MCLA1608V1-R068-R
MCLA1608V1-R068-R
    EATON(伊顿)
    固定电感器 0603 68nH ±10% 50mA 200mΩ 250MHz 15@50MHz
MCLA1608V1-R068-R 数据手册
Technical Data 10975 Effective November 2019 MCLA1608V1 Automotive multilayer chip inductor Applications • ADAS • Infotainment • Wireless communications • Wifi, bluetooth, satellite • Antenna tuning • On board computer Product features • AEC-Q200 qualified • 0603 (1608 metric) package • Multilayer monolithic construction yields high reliability • Inductance range from 0.047 uH to 3.9 uH • Moisture sensitivity level (MSL): 1 Environmental data • Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) HALOGEN Pb HF FREE MCLA1608V1 Automotive multilayer chip inductor  Technical Data 10975 Effective November 2019 Product specifications Part number OCL Tolerance (%) OCL (µH) Q minimum DCR@ (Ω) @ +25 °C maximum Test frequency (MHz) Test voltage (mV) SRF (MHz) minimum I Rated (mA) MCLA1608V1-R047-R ±10 0.047 15 0.2 50 50 260 50 MCLA1608V1-R056-R ±10 0.056 15 0.2 50 50 260 50 MCLA1608V1-R068-R ±10 0.068 15 0.2 50 50 250 50 MCLA1608V1-R082-R ±10 0.082 15 0.2 50 50 245 50 MCLA1608V1-R100-R ±10 0.10 20 0.25 25 50 240 50 MCLA1608V1-R120-R ±10 0.12 20 0.3 25 50 205 50 MCLA1608V1-R150-R ±10 0.15 20 0.3 25 50 180 50 MCLA1608V1-R180-R ±10 0.18 20 0.3 25 50 165 50 MCLA1608V1-R220-R ±10 0.22 20 0.4 25 50 150 50 MCLA1608V1-R270-R ±10 0.27 20 0.45 25 50 136 50 MCLA1608V1-R330-R ±10 0.33 20 0.5 25 50 125 50 MCLA1608V1-R390-R ±10 0.39 20 0.6 25 50 110 50 MCLA1608V1-R470-R ±10 0.47 20 0.7 25 50 105 50 MCLA1608V1-R560-R ±10 0.56 20 0.7 25 50 95 50 MCLA1608V1-R680-R ±10 0.68 20 0.9 25 50 90 50 MCLA1608V1-R820-R ±10 0.82 20 1.0 25 50 85 50 MCLA1608V1-1R0-R ±10 1.0 25 0.5 10 50 75 25 MCLA1608V1-1R2-R ±10 1.2 25 0.55 10 50 65 25 MCLA1608V1-1R5-R ±10 1.5 25 0.7 10 50 60 25 MCLA1608V1-1R8-R ±10 1.8 25 0.75 10 50 55 25 MCLA1608V1-2R2-R ±10 2.2 25 0.8 10 50 50 25 MCLA1608V1-2R7-R ±10 2.7 25 0.9 10 50 45 15 MCLA1608V1-3R3-R ±10 3.3 25 1.0 10 50 40 15 MCLA1608V1-3R9-R ±10 3.9 25 1.3 10 50 35 15 1. Test frequency and voltage is for open circuit inductance (OCL) and Q at +25 °C 2. Rated I: When rated I is applied to the product, self-temperature rise will be 40 °C or less. 2 www.eaton.com/electronics 3. Part Number Definition: MCLA1608V1-xxx-R MCLA1608V1 = Product code and size xxx= inductance value in µH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant Technical Data 10975 MCLA1608V1  Automotive multilayer chip inductor Effective November 2019  Mechanical parameters, schematic, pad layout (mm) Recommended pad layout Schematic Part Number L W T a F G H MCLA1608V1-xxx-R 1.60±0.20 0.80±0.20 0.80±0.20 0.30±0.20 1.20 ref 0.40 ref 0.90 ref Part marking: No marking All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.1 millimeters unless stated otherwise Pad layout dimensions are reference only Traces or vias underneath the inductor is not recommended Packaging information (mm) Drawing not to scale Supplied in tape and reel packaging, 4000 parts per 7” diameter reel Boom cover tape Top cover tape Center lines of cavity Boom cover tape Top cover tape Direcon of feed W±0.2 8.00 F±0.1 3.50 E1±0.2 1.75 E2 Min na P0±0.2 4.00 P1±0.2 4.00 P2±0.1 2.00 D0±0.1 1.55 A0 1.1±0.2 B0 1.9±0.2 T 0.95±0.1 T1 Max na www.eaton.com/electronics 3 MCLA1608V1 Automotive multilayer chip inductor  Technical Data 10975 Effective November 2019 Inductance vs frequency Inductance (nH) MCLA1608V1-R047-R Frequency (MHz) Inductance (nH) MCLA1608V1-R470-R Frequency (MHz) Inductance (nH) MCLA1608V1-3R9-R Frequency (MHz) 4 www.eaton.com/electronics Technical Data 10975 MCLA1608V1  Automotive multilayer chip inductor Effective November 2019  Q vs frequency Q MCLA1608V1-R047-R Frequency (MHz) Q MCLA1608V1-R470-R Frequency (MHz) Q MCLA1608V1-3R9-R Frequency (MHz) www.eaton.com/electronics 5 Technical Data 10975 MCLA1608V1 Automotive multilayer chip inductor  Effective November 2019 Solder reflow profile Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2019 Eaton All Rights Reserved Printed in USA Publication No. 10975 BU-MC19103 November 2019 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
MCLA1608V1-R068-R 价格&库存
很抱歉,暂时无法提供与“MCLA1608V1-R068-R”相匹配的价格&库存,您可以联系我们找货
