MCQ1V3216-R560-R
MCQ1V3216-R560-R
    EATON(伊顿)
    固定电感器 1206 560nH ±10% 150mA 500mΩ 115MHz 30@25MHz
MCQ1V3216-R560-R 数据手册
Technical Data 11102 Effective June 2020 MCQ1V3216 Multilayer high Q chip inductor Applications • Industrial connectivity (IoT) • Wireless communications • Bluetooth • WiFi • Antenna • Machine-to-machine (M2M) • Mobile phones Product features • Wearable devices • 1206 (3216 metric) package • Wireless LAN • Multilayer monolithic construction yields high reliability • Computing/gaming consoles • Inductance range from 0.047 µH to 4.7 µH • RF transceiver modules • Moisture sensitivity level (MSL): 1 • Broadband components Environmental compliance and general specifications • Operating temperature range: -40 °C to +85 °C (ambient plus self-temperature rise) HALOGEN Pb HF FREE MCQ1V3216 Multilayer high Q chip inductor  Technical Data 11102 Effective June 2020 Product specifications Ls Tolerance (%) Ls1 (µH) Q minimum DCR (Ω) @ +25 °C maximum Test frequency2 (MHz) Test voltage2 (mV) SRF (MHz) minimum Rated I3 maximum (mA) MCQ1V3216-R047-R ±10 0.047 30 0.15 50 50 320 300 MCQ1V3216-R056-R ±10 0.056 30 0.2 50 50 320 300 MCQ1V3216-R068-R ±10 0.068 30 0.25 50 50 280 300 MCQ1V3216-R082-R ±10 0.082 30 0.25 50 50 280 300 MCQ1V3216-R100-R ±10 0.10 25 0.25 25 50 235 250 MCQ1V3216-R120-R ±10 0.12 25 0.25 25 50 220 250 MCQ1V3216-R150-R ±10 0.15 25 0.25 25 50 200 250 MCQ1V3216-R180-R ±10 0.18 25 0.3 25 50 185 250 MCQ1V3216-R220-R ±10 0.22 25 0.3 25 50 170 250 MCQ1V3216-R270-R ±10 0.27 25 0.3 25 50 150 250 MCQ1V3216-R330-R ±10 0.33 25 0.3 25 50 145 250 MCQ1V3216-R390-R ±10 0.39 30 0.5 25 50 135 200 MCQ1V3216-R470-R ±10 0.47 30 0.5 25 50 125 200 MCQ1V3216-R560-R ±10 0.56 30 0.5 25 50 115 150 MCQ1V3216-R680-R ±10 0.68 30 0.5 25 50 105 150 MCQ1V3216-R820-R ±10 0.82 30 0.6 25 50 100 150 MCQ1V3216-1R0-R ±10 1.0 35 0.3 10 50 75 100 MCQ1V3216-1R2-R ±10 1.2 35 0.4 10 50 65 100 MCQ1V3216-1R5-R ±10 1.5 35 0.4 10 50 60 50 MCQ1V3216-1R8-R ±10 1.8 35 0.4 10 50 55 50 MCQ1V3216-2R2-R ±10 2.2 35 0.5 10 50 50 50 MCQ1V3216-2R7-R ±10 2.7 35 0.5 10 50 45 50 MCQ1V3216-3R3-R ±10 3.3 35 0.5 10 50 41 50 MCQ1V3216-3R9-R ±10 3.9 35 0.6 10 50 38 50 MCQ1V3216-4R7-R ±10 4.7 35 0.65 10 50 35 25 Part number 4 1. Ls = Inductance 2. Ls and Q test voltage and frequency 3. Rated I: Current rating for an approximate self-temperature rise of 40 °C or less. 2 www.eaton.com/electronics 4. Part Number Definition: MCQ1V3216-xxx-R MCQ1V3216 = Product code and size xxx= inductance value in µH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant Technical Data 11102 MCQ1V3216  Multilayer high Q chip inductor Effective June 2020  Mechanical parameters, schematic, pad layout (mm) Recommended pad layout Schematic Part Number L W T a F G H MCQ1V3216-xxx-R 3.20 ±0.20 1.60 ±0.20 0.90 ±0.20 0.50 ±0.30 2.00 ref 1.40 ref 1.20 ref Part marking: No marking All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.1 millimeters unless stated otherwise Pad layout dimensions are reference only Traces or vias underneath the inductor is not recommended Packaging information (mm) Drawing not to scale Supplied in tape and reel packaging, 4000 parts per 7” diameter reel W±0.2 8.00 F±0.1 3.50 E1±0.2 1.75 E2 Min na P0±0.2 4.00 P1±0.2 4.00 P2±0.1 2.00 D0±0.1 1.55 A0 1.9±0.2 B0 3.5±0.2 T 0.95±0.1 T1 Max na www.eaton.com/electronics 3 MCQ1V3216 Multilayer high Q chip inductor  Technical Data 11102 Effective June 2020 Qualification testing No. Test item Sample size (pcs) 1 External visual 72 2 Physical dimension 72 Specification Specification 3 Initial electrical test 72 Specification User spec 4 Solderability 6 +245 °C ±5 °C, dipping 5 ±1 s >95% solder coverage 5 Resistance to soldering heat 6 +260 ±5 °C for 10±1 s 1. ΔL/L
MCQ1V3216-R560-R 价格&库存
很抱歉,暂时无法提供与“MCQ1V3216-R560-R”相匹配的价格&库存,您可以联系我们找货
MCQ1V3216-R560-R
  • 4000+0.270234000+0.03389
