Technical Data 10976
Effective November 2019
MCLA1608V2
Automotive grade multilayer chip inductor
Applications
ADAS
Infotainment
Wireless communications
Wifi, bluetooth, satellite
Antenna tuning
On board computer
Product features
AEC-Q200 qualified
0603 (1608 metric) package
Multilayer monolithic construction yields high
reliability
Inductance range from 1.0 nH to 470 nH
Moisture sensitivity level (MSL): 1
Environmental data
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
HALOGEN
Pb HF
FREE
MCLA1608V2
Product specifications
Part number
OCL
Tolerance
OCL
(nH)
Q minimum
DCR@ (Ω)
@ +25 °C
maximum
Test
frequency
(MHz)
Test
voltage (mV)
SRF (MHz)
minimum
I Rated (mA)
MCLA1608V2-1R0-R
±0.3nH
1.0
8
0.05
100
50
10000
500
MCLA1608V2-1R2-R
±0.3nH
1.2
8
0.05
100
50
10000
500
MCLA1608V2-1R5-R
±0.3nH
1.5
8
0.1
100
50
6000
500
MCLA1608V2-1R8-R
±0.3nH
1.8
8
0.1
100
50
6000
500
MCLA1608V2-2R2-R
±0.3nH
2.2
8
0.1
100
50
6000
500
MCLA1608V2-2R7-R
±0.3nH
2.7
10
0.12
100
50
6000
500
MCLA1608V2-3R3-R
±0.3nH
3.3
10
0.15
100
50
6000
500
MCLA1608V2-3R9-R
±0.3nH
3.9
10
0.16
100
50
6000
500
MCLA1608V2-4R7-R
±0.3nH
4.7
10
0.2
100
50
6000
500
MCLA1608V2-5R6-R
±0.3nH
5.6
10
0.25
100
50
5000
500
MCLA1608V2-6R8-R
±5%
6.8
10
0.3
100
50
5000
500
MCLA1608V2-8R2-R
±5%
8.2
10
0.35
100
50
4500
500
MCLA1608V2-100-R
±5%
10
12
0.4
100
50
3500
300
MCLA1608V2-120-R
±5%
12
12
0.45
100
50
3000
300
MCLA1608V2-150-R
±5%
15
12
0.5
100
50
2300
300
MCLA1608V2-180-R
±5%
18
12
0.55
100
50
2200
300
MCLA1608V2-220-R
±5%
22
12
0.6
100
50
2000
300
MCLA1608V2-270-R
±5%
27
12
0.65
100
50
1700
300
MCLA1608V2-330-R
±5%
33
12
0.7
100
50
1500
300
MCLA1608V2-390-R
±5%
39
12
0.7
100
50
1400
300
MCLA1608V2-470-R
±5%
47
12
0.7
100
50
1200
300
MCLA1608V2-560-R
±5%
56
12
0.75
100
50
1100
300
MCLA1608V2-680-R
±5%
68
12
0.85
100
50
900
300
MCLA1608V2-820-R
±5%
82
8
1.0
100
50
800
300
MCLA1608V2-101-R
±5%
100
8
1.2
100
50
700
300
MCLA1608V2-121-R
±5%
120
8
1.4
50
50
600
200
MCLA1608V2-151-R
±5%
150
8
1.6
50
50
500
200
MCLA1608V2-181-R
±5%
180
8
1.9
50
50
400
200
MCLA1608V2-221-R
±5%
220
8
2.4
50
50
350
200
MCLA1608V2-271-R
±5%
270
8
2.6
50
50
350
150
MCLA1608V2-331-R
±5%
330
8
2.8
50
50
350
150
MCLA1608V2-391-R
±5%
390
8
3.2
50
50
300
150
MCLA1608V2-431-R
±5%
430
8
3.4
50
50
280
150
MCLA1608V2-471-R
±5%
470
8
3.6
50
50
250
150
1. Test frequency and voltage are for open circuit inductance (OCL) and Q at +25 °C
2. Rated I: When rated I is applied to the product, self-temperature rise will be 20 °C or less.
2
www.eaton.com/electronics
3. Part Number Definition: MCLA1608V2-xxx-R
MCLA1608V2 = Product code and size
xxx= inductance value in nH, R= decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
MCLA1608V2
Mechanical parameters, schematic, pad layout (mm)
Recommended pad layout
Schematic
Part Number
L
W
T
a
F
G
H
MCLA1608V2-xxx-R
1.60±0.20
0.80±0.20
0.80±0.20
0.30±0.20
1.20 ref
0.40 ref
0.90 ref
Part marking: No marking
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.1 millimeters unless stated otherwise
Pad layout dimensions are reference only
Traces or vias underneath the inductor is not recommended
Packaging information (mm)
Drawing not to scale
Supplied in tape and reel packaging, 4000 parts per 7” diameter reel
Boom cover tape
Top cover tape
Center lines of cavity
Boom cover tape
Top cover tape
Direcon of feed
W±0.2
8.00
F±0.1
3.50
E1±0.2
1.75
E2 Min
na
P0±0.2
4.00
P1±0.2
4.00
P2±0.1
2.00
D0±0.1
1.55
A0
1.1±0.2
B0
1.9±0.2
T
0.95±0.1
T1 Max
na
3
MCLA1608V2
Inductance and Q vs frequency
M C L A 1608V 2-1R 0-R
100
10
1
50
0.1
500
5000
F requency ( MHz)
Ls
Q
M C L A 1608V 2-100-R
1000
100
10
1
50
500
F requency ( MHz)
Ls
5000
Q
M C L A 1608V 2-471-R
10000
1000
100
10
1
50
500
F requency ( MHz)
Ls
Q
4
MCLA1608V2
Solder reflow profile
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used
in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2019 Eaton
All Rights Reserved
Printed in USA
Publication No. 10976 BU-MC19104
Novemeber 2019
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“MCLA1608V2-100-R”相匹配的价格&库存,您可以联系我们找货
