BWCS00231715R12G00
BWCS00231715R12G00
    CHILISIN(奇力新)
    固定电感器 Nonstandard 120nH ±2% 400mA 510mΩ 1.1GHz 50@250MHz
BWCS00231715R12G00 数据手册
SMD Wire Wound Ceramic Chip Inductors - BWCS Series BWCS Series Due to accurate wire winding technology, these chip inductors are designed for filtering, impedance matching, resonance and choke circuits for RF designer. Both standard series custom designs are available. Features Applications  RoHS Compliant  Ceramic body and wire wound construction provide high SRFs  RF products for cellular phone  GPS receiver  Exceptional Q values even at high frequencies  Highest possible SRFs as well as excellent Q values  The non-magnetic coil form assures utmost thermal stability, predictability and batch consistency      CS series is standard for RF designers  Security system and other RF modules Base Station Repeater Wireless LAN/ mouse/ keyboard/ earphone Remote control Product Identification Shape and Dimensions / Recommended Pattern BWCS00060404 BWCS00120707 Dimensions A Max B Max C Max D E F G H I J inch 0.023 0.018 0.018 - 0.015 0.004 - 0.018 0.007 0.009 mm 0.58 0.46 0.45 - 0.38 0.1 - 0.46 0.18 0.23 inch 0.047 0.025 0.026 0.010 0.020 0.009 0.022 0.026 0.014 0.018 mm 1.19 0.64 0.66 0.25 0.51 0.23 0.56 0.66 0.36 0.46 BWCS00060404 BWCS00120707 SMD Wire Wound Ceramic Chip Inductors - BWCS Series BWCS00161008/ 231715/ 292821 BWCS00493834 Dimensions A BWCS00161008 B C D E F G H I J 1.02±0.1 0.82+0.2-0.1 0.51 0.76 0.33 0.86 1.02 0.64 0.64 A Max B Max C Max D E F G H I J inch 0.093 0.068 0.06 0.028 0.050 0.020 0.040 0.070 0.040 0.030 mm 2.35 1.73 1.52 0.71 1.27 0.51 1.02 1.78 1.02 0.76 inch 0.115 0.110 0.083 0.046 0.080 0.020 0.060 0.100 0.040 0.050 mm 2.92 2.79 2.1 1.16 2.03 0.51 1.52 2.54 1.02 1.27 inch 0.197 0.154 0.135 0.07 0.1 0.025 0.128 0.12 0.045 0.118 mm 4.95 3.81 3.43 1.78 2.54 0.64 3.25 3.05 1.14 3.00 mm +0.2 1.6 -0.1 BWCS00231715 BWCS00292821 BWCS00493834 SMD Wire Wound Ceramic Chip Inductors - BWCS Series Electrical Characteristics Inductance Tolerance (nH) (±%) BWCS000604040N5□00 0.5 10 BWCS000604040N6□00 0.6 BWCS000604041N2□00 Test Q SRF RDC Irms Min (GHz) Typ (Ω) Max (mA) Typ 250 4 23.5 0.02 1250 10 250 6 24.5 0.03 1000 1.2 5 250 13 17.9 0.042 870 BWCS000604041N3□00 1.3 5 250 11 17.6 0.048 820 BWCS000604041N4□00 1.4 5 250 14 17 0.08 630 BWCS000604041N5□00 1.5 5 250 11 17 0.09 600 BWCS000604042N2□00 2.2 5 250 15 16.7 0.07 700 BWCS000604042N3□00 2.3 5 250 18 16.5 0.07 670 BWCS000604042N4□00 2.4 5 250 13 13 0.082 620 BWCS000604042N5□00 2.5 5 250 16 12.5 0.165 440 BWCS000604043N3□00 3.3 5 250 14 12.8 0.08 630 BWCS000604043N4□00 3.4 5 250 11 12.7 0.08 630 BWCS000604043N5□00 3.5 5 250 16 12.4 0.08 630 BWCS000604043N6□00 3.6 5 250 18 12.5 0.105 550 BWCS000604043N7□00 3.7 5 250 15 10.6 0.105 550 BWCS000604043N8□00 3.8 5 250 16 10.2 0.18 420 BWCS000604043N9□00 3.9 5 250 12 11.2 0.24 360 BWCS000604044N8□00 4.8 5 250 17 11 0.096 570 BWCS000604044N9□00 4.9 5 250 18 11.7 0.13 510 BWCS000604045N0□00 5.0 5 250 18 11.5 0.13 510 BWCS000604045N1□00 5.1 5 250 18 11.1 0.13 510 BWCS000604045N2□00 5.2 5 250 18 10 0.17 430 BWCS000604045N3□00 5.3 5 250 18 10.6 0.13 510 BWCS000604045N4□00 5.4 5 250 18 10.2 0.13 510 BWCS000604045N5□00 5.5 5 250 16 9.5 0.285 330 BWCS000604046N7□00 6.7 5 250 18 6.8 0.15 460 BWCS000604046N8□00 6.8 5 250 18 9.5 0.15 460 BWCS000604046N9□00 6.9 5 250 18 9.3 0.15 460 BWCS000604047N0□00 7.0 5 250 18 6.7 0.21 390 BWCS000604047N1□00 7.1 5 250 18 9.5 0.25 390 BWCS000604047N2□00 7.2 5 250 18 9.4 0.25 390 BWCS000604047N3□00 7.3 5 250 18 9.3 0.25 390 Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance : J=±5% , K=±10%  Operating temperature range-40℃~125℃(Including self - temperature rise)  Irms for a 15℃ temperature rise from 25℃ ambient with current  Measure Equipment: L & Q:HP4286A/HP4287A/AgilentE4991/Keysight E4982A SRF:Agilent HP8753D/Agilent HP8722ES RDC:HP4287A Irms:HP4284A+HP42841A/HP4285A+HP42841A Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Wire Wound Ceramic Chip Inductors - BWCS Series Electrical Characteristics Inductance Tolerance (nH) (±%) BWCS000604047N4□00 7.4 5 BWCS000604047N5□00 7.5 BWCS000604047N6□00 Test Q SRF RDC Irms Min (GHz) Typ (Ω) Max (mA) Typ 250 18 9.1 0.25 390 5 250 15 6.8 0.34 300 7.6 5 250 17 9.3 0.3 340 BWCS000604047N7□00 7.7 5 250 17 9.2 0.3 340 BWCS000604047N8□00 7.8 5 250 17 9.2 0.3 340 BWCS000604047N9□00 7.9 5 250 17 9.1 0.3 340 BWCS000604048N0□00 8.0 5 250 17 9.2 0.3 340 BWCS000604048N1□00 8.1 5 250 17 9.1 0.3 340 BWCS000604048N2□00 8.2 5 250 17 6.4 0.27 340 BWCS000604048N4□00 8.4 5 250 15 8.9 0.38 300 BWCS000604048N5□00 8.5 5 250 15 8.9 0.38 300 BWCS000604048N7□00 8.7 5 250 15 6.3 0.38 300 BWCS000604049N0□00 9.0 5 250 15 6.4 0.38 300 BWCS000604049N4□00 9.4 5 250 16 6.4 0.4 280 BWCS000604049N6□00 9.6 5 250 16 6.2 0.4 280 BWCS0006040411N□00 11 5 250 16 5.7 0.44 280 BWCS0006040412N□00 12 5 250 17 5.6 0.36 300 BWCS0006040413N□00 13 5 250 16 6.7 0.5 270 BWCS0006040414N□00 14 5 250 16 5.1 0.5 270 Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance :  J=±5% , K=±10% Operating temperature range-40℃~125℃(Including self - temperature rise)  Irms for a 15℃ temperature rise from 25℃ ambient with current  Measure Equipment: L & Q:HP4286A/HP4287A/AgilentE4991/Keysight E4982A SRF:Agilent HP8753D/Agilent HP8722ES RDC:HP4287A Irms:HP4284A+HP42841A/HP4285A+HP42841A Typical L vs. Frequency Typical Q vs. Frequency 100 14 7N0 90 12N 12 12N 80 8 Q L(nH) 10 7N0 6 70 2N3 60 3N9 50 0N6 40 3N9 4 30 20 2N3 2 10 0N6 0 0 1 10 100 FREQUENCY(MHz) 1000 10000 1 10 100 FREQUENCY(MHz) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 1000 10000 SMD Wire Wound Ceramic Chip Inductors - BWCS Series Electrical Characteristics Inductance Tolerance (nH) (±%) BWCS001207071N0□00 1.0 10 / 5 / ±0.1nH BWCS001207071N2□00 1.2 BWCS001207071N3□00 Test Q SRF RDC Irms Min (GHz) Min (Ω) Max (mA) Max 250 16 12.7 0.045 1360 10 / 5 / ±0.1nH 250 10 10.4 0.140 640 1.3 10 / ±0.1nH 250 10 10.4 0.140 640 BWCS001207071N9□00 1.9 10 / 5 / ±0.1nH 250 16 11.3 0.070 1040 BWCS001207072N0□00 2.0 10 / 5 / ±0.1nH 250 16 11.1 0.070 1040 BWCS001207072N2□00 2.2 10 / 5 / ±0.1nH 250 19 10.8 0.070 960 BWCS001207072N4□00 2.4 10 / 5 / ±0.1nH 250 15 10.5 0.068 790 BWCS001207072N5□00 2.5 10 / 5 / ±0.1nH 250 13 10.4 0.150 640 BWCS001207072N7□00 2.7 10 / 5 / ±0.1nH 250 16 10.4 0.120 640 BWCS001207073N3□00 3.3 10 / 5 / 3 250 19 7.00 0.066 840 BWCS001207073N6□00 3.6 10 / 5 / 3 250 19 6.80 0.066 840 BWCS001207073N9□00 3.9 10 / 5 / 3 250 19 6.00 0.066 840 BWCS001207074N3□00 4.3 10 / 5 / 3 250 18 6.00 0.091 700 BWCS001207074N7□00 4.7 10 / 5 / 3 250 15 4.77 0.130 640 BWCS001207075N1□00 5.1 10 / 5 / 3 250 20 4.80 0.083 800 BWCS001207075N6□00 5.6 10 / 5 / 3 250 20 4.80 0.083 760 BWCS001207075N8□00 5.8 10 / 5 / 3 250 20 4.80 0.083 760 BWCS001207076N2□00 6.2 10 / 5 / 3 250 20 4.80 0.083 760 BWCS001207076N8□00 6.8 10 / 5 / 3 250 20 4.80 0.083 680 BWCS001207077N3□00 7.3 10 / 5 / 3 250 20 4.80 0.12 680 BWCS001207077N5□00 7.5 10 / 5 / 3 250 22 4.80 0.10 680 BWCS001207078N2□00 8.2 10 / 5 / 3 250 22 4.40 0.10 680 BWCS001207078N7□00 8.7 10 / 5 / 3 250 18 4.10 0.20 480 BWCS001207079N0□00 9.0 10 / 5 / 3 250 22 4.16 0.10 680 BWCS001207079N1□00 9.1 10 / 5 / 3 250 22 4.16 0.10 680 BWCS001207079N5□00 9.5 10 / 5 / 3 250 18 4.00 0.20 480 BWCS0012070710N□00 10 10 / 5 / 3 / 2 250 21 3.90 0.20 480 BWCS0012070711N□00 11 10 / 5 / 3 / 2 250 24 3.68 0.12 640 BWCS0012070712N□00 12 10 / 5 / 3 / 2 250 24 3.60 0.12 640 BWCS0012070713N□00 13 10 / 5 / 3 / 2 250 24 3.45 0.21 440 BWCS0012070715N□00 15 10 / 5 / 3 / 2 250 24 3.28 0.17 560 BWCS0012070716N□00 16 10 / 5 / 3 / 2 250 24 3.10 0.22 560 Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance : B=±0.1nH , G=±2% , H=±3% , J=±5% , K=±10%  Operating temperature range-40℃~125℃(Including self - temperature rise)  Irms for a 15℃ temperature rise from 25℃ ambient with current  Measure Equipment: L & Q:Agilent E4991A+Agilent HP16197A SRF:Agilent HP8753D/Agilent HP8722ES RDC:HP4287A Irms:HP4284A+HP42841A/HP4285A+HP42841A Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Wire Wound Ceramic Chip Inductors - BWCS Series Electrical Characteristics Inductance Tolerance (nH) (±%) BWCS0012070718N□00 18 10 / 5 / 3 / 2 BWCS0012070719N□00 19 BWCS0012070720N□00 Test Q SRF RDC Irms Min (GHz) Min (Ω) Max (mA) Max 250 25 3.10 0.23 420 10 / 5 / 3 / 2 250 24 3.04 0.20 480 20 10 / 5 / 3 / 2 250 25 3.00 0.25 420 BWCS0012070722N□00 22 10 / 5 / 3 / 2 250 25 2.80 0.30 400 BWCS0012070723N□00 23 10 / 5 / 3 / 2 250 22 2.72 0.30 400 BWCS0012070724N□00 24 10 / 5 / 3 / 2 250 25 2.70 0.30 400 BWCS0012070727N□00 27 10 / 5 / 3 / 2 250 24 2.48 0.30 400 BWCS0012070730N□00 30 10 / 5 / 3 / 2 250 25 2.35 0.35 400 BWCS0012070733N□00 33 10 / 5 / 3 / 2 250 24 2.35 0.40 400 BWCS0012070736N□00 36 10 / 5 / 3 / 2 250 24 2.32 0.44 320 BWCS0012070739N□00 39 10 / 5 / 3 / 2 250 25 2.10 0.55 200 BWCS0012070740N□00 40 10 / 5 / 3 / 2 250 24 2.24 0.65 320 BWCS0012070743N□00 43 10 / 5 / 3 / 2 250 25 2.03 0.81 100 BWCS0012070747N□00 47 10 / 5 / 3 / 2 250 20 2.10 0.83 150 BWCS0012070751N□00 51 10 / 5 / 3 / 2 250 25 1.75 0.82 100 BWCS0012070756N□00 56 10 / 5 / 3 / 2 250 22 1.76 0.97 100 BWCS0012070768N□00 68 10 / 5 / 3 / 2 250 22 1.62 1.12 100 BWCS0012070782N□00 82 10 / 5 / 3 / 2 250 20 1.26 1.55 50 BWCS00120707R10□00 100 10 / 5 / 3 / 2 250 20 1.16 2.00 30 BWCS00120707R18□00 180 10 / 5 / 3 / 2 100 8 0.70 2.70 50 BWCS00120707R22□00 220 10 / 5 / 3 / 2 100 8 0.70 4.00 50 Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance : B=±0.1nH , G=±2% , H=±3% , J=±5% , K=±10%  Operating temperature range-40℃~125℃(Including self - temperature rise)  Irms for a 15℃ temperature rise from 25℃ ambient with current  Measure Equipment: L & Q:Agilent E4991A+Agilent HP16197A SRF:Agilent HP8753D/Agilent HP8722ES RDC:HP4287A Irms:HP4284A+HP42841A/HP4285A+HP42841A Typical L vs. Frequency Typical Q vs. Frequency 1000 100 R10 3N3 90 47N 80 70 100 L(nH) 60 Q 15N 50 15N 40 10 47N 30 R10 3N3 20 10 1 0 1 10 100 FREQUENCY(MHz) 1000 10000 1 10 100 FREQUENCY(MHz) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 1000 10000 SMD Wire Wound Ceramic Chip Inductors – BWCS Series Electrical Characteristics Inductance Tolerance (nH) (±%) BWCS001610081N600 1.6 10 / 5 / ±0.1nH BWCS001610081N800 1.8 BWCS001610082N200 Test Q SRF RDC Irms Min (MHz) Min (Ω) Max (mA) Max 250 24 12500 0.030 700 Red 10 / 5 / ±0.1nH 250 16 12500 0.045 700 Black 2.2 10 / 5 / ±0.1nH 250 13 12500 0.250 700 Yellow BWCS001610083N300 3.3 10 / 5 / 3 / 2 250 35 5900 0.045 700 Blue BWCS001610083N600 3.6 10 / 5 / 3 / 2 250 22 5900 0.063 700 Red BWCS001610083N900 3.9 10 / 5 / 3 / 2 250 22 6900 0.080 700 Brown BWCS001610084N300 4.3 10 / 5 / 3 / 2 250 22 5900 0.063 700 Orange BWCS001610084N700 4.7 10 / 5 / 3 / 2 250 20 5800 0.116 700 Violet BWCS001610085N100 5.1 10 / 5 / 3 / 2 250 20 5700 0.140 700 Green BWCS001610085N600 5.6 10 / 5 / 3 / 2 250 20 5800 0.170 700 Yellow BWCS001610086N300 6.3 10 / 5 / 3 / 2 250 20 5700 0.140 700 White BWCS001610086N800 6.8 10 / 5 / 3 / 2 250 27 5800 0.110 700 Red BWCS001610087N500 7.5 10 / 5 / 3 / 2 250 28 4800 0.106 700 Brown BWCS001610088N200 8.2 10 / 5 / 3 / 2 250 28 4700 0.109 700 White BWCS001610088N700 8.7 10 / 5 / 3 / 2 250 28 4600 0.109 700 Yellow BWCS001610089N100 9.1 10 / 5 / 3 / 2 250 28 4800 0.120 700 Violet BWCS001610089N500 9.5 10 / 5 / 3 / 2 250 28 5400 0.135 700 Blue BWCS0016100810N00 10 10 / 5 / 3 / 2 250 31 4800 0.130 700 Orange BWCS0016100811N00 11 10 / 5 / 3 / 2 250 33 4000 0.086 700 Gray BWCS0016100812N00 12 10 / 5 / 3 / 2 250 35 4000 0.130 700 Yellow BWCS0016100813N00 13 10 / 5 / 3 / 2 250 30 4000 0.160 700 Black BWCS0016100815N00 15 10 / 5 / 3 / 2 250 35 4000 0.170 700 Green BWCS0016100816N00 16 10 / 5 / 3 / 2 250 34 3300 0.104 700 White BWCS0016100818N00 18 10 / 5 / 3 / 2 250 35 3100 0.170 700 Blue BWCS0016100820N00 20 10 / 5 / 3 / 2 250 38 3000 0.190 700 Red BWCS0016100822N00 22 10 / 5 / 3 / 2 250 38 3000 0.190 700 Violet BWCS0016100823N00 23 10 / 5 / 3 / 2 250 38 2850 0.190 700 Orange BWCS0016100824N00 24 10 / 5 / 3 / 2 250 37 2650 0.135 700 Black BWCS0016100827N00 27 10 / 5 / 3 / 2 250 40 2800 0.220 600 Gray BWCS0016100830N00 30 10 / 5 / 3 / 2 250 37 2250 0.144 600 Brown BWCS0016100833N00 33 10 / 5 / 3 / 2 250 40 2300 0.220 600 White BWCS0016100836N00 36 10 / 5 / 3 / 2 250 38 2080 0.250 600 Red BWCS0016100839N00 39 10 / 5 / 3 / 2 250 40 2200 0.250 600 Black BWCS0016100843N00 43 10 / 5 / 3 / 2 250 39 2000 0.280 600 Orange Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance : B=±0.1nH , G=±2% , H=±3% , J=±5% , K=±10%    Operating temperature range-40℃~125℃(Including self - temperature rise) Irms for a 15℃ temperature rise from 25℃ ambient with current Measure Equipment: L & Q:Agilent E4991A+Agilent HP16197A SRF:Agilent HP8753D/Agilent E4991A RDC:Chroma 16502 Irms:HP4284A+HP42841A/HP4285A+HP42841A Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. Color SMD Wire Wound Ceramic Chip Inductors – BWCS Series Electrical Characteristics Inductance Tolerance (nH) (±%) BWCS0016100847N00 47 10 / 5 / 3 / 2 BWCS0016100851N00 51 BWCS0016100851N00 Test Q SRF RDC Irms Min (MHz) Min (Ω) Max (mA) Max 200 38 2000 0.280 600 Brown 10 / 5 / 3 / 2 200 38 1900 0.310 600 Brown 51 10 / 5 / 3 / 2 200 38 1900 0.310 600 Brown BWCS0016100856N00 56 10 / 5 / 3 / 2 200 38 1900 0.310 600 Red BWCS0016100868N00 68 10 / 5 / 3 / 2 200 37 1700 0.340 600 Orange BWCS0016100872N00 72 10 / 5 / 3 / 2 150 34 1700 0.490 400 Yellow BWCS0016100882N00 82 10 / 5 / 3 / 2 150 34 1700 0.540 400 Green BWCS0016100891N00 91 10 / 5 / 3 / 2 150 34 1400 0.580 400 Black BWCS00161008R1000 100 10 / 5 / 3 / 2 150 34 1400 0.580 400 Blue BWCS00161008R1100 110 10 / 5 / 3 / 2 150 32 1350 0.610 300 Violet BWCS00161008R1200 120 10 / 5 / 3 / 2 150 32 1300 0.750 300 Gray BWCS00161008R1500 150 10 / 5 / 3 / 2 150 28 990 0.920 280 White BWCS00161008R1600 160 10 / 5 / 3 / 2 100 25 990 1.250 240 Yellow BWCS00161008R1800 180 10 / 5 / 3 / 2 100 25 990 1.250 240 Black BWCS00161008R2000 200 10 / 5 / 3 / 2 100 25 900 2.100 200 Red BWCS00161008R2100 210 10 / 5 / 3 / 2 100 27 895 2.060 200 Gray BWCS00161008R2200 220 10 / 5 / 3 / 2 100 25 900 2.100 200 Brown BWCS00161008R2400 240 10 / 5 / 3 / 2 100 25 900 2.200 200 Green BWCS00161008R2500 250 10 / 5 / 3 / 2 100 25 822 3.550 120 Violet BWCS00161008R2700 270 10 / 5 / 3 / 2 100 24 900 2.800 170 Red BWCS00161008R3300 330 10 / 5 / 3 / 2 100 25 900 3.890 100 Orange BWCS00161008R3900 390 10 / 5 / 3 / 2 100 25 900 4.350 100 Yellow BWCS00161008R4700 470 10 / 5 / 3 / 2 100 25 500 4.500 100 Brown BWCS00161008R5600 560 10 / 5 / 3 / 2 100 23 460 4.700 90 Blue Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance : B=±0.1nH , G=±2% , H=±3% , J=±5% , K=±10%  Operating temperature range-40℃~125℃(Including self - temperature rise)  Irms for a 15℃ temperature rise from 25℃ ambient with current  Measure Equipment: L & Q:Agilent E4991A+Agilent HP16197A SRF:Agilent HP8753D/Agilent E4991A RDC:Chroma 16502 Irms:HP4284A+HP42841A/HP4285A+HP42841A Typical L vs. Frequency Typical Q vs. Frequency Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. Color SMD Wire Wound Ceramic Chip Inductors – BWCS Series Electrical Characteristics Test Inductance Tolerance (nH) (±%) SRF RDC Irms (Ω) Max (mA) Max BWCS002317152N700 2.7 10 / 5 / 2 250 50 1500 7900 0.06 800 Yellow BWCS002317152N800 2.8 10 / 5 / 2 250 80 1500 7900 0.06 800 Gray BWCS002317153N000 3.0 10 / 5 / 2 250 65 1500 7900 0.06 800 White BWCS002317153N300 3.3 10 / 5 / 2 250 50 1500 7900 0.08 600 Black BWCS002317155N600 5.6 10 / 5 / 2 250 65 1000 5500 0.08 600 Orange BWCS002317156N800 6.8 10 / 5 / 2 250 50 1000 5500 0.11 600 Brown BWCS002317157N500 7.5 10 / 5 / 2 250 50 1000 4500 0.14 600 Green BWCS002317158N200 8.2 10 / 5 / 2 250 50 1000 4700 0.12 600 Red BWCS0023171510N00 10 10 / 5 / 2 250 60 500 4200 0.10 600 Blue BWCS0023171512N00 12 10 / 5 / 2 250 50 500 4000 0.15 600 Orange BWCS0023171515N00 15 10 / 5 / 2 250 50 500 3400 0.17 600 Yellow BWCS0023171518N00 18 10 / 5 / 2 250 50 500 3300 0.20 600 Green BWCS0023171522N00 22 10 / 5 / 2 250 55 500 2600 0.22 500 Blue BWCS0023171524N00 24 10 / 5 / 2 250 50 500 2000 0.22 500 Gray BWCS0023171527N00 27 10 / 5 / 2 250 55 500 2500 0.25 500 Violet BWCS0023171533N00 33 10 / 5 / 2 250 60 500 2050 0.27 500 Gray BWCS0023171536N00 36 10 / 5 / 2 250 55 500 1700 0.27 500 Orange BWCS0023171539N00 39 10 / 5 / 2 250 60 500 2000 0.29 500 White BWCS0023171543N00 43 10 / 5 / 2 200 60 500 1650 0.34 500 Yellow BWCS0023171547N00 47 10 / 5 / 2 200 60 500 1650 0.31 500 Black BWCS0023171556N00 56 10 / 5 / 2 200 60 500 1550 0.34 500 Brown BWCS0023171568N00 68 10 / 5 / 2 200 60 500 1450 0.38 500 Red BWCS0023171582N00 82 10 / 5 / 2 150 65 500 1300 0.42 400 Orange BWCS0023171591N00 91 10 / 5 / 2 150 65 500 1200 0.48 400 Black BWCS00231715R1000 100 10 / 5 / 2 150 65 500 1200 0.46 400 Yellow BWCS00231715R1100 110 10 / 5 / 2 150 50 250 1000 0.48 400 Brown BWCS00231715R1200 120 10 / 5 / 2 150 50 250 1100 0.51 400 Green BWCS00231715R1500 150 10 / 5 / 2 100 50 250 920 0.56 400 Blue BWCS00231715R1800 180 10 / 5 / 2 100 50 250 870 0.64 400 Violet BWCS00231715R2000 200 10 / 5 / 2 100 50 250 860 0.68 400 Red BWCS00231715R2200 220 10 / 5 / 2 100 50 250 850 0.70 400 Gray BWCS00231715R2400 240 10 / 5 / 2 100 44 250 690 1.00 350 Red Frequency (MHz) Q Test (MHz) Min Part Number Min Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance : G=±2% , J=±5% , K=±10%  Operating temperature range-40℃~125℃(Including self - temperature rise)  Irms for a 15℃ temperature rise from 25℃ ambient with current  Measure Equipment: L & Q:Agilent E4991A+Agilent HP16197A SRF:Agilent HP8753D/Agilent E4991A RDC:Chroma 16502 Irms:HP4284A+HP42841A/HP4285A+HP42841A Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. Color SMD Wire Wound Ceramic Chip Inductors – BWCS Series Electrical Characteristics Test Inductance Tolerance (nH) (±%) SRF RDC Irms (Ω) Max (mA) Max BWCS00231715R2500 250 10 / 5 / 2 100 45 250 660 1.20 350 Yellow BWCS00231715R2700 270 10 / 5 / 2 100 48 250 650 1.00 350 White BWCS00231715R3000 300 10 / 5 / 2 100 25 250 450 1.40 310 Orange BWCS00231715R3300 330 10 / 5 / 2 100 48 250 600 1.40 310 Black BWCS00231715R3900 390 10 / 5 / 2 100 48 250 560 1.50 290 Brown BWCS00231715R4700 470 10 / 5 / 2 50 33 100 450 1.76 250 Violet BWCS00231715R5100 510 10 / 5 / 2 25 23 50 340 1.90 230 Gray BWCS00231715R5600 560 10 / 5 / 2 25 23 50 340 1.90 230 Orange BWCS00231715R6200 620 10 / 5 / 2 25 23 50 220 2.20 210 Yellow BWCS00231715R6800 680 10 / 5 / 2 25 23 50 188 2.20 190 Green BWCS00231715R8200 820 10 / 5 / 2 25 23 50 215 2.35 180 Blue BWCS002317151R000 1000 10 / 5 / 2 25 20 50 100 2.50 170 Gray BWCS002317151R200 1200 10 / 5 7.9 18 25 100 2.50 170 White BWCS002317151R800 1800 10 / 5 / 2 7.9 16 7.9 80 2.50 170 Orange BWCS002317152R200 2200 10 / 5 / 2 7.9 16 7.9 65 3.90 140 Gray BWCS002317153R300 3300 10 / 5 / 2 7.9 15 7.9 40 4.40 90 Red BWCS002317154R700 4700 10 / 5 / 2 7.9 15 7.9 40 6.40 90 Yellow Frequency (MHz) Q Test (MHz) Min Part Number Min Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance : G=±2% , J=±5% , K=±10%  Operating temperature range-40℃~125℃(Including self - temperature rise)  Irms for a 15℃ temperature rise from 25℃ ambient with current  Measure Equipment: L & Q:Agilent E4991A+Agilent HP16197A SRF:Agilent HP8753D/Agilent E4991A RDC:Chroma 16502 Irms:HP4284A+HP42841A/HP4285A+HP42841A Typical L vs. Frequency Typical Q vs. Frequency Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. Color SMD Wire Wound Ceramic Chip Inductors – BWCS Series Electrical Characteristics Part Number Inductance Tolerance Test Frequency Q Color Coding SRF RDC Irms (MHz) Min (Ω) Max (mA) Max 1ST 2ND 3RD (nH) (±%) BWCS0029282110N00 10 10 / 5 / 2 50 50 500 4100 0.08 1000 Brown Black Black BWCS0029282112N00 12 10 / 5 / 2 50 50 500 3300 0.09 1000 Brown Red Black BWCS0029282115N00 15 10 / 5 / 2 50 50 500 2500 0.10 1000 Brown Green Black BWCS0029282118N00 18 10 / 5 / 2 50 50 350 2500 0.11 1000 Brown Gray Black BWCS0029282122N00 22 10 / 5 / 2 50 55 350 2400 0.12 1000 Red Red Black BWCS0029282127N00 27 10 / 5 / 2 50 55 350 1600 0.13 1000 Red Violet Black BWCS0029282133N00 33 10 / 5 / 2 50 60 350 1600 0.14 1000 Orange Orange Black BWCS0029282139N00 39 10 / 5 / 2 50 60 350 1500 0.15 1000 Orange White Black BWCS0029282147N00 47 10 / 5 / 2 50 65 350 1500 0.16 1000 Yellow Violet Black BWCS0029282156N00 56 10 / 5 / 2 50 65 350 1300 0.18 1000 Green Blue Black BWCS0029282168N00 68 10 / 5 / 2 50 65 350 1300 0.20 1000 Blue Gray Black BWCS0029282182N00 82 10 / 5 / 2 50 60 350 1000 0.22 1000 Gray Red Black BWCS00292821R1000 100 10 / 5 / 2 25 60 350 1000 0.56 650 Brown Black Brown BWCS00292821R1200 120 10 / 5 / 2 25 60 350 950 0.63 650 Brown Red Brown BWCS00292821R1500 150 10 / 5 / 2 25 45 100 850 0.70 580 Brown Green Brown BWCS00292821R1800 180 10 / 5 / 2 25 45 100 750 0.77 620 Brown Gray Brown BWCS00292821R2000 200 10 / 5 / 2 25 45 100 700 0.84 500 Red Black Brown BWCS00292821R2200 220 10 / 5 / 2 25 45 100 700 0.84 500 Red Red Brown BWCS00292821R2700 270 10 / 5 / 2 25 45 100 600 0.91 500 Red Violet Brown BWCS00292821R3300 330 10 / 5 / 2 25 45 100 570 1.05 450 Orange Orange Brown BWCS00292821R3900 390 10 / 5 / 2 25 45 100 500 1.12 470 Orange White Brown BWCS00292821R4700 470 10 / 5 / 2 25 45 100 450 1.19 470 Yellow Violet Brown BWCS00292821R5600 560 10 / 5 / 2 25 45 100 415 1.33 400 Green Blue Brown BWCS00292821R6200 620 10 / 5 / 2 25 45 100 375 1.40 300 Blue Red Brown BWCS00292821R6800 680 10 / 5 / 2 25 45 100 375 1.47 400 Blue Gray Brown BWCS00292821R7500 750 10 / 5 / 2 25 45 100 360 1.54 360 Violet BWCS00292821R8200 820 10 / 5 / 2 25 45 100 350 1.61 400 Gray BWCS00292821R9100 910 10 / 5 / 2 25 35 50 320 1.68 380 White Brown Brown BWCS002928211R000 1000 10 / 5 / 2 25 35 50 290 1.75 370 Brown Black Red BWCS002928211R200 1200 10 / 5 / 2 7.9 35 50 250 2.0 310 Brown Red Red BWCS002928211R500 1500 10 / 5 / 2 7.9 28 50 200 2.3 330 Brown Green Red BWCS002928211R800 1800 10 / 5 / 2 7.9 28 50 160 2.6 300 Brown Red (MHz) Min Test Frequency (MHz) Green Brown Red Brown Gray Note: When ordering, please specify tolerance code. Tolerance : G=±2% , J=±5% , K=±10%  Operating temperature range-40℃~125℃(Including self - temperature rise)  Irms for a 15℃ temperature rise from 25℃ ambient with current  Measure Equipment: 1st Code 3rd Code L & Q:Agilent E4991A+Agilent HP16197A SRF:Agilent HP8753D/Agilent E4991A RDC:Chroma 16502 Irms:HP4284A+HP42841A/HP4285A+HP42841A Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 2nd Code COLOR CODING SMD Wire Wound Ceramic Chip Inductors – BWCS Series Electrical Characteristics Part Number Inductance Tolerance Test Frequency Q Color Coding SRF RDC Irms (MHz) Min (Ω) Max (mA) Max 1ST 2ND 3RD (nH) (±%) BWCS002928212R200 2200 10 / 5 / 2 7.9 28 50 160 2.8 280 Red Red Red BWCS002928212R700 2700 10 / 5 / 2 7.9 22 25 140 3.2 290 Red Violet Red BWCS002928213R300 3300 10 / 5 / 2 7.9 22 25 110 3.4 290 Orange Orange Red BWCS002928213R900 3900 10 / 5 / 2 7.9 20 25 100 3.6 260 Orange White Red BWCS002928214R700 4700 10 / 5 / 2 7.9 20 25 90 4.0 260 Yellow Violet Red BWCS002928215R600 5600 10 / 5 / 2 7.9 18 7.9 45 4.0 240 Green Blue Red BWCS002928216R800 6800 10 / 5 / 2 7.9 18 7.9 40 4.9 200 Blue Gray Red BWCS002928218R200 8200 10 / 5 / 2 7.9 18 7.9 25 6.0 170 Gray Red Red BWCS0029282110000 10000 10 / 5 / 2 2.52 18 7.9 25 8.0 150 Brown BWCS0029282115000 15000 10 / 5 / 2 2.52 15 7.9 20 11 100 Brown Green Orange (MHz) Min Test Frequency (MHz) Black Orange Note: When ordering, please specify tolerance code. Tolerance : G=±2% , J=±5% , K=±10%  Operating temperature range-40℃~125℃(Including self - temperature rise)  Irms for a 15℃ temperature rise from 25℃ ambient with current  Measure Equipment: 1st Code 3rd Code L & Q:Agilent E4991A+Agilent HP16197A SRF:Agilent HP8753D/Agilent E4991A RDC:Chroma 16502 2nd Code COLOR CODING Irms:HP4284A+HP42841A/HP4285A+HP42841A Typical L vs. Frequency Typical Q vs. Frequency Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Wire Wound Ceramic Chip Inductors – BWCS Series Electrical Characteristics Test Inductance Tolerance (uH) (±%) Q BWCS00493834-1R0□00 1.0 5 7.9 60 BWCS00493834-1R2□00 1.2 5 7.9 BWCS00493834-1R5□00 1.5 5/2 BWCS00493834-1R8□00 1.8 BWCS00493834-2R2□00 Test SRF RDC Irms (MHz) Min (Ω) Max (mA) Typ 50 310 1.2 480 62 50 230 1.2 480 7.9 65 50 210 1.6 430 5 7.9 68 50 190 2.0 380 2.2 5/2 7.9 63 50 170 2.2 340 BWCS00493834-2R7□00 2.7 5/2 7.9 60 50 160 3.2 300 BWCS00493834-3R3□00 3.3 5/2 7.9 60 50 145 3.8 270 BWCS00493834-3R9□00 3.9 5/2 7.9 61 50 130 5.0 240 BWCS00493834-4R7□00 4.7 5 7.9 60 50 115 5.4 230 BWCS00493834-5R6□00 5.6 5 7.9 42 50 100 5.7 220 BWCS00493834-6R8□00 6.8 5 7.9 32 50 90 6.6 210 BWCS00493834-8R2□00 8.2 5/2 7.9 35 50 80 7.0 200 BWCS00493834-100□00 10 5 7.9 27 50 70 7.7 190 BWCS00493834-120□00 12 5 2.5 34 10 58 8.7 180 BWCS00493834-150□00 15 5/2 2.5 32 10 48 9.6 170 BWCS00493834-180□00 18 5 2.5 28 10 36 10.5 160 BWCS00493834-220□00 22 5/2 2.5 28 10 34 11.5 155 BWCS00493834-270□00 27 5 2.5 28 10 30 12.5 150 BWCS00493834-330□00 33 5/2 2.5 20 10 20 13.5 145 Part Number Frequency Min (MHz) Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance : G=±2% , J=±5% Operating temperature range-40℃~125℃(Including self - temperature rise)   Irms for a 15℃ temperature rise from 25℃ ambient with current  Measure Equipment: L & Q:HP4286A/HP4287A/AgilentE4991/Keysight E4982A SRF:Agilent HP8753D/Agilent E4991A RDC:Chroma 16502 Irms:HP4284A+HP42841A/HP4285A+HP42841A Typical L vs. Frequency Typical Q vs. Frequency 80 40 35 70 270 60 25 50 Q L(nH) 1R5 30 20 3R3 40 100 100 30 15 5R6 10 5R6 270 20 3R3 10 5 1R5 0 0 1 10 100 FREQUENCY(MHz) 1000 1 10 100 FREQUENCY(MHz) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 1000 SMD Wire Wound Ceramic Chip Inductors - BWCS Series Packaging Specifications Tape Dimensions Tape Material Figure 1 Figure 2 Figure 3 Reel Dimensions Dimensions in mm TYPE Tape Dimensions Fig. Reel Dimensions Quantity A B T W P F K A B C D PCS / Reel BWCS00060404 1 0.47 0.60 0.65 8 2 3.5 0.45 178 60 12 1.5 4000 BWCS00120707 1 0.67 1.20 0.75 8 2 3.5 0.59 178 60 12 1.5 4000 BWCS00161008 2 1.25 1.90 1.05 8 4 3.5 - 178 60 12 1.5 4000 BWCS00231715 3 1.85 2.45 0.23 8 4 3.5 1.50 178 60 12 1.5 2000 BWCS00292821 3 2.80 2.95 0.23 8 4 3.5 2.20 178 60 12 1.5 2000 BWCS00493834 3 3.90 4.90 0.30 12 8 5.5 3.20 178 60 16 1.4 600
BWCS00231715R12G00 价格&库存
很抱歉,暂时无法提供与“BWCS00231715R12G00”相匹配的价格&库存,您可以联系我们找货
