MCLA1005V2-150-R
MCLA1005V2-150-R
    EATON(伊顿)
    固定电感器 0402 15nH ±5% 300mA 500mΩ 2.3GHz 8@100MHz
MCLA1005V2-150-R 数据手册
Technical Data 10974 Effective November 2019 MCLA1005V2 Automotive multilayer chip inductor Applications • ADAS • Infotainment • Wireless communications • Wifi, bluetooth, satellite • Antennas tuning • On board computer Product features • AEC-Q200 qualified • 0402 (1005 metric) package • Multilayer monolithic construction yields high reliability • Inductance range from 1.0 nH to 330 nH • Moisture sensitivity level (MSL): 1 Environmental data • Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) HALOGEN Pb HF FREE MCLA1005V2 Automotive multilayer chip inductor  Technical Data 10974 Effective November 2019 Product specifications Part number OCL Tolerance OCL (nH) Q minimum DCR@ (Ω) @ +25 °C maximum Test frequency (MHz) Test voltage (mV) SRF (MHz) minimum I Rated (mA) MCLA1005V2-1R0-R ±0.3nH 1.0 8 0.1 100 50 10000 400 MCLA1005V2-1R1-R ±0.3nH 1.1 8 0.1 100 50 10000 400 MCLA1005V2-1R2-R ±0.3nH 1.2 8 0.1 100 50 10000 400 MCLA1005V2-1R3-R ±0.3nH 1.3 8 0.1 100 50 10000 400 MCLA1005V2-1R5-R ±0.3nH 1.5 8 0.1 100 50 6000 300 MCLA1005V2-1R6-R ±0.3nH 1.6 8 0.12 100 50 6000 300 MCLA1005V2-1R8-R ±0.3nH 1.8 8 0.12 100 50 6000 300 MCLA1005V2-2R0-R ±0.3nH 2.0 8 0.15 100 50 6000 300 MCLA1005V2-2R2-R ±0.3nH 2.2 8 0.15 100 50 6000 300 MCLA1005V2-2R4-R ±0.3nH 2.4 8 0.15 100 50 6000 300 MCLA1005V2-2R7-R ±0.3nH 2.7 8 0.15 100 50 6000 300 MCLA1005V2-3R0-R ±0.3nH 3.0 8 0.2 100 50 6000 300 MCLA1005V2-3R3-R ±0.3nH 3.3 8 0.2 100 50 6000 300 MCLA1005V2-3R6-R ±0.3nH 3.6 8 0.2 100 50 4000 300 MCLA1005V2-3R9-R ±0.3nH 3.9 8 0.2 100 50 4000 300 MCLA1005V2-4R3-R ±0.3nH 4.3 8 0.2 100 50 4000 300 MCLA1005V2-4R7-R ±0.3nH 4.7 8 0.25 100 50 4000 300 MCLA1005V2-5R1-R ±0.3nH 5.1 8 0.25 100 50 4000 300 MCLA1005V2-5R6-R ±0.3nH 5.6 8 0.25 100 50 4000 300 MCLA1005V2-6R2-R ±0.3nH 6.2 8 0.3 100 50 3900 300 MCLA1005V2-6R8-R ±5% 6.8 8 0.3 100 50 3900 300 MCLA1005V2-7R5-R ±5% 7.5 8 0.4 100 50 3700 300 MCLA1005V2-8R2-R ±5% 8.2 8 0.4 100 50 3600 300 MCLA1005V2-9R1-R ±5% 9.1 8 0.4 100 50 3400 300 MCLA1005V2-100-R ±5% 10 8 0.4 100 50 3200 300 MCLA1005V2-120-R ±5% 12 8 0.5 100 50 2700 300 MCLA1005V2-150-R ±5% 15 8 0.5 100 50 2300 300 MCLA1005V2-180-R ±5% 18 8 0.6 100 50 2100 300 MCLA1005V2-200-R ±5% 20 8 0.6 100 50 2000 300 MCLA1005V2-220-R ±5% 22 8 0.6 100 50 1900 300 MCLA1005V2-270-R ±5% 27 8 0.7 100 50 1600 300 MCLA1005V2-330-R ±5% 33 8 0.8 100 50 1300 200 MCLA1005V2-390-R ±5% 39 8 1 100 50 1200 200 MCLA1005V2-430-R ±5% 43 8 1.1 100 50 1100 200 MCLA1005V2-470-R ±5% 47 8 1.1 100 50 1000 200 MCLA1005V2-560-R ±5% 56 8 1.2 100 50 750 200 MCLA1005V2-680-R ±5% 68 8 1.4 100 50 750 180 MCLA1005V2-820-R ±5% 82 8 2.4 100 50 750 150 MCLA1005V2-101-R ±5% 100 8 2.6 100 50 700 150 MCLA1005V2-121-R ±5% 120 8 2.8 100 50 600 150 1. Test frequency and voltage is for open circuit inductance (OCL) and Q at +25 °C 2. Rated I: When rated I is applied to the product, self-temperature rise will be 20 °C or less. 2 www.eaton.com/electronics 3. Part Number Definition: MCLA1005V2-xxx-R MCLA1005V2 = Product code and size xxx= inductance value in nH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant Technical Data 10974 MCLA1005V2  Automotive multilayer chip inductor Effective November 2019  Part number OCL Tolerance OCL (nH) Q minimum DCR@ (Ω) @ +25 °C maximum Test frequency (MHz) Test voltage (mV) SRF (MHz) minimum I Rated (mA) MCLA1005V2-151-R ±5% 150 8 3.2 100 50 550 100 MCLA1005V2-181-R ±5% 180 8 3.7 100 50 500 100 MCLA1005V2-221-R ±5% 220 8 4.0 100 50 450 100 MCLA1005V2-271-R ±5% 270 8 4.5 100 50 400 100 MCLA1005V2-331-R ±5% 330 6 7.0 50 50 350 50 1. Test frequency and voltage is for open circuit inductance (OCL) and Q at +25 °C 2. Rated I: When rated I is applied to the product, self-temperature rise will be 20 °C or less. 3. Part Number Definition: MCLA1005V2-xxx-R MCLA1005V2 = Product code and size xxx= inductance value in nH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant Mechanical parameters, schematic, pad layout (mm) Recommended pad layout Schematic Part Number L W T A L1 F G H MCLA1005V2-xxx-R 1.00±0.15 0.50±0.15 0.50±0.15 0.25±0.10 0.50±0.15 0.85 ref 0.15 ref 0.75 ref Part marking: No marking All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.1 millimeters unless stated otherwise Dimension L1 is for orientation Pad layout dimensions are reference only Traces or vias underneath the inductor is not recommended www.eaton.com/electronics 3 MCLA1005V2 Automotive multilayer chip inductor  Technical Data 10974 Effective November 2019 Packaging information (mm) Drawing not to scale Supplied in tape and reel packaging, 10000 parts per 7” diameter reel 4 www.eaton.com/electronics W±0.2 8.00 F±0.1 3.50 E1±0.2 1.75 E2 Min na P0±0.2 4.00 P1±0.1 2.00 P2±0.1 2.00 D0±0.1 1.55 A0 0.65±0.1 B0 1.15±0.1 T 0.6±0.1 T1 Max na Technical Data 10974 MCLA1005V2  Automotive multilayer chip inductor Effective November 2019  Inductance and Q vs frequency M C L A 1005V 2-1R 0-R 100 10 1 50 500 0.1 5000 F requency ( MMH Hz) Ls Q M C L A 1005V 2-100-R 100 10 1 50 500 F requency ( MHz) Ls 5000 Q M C L A 1005V 2-331-R 10000 1000 100 10 1 0.1 50 500 F requency ( MHz) Ls Q www.eaton.com/electronics 5 Technical Data 10974 MCLA1005V2 Automotive multilayer chip inductor  Effective November 2019 Solder reflow profile Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2019 Eaton All Rights Reserved Printed in USA Publication No. 10974 BU-MC19102 November 2019 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
MCLA1005V2-150-R 价格&库存
很抱歉,暂时无法提供与“MCLA1005V2-150-R”相匹配的价格&库存,您可以联系我们找货
MCLA1005V2-150-R
  • 1+0.888571+0.11495
  • 10+0.3008310+0.03892
  • 25+0.2762125+0.03574
  • 50+0.2584450+0.03344
  • 100+0.24430100+0.03161
  • 250+0.22628250+0.02928
  • 500+0.21319500+0.02758
  • 1000+0.201071000+0.02601
  • 2500+0.185992500+0.02406
库存:13257
MCLA1005V2-150-R
  • 10000+0.1653310000+0.02139
  • 20000+0.1558820000+0.02017
  • 30000+0.1506130000+0.01949
  • 50000+0.1442350000+0.01866
  • 70000+0.1401770000+0.01814
  • 100000+0.13601100000+0.01760
库存:13257
