Technical Data 10909
Effective April 2019
HCM1A1105V2
Automotive grade high current power inductors
Applications
Product features
AEC-Q200 qualified
High current carrying capacity
Body electronics
• Central body control module
Headlamps, tail lamps and interior lighting and
LED lighting
Heating ventilation and air conditioning
controllers (HVAC)
Doors, window lift and seat control
Advanced driver assistance systems
• Adaptive cruise control (ACC)
Automatic parking control
Collision avoidance system/ Car black
box system
Infotainment and cluster electronics
• Audio subsystem: head unit and trunk amp
Digital instrument cluster
In-vehicle infotainment (IVI) and navigation
Port power/USB HUB for front and rear
passengers
Magnetically shielded, low EMI
DC-DC converter applications up to 1 MHz
Filtering applications up to Self Resonant
Frequency (SRF) [See product specification
table]
Inductance range from 0.68 μH to 68 μH
Electronic stability control system (ESC)
Current range from 2.3 A to 30 A
Electric parking brake
11.2 mm x 10.3 mm footprint surface mount
package in a 5.0 mm height
Moisture Sensitivity Level (MSL): 1
Alloy powder core material
Chassis and safety electronics
• Airbag control unit
Engine and Powertrain Systems
• Electric pumps, motor control and auxiliaries
Powertrain control module (PCU)/
Engine Control unit (ECU)
Transmission Control Unit (TCU)
Environmental data
Storage temperature range (Component):
-55 °C to +155 °C
Operating temperature range: -55 °C to +155 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
HCM1A1105V2
Product specifications
Part number6
OCL1
(μH) ± 20%
FLL2 (μH)
minimum
Irms3
(A)
Isat4
(A)
DCR (mΩ)
typical @ +20 °C
DCR (mΩ)
maximum @ +20 °C
SRF (MHz)
typical
K-factor5
HCM1A1105V2-R68-R
0.68
0.44
24.5
30
1.65
1.93
57
283
HCM1A1105V2-R72-R
0.72
0.46
23
24
1.55
1.71
54
298
HCM1A1105V2-R90-R
0.90
0.58
22
23
1.74
2.02
42
262
HCM1A1105V2-1R0-R
1.0
0.64
2.10
2.40
44
218
HCM1A1105V2-1R2-R
1.2
0.77
21
21
2.10
2.40
37
222
HCM1A1105V2-1R5-R
1.5
0.96
16.5
3.34
31
232
HCM1A1105V2-2R2-R
2.2
1.41
14.5
19
3.90
4.49
24
161
HCM1A1105V2-2R8-R
2.8
1.79
12
18
5.20
6.00
21
122
HCM1A1105V2-3R3-R
3.3
2.11
9.5
16
9.23
10.7
18
96
HCM1A1105V2-4R7-R
4.7
3.01
8.5
13
11.7
13.5
14
90
HCM1A1105V2-5R6-R
5.6
3.58
8.0
12
14.0
16.5
13
98
HCM1A1105V2-6R8-R
6.8
4.35
7.0
10
17.1
20.0
11
70
HCM1A1105V2-100-R
10
6.40
6.2
7.0
22.0
27.0
9
74
HCM1A1105V2-120-R
12
7.68
5.0
8.0
31.2
35.9
9
56
HCM1A1105V2-150-R
15
9.60
4.7
7.0
34.7
40.3
7
65
HCM1A1105V2-220-R
22
14.1
4.0
6.0
52.3
61.0
5
42
HCM1A1105V2-330-R
33
21.1
3.5
3.5
70.0
84.0
4
44
HCM1A1105V2-470-R
47
30.1
3.0
3.0
97.6
117
3
35
HCM1A1105V2-680-R
68
43.5
2.3
4.0
160
211
3
25
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, +25 °C
2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, Isat, , +25 °C
3. Irms: DC current for an approximate temperature rise of 30 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed +155 °C under worst case operating
conditions verified in the end application.
4. Isat: Peak current for approximately 20% rolloff @ +25 °C
5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (Gauss), K: (K-factor from table),
L: (Inductance in μH), ΔI (Peak to peak ripple current in Amps).
6. Part Number Definition: HCM1A1105V2-xxx-R
HCM1A1105V2 = Product code and size
xxx= inductance value in μH, R= decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
Dimensions (mm)
Schematic
1
2
Part marking: 1AxxxV2, xxx=inductance value in uH, R=decimal point. If no R is present then last character equals number of zeros.
xxxx=Lot code
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.3 millimeters unless stated otherwise
Pad layout tolerances are ±0.1 millimeters unless stated otherwise
DCR measured from point “a” to point “b”
Do not route traces or vias underneath the inductor
2
www.eaton.com/electronics
HCM1A1105V2
Packaging information (mm)
Drawing not to scale
Supplied in tape and reel packaging, 500 parts per 13” diameter reel
Core loss vs Bp-p
HCM1A1105V2-R72-R
HCM1A1105V2-R68-R
10000
1000
700 kHz
500 kHz
300 kHz
1000
700 kHz
500 kHz
300 kHz
100
100 kHz
50 kHz
100
100 kHz
50 kHz
10
1
Core Loss (mW)
Core Loss (mW)
10000
1
0.1
0.1
0.01
10
0.01
100
1000
Bp-p (Gauss)
HCM1A1105V2-1R0-R
HCM1A1105V2-R90-R
10000
1000
700 kHz
500 kHz
300 kHz
1000
100
100 kHz
50 kHz
100
10
1
Core Loss (mW)
Core Loss (mW)
10000
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
10
1
0.1
0.1
0.01
1000
100
Bp-p (Gauss)
0.01
100
1000
Bp-p (Gauss)
1000
100
Bp-p (Gauss)
3
HCM1A1105V2
Core loss vs Bp-p
HCM1A1105V2-1R2-R
HCM1A1105V2-1R5-R
10000
10000
100
700 kHz
500 kHz
300 kHz
1000
100 kHz
50 kHz
100
10
1
0.1
0.01
Core Loss (mW)
Core Loss (mW)
1000
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
10
1
0.1
100
0.01
1000
Bp-p (Gauss)
1000
100
Bp-p (Gauss)
HCM1A1105V2-2R2-R
HCM1A1105V2-2R8-R
10000
1000
700 kHz
500 kHz
300 kHz
100
100 kHz
50 kHz
10
1
0.1
0.01
700 kHz
500 kHz
300 kHz
1000
Core Loss (mW)
Core Loss (mW)
10000
100 kHz
100
50 kHz
10
1
0.1
100
0.01
1000
Bp-p (Gauss)
Bp-p (Gauss)
HCM1A1105V2-3R3-R
HCM1A1105V2-4R7-R
10000
10000
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
100
10
1
0.1
100 kHz
50 kHz
100
10
1
0.1
100
1000
Bp-p (Gauss)
4
700 kHz
500 kHz
300 kHz
1000
Core Loss (mW)
Core Loss (mW)
1000
0.01
1000
100
0.01
100
1000
Bp-p (Gauss)
HCM1A1105V2
Core loss vs Bp-p
HCM1A1105V2-6R8-R
HCM1A1105V2-5R6-R
10000
10000
Core Loss (mW)
100
10
1
100
10
1
0.1
0.1
0.01
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
1000
Core Loss (mW)
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
1000
0.01
100
1000
Bp-p (Gauss)
HCM1A1105V2-100-R
HCM1A1105V2-120-R
10000
10000
Core Loss (mW)
100
10
1
0.1
100
50 kHz
10
1
0.1
100
0.01
1000
Bp-p (Gauss)
1000
HCM1A1105V2-220-R
HCM1A1105V2-150-R
10000
100
10
1
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
1000
Core Loss (mW)
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
1000
100
10
1
0.1
0.1
0.01
100
Bp-p (Gauss)
10000
Core Loss (mW)
700 kHz
500 kHz
300 kHz
100 kHz
1000
Core Loss (mW)
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
1000
0.01
1000
100
Bp-p (Gauss)
0.01
100
1000
Bp-p (Gauss)
1000
100
Bp-p (Gauss)
5
HCM1A1105V2
Core loss vs Bp-p
HCM1A1105V2-330-R
HCM1A1105V2-470-R
10000
10000
100
700 kHz
500 kHz
300 kHz
1000
100 kHz
50 kHz
100
10
1
0.1
0.01
100
1
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
1000
100
10
1
0.1
100
1000
Bp-p (Gauss)
100
1000
Bp-p (Gauss)
HCM1A1105V2-680-R
Core Loss (mW)
100 kHz
50 kHz
10
0.01
1000
10000
6
700 kHz
500 kHz
300 kHz
0.1
Bp-p (Gauss)
0.01
Core Loss (mW)
Core Loss (mW)
1000
HCM1A1105V2
Inductance and impedance vs. frequency
HCM1A1105V2-R68-R
HCM1A1105V2-R72-R
1000
Impedance
100
1
10
1
Inductance
1
10
100
Frequency (MHz)
1.5
Inductance
0.5
0.1
0.1
1
1
10
100
Frequency (MHz)
0.1
HCM1A1105V2-1R0-R
4
4
10000
10000
3.5
3.5
1000
2.5
100
Impedance
2
10
1.5
1
1
Inductance
0.5
0.1
1
10
100
Frequency (MHz)
Inductance (uH)
3
Impedance (Ohm)
2.5
1
100
Impedance
10
2
1
Inductance
10
Frequency (MHz)
1
10
Frequency (MHz)
100
0.1
100
0.1
10000
7
Inductance (uH)
Inductance (uH)
1000
1
0.1
8
10000
0.1
1
Inductance
HCM1A1105V2-1R5-R
5
1.5
0.1
6
1
100
Impedance
2
HCM1A1105V2-1R2-R
3
1000
3
0.5
Impedance (Ohm)
Inductance (uH)
Impedance
1
HCM1A1105V2-R90-R
Impedance (Ohm)
0.5
1000
1000
6
Impedance
5
100
4
10
3
2
Inductance
1
0.1
1
10
Frequency (MHz)
100
Impedance (Ohm)
1.5
10000
2
Inductance (uH)
Inductance (uH)
2
2.5
Impedance (Ohm)
10000
Impedance (Ohm)
2.5
0.1
7
HCM1A1105V2
HCM1A1105V2-2R8-R
HCM1A1105V2-2R2-R
100
Impedance
6
10
4
1
Inductance
0.1
1
10
100
Frequency (MHz)
1000
12
8
10
6
4
1
0.1
40
10000
10000
Impedance
15
10
10
1
5
Inductance
0.1
1
10
Frequency (MHz)
100
1000
30
Inductance (uH)
1000
Impedance (Ohm)
35
25
Inductance (uH)
100
HCM1A1105V2-4R7-R
30
25
Impedance
10
15
10
Inductance
0.1
HCM1A1105V2-5R6-R
10000
45
Impedance
30
100
25
15
10
1
5
Inductance
0.1
1
10
Frequency (MHz)
100
0.1
10
Frequency (MHz)
100
0.1
HCM1A1105V2-6R8-R
60
10000
1000
Inductance (uH)
Inductance (uH)
35
1
50
1000
Impedance (Ohm)
40
100
0.1
50
8
10
Frequency (MHz)
HCM1A1105V2-3R3-R
Inductance
2
0.1
100
Impedance
10
Impedance (Ohm)
2
40
100
Impedance
30
10
10
Inductance
0.1
1
10
Frequency (MHz)
100
0.1
Impedance (Ohm)
8
1000
10000
16
Impedance (Ohm)
10
18
Inductance (uH)
Inductance (uH)
12
10000
Impedance (Ohm)
14
HCM1A1105V2
HCM1A1105V2-120-R
HCM1A1105V2-100-R
60
Impedance
100
40
10
30
10
Inductance
0.1
1
10
100
10000
80
60
10
Inductance
0.1
1
100000
140
100
60
10
40
1
Inductance
0.1
1
10
100
1000
Impedance
100
10
1
Inductance
0.1
1
10
100
HCM1A1105V2-470-R
150
100
100
10
50
1
Inductance
1
10
Frequency (MHz)
100
0.1
100000
450
10000
400
Inductance (uH)
1000
Impedance
0.1
500
10000
0.1
10000
HCM1A1105V2-330-R
100000
200
0.1
100000
Frequency (MHz)
250
200
180
160
140
120
100
80
60
40
Frequency (MHz)
300
Inductance (uH)
0.1
Inductance (uH)
Impedance
Impedance (Ohm)
Inductance (uH)
1000
100
Impedance (Ohm)
10000
120
HCM1A1105V2-220-R
HCM1A1105V2-150-R
160
Frequency (MHz)
Frequency (MHz)
80
100
40
1000
Impedance
Impedance (Ohm)
50
100
Impedance (Ohm)
1000
100000
350
1000
Impedance
300
250
100
200
10
150
100
1
50
Impedance (Ohm)
Inductance (uH)
70
120
Inductance (uH)
10000
Impedance (Ohm)
80
Inductance
0.1
1
10
100
0.1
Frequency (MHz)
9
HCM1A1105V2
HCM1A1105V2-680-R
100000
10000
500
1000
Impedance
400
100
300
10
200
1
100
Impedance (Ohm)
Inductance (uH)
600
Inductance
0.1
1
10
100
0.1
Frequency (MHz)
Inductance and temperature rise vs. current
HCM1A1105V2-R68-R
HCM1A1105V2-R72-R
0.4
0.3
0.2
Temperature rise
0.1
0.0
40
50
Idc (A)
60
70
80
90
100
0.7
90
0.6
60
0.4
50
0.3
40
0.2
0.8
80
OCL (uH)
10
70
Inductance
60
0.5
50
0.4
40
0.3
30
0.2
Temperature rise
Idc (A)
10
40
0.0
50
60
OCL (uH)
90
Temperature rise (℃ )
100
0.9
0.1
30
Temperature rise
10
0.0
15.0
30.0
Idc (A)
45.0
HCM1A1105V2-1R0-R
1.0
0.6
70
0.5
HCM1A1105V2-R90-R
0.7
80
Inductance
T emperature rise ( ℃)
OCL (uH)
0.5
Temperature rise℃
Inductance
0.8
1.1
1.0
0.9
0.8
0.7
0.6
0.5
0.4
0.3
0.2
0.1
0.0
100
90
80
Inductance
70
60
50
40
30
Temperature rise
Idc (A)
10
40
50
60
Temperature rise (℃)
0.6
100
90
80
70
60
50
40
30
OCL (uH)
0.7
HCM1A1105V2
1.6
100
90
1.4
90
80
Inductance
70
60
50
40
30
Temperature rise
16
24
32
Idc (A)
40
48
60
0.8
50
0.6
40
0.4
10
0.2
10
15
60
50
40
30
Temperature rise
OCL (uH)
70
24
Idc (A)
30
36
42
48
1.5
40
50
30
Temperature rise
12
16
Idc (A)
24
80
70
60
50
40
30
Temperature rise
8
12
16
Idc (A)
Idc (A)
24
28
32
28
32
36
100
4.5
90
Inductance
4.0
OCL (uH)
OCL (uH)
2.0
60
80
70
8
90
5.0
90
Inductance
4
1.0
0.0
100
HCM1A1105V2-4R7-R
2.5
0.0
45
1.5
1.0
Idc (A)
40
2.0
HCM1A1105V2-3R3-R
3.0
35
Inductance
0.5
10
18
30
100
2.5
OCL (uH)
80
Inductance
12
25
3.0
90
6
HCM1A1105V2-2R8-R
100
HCM1A1105V2-2R2-R
2.4
2.2
2.0
1.8
1.6
1.4
1.2
1.0
0.8
0.6
0.4
0.2
0.0
30
Temperature rise
8
70
1.0
80
3.5
70
3.0
60
2.5
50
2.0
40
1.5
10
1.0
0.0
30
Temperature rise
Inductance
1.2
100
OCL (uH)
1.3
1.2
1.1
1.0
0.9
0.8
0.7
0.6
0.5
0.4
0.3
0.2
0.1
0.0
HCM1A1105V2-1R5-R
OCL (uH)
HCM1A1105V2-1R2-R
10
10
15
30
HCM1A1105V2
HCM1A1105V2-5R6-R
HCM1A1105V2-6R8-R
80
70
60
50
3
40
2
30
Temperature rise
2
4
6
8
10 12 14 16 18 20 22 24 26
4
60
3
40
50
4
6
HCM1A1105V2-100-R
8
10
100
10
90
60
6
50
5
40
4
30
3
Temperature rise
1
10
8
10
Idc (A)
12
14
16
18
60
10
50
8
40
6
30
4
Temperature rise
12
2
3
4
5
6
Idc (A)
7
8
70
60
6
40
50
30
Temperature rise
4
6
8
10
10
12
Idc (A)
14
16
18
10
11
12
90
80
Inductance
70
16
60
50
12
40
8
10
OCL (uH)
OCL (uH)
70
1
80
Inductance
24
80
HCM1A1105V2-220-R
14
90
2
90
2
22
4
100
Inductance
16
HCM1A1105V2-150-R
18
18
100
10
OCL (uH)
70
7
4
Idc (A)
16
12
Temperatur
e rise (eC)
OCL (uH)
80
Inductance
2
14
14
9
HCM1A1105V2-120-R
11
2
Idc (A)
8
30
Temperature rise
1
10
2
5
1
90
Inductance
30
Temperature rise
2
3
4
5
6
Idc (A)
7
8
9
10 11 12
OCL (uH)
4
100
6
OCL (uH)
Inductance
Temperature rise (°C)
5
90
100
6
HCM1A1105V2
90
80
Inductance
70
60
50
40
30
Temperature rise
0.0 1.0 2.0 3.0 4.0 5.0 6.0 7.0 8.0 9.0 10.0 11.0
48
100
42
90
80
Inductance
36
70
30
60
24
50
18
40
30
Temperature rise
12
Idc (A)
100
OCL (uH)
34
32
30
28
26
24
22
16
14
12
10
8
6
4
2
HCM1A1105V2-470-R
OCL (uH)
HCM1A1105V2-330-R
10
0.0
1.0
2.0
3.0
4.0
5.0
Idc (A)
6.0
7.0
8.0
9.0
HCM1A1105V2-680-R
70
100
90
Inductance
80
OCL (uH)
50
70
60
40
50
30
40
Temperature rise
60
10
2
3
4
5
Idc (A)
6
7
8
9
10
13
HCM1A1105V2
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“HCM1A1105V2-470-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+8.39442500+1.09088
- 1000+7.916101000+1.02872
- 1500+7.649221500+0.99404
- 2500+7.326212500+0.95206
- 3500+7.121153500+0.92541
- 5000+6.910205000+0.89800
- 国内价格 香港价格
- 1+14.188691+1.84386
- 10+11.6984710+1.52025
- 25+10.8251925+1.40677
- 50+10.2064850+1.32636
- 100+9.62209100+1.25042
- 250+8.90257250+1.15691
