Effective June 2017
Supersedes Sepetember 2011
Technical Data DS4313
FP1308
High frequency, high current power inductors
Applications
Voltage regulator modules (VRMs) for servers
and microprocessors
Multi-phase buck inductors
High frequency, high current switching power
RE F
CO P1
30
M
NE M 8R
W EN 3DE DE R
SI D F
GN O
S R
supplies
SMD Device
Environmental data
Product features
13.7 x 12.9 x 8.0mm surface mount package
High current handling capability, compact
footprint
Ferrite core material
Inductance range from 0.110µH to 0.440µH
Current range from 32 to 120 amps
Frequency range up to 2MHz
Halogen free, lead free, RoHS compliant
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Pb HF
FREE
HALOGEN
Product Specifications
Part
Rated
5
Number
Inductance (μH)
FP1308-R11-R
0.110
FP1308-R21-R
0.210
FP1308-R26-R
0.260
FP1308-R32-R
0.320
FP1308-R44-R
0.440
OCL1
Irms2
Isat3
DCR (mΩ) @
DCR (mΩ) @
K-factor4
± 10% (μH)
0.110
0.210
0.260
0.320
0.440
(Amps)
68
68
68
68
68
(Amps)
120
72
60
45
32
25°C Typical
0.20
0.20
0.20
0.20
0.20
25°C Max
0.24
0.24
0.24
0.24
0.24
21.330
21.333
21.335
21.340
21.366
1 Open Circuit Inductance (OCL) Test Parameters: 100kHz, 1.0Vrms, 0.0Adc
2 Irms: DC current for an approximate temperature rise of 40°C without core loss. Derating is
necessary for AC currents. PCB pad layout, trace thickness and width, air-flow and proximity of
other heat generating components will affect the temperature rise. It is recommended the part
temperature not exceed 125°C under worst case operating conditions verified in the end
application.
3 Isat: Peak current for approximately 20% rolloff at +25°C.
4 K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p (mT): (Gauss), K:
(K-factor from table), L: (inductance in μH), ΔI (peak-to-peak ripple current in amps).
5 Part Number Definition: FP1308-xxx-R
• FP1308 = Product code and size
• xxx= Inductance value in μH, R = decimal point. If no “R” is present, then
third character = # of zeros.
• “-R” suffix = RoHS compliant
Effective June 2017
Dimensions - mm
1
7.62
2.54 (2plcs)
12.95 max.
Schematic
Recommended Pad Layout
Front View
Bottom View
Top View
1
RE F
CO P1
3
M
NE M 08
W EN R3
DE DE -R
SI D
GN FO
S R
3.18
5.4
7.2
8.0
13.70 max.
FP1308-XXX
wwllyy R
2
Left View
2
8.0 max.
Part Marking: FP1308
xxx = Inductance value in μH. (R = Decimal point). If no “R” is present, then last character is # 0f zeros
Packaging Information - mm
1.5 dia. +0.1/-0.0
wwllyy = Date code
4.0
1.5 diia. min
2.0
R = Revision level
A
1.75
Section A-A
13.9
FP1308-XXX
wwllyy R
13.2
8.2
A
User direction of feed
Supplied in tape-and-reel packaging, 400 parts per reel, 13” diameter reel.
Temperature Rise vs. Total Loss
Temperature Rise (°C)
100
80
60
40
1
1.5
Total Loss (W)
2
www.eaton.com/electronics
2
2.5
3
11.5
24.0 ±0.3
FP1308
Effective June 2017
Core Loss
Core Loss vs B p-p
1MHz
10
500kHz 100kHz
300kHz
50kHz
C o r e L o s s (W )
RE F
CO P1
3
M
NE M 08
W EN R3
DE DE -R
SI D
GN FO
S R
1
0.1
0.01
0.001
0.0001
1
10
100
1000
B p-p (mT)
Inductance Characteristics
OCL vs I sat
120%
100%
% of OCL
80%
60%
-40 °C
40%
+25 °C
20%
+125 °C
0%
0%
20%
40%
60%
80%
100%
120%
140%
160%
% of Isat
3
FP1308
Effective June 2017
Solder Reflow Profile
TP
TC -5°C
25°C
Preheat
A
t
Volume
mm3
220°C
220°C
RE F
CO P1
3
M
NE M 08
W EN R3
DE DE -R
SI D
GN FO
S R
Temperature
TL
T smax
Table 1 - Standard SnPb Solder (Tc)
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
Package
Thickness
2.5mm
ts
Time 25°C to Peak
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020
Profile Feature
Preheat and Soak
• Temperature min. (Tsmin)
• Temperature max. (Tsmax)
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to Peak Temperature
100°C
150°C
150°C
200°C
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Compan . Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant inju y to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. DS4313 BU-SB111090
June 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“FP1308-R21-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 400+11.09667400+1.43510
- 800+10.57241800+1.36730
- 1200+10.310291200+1.33340
- 2000+9.873412000+1.27690
- 2800+9.698662800+1.25430
- 4000+9.523914000+1.23170
- 国内价格
- 400+10.30108
- 800+9.83394
- 1200+9.55844
- 2000+9.18713
- 2800+9.00746
- 4000+8.81581
- 国内价格 香港价格
- 400+12.15593400+1.57210
- 800+11.46342800+1.48253
- 1200+11.077321200+1.43260
- 2000+10.609772000+1.37214
- 2800+10.312922800+1.33374
- 4000+10.007714000+1.29427
- 国内价格 香港价格
- 1+19.985191+2.58463
- 10+16.4651510+2.12940
- 100+13.54201100+1.75135
