MCL1005-390-R
MCL1005-390-R
    EATON(伊顿)
    固定电感器 0402 39nH ±5% 200mA 1Ω 1.2GHz 8@100MHz
MCL1005-390-R 数据手册
Technical Data 10925 Effective June 2019 MCL1005 Multilayer chip inductor Applications Product features • 0402 (1005 metric) package • High self resonant frequency (SRF) • Multilayer monolithic construction yields high reliability • Suitable for wave and reflow soldering • Inductance range from 1.0 nH to 360 nH • Moisture sensitivity level (MSL): 1 • Industrial connectivity (IoT) • Wireless communiations • Bluetooth • WiFi • Antenna • Machine-to-machine (M2M) • Mobile phones • Wearable devices • Wireless LAN • Computing/gaming consoles • Broadband components • RF transciever modules Environmental data • Operating temperature range: -55 °C to +125 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant HALOGEN Pb HF FREE MCL1005 Multilayer chip inductor  Technical Data 10925 Effective June 2019 Product specifications Part number OCL (nH) ±5% I Rated (mA) maximum DCR (Ω) maximum @ +25°C SRF (MHz) minimum Q (minimum) Test frequency (MHz) Test voltage (mV) MCL1005-1R0-R 1.0 ±0.3nH 400 0.10 10000 8 100 50 MCL1005-1R1-R 1.1 ±0.3nH 400 0.10 10000 8 100 50 MCL1005-1R2-R 1.2 ±0.3nH 400 0.10 10000 8 100 50 MCL1005-1R3-R 1.3 ±0.3nH 400 0.10 10000 8 100 50 MCL1005-1R5-R 1.5 ±0.3nH 300 0.10 6000 8 100 50 MCL1005-1R6-R 1.6 ±0.3nH 300 0.12 6000 8 100 50 MCL1005-1R8-R 1.8 ±0.3nH 300 0.12 6000 8 100 50 MCL1005-2R0-R 2.0 ±0.3nH 300 0.15 6000 8 100 50 MCL1005-2R2-R 2.2 ±0.3nH 300 0.15 6000 8 100 50 MCL1005-2R4-R 2.4 ±0.3nH 300 0.15 6000 8 100 50 MCL1005-2R7-R 2.7 ±0.3nH 300 0.15 6000 8 100 50 MCL1005-3R0-R 3.0 ±0.3nH 300 0.20 6000 8 100 50 MCL1005-3R3-R 3.3 ±0.3nH 300 0.20 6000 8 100 50 MCL1005-3R6-R 3.6 ±0.3nH 300 0.20 4000 8 100 50 MCL1005-3R9-R 3.9 ±0.3nH 300 0.20 4000 8 100 50 MCL1005-4R3-R 4.3 ±0.3nH 300 0.20 4000 8 100 50 MCL1005-4R7-R 4.7 ±0.3nH 300 0.25 4000 8 100 50 MCL1005-5R1-R 5.1 ±0.3nH 300 0.25 4000 8 100 50 MCL1005-5R6-R 5.6 ±0.3nH 300 0.25 4000 8 100 50 MCL1005-6R2-R 6.2 ±0.3nH 300 0.30 3900 8 100 50 MCL1005-6R8-R 6.8 300 0.30 3900 8 100 50 MCL1005-7R5-R 7.5 300 0.40 3700 8 100 50 MCL1005-8R2-R 8.2 300 0.40 3600 8 100 50 MCL1005-9R1-R 9.1 300 0.40 3400 8 100 50 MCL1005-100-R 10 300 0.40 3200 8 100 50 MCL1005-120-R 12 300 0.50 2700 8 100 50 MCL1005-150-R 15 300 0.50 2300 8 100 50 MCL1005-180-R 18 300 0.60 2100 8 100 50 MCL1005-200-R 20 300 0.60 2000 8 100 50 MCL1005-220-R 22 300 0.60 1900 8 100 50 MCL1005-270-R 27 300 0.70 1600 8 100 50 MCL1005-330-R 33 200 0.80 1300 8 100 50 MCL1005-390-R 39 200 1.00 1200 8 100 50 MCL1005-430-R 43 200 1.10 1100 8 100 50 MCL1005-470-R 47 200 1.10 1000 8 100 50 MCL1005-560-R 56 200 1.20 750 8 100 50 MCL1005-680-R 68 180 1.40 750 8 100 50 MCL1005-820-R 82 150 2.40 750 8 100 50 MCL1005-101-R 100 150 2.60 700 8 100 50 1. Test frequency and voltage are for OCL and Q at +25 °C 2. Resistance to soldering heat: +260 ±5 °C for 10 ± 1 second 3. At low temperature resistance (-55 ±2°C) the inductance change is within ±10% and the Q within ±20% 4. At high temperature resistance (+125 ±2°C) the inductance change is within ±10% and the Q within ±20% 2 www.eaton.com/electronics 5. At high temperature load (+125 ±2°C) the inductance change is within ±10% and the Q within ±20% 6. Rated I: When rated I is applied to the product, self-temperature rise will be 40 °C or less. 7. Part Number Definition: MCL1005-xxx-R MCL1005 = Product code and size xxx= inductance value in nH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant Technical Data 10925 MCL1005 Multilayer chip inductor Effective June 2019  Product specifications Part number OCL (nH) ±5% I Rated (mA) maximum DCR (Ω) maximum @ +25°C SRF (MHz) minimum Q (minimum) Test frequency (MHz) Test voltage (mV) MCL1005-121-R 120 150 2.80 600 8 100 50 MCL1005-151-R 150 100 3.20 550 8 100 50 MCL1005-181-R 180 100 3.70 500 8 100 50 MCL1005-221-R 220 100 4.00 450 8 100 50 MCL1005-271-R 270 100 4.50 400 8 100 50 MCL1005-331-R 330 50 7.00 350 6 50 50 MCL1005-361-R 360 50 7.50 300 6 50 50 1. Test frequency and voltage are for OCL and Q at +25 °C 2. Resistance to soldering heat: +260 ±5 °C for 10 ± 1 second 3. At low temperature resistance (-55 ±2°C) the inductance change is within ±10% and the Q within ±20% 4. At high temperature resistance (+125 ±2°C) the inductance change is within ±10% and the Q within ±20% 5. At high temperature load (+125 ±2°C) the inductance change is within ±10% and the Q within ±20% 6. Rated I: When rated I is applied to the product, self-temperature rise will be 40 °C or less. 7. Part Number Definition: MCL1005-xxx-R MCL1005 = Product code and size xxx= inductance value in nH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant Dimensions (mm) Schematic Recommended pad layout B L C Part Number L W T a A B C MCL1005-xxx-R 1.0 ±0.15 0.50 ±0.15 0.50 ±0.15 0.25 ±0.10 0.85 ±0.10 0.8 ±0.10 0.2 ±0.10 No part marking All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.2 millimeters unless stated otherwise Pad layout tolerances are ±0.1 millimeters unless stated otherwise Do not route traces or vias underneath the inductor www.eaton.com/electronics 3 MCL1005 Multilayer chip inductor  Technical Data 10925 Effective June 2019 Packaging information (mm) Drawing not to scale Supplied in tape and reel packaging, 10000 parts per 7” diameter reel W ±0.3 F±0.05 E1±0.10 E2 Min P0±0.10 P1±0.05 P2±0.1 D0+0.10/-0 A0 B0 T Max T1 Max 8.00 3.50 1.75 6.25 4.00 2.00 2.00 1.50 0.65±0.10 1.15±0.10 0.8 na Inductance vs frequency Q vs frequency 120 60 MCL1005-101-R 50 80 MCL1005-470-R 60 MCL1005-470-R 10 20 MCL1005-1R0-R 100 1000 Frequency(MHz) 4 30 20 40 0 MCL1005-1R0-R 40 Q Inductance(nH) 100 www.eaton.com/electronics 0 10000 MCL1005-101-R 100 1000 Frequency(MHz) 10000 Technical Data 10925 MCL1005 Multilayer chip inductor Effective June 2019  Solder reflow profile TP TC -5 °C tP Max. ramp up rate = 3° C/s Max. ramp down rate = 6 °C/s Temperature TL Preheat A T smax Package Thickness Volume mm3
MCL1005-390-R
1. 物料型号:MCL1005 2. 器件简介:适用于工业连接(物联网)、无线通信、蓝牙、Wi-Fi、天线、机器对机器(M2M)、移动电话和可穿戴设备。 3. 引脚分配:文档中未明确提供引脚分配信息,但提供了推荐的焊盘布局。 4. 参数特性: - 操作温度范围:-55°C 至 +125°C - 焊接回流温度:符合J-STD-020标准 - RoHS合规 - 电感范围:1.0 nH 至 360 nH - 高自谐振频率(SRF):最小10000 MHz - Q值(最小):8 - 直流电阻(DCR):在+25°C时的最大值 5. 功能详解:多層单片构造提供高可靠性,适用于波峰焊接和回流焊接。 6. 应用信息:文档提供了详细的产品规格表,包括不同型号的额定电流、直流电阻、自谐振频率和品质因数(Q)。 7. 封装信息:0402 (1005公制)封装,提供了尺寸图和封装信息,包括胶带和卷轴包装信息,每卷7英寸直径可装10000个部件。
MCL1005-390-R 价格&库存
很抱歉,暂时无法提供与“MCL1005-390-R”相匹配的价格&库存,您可以联系我们找货
MCL1005-390-R
    • 1+0.03305
    • 200+0.01286
    • 500+0.01242
    • 1000+0.01221
    MCL1005-390-R
    • 10000+0.1016310000+0.01276
    • 20000+0.0958220000+0.01203
    • 30000+0.0925830000+0.01163
    • 50000+0.0886650000+0.01113
    • 70000+0.0861670000+0.01082
    • 100000+0.08360100000+0.01050
    • 250000+0.07736250000+0.00971
    • 500000+0.07295500000+0.00916
    • 1000000+0.068811000000+0.00864
    库存:7517
    MCL1005-390-R
    • 1+0.878281+0.11025
    • 10+0.1576710+0.01980
    • 100+0.13217100+0.01659
    • 1000+0.108861000+0.01367
    • 5000+0.094935000+0.01192
    库存:7517
