Technical Data 10904
Effective April 2019
HCM1A1305V2
Automotive grade high current power inductors
Applications
Product features
AEC-Q200 qualified
High current carrying capacity
Magnetically shielded, low EMI
DC-DC converter applications up to 1 MHz
Filtering applications up to Self Resonant
Frequency (SRF) [See product specification
table]
Inductance range from 0.10 μH to 33 μH
Current range from 4.5 A to 80 A
13.8 mm x 12.9 mm footprint surface mount
package in a 5.0 mm height
Moisture Sensitivity Level (MSL): 1
Alloy powder core material
Body electronics
• Central body control module
Headlamps, tail lamps and interior lighting and
LED lighting
Heating ventilation and air conditioning
controllers (HVAC)
Doors, window lift and seat control
Advanced driver assistance systems
• Adaptive cruise control (ACC)
Automatic parking control
Collision avoidance system/ Car black
box system
Infotainment and cluster electronics
• Audio subsystem: head unit and trunk amp
Digital instrument cluster
In-vehicle infotainment (IVI) and navigation
Chassis and safety electronics
• Airbag control unit
Electronic stability control system (ESC)
Electric parking brake
Electronic power steering (EPS)
Engine and Powertrain Systems
• Electric pumps, motor control and auxiliaries
Powertrain control module (PCU)/
Engine Control unit (ECU)
Transmission Control Unit (TCU)
Environmental data
Storage temperature range (Component):
-55 °C to +155 °C
Operating temperature range: -55 °C to +155 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
HCM1A1305V2
Product specifications
Part number6
OCL1
(μH) ± 20%
FLL2 (μH)
minimum
Irms3
(A)
Isat4
(A)
DCR (mΩ)
typical @ +20 °C
DCR (mΩ)
maximum @ +20 °C
SRF (MHz)
typical
K-factor5
HCM1A1305V2-R10-R
0.10
0.064
43
80
0.33
0.59
234
908
HCM1A1305V2-R22-R
0.22
0.14
48
60
0.53
0.61
107
449
HCM1A1305V2-R33-R
0.33
0.21
46
50
0.59
0.69
70
345
HCM1A1305V2-R47-R
0.47
0.30
44
50
0.70
0.85
58
266
HCM1A1305V2-R56-R
0.56
0.36
29.5
50
1.15
1.33
57
202
HCM1A1305V2-R68-R
0.68
0.44
30
45
1.15
1.33
46
191
HCM1A1305V2-R82-R
0.82
0.52
27
36
1.40
1.61
45
197
HCM1A1305V2-1R0-R
1.0
0.64
24
35
1.78
2.05
40
165
HCM1A1305V2-1R5-R
1.5
0.96
19
27
2.60
3.00
30
156
HCM1A1305V2-1R8-R
1.8
1.15
17
26
3.25
3.74
30
132
HCM1A1305V2-2R2-R
2.2
1.41
15
25
4.04
4.65
25
118
HCM1A1305V2-3R3-R
3.3
2.11
12
19
5.75
9.20
16
95
HCM1A1305V2-4R7-R
4.7
3.01
11
18
8.15
9.38
13
93
HCM1A1305V2-5R6-R
5.6
3.58
10
17
11
12.7
11
72
HCM1A1305V2-6R0-R
6.0
3.84
9.7
16
11
12.7
11
73
HCM1A1305V2-6R8-R
6.8
4.35
9.5
15
12.1
14.0
11
82
HCM1A1305V2-7R8-R
7.8
4.99
7.6
15
15
17.3
10
62
HCM1A1305V2-8R2-R
8.2
5.25
7.5
13
16
18.5
9
59
HCM1A1305V2-100-R
10
6.40
7.5
13
18.17
20.9
8
54
HCM1A1305V2-120-R
12
7.68
7.0
9.0
19.5
23.0
6
59
HCM1A1305V2-150-R
15
9.60
6.5
9.5
23.5
27.1
6
50
HCM1A1305V2-220-R
22
14.1
5.0
7.0
34.7
40.0
5
50
HCM1A1305V2-330-R
33
21.1
4.5
5.2
49.2
58.0
3
37
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, +25 °C
2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, Isat, , +25 °C
3. Irms: DC current for an approximate temperature rise of 30 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed +155 °C under worst case operating
conditions verified in the end application.
2
www.eaton.com/electronics
4. Isat: Peak current for approximately 20% rolloff @ +25 °C
5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (Gauss), K: (K-factor from table),
L: (Inductance in μH), ΔI (Peak to peak ripple current in Amps).
6. Part Number Definition: HCM1A1305V2-xxx-R
HCM1A1305V2 = Product code and size
xxx= inductance value in μH, R= decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
HCM1A1305V2
Dimensions (mm)
Schematic
Dimension A
HCM1A1305V2-R10
through R47-R,
HCM1A1305V2-R56
through 2R2-R
HCM1A1305V23R3 through
330-R
4.4 ±0.3
3.68 ±0.3
4.7 ±0.3
1
2
Part marking: 1AxxxV2, xxx=inductance value in uH, R=decimal point. If no R is present then last character equals number of zeros. xxxx=Lot code
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.3 millimeters unless stated otherwise
Pad layout tolerances are ±0.1 millimeters unless stated otherwise
DCR measured from point “a” to point “b”
Do not route traces or vias underneath the inductor
Packaging information (mm)
Drawing not to scale
Supplied in tape and reel packaging, 250 parts per 13” diameter reel
3
HCM1A1305V2
Core loss vs Bp-p
HCM1A1305V2-R22-R
HCM1A1305V2-R10-R
10000
1000
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
Core Loss (mW)
100
10
1
Core Loss (mW)
10000
700 kHz
500 kHz
300 kHz
100
100 kHz
50 kHz
10
1
0.1
0.1
0.01
1000
0.01
100
1000
Bp-p (Gauss)
HCM1A1305V2-R47-R
HCM1A1305V2-R33-R
10000
10000
100
700 kHz
500 kHz
300 kHz
1000
100 kHz
50 kHz
100
10
1
Core Loss (mW)
Core Loss (mW)
1000
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
10
1
0.1
0.1
0.01
0.01
100
1000
100
HCM1A1305V2-R56-R
HCM1A1305V2-R68-R
10000
10000
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
100
10
1
0.1
700 kHz
500 kHz
300 kHz
1000
Core Loss (mW)
Core Loss (mW)
1000
0.01
1000
Bp-p (Gauss)
Bp-p (Gauss)
100 kHz
50 kHz
100
10
1
0.1
100
1000
Bp-p (Gauss)
4
1000
100
Bp-p (Gauss)
0.01
100
1000
Bp-p (Gauss)
HCM1A1305V2
Core loss vs Bp-p
HCM1A1305V2-R82-R
HCM1A1305V2-1R0-R
10000
10000
100
700 kHz
500 kHz
300 kHz
1000
100 kHz
50 kHz
100
10
1
Core Loss (mW)
Core Loss (mW)
1000
100 kHz
50 kHz
10
1
0.1
0.01
700 kHz
500 kHz
300 kHz
0.1
100
0.01
1000
Bp-p (Gauss)
100
HCM1A1305V2-1R8-R
HCM1A1305V2-1R5-R
10000
10000
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
100
10
1
700 kHz
500 kHz
300 kHz
1000
Core Loss (mW)
Core Loss (mW)
1000
100 kHz
50 kHz
100
10
1
0.1
0.1
0.01
0.01
100
1000
100
HCM1A1305V2-3R3-R
HCM1A1305V2-2R2-R
10000
10000
100
10
1
700 kHz
500 kHz
300 kHz
1000
100 kHz
50 kHz
100
Core Loss (mW)
1000
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
10
1
0.1
0.1
0.01
1000
Bp-p (Gauss)
Bp-p (Gauss)
Core Loss (mW)
1000
Bp-p (Gauss)
0.01
100
1000
Bp-p (Gauss)
1000
100
Bp-p (Gauss)
5
HCM1A1305V2
Core loss vs Bp-p
HCM1A1305V2-4R7-R
HCM1A1305V2-5R6-R
10000
10000
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
100
Core Loss (mW)
Core Loss (mW)
1000
10
1
0.1
0.01
1000
700 kHz
500 kHz
300 kHz
100
100 kHz
50 kHz
10
1
0.1
100
0.01
1000
Bp-p (Gauss)
HCM1A1305V2-6R8-R
10000
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
1000
100
10
1
1000
700 kHz
500 kHz
300 kHz
100
100 kHz
50 kHz
Core Loss (mW)
10000
Core Loss (mW)
1000
Bp-p (Gauss)
HCM1A1305V2-6R0-R
10
1
0.1
0.1
0.01
100
0.01
100
1000
100
HCM1A1305V2-8R2-R
HCM1A1305V2-7R8-R
10000
1000
700 kHz
500 kHz
300 kHz
100
100 kHz
50 kHz
10
1
1000
700 kHz
500 kHz
300 kHz
100
100 kHz
50 kHz
10
1
0.1
0.1
0.01
100
1000
Bp-p (Gauss)
6
Core Loss (mW)
Core Loss (mW)
10000
0.01
1000
Bp-p (Gauss)
Bp-p (Gauss)
100
1000
Bp-p (Gauss)
HCM1A1305V2
Core loss vs Bp-p
HCM1A1305V2-100-R
HCM1A1305V2-120-R
10000
10000
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
100
10
1
0.1
0.01
700 kHz
500 kHz
300 kHz
1000
Core Loss (mW)
Core Loss (mW)
1000
100 kHz
50 kHz
100
10
1
0.1
100
0.01
1000
Bp-p (Gauss)
100
HCM1A1305V2-150-R
HCM1A1305V2-220-R
10000
10000
100
10
1
0.1
1000
700 kHz
500 kHz
300 kHz
100
100 kHz
50 kHz
10
1
0.1
100
0.01
1000
Bp-p (Gauss)
100
1000
Bp-p (Gauss)
HCM1A1305V2-330-R
10000
700 kHz
500 kHz
300 kHz
1000
Core Loss (mW)
Core Loss (mW)
100 kHz
50 kHz
Core Loss (mW)
700 kHz
500 kHz
300 kHz
1000
0.01
1000
Bp-p (Gauss)
100 kHz
50 kHz
100
10
1
0.1
0.01
100
1000
Bp-p (Gauss)
7
HCM1A1305V2
Inductance and impedance vs. frequency
0.4
0.3
Impedance
10
0.2
Inductance (uH)
100
Impedance (Ohm)
0.1
1
10
0.4
1000
0.3
100
Inductance
100
10
0.2
1
0.1
Inductance
Impedance
1
0.1
0.5
0.1
1
0.1
100
Frequency (MHz)
Frequency (MHz)
HCM1A1305V2-R33-R
HCM1A1305V2-R47-R
1000
1
10000
1.4
0.9
1.2
0.8
10
0.5
0.4
Inductance
0.3
100
0.8
Impedance
0.6
10
Inductance
0.4
1
0.2
1000
1
Inductance (uH)
Impedance
0.6
Impedance (Ohm)
100
0.7
Inductance (uH)
10
Impedance (Ohm)
Inductance (uH)
HCM1A1305V2-R22-R
1000
Impedance (Ohm)
HCM1A1305V2-R10-R
0.5
1
0.2
0.1
1
10
100
0.1
1
100
0.1
Frequency (MHz)
Frequency (MHz)
HCM1A1305V2-R56-R
2
10
10000
HCM1A1305V2-R68-R
10000
2.5
1.8
100
Impedance
1
0.8
10
0.6
Inductance
0.4
1
Impedance (Ohm)
Inductance (uH)
1.2
1000
2
100
1.5
Impedance
10
1
Inductance
0.5
1
0.2
1
10
Frequency (MHz)
8
100
0.1
1
10
Frequency (MHz)
100
0.1
Impedance (Ohm)
1000
1.4
Inductance (uH)
1.6
HCM1A1305V2
HCM1A1305V2-R82-R
3.5
HCM1A1305V2-1R0-R
10000
4
10000
3.5
1000
10
1
Inductance
1
Inductance (uH)
1.5
Impedance (Ohm)
0.5
2.5
Impedance
10
1.5
1
Inductance
1
0.5
0.1
1
10
100
0.1
1
HCM1A1305V2-1R5-R
8
10000
12
1000
10
6
Impedance
Impedance (Ohm)
100
4
10
3
2
Inductance
1
Inductance (uH)
7
5
1
10
100
0.1
10000
1000
8
Impedance
100
6
10
4
1
Inductance
0.1
Frequency (MHz)
0.1
1
10
100
0.1
Frequency (MHz)
HCM1A1305V2-2R2-R
14
100
HCM1A1305V2-1R8-R
2
0.1
10
Frequency (MHz)
Frequency (MHz)
Inductance (uH)
100
2
Impedance (Ohm)
Inductance (uH)
100
Impedance
2
3
2.5
Impedance (Ohm)
3
10000
25
1000
15
12
HCM1A1305V2-3R3-R
10000
1000
10
4
1
2
10
1
5
Inductance
0.1
1
Inductance
10
Frequency (MHz)
100
Impedance (Ohm)
6
Impedance
Inductance (uH)
Impedance
8
Impedance (Ohm)
Inductance (uH)
10
100
0.1
1
10
100
0.1
Frequency (MHz)
9
HCM1A1305V2
10
15
10
1
1
10
100
100
30
10
Inductance
0.1
Frequency (MHz)
HCM1A1305V2-6R0-R
60
30
10
10
Inductance (uH)
100
0.1
100
0.1
10000
1000
Impedance
100
30
10
10
Inductance
1
10
100
0.1
1
10
100
HCM1A1305V2-8R2-R
HCM1A1305V2-7R8-R
90
100000
100000
80
60
10000
30
10
10
Inductance
1
10
Frequency (MHz)
10
60
100
0.1
Inductance (uH)
100
10000
70
1000
Impedance
Impedance (Ohm)
Inductance (uH)
50
40
0.1
Frequency (MHz)
Frequency (MHz)
70
10
HCM1A1305V2-6R8-R
Inductance
Frequency (MHz)
40
Impedance
Impedance (Ohm)
Inductance (uH)
1
50
1000
40
0.1
60
10000
50
1
10
Inductance
0.1
Impedance
1000
Impedance
50
100
40
30
10
10
Inductance
0.1
1
10
Frequency (MHz)
100
0.1
Impedance (Ohm)
5
1000
40
Inductance (uH)
100
Impedance (Ohm)
Inductance (uH)
Impedance
1000
25
10000
Impedance (Ohm)
35
30
HCM1A1305V2-5R6-R
60
10000
Impedance (Ohm)
HCM1A1305V2-4R7-R
40
HCM1A1305V2
HCM1A1305V2-100-R
HCM1A1305V2-120-R
120
100000
100
10000
120
100000
10000
60
100
40
10
100
10
30
1
1
Inductance
Impedance
0.1
1
Inductance
10
100
0.1
Frequency (MHz)
0.1
1
10
100
0.1
Frequency (MHz)
HCM1A1305V2-150-R
200
Impedance (Ohm)
1000
Impedance
Inductance (uH)
Inductance (uH)
80
Impedance (Ohm)
90
HCM1A1305V2-220-R
100000
250
100000
180
Impedance
100
100
80
10
60
40
1
10
100
HCM1A1305V2-330-R
50
1
0.1
1
10
100
0.1
Frequency (MHz)
180
1000
Impedance
150
100
120
90
10
60
Impedance (Ohm)
10000
210
Inductance (uH)
10
100000
240
1
30
100
Frequency (MHz)
270
1000
Impedance
150
Inductance
Inductance
0.1
Inductance (uH)
1000
120
Impedance (Ohm)
Inductance (uH)
140
10000
200
Impedance (Ohm)
10000
160
Inductance
0.1
1
10
100
0.1
Frequency (MHz)
11
HCM1A1305V2
Inductance and temperature rise vs. current
HCM1A1305V2-R22-R
HCM1A1305V2-R10-R
Inductance
0.09
90
0.22
60
0.06
50
0.05
40
0.04
30
Temperature rise
0.14
60
0.12
50
0.10
40
0.08
0.01
10
0.02
0.00
40
60
80
100
120
140
30
0.06
0.02
0.16
Temperature rise
0.04
10
60
0.35
70
60
0.20
50
0.15
40
30
0.10
Temperature rise
100
120
140
90
0.40
80
0.35
70
0.30
60
0.25
50
0.20
40
0.15
30
Temperature rise
0.00
60
HCM1A1305V2-R56-R
0.60
50.0
0.30
40.0
30.0
0.20
Temperature rise
20.0
0.10
10.0
40
50
60
Idc (A)
12
70
80
90
100
110
0.0
140
Inductance
90
80
0.50
OCL (uH)
60.0
Temperature rise (℃)
OCL (uH)
70.0
120
0.60
80.0
0.40
0.00
0.70
90.0
0.50
100
HCM1A1305V2-R68-R
100.0
Inductance
80
Idc (A)
Idc (A)
0.70
10
80
100
0.10
OCL (uH)
OCL (uH)
0.25
80
60
Inductance
0.45
90
0.30
40
120
0.50
100
Inductance
HCM1A1305V2-R47-R
HCM1A1305V2-R33-R
Idc (A)
Idc (A)
0.00
0.03
90
0.18
OCL (uH)
70
0.07
100
Inductance
0.20
80
0.08
OCL (uH)
0.24
70
60
0.40
50
0.30
40
30
0.20
Temperature rise
0.00
10
40
50
60
Idc (A)
70
80
90
100
110
0.10
100
0.11
HCM1A1305V2
HCM1A1305V2-1R0-R
0.70
1.00
60
0.50
50
0.40
40
0.30
30
Temperature rise
0.10
40
50
60
70
80
90
80
70
0.70
60
0.60
50
0.50
40
0.40
0.30
0.10
10
40
HCM1A1305V2-1R5-R
60
0.80
50
40
0.60
30
0.40
Temperature rise
0.20
0.00
5
10
15
30
35
40
45
50
55
60
80
1.40
70
1.20
60
1.00
50
0.80
40
0.60
10
10
15
30
35
40
45
50
55
60
Idc (A)
HCM1A1305V2-3R3-R
Inductance
100.0
3.50
100
Inductance
90.0
90
2.00
3.00
80.0
1.40
60
1.20
50
1.00
40
0.80
30
0.60
Temperature rise
0.40
10
0.00
10
15
70.0
60.0
2.00
50.0
1.50
40.0
30.0
1.00
OCL (uH)
70
1.60
80
1.80
OCL (uH)
30
Temperature rise
0.20
HCM1A1305V2-2R2-R
2.20
90
1.60
Idc (A)
2.40
100
0.40
10
OCL (uH)
OCL (uH)
1.00
70
Inductance
1.80
80
1.20
70
2.00
90
1.40
60
HCM1A1305V2-1R8-R
100
Inductance
50
Idc (A)
Idc (A)
1.60
30
Temperature rise
30
Idc (A)
35
40
45
50
55
Temperature rise
0.20
90
0.80
OCL (uH)
70
100
Inductance
0.90
OCL (uH)
90
80
0.60
0.00
1.10
Inductance
0.80
100
HCM1A1305V2-R82-R
20.0
0.50
10.0
0.00
4
6
8
10
12
14
16
18
24
26
28
30
32
34
36
38
0.0
Idc (A)
13
HCM1A1305V2
HCM1A1305V2-4R7-R
HCM1A1305V2-5R6-R
90
4.00
2.40
50
2.00
40
1.60
30
Temperature rise
0.40
10
0.00
10
15
30
35
40
45
60
3.0
50
40
2.0
70
10
0.0
10
15
Idc (A)
7.0
90
5.0
50
40
Temperature rise
30
10
15
80
70
60
4.0
50
3.0
40
30
Temperature rise
2.0
25
30
35
40
8.0
80
7.0
50
40
3.0
Temperature rise
2.0
30
10
4
6
8
10 12 14 16 18 20 22 24 26 28 30 32 34
Idc (A)
10
15
30
35
Inductance
90
80
70
6.0
OCL (uH)
60
4.0
0.0
90
70
5.0
5
HCM1A1305V2-8R2-R
6.0
100
7.0
10
Idc (A)
HCM1A1305V2-7R8-R
Inductance
Idc (A)
8.0
Inductance
OCL (uH)
40
5.0
OCL (uH)
OCL (uH)
60
3.0
Temperature rise℃
70
1.0
14
35
6.0
80
4.0
0.0
30
HCM1A1305V2-6R8-R
100
Inductance
2.0
25
Idc (A)
HCM1A1305V2-6R0-R
6.0
30
Temperature rise
1.20
80
4.0
OCL (uH)
OCL (uH)
2.80
60
70
3.20
90
5.0
80
3.60
100
Inductance
Inductance
4.40
6.0
100
60
5.0
50
4.0
40
3.0
30
Temperature rise
2.0
0.0
10
4
6
8
10
12
14
16
Idc (A)
18
24
26
28
30
4.80
HCM1A1305V2
HCM1A1305V2-100-R
HCM1A1305V2-120-R
9
90
12
6
50
5
40
4
Temperature rise
3
30
2
10
4
6
8
10
12
14
16
18
24
OCL (uH)
60
80
9
70
8
60
7
50
6
5
10
1
4
6
80
18
60
8
50
40
6
30
Temperature rise
10
8
10
16
18
14
16
18
90
80
70
16
OCL (uH)
OCL (uH)
10
6
14
Inductance
22
12
4
12
24
90
2
10
HCM1A1305V2-220-R
100
14
Idc (A)
Inductance
3
HCM1A1305V2-150-R
4
40
Temperature rise
4
Idc (A)
16
90
10
70
7
100
Inductance
11
80
8
OCL (uH)
13
Inductance
10
100
14
60
12
50
10
40
8
30
Temperature rise
6
10
2
Idc (A)
11
2
3
4
5
6
7
8
9
10
11
12
13
14
15
Idc (A)
HCM1A1305V2-330-R
35
100
Inductance
90
30
OCL (uH)
70
60
15
40
30
Temperature rise
10
80
25
10
2
3
4
5
6
7
8
9
10
11
12
13
Idc (A)
15
HCM1A1305V2
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“HCM1A1305V2-6R0-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 250+7.25461
- 15000+5.98505
