Technical Data 10925
Effective June 2019
MCL1005
Multilayer chip inductor
Applications
Product features
0402 (1005 metric) package
High self resonant frequency (SRF)
Multilayer monolithic construction yields high
reliability
Suitable for wave and reflow soldering
Inductance range from 1.0 nH to 360 nH
Moisture sensitivity level (MSL): 1
Industrial connectivity (IoT)
Wireless communiations
Bluetooth
WiFi
Antenna
Machine-to-machine (M2M)
Mobile phones
Wearable devices
Wireless LAN
Computing/gaming consoles
Broadband components
RF transciever modules
Environmental data
Operating temperature range: -55 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
MCL1005
Effective June 2019
Product specifications
Part number
OCL
(nH) ±5%
I Rated
(mA) maximum
DCR (Ω)
maximum @ +25°C
SRF
(MHz) minimum
Q
(minimum)
Test frequency
(MHz)
Test voltage
(mV)
MCL1005-1R0-R
1.0 ±0.3nH
400
0.10
10000
8
100
50
MCL1005-1R1-R
1.1 ±0.3nH
400
0.10
10000
8
100
50
MCL1005-1R2-R
1.2 ±0.3nH
400
0.10
10000
8
100
50
MCL1005-1R3-R
1.3 ±0.3nH
400
0.10
10000
8
100
50
MCL1005-1R5-R
1.5 ±0.3nH
300
0.10
6000
8
100
50
MCL1005-1R6-R
1.6 ±0.3nH
300
0.12
6000
8
100
50
MCL1005-1R8-R
1.8 ±0.3nH
300
0.12
6000
8
100
50
MCL1005-2R0-R
2.0 ±0.3nH
300
0.15
6000
8
100
50
MCL1005-2R2-R
2.2 ±0.3nH
300
0.15
6000
8
100
50
MCL1005-2R4-R
2.4 ±0.3nH
300
0.15
6000
8
100
50
MCL1005-2R7-R
2.7 ±0.3nH
300
0.15
6000
8
100
50
MCL1005-3R0-R
3.0 ±0.3nH
300
0.20
6000
8
100
50
MCL1005-3R3-R
3.3 ±0.3nH
300
0.20
6000
8
100
50
MCL1005-3R6-R
3.6 ±0.3nH
300
0.20
4000
8
100
50
MCL1005-3R9-R
3.9 ±0.3nH
300
0.20
4000
8
100
50
MCL1005-4R3-R
4.3 ±0.3nH
300
0.20
4000
8
100
50
MCL1005-4R7-R
4.7 ±0.3nH
300
0.25
4000
8
100
50
MCL1005-5R1-R
5.1 ±0.3nH
300
0.25
4000
8
100
50
MCL1005-5R6-R
5.6 ±0.3nH
300
0.25
4000
8
100
50
MCL1005-6R2-R
6.2 ±0.3nH
300
0.30
3900
8
100
50
MCL1005-6R8-R
6.8
300
0.30
3900
8
100
50
MCL1005-7R5-R
7.5
300
0.40
3700
8
100
50
MCL1005-8R2-R
8.2
300
0.40
3600
8
100
50
MCL1005-9R1-R
9.1
300
0.40
3400
8
100
50
MCL1005-100-R
10
300
0.40
3200
8
100
50
MCL1005-120-R
12
300
0.50
2700
8
100
50
MCL1005-150-R
15
300
0.50
2300
8
100
50
MCL1005-180-R
18
300
0.60
2100
8
100
50
MCL1005-200-R
0.60
2000
8
100
50
MCL1005-220-R
22
300
0.60
1900
8
100
50
MCL1005-270-R
27
300
0.70
1600
8
100
50
MCL1005-330-R
33
200
0.80
1300
8
100
50
MCL1005-390-R
39
200
1.00
1200
8
100
50
MCL1005-430-R
43
200
1.10
1100
8
100
50
MCL1005-470-R
47
200
1.10
1000
8
100
50
MCL1005-560-R
56
200
1.20
750
8
100
50
MCL1005-680-R
68
180
1.40
750
8
100
50
MCL1005-820-R
82
150
2.40
750
8
100
50
MCL1005-101-R
100
150
2.60
700
8
100
50
1. Test frequency and voltage are for OCL and Q at +25 °C
2. Resistance to soldering heat: +260 ±5 °C for 10 ± 1 second
3. At low temperature resistance (-55 ±2°C) the inductance change is within ±10% and the Q within ±20%
4. At high temperature resistance (+125 ±2°C) the inductance change is within ±10% and the Q within ±20%
2
www.eaton.com/electronics
5. At high temperature load (+125 ±2°C) the inductance change is within ±10% and the Q within ±20%
6. Rated I: When rated I is applied to the product, self-temperature rise will be 40 °C or less.
7. Part Number Definition: MCL1005-xxx-R
MCL1005 = Product code and size
xxx= inductance value in nH, R= decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
MCL1005
Effective June 2019
Part number
OCL
(nH) ±5%
I Rated
(mA) maximum
DCR (Ω)
maximum @ +25°C
SRF
(MHz) minimum
Q
(minimum)
Test frequency
(MHz)
Test voltage
(mV)
MCL1005-121-R
120
150
2.80
600
8
100
50
MCL1005-151-R
150
100
3.20
550
8
100
50
MCL1005-181-R
180
100
3.70
500
8
100
50
MCL1005-221-R
220
100
4.00
450
8
100
50
MCL1005-271-R
270
100
4.50
400
8
100
50
MCL1005-331-R
330
50
7.00
350
6
50
50
MCL1005-361-R
360
50
7.50
300
6
50
50
Dimensions (mm)
Schematic
Recommended pad layout
B
L
C
Part Number
L
W
T
a
A
B
C
MCL1005-xxx-R
1.0 ±0.15
0.50 ±0.15
0.50 ±0.15
0.25 ±0.10
0.85 ±0.10
0.8 ±0.10
0.2 ±0.10
No part marking
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.2 millimeters unless stated otherwise
Pad layout tolerances are ±0.1 millimeters unless stated otherwise
Do not route traces or vias underneath the inductor
3
MCL1005
Effective June 2019
Packaging information (mm)
Drawing not to scale
Supplied in tape and reel packaging, 10000 parts per 7” diameter reel
W ±0.3
F±0.05
E1±0.10
E2 Min
P0±0.10
P1±0.05
P2±0.1
D0+0.10/-0
A0
B0
T Max
T1 Max
8.00
3.50
1.75
6.25
4.00
2.00
2.00
1.50
0.65±0.10
1.15±0.10
0.8
na
Inductance vs frequency
Q vs frequency
120
60
MCL1005-101-R
50
80
MCL1005-470-R
60
MCL1005-470-R
10
MCL1005-1R0-R
100
1000
Frequency(MHz)
4
30
MCL1005-1R0-R
40
Q
Inductance(nH)
100
MCL1005-101-R
100
1000
Frequency(MHz)
10000
MCL1005
Effective June 2019
Solder reflow profile
TP
TC -5 °C
tP
Max. ramp up rate = 3° C/s
Max. ramp down rate = 6 °C/s
Temperature
TL
Preheat
A
T smax
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“MCL1005-1R8-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10000+0.0940710000+0.01180
- 20000+0.0886920000+0.01113
- 30000+0.0857030000+0.01075
- 50000+0.0820650000+0.01029
- 70000+0.0797570000+0.01000
- 100000+0.07737100000+0.00971
- 250000+0.07160250000+0.00898
- 500000+0.06752500000+0.00847
- 1000000+0.063681000000+0.00799
- 国内价格
- 10000+0.09310
- 100000+0.08827
- 400000+0.08222
- 国内价格 香港价格
- 10000+0.1133010000+0.01421
- 20000+0.1115320000+0.01399
- 40000+0.1097640000+0.01377
- 50000+0.1092550000+0.01370
- 150000+0.10622150000+0.01332
- 国内价格 香港价格
- 1+0.879161+0.11025
- 10+0.1578310+0.01980
- 100+0.13230100+0.01659
- 1000+0.108971000+0.01367
- 5000+0.095035000+0.01192
