Technical Data 4370
Effective August 2018
Supersedes September 2017
HCM1104
High current power inductors
Applications
Voltage Regulator Module (VRM)
Multi-phase regulators
Point-of-Load modules
Desktop and server VRMs and EVRDs
Base station equipment
Notebook and laptop regulators
Battery power systems
Graphics cards
Data networking and storage systems
Environmental data
Product features
High current carrying capacity
Low core losses
Magnetically shielded, low EMI
Frequency range up to 5 MHz
Inductance range from 0.2 μH to 22 μH
Current range from 5 A to 45 A
11.5 mm x 10.3 mm footprint surface mount
package in a 4.0 mm height
Iron powder core material
Storage temperature range (Component):
-55 °C to +125 °C
Operating temperature range: -55 °C to +125 °C
(ambient + self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
HCM1104
Technical Data 4370
Product Specifications
OCL1
(μH) ± 20%
FLL2 (μH)
minimum
Irms3
(A)
Isat4,5
(A)
DCR (mΩ)
typical @
+20 °C
DCR (mΩ)
maximum @
+20 °C
K-factor6
HCM1104-R20-R
0.20
0.13
32
45
0.63
0.72
411
HCM1104-R36-R
0.36
0.23
30
42
1.04
1.20
269
HCM1104-R45-R
0.45
0.29
29
36
1.07
1.23
219
HCM1104-R56-R
0.56
0.36
25
32
1.56
1.80
230
HCM1104-R90-R
0.90
0.58
22
28
2.17
2.50
236
HCM1104-1R0-R
1.0
0.56
18
28
3.0
3.3
378
HCM1104-1R5-R
1.5
0.84
16
32
3.8
4.2
310
HCM1104-2R2-R
2.2
1.23
12
18
6.0
7.0
253
HCM1104-3R3-R
3.3
1.85
10
16
10.8
11.8
220
HCM1104-4R7-R
4.7
2.63
8.5
15
17
HCM1104-100-R
10
5.60
7.5
8.5
27
30
116
HCM1104-220-R
22
12.3
5.0
5.5
60
66
92
Part Number
7
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, @ +25 °C
2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, @ Isat, @ +25 °C
3. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case operating
conditions verified in the end application.
4. Isat: Peak current for approximately 20% rolloff @ +25 °C- HCM1104-R20-R to HCM1104-R90-R
5. Isat: Peak current for approximately 30% rolloff @ +25 °C HCM1104-1R0-R to HCM1104-220-R
6. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (Gauss), K: (K-factor from table), L:
(Inductance in μH), ΔI (Peak to peak ripple current in Amps).
7. Part Number Definition: HCM1104-xxx-R
HCM1104 = Product code and size
xxx= inductance value in μH, R= decimal point ,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
Dimensions (mm)
Recommended pad layout
Part marking: xxx=inductance value in uH, R= decimal point. If no R is present then last character equals number of zeros.
wlyy=date code, R=revision level
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.3 millimeters unless stated otherwise
Color: Grey
Do not route traces or vias underneath the inductor
2
www.eaton.com/electronics
Schematic
HCM1104
Technical Data 4370
Packaging information (mm)
Supplied in tape and reel packaging, 850parts per 13” diameter reel
50.0
50.0
40.0
40.0
Temperature Rise (° C)
Temperature rise vs. total loss
30.0
HCM1104-R20-R
HCM1104-R36-R
HCM1104-R45-R
HCM1104-R56-R
HCM1104-R90-R
20.0
10.0
HCM1104-1R0-R
30.0
HCM1104-1R5-R
20.0
HCM1104-3R3-R/ HCM11044R7-R/HCM1104-220-R
10.0
HCM1104-2R2-R/ HCM1104100-R
0.0
0.0
0.0
0.5
1.0
Total Loss (W)
1.5
2.0
0.0
0.5
1.0
1.5
2.0
Total Loss (W)
3
HCM1104
Technical Data 4370
Core loss vs. Bp-p
10,000
1 MHz
500 kHz
300 kHz
200KHz
1000
Core Loss (mW)
100 kHz
50 kH z
25 kH z
100
10
1
0.1
100
1 000
10, 000
B p-p (Gauss)
10,000
1MHz
500 kHz
300 kHz
200 kHz
1000
Core Loss (mW)
100 kHz
50 kH z
25 kH z
100
10
1
0.1
100
1 000
B p-p (Gauss)
4
10, 000
HCM1104
Technical Data 4370
Inductance characteristics
HCM1104-R36-R
HCM1104-R20-R
100%
100%
90%
80%
80%
% of OC L
% of OC L
90%
70%
70%
60%
60%
50%
50%
40%
40%
40
50
60
70
80
90
1 00
40
50
I DC (A)
HCM1104-R45-R
100%
60
70
80
90
1 00
I DC (A )
HCM1104-R56-R
100%
90%
80%
80%
% of OC L
% of OC L
90%
70%
70%
60%
60%
50%
50%
40%
40%
40
50
60
70
10
I DC (A )
30
40
I DC (A )
50
60
70
HCM1104-1R0-R
HCM1104-R90-R
100 %
100 %
90%
90%
80%
% of OCL
% of OC L
80%
70%
60%
70%
60%
50%
50%
40%
I DC (A )
40
50
60
40%
10
15
Idc (A)
25
30
35
40
5
HCM1104
Technical Data 4370
HCM1104-1R5-R
9 0%
90%
8 0%
80%
7 0%
70%
6 0%
60%
5 0%
50%
4 0%
HCM1104-2R2-R
100%
% of OCL
% of OCL
100%
40%
10
15
Idc (A)
30
2
4
6
8
10 12 14 16 18 20 22 24 26 28
Idc (A)
HCM1104-3R3-R
100%
HCM1104-4R7-R
100%
90%
9 0%
%of OCL
% of OCL
80%
70%
60%
8 0%
7 0%
6 0%
50%
5 0%
40%
6
4
8
10
12
14
16
18
4 0%
Idc (A)
HCM1104-100-R
100%
2
4
8
6
Idc (A)
10
12
14
16
18
HCM1104-220-R
110%
100%
9 0%
90%
8 0%
%of OCL
%of OCL
7 0%
80%
70%
6 0%
60%
5 0%
4 0%
6
50%
4
6
8
Idc (A)
10
12
14
16
40%
4
Idc (A)
6
8
10
HCM1104
Technical Data 4370
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“HCM1104-2R2-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+10.582711+1.37544
- 10+8.7072610+1.13169
- 100+7.16082100+0.93069
- 国内价格 香港价格
- 850+6.03207850+0.78399
- 1700+5.688401700+0.73932
- 2550+5.496692550+0.71441
- 4250+5.264624250+0.68425
- 5950+5.117345950+0.66510
- 8500+4.965828500+0.64541
- 国内价格
- 850+8.66925
- 15300+6.52915
