MCL2012V2-470-R
MCL2012V2-470-R
    EATON(伊顿)
    固定电感器 0805 47nH ±5% 300mA 700mΩ 1GHz 18@100MHz
MCL2012V2-470-R 数据手册
Technical Data 10929 Effective June 2019 MCL2012V2 Multilayer chip inductor Applications Product features • Industrial connectivity (IoT) • Wireless communiations • Bluetooth • WiFi • Antenna • Machine-to-machine (M2M) • Mobile phones • Wearable devices • Wireless LAN • Computing/gaming consoles • 0805 (2012 metric) package • High self resonant frequency (SRF) Broadband components • • Multilayer monolithic construction yields high reliability RF transciever modules • • Suitable for wave and reflow soldering • Inductance range from 1.5 nH to 470 nH Environmental data • Moisture sensitivity level (MSL): 1 • Operating temperature range: -40 °C to +85 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant HALOGEN Pb HF FREE MCL2012V2 Multilayer chip inductor  Technical Data 10929 Effective June 2019 Product specifications Part number OCL (nH) ±5% I Rated (mA) maximum DCR (Ω) maximum @ +25°C SRF (MHz) minimum Q minimimum Test frequency (MHz) Test voltage (mV) MCL2012V2-1R5-R 1.5 ± 0.3nH 500 0.10 6000 10 100 50 MCL2012V2-1R8-R 1.8 ± 0.3nH 500 0.10 6000 10 100 50 MCL2012V2-2R2-R 2.2 ±0.3nH 500 0.10 6000 10 100 50 MCL2012V2-2R7-R 2.7 ±0.3nH 500 0.10 5500 12 100 50 MCL2012V2-3R0-R 3.0 ±0.3nH 500 0.13 5000 12 100 50 MCL2012V2-3R3-R 3.3± 0.3nH 500 0.13 5000 12 100 50 MCL2012V2-3R9-R 3.9 ±0.3nH 500 0.15 4500 12 100 50 MCL2012V2-4R7-R 4.7 ± 0.3nH 500 0.20 4000 12 100 50 MCL2012V2-5R6-R 5.6 ± 0.3nH 500 0.23 3500 15 100 50 MCL2012V2-6R8-R 6.8 500 0.25 3000 15 100 50 MCL2012V2-8R2-R 8.2 500 0.28 2500 15 100 50 MCL2012V2-100-R 10 500 0.30 2200 15 100 50 MCL2012V2-120-R 12 500 0.35 2000 15 100 50 MCL2012V2-150-R 15 500 0.40 1800 15 100 50 MCL2012V2-180-R 18 300 0.45 1600 15 100 50 MCL2012V2-220-R 22 300 0.50 1500 15 100 50 MCL2012V2-270-R 27 300 0.55 1400 15 100 50 MCL2012V2-330-R 33 300 0.60 1300 15 100 50 MCL2012V2-390-R 39 300 0.65 1100 15 100 50 MCL2012V2-470-R 47 300 0.70 1000 18 100 50 MCL2012V2-560-R 56 300 0.75 900 18 100 50 MCL2012V2-680-R 68 300 0.80 850 18 100 50 MCL2012V2-820-R 82 300 0.90 800 18 100 50 MCL2012V2-101-R 100 300 0.90 700 18 100 50 MCL2012V2-121-R 120 300 0.95 600 13 100 50 MCL2012V2-151-R 150 300 1.20 550 13 100 50 MCL2012V2-181-R 180 300 1.30 500 13 100 50 MCL2012V2-221-R 220 300 1.50 400 12 100 50 MCL2012V2-271-R 270 300 1.80 350 12 100 50 MCL2012V2-331-R 330 300 2.00 300 12 50 50 MCL2012V2-391-R 390 300 2.00 250 10 50 50 MCL2012V2-471-R 470 300 2.00 200 10 50 50 1. Test frequency and voltage is for OCL and Q at +25 °C 2. Resistance to soldering heat: +260 ±5 °C for 10 ± 1 second 3. At low temperature resistance (-40 ±2°C) the inductance change is within ±10% and the Q within ±20% 4. At high temperature rsistance (+85 ±2°C) the inductance change is within ±10% and the Q within ±20% 5. At high temperature load (+85 ±2°C) the inductance change is within ±10% and the Q within ±20% 2 www.eaton.com/electronics 6. Rated I: When rated I is applied to the product, self-temperature rise will be 40 °C or less. 7. Part Number Definition: MCL2012V2-xxx-R MCL2012 = Product code and size V2= Version indictaor xxx= inductance value in nH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant Technical Data 10929 MCL2012V2 Multilayer chip inductor Effective June 2019  Dimensions (mm) Schematic Recommended pad layout B L C Part Number L W T a A B C MCL2012V2-xxx-R 2.0 ±0.20 1.2 ±0.20 0.90 ±0.20 0.50 ±0.30 1.6 ±0.10 1.2 ±0.10 04 ±0.10 No part marking All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.2 millimeters unless stated otherwise Pad layout tolerances are ±0.1 millimeters unless stated otherwise Do not route traces or vias underneath the inductor Packaging information (mm) Drawing not to scale Supplied in tape and reel packaging, 4000 parts per 7” diameter reel W ±0.3 F±0.05 E1±0.10 E2 Min P0±0.10 P1±0.2 P2±0.1 D0+0.10/-0 A0 B0 T Max T1 Max 8.00 3.50 1.75 6.25 4.00 4.00 2.00 1.50 1.5±0.20 2.3±0.20 1.10 na www.eaton.com/electronics 3 MCL2012V2 Multilayer chip inductor  Technical Data 10929 Effective June 2019 Inductance vs frequency 150 Inductance(nH) 125 100 MCL2012V2-101-R MCL2012V2-560-R 75 50 25 0 MCL2012V2-3R0-R 100 1000 10000 Frequency(MHz) Q vs frequency 80 MCL2012V2-3R0-R 70 60 Q 50 40 30 20 MCL2012V2-560-R MCL2012V2-101-R 10 0 100 1000 Frequency(MHz) 4 www.eaton.com/electronics 10000 Technical Data 10929 MCL2012V2 Multilayer chip inductor Effective June 2019  Solder reflow profile TP TC -5 °C tP Max. ramp up rate = 3° C/s Max. ramp down rate = 6 °C/s Temperature TL Preheat A T smax Package Thickness Volume mm3
MCL2012V2-470-R
1. 物料型号:MCL2012V2系列,包括多种型号,例如MCL2012V2-1R5-R、MCL2012V2-1R8-R等,每个型号具有不同的电感值。
2. 器件简介:这些电感器采用多层单体结构,具有高可靠性,适用于回流焊和波峰焊,尺寸为0805(2012公制)。
3. 引脚分配:文档中没有明确提供引脚分配图,但提供了推荐的焊盘布局。
4. 参数特性: - 电感范围:1.5 nH 至 470 nH。 - 自谐振频率(SRF):最小值为不同型号而异,从1000 MHz至6000 MHz不等。 - 直流电阻(DCR):在+25°C时的最大值从0.10 mΩ至2.00 mΩ不等。 - 额定电流:最大500 mA至300 mA不等,取决于型号。
5. 功能详解:电感器适用于多种应用,包括工业连接(物联网)、无线通信、蓝牙、Wi-Fi、天线、机器对机器(M2M)、移动电话、可穿戴设备、无线局域网、计算/游戏控制台、宽带组件和射频收发器模块。
6. 应用信息:电感器适用于广泛的应用领域,包括工业物联网、无线通信等。
7. 封装信息:提供了详细的尺寸图和封装信息,包括推荐的焊盘布局和包装信息。
8. 环境数据:工作温度范围为-40°C至+85°C,符合J-STD-020标准的焊接回流温度,且为无卤素、无镓的产品。
9. 其他技术数据:包括电感与频率的关系图、Q值与频率的关系图、焊接回流曲线和波峰焊接曲线。
MCL2012V2-470-R 价格&库存
很抱歉,暂时无法提供与“MCL2012V2-470-R”相匹配的价格&库存,您可以联系我们找货
MCL2012V2-470-R
    • 3402+0.198293402+0.02566
    库存:4000
    MCL2012V2-470-R
      • 3402+0.18422
      库存:4000
      MCL2012V2-470-R
      • 4000+0.14268
      • 40000+0.13059
      • 160000+0.11487
      库存:4000
      MCL2012V2-470-R
        库存:4000
