MCQ1V1608-R150-R
MCQ1V1608-R150-R
    EATON(伊顿)
    固定电感器 0603 150nH ±10% 50mA 300mΩ 180MHz 20@25MHz
MCQ1V1608-R150-R 数据手册
Technical Data 11101 Effective June 2020 MCQ1V1608 Multilayer high Q chip inductor Applications • Industrial connectivity (IoT) • Wireless communications • Bluetooth • WiFi • Antenna • Machine-to-machine (M2M) • Mobile phones Product features • Wearable devices • 0603 (1608 metric) package • Wireless LAN • Multilayer monolithic construction yields high reliability • Computing/gaming consoles • Inductance range from 0.047 µH to 3.9 µH Moisture sensitivity level (MSL): 1 • RF transceiver modules • • Broadband components Environmental compliance and general specifications • Operating temperature range: -40 °C to +85 °C (ambient plus self-temperature rise) HALOGEN Pb HF FREE MCQ1V1608 Multilayer high Q chip inductor  Technical Data 11101 Effective June 2020 Product specifications Part number4 Ls Tolerance (%) Ls1 (µH) Q minimum DCR (Ω) @ +25 °C maximum Test frequency2 (MHz) Test voltage2 (mV) SRF (MHz) minimum Rated I3 (mA) maximum MCQ1V1608-R047-R ±10 0.047 15 0.2 50 50 260 50 MCQ1V1608-R056-R ±10 0.056 15 0.2 50 50 260 50 MCQ1V1608-R068-R ±10 0.068 15 0.2 50 50 250 50 MCQ1V1608-R082-R ±10 0.082 15 0.2 50 50 245 50 MCQ1V1608-R100-R ±10 0.10 20 0.25 25 50 240 50 MCQ1V1608-R120-R ±10 0.12 20 0.3 25 50 205 50 MCQ1V1608-R150-R ±10 0.15 20 0.3 25 50 180 50 MCQ1V1608-R180-R ±10 0.18 20 0.3 25 50 165 50 MCQ1V1608-R220-R ±10 0.22 20 0.4 25 50 150 50 MCQ1V1608-R270-R ±10 0.27 20 0.45 25 50 136 50 MCQ1V1608-R330-R ±10 0.33 20 0.5 25 50 125 50 MCQ1V1608-R390-R ±10 0.39 20 0.6 25 50 110 50 MCQ1V1608-R470-R ±10 0.47 20 0.7 25 50 105 50 MCQ1V1608-R560-R ±10 0.56 20 0.7 25 50 95 50 MCQ1V1608-R680-R ±10 0.68 20 0.9 25 50 90 50 MCQ1V1608-R820-R ±10 0.82 20 1.0 25 50 85 50 MCQ1V1608-1R0-R ±10 1.0 25 0.5 10 50 75 25 MCQ1V1608-1R2-R ±10 1.2 25 0.55 10 50 65 25 MCQ1V1608-1R5-R ±10 1.5 25 0.7 10 50 60 25 MCQ1V1608-1R8-R ±10 1.8 25 0.75 10 50 55 25 MCQ1V1608-2R2-R ±10 2.2 25 0.8 10 50 50 25 MCQ1V1608-2R7-R ±10 2.7 25 0.9 10 50 45 15 MCQ1V1608-3R3-R ±10 3.3 25 1.0 10 50 40 15 MCQ1V1608-3R9-R ±10 3.9 25 1.3 10 50 35 15 1. Ls = Inductance 2. Ls and Q test voltage and frequency 3. Rated I: Current rating for an approximate self-temperature rise of 40 °C or less. 2 www.eaton.com/electronics 4. Part Number Definition: MCQ1V1608-xxx-R MCQ1V1608 = Product code and size xxx= inductance value in µH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant Technical Data 11101 MCQ1V1608  Multilayer high Q chip inductor Effective June 2020  Mechanical parameters, schematic, pad layout (mm) Recommended pad layout Schematic Part Number L W T a F G H MCQ1V1608-xxx-R 1.60 ±0.20 0.80 ±0.20 0.80 ±0.20 0.30 ±0.20 1.20 ref 0.40 ref 0.90 ref Part marking: No marking All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.1 millimeters unless stated otherwise Pad layout dimensions are reference only Traces or vias underneath the inductor is not recommended Packaging information (mm) Drawing not to scale Supplied in tape and reel packaging, 4000 parts per 7” diameter reel W±0.2 8.00 F±0.1 3.50 E1±0.2 1.75 E2 Min na P0±0.2 4.00 P1±0.2 4.00 P2±0.1 2.00 D0±0.1 1.55 A0 1.1±0.2 B0 1.9±0.2 T 0.95±0.1 T1 Max na www.eaton.com/electronics 3 MCQ1V1608 Multilayer high Q chip inductor  Technical Data 11101 Effective June 2020 Qualification testing No. Test item Sample size (pcs) 1 External visual 72 2 Physical dimension 72 Specification Spec 3 Initial electrical test 72 Specification User spec 4 Solderability 6 +245 °C±5 °C, dipping 5±1 s >95% solder coverage 5 Resistance to soldering heat 6 +260 ±5 °C for 10±1 s 1. ΔL/L
MCQ1V1608-R150-R
1. 物料型号:MCQ1V1608系列,包括多种不同的电感值,如0.047μH至3.9μH。 2. 器件简介:这些电感器采用0603(1608公制)封装,具有多层单体结构,提供高可靠性。它们适用于多种应用,包括工业连接、无线通信、蓝牙、Wi-Fi、天线、机器对机器通信、移动电话、可穿戴设备、无线局域网、计算/游戏控制台、宽带组件和射频收发模块。 3. 引脚分配:文档中提供了推荐的焊盘布局和原理图,但没有具体说明引脚分配。 4. 参数特性:包括电感公差、最小Q值、直流电阻(DCR)、测试频率、测试电压、自谐振频率(SRF)、额定电流等。 5. 功能详解:文档详细列出了不同型号的电感器的参数,如电感值、Q值、直流电阻等,并提供了不同频率下的电感值和Q值图表。 6. 应用信息:适用于多种无线通信和工业应用,包括物联网、无线局域网、移动电话等。 7. 封装信息:提供了机械参数、原理图和焊盘布局,以及包装信息,如卷带包装,每卷4000个部件。
MCQ1V1608-R150-R 价格&库存
很抱歉,暂时无法提供与“MCQ1V1608-R150-R”相匹配的价格&库存,您可以联系我们找货
MCQ1V1608-R150-R
    • 1+0.04558
    • 200+0.01772
    • 500+0.01707
    • 1000+0.01674
