Technical Data 10673
Effective June 2018
Supersedes May 2017
FP2207R
High frequency, high current power inductors
Applications
Product features
High current carrying capacity
Low core loss
Magnetically shielded
22.5 mm x 8.2 mm footprint surface mountpackage in a 7.25 mm height
Moisture Sensitivity Level: 1
Ferrite core material
Multi-phase and Vcore regulators
Voltage Regulator Modules (VRMs) and highpower density VRMs
• Server and desktop
Central processing unit (CPU)
Graphics processing unit (GPU)
Application specific integrated circuit (ASIC)
Data networking and storage systems
Graphics cards and battery power systems
Point-of-Load modules (POL)
Environmental data
Storage temperature range (Component):
-55 °C to +125 °C
Operating temperature range: -55 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Halogen free, lead free, RoHS compliant
HALOGEN
Pb HF
FREE
FP2207R
Effective June 2018
Product Specifications
Part Number8
OCL1
(nH) ±10%
FLL2 (nH)
minimum
Irms3
(A)
Isat14
(A)
Isat25
(A)
Isat36
(A)
DCR (mΩ)
±15% @ +20 °C
K-factor7
230
196
50
70
77
72
0.47
182.5
R1 Version
FP2207R1-R230-R
1. Open Circuit Inductance (OCL) Test Parameters: 1.0 MHz, 0.1 Vrms, 0.0 Adc, +25 °C
2. Full Load Inductance (FLL) Test Parameters: 1.0 MHz, 0.1 Vrms, Isat1, +25 °C
3. Irms : DC current for an approximate temperature rise of 40 °C without core loss. Derating is
necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat
generating components will affect the temperature rise. It is recommended that the temperature of the
part not exceed +125 °C under worst case operating conditions verified in the end application.
4. Isat1: Peak current for approximately 5% rolloff @ +25 °C
5. Isat2: Peak current for approximately 20% rolloff @ +100 °C
6. Isat3: Peak current for approximately 20% rolloff @ +125 °C
7. K-factor: Used to determine Bp-p for core loss (see graph).
Bp-p = K * L * ΔI * 10-3 Bp-p: (Gauss), K: (K-factor from table),
L: (Inductance in nH), ΔI (Peak to peak ripple current in Amps).
8. Part Number Definition: FP2207Rx-Rxxx-R
FP2207R= Product code and size
x= Version indicator
Rxxx= Inductance value in μH, R= decimal point
-R suffix = RoHS compliant
Note: Hipot: 250 Vdc minimum for 2 seconds, 0.1 mA
conductor to uncoated core (test points c to d)
Dimensions (mm)
c
typ
d
typ
Part marking: FP2207Rx (x = Version indicator), Rxxx = Inductance value in uH, R= decimal point), xxxx=Lot code
Tolerances are ±0.15 unless stated otherwise
Pad layout tolerances are ±0.1 unless stated otherwise
Soldering surfaces to be coplanar within 0.1 millimeters
DCR measured from point “a” to point “b”
Hipot measured from point “c” to point “d”
Secure Inductor to PCB using Circuit Bond LV (or equivalent) adhesive for mechanical stability to meet Vibration, Mechanical shock and shear
force requirements.
Do not route traces or vias underneath the inductor
2
www.eaton.com/electronics
FP2207R
Effective June 2018
Packaging information (mm)
Supplied in tape and reel packaging , 500 parts per 13” diameter reel
Temperature rise vs. total loss
FP2207R1
60
Temperature Rise (°C)
50
40
30
0.2
0.4
0.6
0.8
1.0
1.2
1.4
1.6
1.8
2.0
Total Loss (W)
3
FP2207R
Effective June 2018
Core loss vs. Bp-p
FP2207R1
10
2 MHz
1.5 MHz
Core Loss (W)
1
1 MHz
700 kHz
0.1
0.01
0.001
100
1000
10000
Bp-p (Gauss)
Inductance characteristics
FP2207R1-R230-R
300
250
Inductance (nH)
200
150
100
-40 °C
+25 °C
50
+100 °C
+125 °C
60
Idc (A)
4
80
100
120
FP2207R
Effective June 2018
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“FP2207R1-R230-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+29.65294500+3.83093
- 1000+27.969361000+3.61343
- 1500+27.069801500+3.49721
- 国内价格
- 1+42.82600
- 10+41.69900
- 国内价格 香港价格
- 1+49.765651+6.42934
- 10+40.9166510+5.28612
- 100+33.65317100+4.34773
- 国内价格 香港价格
- 1+48.258581+6.23464
- 10+39.6960210+5.12842
- 100+32.65519100+4.21880
