Technical Data 11101
Effective June 2020
MCQ1V1608
Multilayer high Q chip inductor
Applications
• Industrial connectivity (IoT)
• Wireless communications
• Bluetooth
• WiFi
• Antenna
• Machine-to-machine (M2M)
• Mobile phones
Product features
• Wearable devices
0603 (1608 metric) package
• Wireless LAN
Multilayer monolithic construction yields high
reliability
• Computing/gaming consoles
Inductance range from 0.047 µH to 3.9 µH
Moisture sensitivity level (MSL): 1
• RF transceiver modules
• Broadband components
Environmental compliance
and general specifications
Operating temperature range: -40 °C to +85 °C
(ambient plus self-temperature rise)
HALOGEN
Pb HF
FREE
MCQ1V1608
Effective June 2020
Product specifications
Part number4
Ls
Tolerance
Ls1
(µH)
Q
minimum
DCR (Ω)
@ +25 °C
maximum
Test frequency2
(MHz)
Test voltage2
(mV)
SRF (MHz)
minimum
Rated I3 (mA)
maximum
MCQ1V1608-R047-R
±10
0.047
15
0.2
50
50
260
50
MCQ1V1608-R056-R
±10
0.056
15
0.2
50
50
260
50
MCQ1V1608-R068-R
±10
0.068
15
0.2
50
50
250
50
MCQ1V1608-R082-R
±10
0.082
15
0.2
50
50
245
50
MCQ1V1608-R100-R
±10
0.10
25
50
240
50
MCQ1V1608-R120-R
±10
0.12
25
50
205
50
MCQ1V1608-R150-R
±10
0.15
25
50
180
50
MCQ1V1608-R180-R
±10
0.18
25
50
165
50
MCQ1V1608-R220-R
±10
0.22
25
50
150
50
MCQ1V1608-R270-R
±10
0.27
25
50
136
50
MCQ1V1608-R330-R
±10
0.33
25
50
125
50
MCQ1V1608-R390-R
±10
0.39
25
50
110
50
MCQ1V1608-R470-R
±10
0.47
25
50
105
50
MCQ1V1608-R560-R
±10
0.56
25
50
95
50
MCQ1V1608-R680-R
±10
0.68
25
50
90
50
MCQ1V1608-R820-R
±10
0.82
25
50
85
50
MCQ1V1608-1R0-R
±10
1.0
25
0.5
10
50
75
25
MCQ1V1608-1R2-R
±10
1.2
25
0.55
10
50
65
25
MCQ1V1608-1R5-R
±10
1.5
25
0.7
10
50
60
25
MCQ1V1608-1R8-R
±10
1.8
25
0.75
10
50
55
25
MCQ1V1608-2R2-R
±10
2.2
25
0.8
10
50
50
25
MCQ1V1608-2R7-R
±10
2.7
25
0.9
10
50
45
15
MCQ1V1608-3R3-R
±10
3.3
25
1.0
10
50
40
15
MCQ1V1608-3R9-R
±10
3.9
25
1.3
10
50
35
15
1. Ls = Inductance
2. Ls and Q test voltage and frequency
3. Rated I: Current rating for an approximate self-temperature rise of 40 °C or less.
2
www.eaton.com/electronics
4. Part Number Definition: MCQ1V1608-xxx-R
MCQ1V1608 = Product code and size
xxx= inductance value in µH, R= decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
MCQ1V1608
Effective June 2020
Mechanical parameters, schematic, pad layout (mm)
Recommended pad layout
Schematic
Part Number
L
W
T
a
F
G
H
MCQ1V1608-xxx-R
1.60 ±0.20
0.80 ±0.20
0.80 ±0.20
0.30 ±0.20
1.20 ref
0.40 ref
0.90 ref
Part marking: No marking
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.1 millimeters unless stated otherwise
Pad layout dimensions are reference only
Traces or vias underneath the inductor is not recommended
Packaging information (mm)
Drawing not to scale
Supplied in tape and reel packaging, 4000 parts per 7” diameter reel
W±0.2
8.00
F±0.1
3.50
E1±0.2
1.75
E2 Min
na
P0±0.2
4.00
P1±0.2
4.00
P2±0.1
2.00
D0±0.1
1.55
A0
1.1±0.2
B0
1.9±0.2
T
0.95±0.1
T1 Max
na
3
MCQ1V1608
Effective June 2020
Qualification testing
No.
Test item
Sample size (pcs)
1
External visual
72
2
Physical dimension
72
Specification
Spec
3
Initial electrical test
72
Specification
User spec
4
Solderability
6
+245 °C±5 °C, dipping 5±1 s
>95% solder coverage
5
Resistance to soldering heat
6
+260 ±5 °C for 10±1 s
1. ΔL/L
很抱歉,暂时无法提供与“MCQ1V1608-R820-R”相匹配的价格&库存,您可以联系我们找货
