Technical Data 4365
Effective July 2017
Supersedes April 2009
FP1505
High frequency, high current power inductors
Applications
SMD Device
Environmental data
Product features
7.0 x 15.0 x 5.0mm surface mount package
Ferrite core material
High current handling capability, low core loss
Designed for high speed, high current switch
mode applications
Tight DCR tolerance for sensing circuits
Inductance range from 100 nH to 400 nH
Current range from 24 A to 105 A
Frequency range up to 1 MHz
Multi-phase regulators
Voltage Regulator Module (VRM)
Desktop and server VRMs and EVRDs
Data networking and storage systems
Notebook regulators
Graphics cards and battery power systems
Point of load modules
DCR current sensing
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Pb HF
FREE
HALOGEN
Technical Data 4365
Effective July 2017
Product specifications
OCL1
FLL2
± 10% (nH)
100
120
150
250
300
400
Min. (nH)
72
86
108
180
217
288
Part
7
Number
FP1505R1-R10-R
FP1505R1-R12-R
FP1505R1-R15-R
FP1505R1-R25-R
FP1505R1-R30-R
FP1505R1-R40-R
Irms3
Isat14
(A)
Isat25
(A) @+25 °C
105
87
72
42
35
24
53
1 Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 1.0 Vrms, 0.0 Adc
2 Full Load Inductance (FLL) Test Parameters: 100 kHz, 1.0 Vrms, Isat1
3 Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is
necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other
heat generating components will affect the temperature rise. It is recommended that the
temperature of the part not exceed +125 °C under worst case operating conditions verified in the
end application.
4 Isat1: Peak current for approximately 20% rolloff at +25 °C.
DCR (mΩ)
(Amps) @+125 °C
90
75
60
32
26
19.5
K-factor6
356.3
356.3
356.3
356.3
356.3
356.3
@+20 °C
0.47 ± 7%
5 Isat2: Peak current for approximately 20% rolloff at +125 °C.
6 K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI * 10-3. Bp-p:(Gauss), K:
(K-factor from table), L: (Inductance in nH), ΔI (Peak-to-peak ripple current in amps).
7 Part Number Definition: FP1505Rx-Rxx-R
• FP1505 = Product code and size
• Rx= DCR indicator
• Rxx= Inductance value in uH, R = decimal point
• -R suffix = RoHS compliant
Dimensions- mm
T o p V iew
F ro n t V iew
S id e V iew
R e co m m ended P a d Layout
a
S ch em atic
1
2 .0
ref
1505Rx
R xx
w w llyy R
1
5 .0 0 M ax
1 4 .7
± 0.3
15
1 .9 ref.
(2x)
2 .8 ref.
2 .5 0 (2 x)
2
2
4 .5 0 (2 x)
b
6 .7
± 0.3
Part Marking:
The nominal DCR is measured between points “a” and “b”
1505Rx Rx = DCR indicator
Rxx = Inductance value in μH. (R = Decimal point).
wwllyy = Date code
R = Revision level
Do not route traces or vias underneath the inductor
Packaging information - mm
1.5 dia
2.0
4.0
1.75
A
1.5 dia
11.5
15.4
7.4
5.4
S ection A -A
Supplied in tape-and-reel packaging, 744 parts per reel, 13” diameter reel.
2
www.eaton.com/electronics
24.0
± 0.3
1505Rx
Rxx
wwllyy R
16.0
A
User direction of feed
FP1505
Technical Data 4365
Effective July 2017
Temperature rise vs total loss
50
T e m p e ra tu re R is e (°C )
45
40
35
30
25
10
5
0.8
1.2
1.6
2
T o ta l L o s s (W )
Core loss vs Bp-p
1
M Hz
10
500
kHz
100
kHz
300 200
kHz kHz
C o re L o s s (W )
1
0.1
0.01
0.001
0.0001
100
1000
10000
Bp - p (G a u s s )
Inductance characteristics
% o f O C L v s . % o f Isat1
100%
% of O C L
80%
-40°C
+25°C
60%
+125°C
40%
20%
0%
0%
20%
40%
60%
80%
100%
120%
140%
% o f I sa t 1
3
FP1505
Technical Data 4365
Effective July 2017
Solder Reflow Profile
TP
TC -5°C
Temperature
TL
25°C
Preheat
A
T smax
Table 1 - Standard SnPb Solder (Tc)
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
t
Volume
mm3
220°C
220°C
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
Package
Thickness
2.5mm
ts
Time 25°C to Peak
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020
Profile Feature
Preheat and Soak
• Temperature min. (Tsmin)
• Temperature max. (Tsmax)
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to Peak Temperature
100°C
150°C
150°C
200°C
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 4365 BU-SB09350
July 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“FP1505R1-R12-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 744+10.94309744+1.41986
- 1488+10.320431488+1.33907
- 2232+9.973132232+1.29401
- 3720+9.552713720+1.23946
- 5208+9.285835208+1.20483
- 7440+9.230457440+1.19765
- 国内价格 香港价格
- 1+17.904011+2.32303
- 10+14.7444210+1.91308
- 100+12.12152100+1.57276
