Technical Data 11189
Effective November 2020
EXL1V0505
High current molded inductor
Applications
Product features
Voltage Regulator Module (VRM)
Multi-phase regulators
Point-of-load (POL) converters
Desktop and server VRMs and EVRDs
Base station equipment
Laptop and notebook regulators
Battery power systems
Graphics cards
Data networking and storage system
High current carrying capacity
Low DCR, high efficiency
Magnetically shielded, low EMI
Soft saturation
Environmental compliance
and general specifications
Inductance range from 5.6 μH to 10 μH
Current range from 5.0 A to 7.2 A
Storage temperature range (Component):
-40 °C to +125 °C
6.2 mm x 5.9 mm footprint surface mount
package in a 5.0 mm height
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Alloy powder core material
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Moisture Sensitivity Level (MSL) 1
HALOGEN
Pb HF
FREE
EXL1V0505
Product specifications
Part number5
OCL1
(μH) ± 20%
FLL2 (μH)
minimum
Irms3 (A) typical
+20 °C rise
+40 °C rise
Isat4
(A)
DCR (mΩ)
typical @ +25 °C
DCR (mΩ)
maximum @ +25 °C
SRF (MHz)
typical
EXL1V0505-5R6-R
5.6
3.13
5.3
7.2
7.2
22
24.2
EXL1V0505-6R8-R
6.8
3.8
4.8
6.4
6.6
26
28.6
18
EXL1V0505-8R2-R
8.2
4.59
4.6
6.1
6.1
29.5
32.5
15
EXL1V0505-100-R
10
5.6
3.8
5.0
5.4
39
43
10
4. Isat: Peak current for approximately 30% rolloff @ +25 °C
5. Part Number Definition: EXL1V0505-xxx-R
EXL1V0505 = Product code and size
xxx= inductance value in μH, R= decimal point,
If no R is present then third digit equals the number of zeros
-R suffix = RoHS compliant
6. Rated operating voltage: 15 V typical
1. Open circuit inductance (OCL) Test parameters: 100 kHz, 0.1 Vrms, 0.0 Adc, +25 °C
2. Full load inductance (FLL) Test parameters: 100 kHz, 0.1 Vrms, Isat, , +25 °C
3. Irms: Heat rated current (Irms) will cause the part temperature rise approximately ΔT of 40 °C. Circuit design,
component, PCB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part
temperature should be verified in the end application. The part temperature (ambient + temp rise) should not exceed
+125 °C under worst case operating conditions.
Mechanical parameters, schematic, pad layout (mm)
Recommended pad layout
Schematic
Figure 1. DCR test
Part number
A
B
EXL1V0505-xxx-R
6.0 ± 0.2
5.7 ± 0.2
C
4.8 ± 0.2
D
E
F
4.3 ± 0.3
1.1 ± 0.2
2.3 ± 0.25
Part marking: 0505, xxx= inductance value in μH (R= decimal point, if no R is present last digit equals number of zeros), yyyy= lot code
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ± 0.3 millimeters unless stated otherwise
Dimensions of recommended PCB layout are reference only.
Pad layout tolerances are ± 0.1 millimeters unless stated otherwise
Four terminal kelvin-clip recommended for DCR testing as shown in Figure 1.
Traces or vias underneath the inductor is not recommended.
2
www.eaton.com/electronics
EXL1V0505
Packaging information (mm)
Drawing not to scale
Supplied in tape and reel packaging, 1500 parts per 13” diameter reel (EIA-481 compliant)
W ± 0.30
16
F ± 0.1
7.5
E1 ± 0.1
1.75
P0 ± 0.1
4.0
P1 ± 0.1
8.0
P2 ± 0.1
2.0
D0 + 0.1/-0
1.5
D1 + 0.1/-0
1.5
A0 ± 0.1
6.4
B0 ± 0.1
6.1
K0 ± 0.1
5.3
T ± 0.05
0.35
P0 X 10 ± 0.2
40
Qualification testing
No.
Test item
Reference standards
Test condition
Acceptable value/range
1
Life
MIL-STD-202
Method 108
+125 °C + Irms for 1000 hours
a. Appearance
b. ΔL/L
很抱歉,暂时无法提供与“EXL1V0505-100-R”相匹配的价格&库存,您可以联系我们找货
