Technical Data 4380
Effective August 2018
Supersedes December 2015
CL1108 and CLA1108
Multi-phase power inductors
Applications
For exclusive use with Volterra® or Maxim®
VPR-Devices
Environmental data
Product features
High current multi-phase inductor applications
50 nH per phase coupled inductor
CLA Family features acoustic noise dampening
properties
Ferrite core material
Patents pending
Moisture Sensitivity Level (MSL): 1
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
Volterra® is a registered trademark of Volterra Semiconductor, LLC.
Maxim® is a registered trademark of Maxim Integrated Devices, Inc.
CL1108 and CLA1108
Technical Data 4380
Product specifications
Functional
Part number4,5
Inductor
phases
Test
DCR
(mΩ)
±10% @
+20 °C
Rated
inductance
per phase3
(nH)
I Rated per
phase3 (Adc)
Imax Peak
per phase3
(Adc)
Pin
numbers
OCL1,2
(nH)
Pin
numbers
OCL1,2
(nH)
Magnetizing
inductance2
(nH) @ 10 Adc
(+25 °C)
CL1108 Family—Standard
CL1108-2-50TR-R
2
0.28
50 ± 20%
50
80
(3-4)
380±20%
(1-2)
380±20%
300
CL1108-3-50TR-R
3
0.28
50 ± 20%
50
80
(3-4)
400±20%
(1-2), (5-6)
380±20%
300
CL1108-4-50TR-R
4
0.28
50 ± 20%
50
80
(3-4), (5-6)
400±20%
(1-2), (7-8)
380±20%
300
CL1108-5-50TR-R
5
0.28
50 ± 20%
50
80
(3-4), (5-6), (7-8)
400±20%
(1-2), (9-10)
380±20%
300
CLA1108 Family—Acoustic Noise Dampening
CLA1108-2-50TR-R
2
0.28
50 ± 20%
50
80
(3-4)
380±20%
(1-2)
380±20%
300
CLA1108-3-50TR-R
3
0.28
50 ± 20%
50
80
(3-4)
400±20%
(1-2), (5-6)
380±20%
300
CLA1108-4-50TR-R
4
0.28
50 ± 20%
50
80
(3-4), (5-6)
400±20%
(1-2), (7-8)
380±20%
300
1. Open Circuit Inductance (OCL)
2. Test parameters: 1 MHz, 0.1 Vrms, 0.0 Adc. @ +25 °C
3. The rated current, Imax peak current, and rated inductance per phase is determined by Volterra/Maxim’s testing and
circuit design. Additional information can be provided by contacting Volterra/Maxim.
4. Part Number Definition: CLx1108-y-50TR-R
• CL(x)1108 = Product code and size (CL= standard, CLA= Acoustic Noise Dampening)
• y = number of phases
• 50 = inductance value per phase nH
• TR = Tape and reel packaging
• -R suffix= RoHS compliant
5. This device is licensed for use only when incorporated within a voltage regulator employing power regulating
devices manufactured by Volterra Semiconductor, LLC or Maxim Integrated Devices, Inc. No license is granted
expressly or by implication to use this device with power regulating devices manufactured by any company other
than Volterra or Maxim.
Dimensions (mm)
Front View
Top View
Bottom View
18.0±0.5
CL/CLA1108-2
CL1108-2-50TR-R
wwllyy R
11.0±0.5
Pin #1
9.0±0.25
27.0±0.5
CL/CLA1108-3
CL1108-3-50TR-R
wwllyy R
11.0±0.5
Pin #1
9.0±0.25
36.0±0.5
CL/CLA1108-4
CL1108-4-50TR-R
wwllyy R
11.0±0.5
Pin #1
45.0±0.8
CL1108-5
CL1108-5-50TR-R
wwllyy R
11.0±0.5
Pin #1
Part marking: Pin 1 dot, CL1108/CLA1108= (product code and size, CL= standard, CLA= acoustic noise
dampening), -2,-3,-4,-5, = (number of phases), -50= inductance value per
phase in nH, TR= tape and reel, -R = RoHS compliant
wwllyy = date code, R = revision level
Tolerances are ±0.25 millimeters unless stated otherwise
All soldering surfaces to be coplanar within 0.13 millimeter
Do not route traces or vias underneath the inductor
2
www.eaton.com/electronics
Technical Data 4380
CL1108 and CLA1108
Pad layouts & schematics (mm)
Recommended Pad Layout
Schematic
9.0
CL/CLA1108-2
4.3
7.0
3.6
9.0
CL/CLA1108-3
4.3
3.1
7.0
2
4
1
3
5
2
4
6
1
3
5
7
2
4
6
8
3.6
9.0
4.3
3
3.6
CL/CLA1108-4
CL1108-5
3.1
7.0
9.0
4.3
3.1
1
3.1
1
3
5
7
9
2
4
6
8
10
7.0
3.6
3
CL1108 and CLA1108
Technical Data 4380
Packaging information (mm)
Supplied in tape and reel packaging on a 13” diameter reel.
1.5Dia
2.0
4.0
Pin #1
8.1
SECTION A-A
11.6
1.5Dia
16.0
2.0
4.0
11.6
1.5Dia
16.0
2.0
4.0
2.0
1.75 20.25
40.4
+/-0.1
44.0
+/-0.3
User Direction of feed
Pin #1
2.0
1.75
16.0
11.6
SECTION A-A
26.25
52.4
+/-0.1
56.0
+/-0.3
CL1108-4-50TR-R
wwllyy R
36.6
8.1
Pin #1
1.5Dia
45.9
8.1
SECTION A-A
4
4.0
2.0
CL1108-5-50TR-R
wwllyy R
CL1108-5
150 parts per reel
2.0
11.6
16.0
32.0
+/-0.3
Pin #1
CL1108-3-50TR-R
wwllyy R
SECTION A-A
28.4
+/-0.1
27.6
8.1
CL/CLA1108-4
200 parts per reel
1.75 14.25
CL1108-2-50TR-R
wwllyy R
18.6
CL/CLA1108-2
500 parts per reel
CL/CLA1108-3
200 parts per reel
2.0
1.75
26.25
52.4
+/-0.1
56.0
+/-0.3
Technical Data 4380
CL1108 and CLA1108
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“CL1108-5-50TR-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 150+86.68566150+10.87055
