.5
29.9
34.3
2
5
HCM1A2213V2-101-R
100
64.0
6.4
8.0
36.0
39.5
1.9
5
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, +25 °C
2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, Isat, , +25 °C
3. Irms: DC current for an approximate temperature rise of 30 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed +155 °C under worst case operating
conditions verified in the end application.
4. Isat: Peak current for approximately 20% rolloff @ +25 °C
5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (Gauss), K: (K-factor from table),
L: (Inductance in μH), ΔI (Peak to peak ripple current in Amps).
6. Part Number Definition: HCM1A2213V2-xxx-R
HCM1A2213V2 = Product code and size
xxx= inductance value in μH, R= decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
Dimensions (mm)
Schematic
1
2
Part marking: 1A2213V2, xxx=inductance value in uH, R=decimal point. If no R is present then last character equals number of zeros. xxxx=Lot code
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.3 millimeters unless stated otherwise
Pad layout tolerances are ±0.1 millimeters unless stated otherwise
DCR measured from point “a” to point “b”
Do not route traces or vias underneath the inductor
2
www.eaton.com/electronics
HCM1A2213V2
Packaging information (mm)
Drawing not to scale
Supplied in tape and reel packaging, 100 parts per 13” diameter reel
Core loss vs Bp-p
HCM1A2213V2-R47-R
HCM1A2213V2-1R0-R
100000
100000
1.0 MHz
700 kHz
500 kHz
300 kHz
1000
100
10
1
1.0 MHz
700 kHz
500 kHz
300 kHz
10000
Core Loss (mW)
Core Loss (mW)
10000
1000
100
10
100
1
1000
Bp-p (Gauss)
Bp-p (Gauss)
HCM1A2213V2-3R3-R
HCM1A2213V2-2R2-R
100000
100000
1.0 MHz
700 kHz
500 kHz
300 kHz
1000
100
1.0 MHz
700 kHz
500 kHz
300 kHz
10000
Core Loss (mW)
Core Loss (mW)
10000
1000
100
10
10
1
1000
100
1
100
1000
Bp-p (Gauss)
1000
100
Bp-p (Gauss)
3
HCM1A2213V2
Core loss vs Bp-p
HCM1A2213V2-4R7-R
HCM1A2213V2-6R8-R
100000
100000
Core Loss (mW)
1000
100
10
1
1.0 MHz
700 kHz
500 kHz
300 kHz
10000
Core Loss (mW)
1.0 MHz
700 kHz
500 kHz
300 kHz
10000
1000
100
10
100
1
1000
1000
100
Bp-p (Gauss)
Bp-p (Gauss)
HCM1A2213V2-150-R
HCM1A2213V2-100-R
100000
100000
Core Loss (mW)
1000
100
1000
100
10
10
1
1.0 MHz
700 kHz
500 kHz
300 kHz
10000
Core Loss (mW)
1.0 MHz
700 kHz
500 kHz
300 kHz
10000
1
100
1000
Bp-p (Gauss)
Bp-p (Gauss)
HCM1A2213V2-220-R
HCM1A2213V2-330-R
100000
100000
1.0 MHz
700 kHz
500 kHz
300 kHz
1000
100
10
1000
100
10
100
1000
Bp-p (Gauss)
4
1.0 MHz
700 kHz
500 kHz
300 kHz
10000
Core Loss (mW)
Core Loss (mW)
10000
1
1000
100
1
1000
100
Bp-p (Gauss)
HCM1A2213V2
Core loss vs Bp-p
HCM1A2213V2-470-R
HCM1A2213V2-750-R
100000
100000
Core Loss (mW)
1000
100
10
1
1.0 MHz
700 kHz
500 kHz
300 kHz
10000
Core Loss (mW)
1.0 MHz
700 kHz
500 kHz
300 kHz
10000
1000
100
10
100
1
1000
Bp-p (Gauss)
HCM1A2213V2-750-R
HCM1A2213V2-101-R
100000
100000
1.0 MHz
700 kHz
500 kHz
300 kHz
1000
100
10
1.0 MHz
700 kHz
500 kHz
300 kHz
10000
Core Loss (mW)
Core Loss (mW)
10000
1
1000
100
Bp-p (Gauss)
1000
100
10
100
1000
Bp-p (Gauss)
1
1000
100
Bp-p (Gauss)
5
HCM1A2213V2
Inductance and impedance vs. frequency
HCM1A2213V2-1R0-R
HCM1A2213V2-R47-R
4
1000
1.6
3.5
0.6
Inductance
0.4
Inductance (uH)
10
0.8
Impedance (Ohm)
2.5
10
1.5
1
1
Inductance
0.1
1
10
100
0.1
1
10
100
0.1
Frequency (MHz)
Frequency (MHz)
HCM1A2213V2-3R3-R
HCM1A2213V2-2R2-R
16
10000
14
10000
12
12
10
100
Impedance
8
10
6
4
Impedance (Ohm)
1000
Inductance (uH)
14
Inductance (uH)
1
0.5
0.2
1
10
100
Impedance
8
100
6
10
4
Inductance
1
2
Inductance
0.1
1000
10
1
2
Impedance
2
0.1
1
10
100
0.1
Frequency (MHz)
Frequency (MHz)
HCM1A2213V2-6R8-R
HCM1A2213V2-4R7-R
60
100
10000
10000
90
100
30
10
10
1
10
Frequency (MHz)
6
70
Impedance
60
100
50
40
10
30
Inductance
10
Inductance
0.1
1000
100
0.1
1
10
Frequency (MHz)
100
0.1
Impedance (Ohm)
Impedance
Inductance (uH)
40
1000
Impedance (Ohm)
Inductance (uH)
50
Impedance (Ohm)
Inductance (uH)
Impedance
1
1000
3
100
1.2
Impedance (Ohm)
1.4
HCM1A2213V2
HCM1A2213V2-150-R
HCM1A2213V2-100-R
80
10000
90
40
10
30
50
40
10
Inductance
10
Inductance
0.1
Impedance
60
30
1
10
70
Impedance (Ohm)
100
Inductance (uH)
Impedance
50
1000
80
1000
60
Impedance (Ohm)
Inductance (uH)
70
100
1
10
100
0.1
1
10
100
0.1
Frequency (MHz)
Frequency (MHz)
HCM1A2213V2-330-R
HCM1A2213V2-220-R
120
200
10000
10000
180
100
60
10
40
Inductance
140
Impedance
120
100
100
80
10
60
1
40
Impedance (Ohm)
Impedance
80
Inductance (uH)
160
1000
Impedance (Ohm)
Inductance (uH)
100
1
Inductance
1
10
100
0.1
Frequency (MHz)
HCM1A2213V2-470-R
10
HCM1A2213V2-750-R
800
100000
10000
140
1000
Impedance
100
100
80
10
60
1
600
1000
Impedance
500
400
100
300
10
200
Inductance
40
Inductance (uH)
160
Impedance (Ohm)
10000
120
0.1
100000
700
180
Inductance (uH)
1
Frequency (MHz)
200
Impedance (Ohm)
Frequency (MHz)
10
0.1
Inductance
100
0.1
1
10
0.1
Frequency (MHz)
7
HCM1A2213V2
HCM1A2213V2-101-R
10000
350
Impedance
250
100
200
150
10
100
Inductance
Inductance (uH)
1000
Impedance (Ohm)
Inductance (uH)
300
1
1
0.1
100000
500
10000
400
300
100
200
10
10
1000
Impedance
Inductance
100
50
Impedance (Ohm)
HCM1A2213V2-820-R
1
0.1
1
0.1
10
Frequency (MHz)
Frequency (MHz)
Inductance and temperature rise vs. current
HCM1A2213V2-R47-R
1.00
0.40
80
0.90
0.35
70
0.80
60
0.25
50
0.20
40
0.15
30
0.10
Temperature rise
0.05
0.00
60
80
100
120
140
80
70
60
0.60
50
0.50
40
0.40
30
0.30
Temperature rise
0.20
10
0.10
Idc (A)
10
HCM1A2213V2-2R2-R
Inductance
OCL (uH)
1.4
60
1.2
50
1.0
40
0.8
30
0.2
10
0.0
40
50
Idc (A)
8
Impedance
120
70
80
90
100
100
90
80
3.0
70
2.5
OCL (uH)
70
1.6
Temperature rise (℃)
1.8
10
100
Inductance
3.5
80
4.0
90
2.0
0.4
60
HCM1A2213V2-3R3-R
100
0.6
Idc (A)
2.4
2.2
90
0.70
OCL (uH)
0.30
100
Inductance
90
Inductance
1.10
0.45
OCL (uH)
HCM1A2213V2-1R0-R
100
60
2.0
50
40
1.5
30
1.0
Temperature rise
0.5
0.0
10
40
50
Idc (A)
60
70
80
90
0.50
HCM1A2213V2
HCM1A2213V2-6R8-R
100
4.8
Inductance
90
4.0
90
Inductance
6.0
80
2.8
60
2.4
50
2.0
40
1.6
30
Temperature rise
0.8
70
60
4.0
50
3.0
40
30
2.0
10
0.4
40
50
60
70
80
0.0
10
15
30
35
10
Inductance
70
6
60
5
50
4
40
Temperature rise
30
2
10
15
30
35
40
45
50
55
60
65
70
75
90
70
60
8
50
40
6
30
Temperature rise
10
15
30
35
40
45
HCM1A2213V2-330-R
35
Inductance
90
Inductance
90
30
80
15
60
50
10
40
30
Temperature rise
5
10
15
Idc (A)
25
30
35
OCL (uH)
70
80
Idc (A)
100
5
4
HCM1A2213V2-220-R
25
OCL (uH)
70
100
Idc (A)
10
OCL (uH)
7
10
60
12
OCL (uH)
80
5
55
Inductance
14
90
8
16
100
3
45
HCM1A2213V2-150-R
HCM1A2213V2-100-R
9
40
Idc (A)
Idc (A)
Temperature rise
1.0
1.2
5.0
OCL (uH)
70
3.2
80
3.6
OCL (uH)
100
70
60
15
40
30
10
Temperature rise
4.4
0.0
7.0
HCM1A2213V2-4R7-R
10
10
15
30
35
Idc (A)
9
HCM1A2213V2
HCM1A2213V2-470-R
Inductance
80
90
100
70
70
30
60
25
50
15
30
10
8
10
12
14
16
18
24
26
28
40
30
4
50
30
10
2
60
40
5
50
Temperature rise
80
60
OCL (uH)
80
35
Temperature rise
2
4
6
8
10
12
14
16
18
Idc (A)
HCM1A2213V2-820-R
HCM1A2213V2-101-R
100
80
90
90
90
80
80
80
70
70
60
60
50
50
40
40
Inductance
70
60
60
50
50
40
40
30
30
OCL (uH)
100
90
70
OCL (uH)
Idc (A)
10
10
4
6
8
10
12
14
16
18
Inductance
30
Temperature rise
Idc (A)
10
90
Inductance
30
Temperature rise
4
6
8
10
Idc (A)
12
14
16
18
40
OCL (uH)
HCM1A2213V2-750-R
100
45
HCM1A2213V2
Solder reflow profile
TP
TC -5 °C
tP
Max. ramp up rate = 3 °C/s
Max. ramp down rate = 6 °C/s
Temperature
TL
Preheat
A
T smax
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“HCM1A2213V2-6R8-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+58.44791
- 15000+42.56033
- 国内价格 香港价格
- 100+61.85540100+7.76366
