Technical Data 11102
Effective June 2020
MCQ1V3216
Multilayer high Q chip inductor
Applications
• Industrial connectivity (IoT)
• Wireless communications
• Bluetooth
• WiFi
• Antenna
• Machine-to-machine (M2M)
• Mobile phones
Product features
• Wearable devices
1206 (3216 metric) package
• Wireless LAN
Multilayer monolithic construction yields high
reliability
• Computing/gaming consoles
Inductance range from 0.047 µH to 4.7 µH
• RF transceiver modules
Moisture sensitivity level (MSL): 1
• Broadband components
Environmental compliance
and general specifications
Operating temperature range: -40 °C to +85 °C
(ambient plus self-temperature rise)
HALOGEN
Pb HF
FREE
MCQ1V3216
Effective June 2020
Product specifications
Ls
Tolerance
Ls1
(µH)
Q
minimum
DCR (Ω)
@ +25 °C
maximum
Test frequency2
(MHz)
Test voltage2
(mV)
SRF (MHz)
minimum
Rated I3
maximum
(mA)
MCQ1V3216-R047-R
±10
0.047
30
0.15
50
50
320
300
MCQ1V3216-R056-R
±10
0.056
30
0.2
50
50
320
300
MCQ1V3216-R068-R
±10
0.068
30
0.25
50
50
280
300
MCQ1V3216-R082-R
±10
0.082
30
0.25
50
50
280
300
MCQ1V3216-R100-R
±10
0.10
25
0.25
25
50
235
250
MCQ1V3216-R120-R
±10
0.12
25
0.25
25
50
220
250
MCQ1V3216-R150-R
±10
0.15
25
0.25
25
50
200
250
MCQ1V3216-R180-R
±10
0.18
25
0.3
25
50
185
250
MCQ1V3216-R220-R
±10
0.22
25
0.3
25
50
170
250
MCQ1V3216-R270-R
±10
0.27
25
0.3
25
50
150
250
MCQ1V3216-R330-R
±10
0.33
25
0.3
25
50
145
250
MCQ1V3216-R390-R
±10
0.39
30
0.5
25
50
135
200
MCQ1V3216-R470-R
±10
0.47
30
0.5
25
50
125
200
MCQ1V3216-R560-R
±10
0.56
30
0.5
25
50
115
150
MCQ1V3216-R680-R
±10
0.68
30
0.5
25
50
105
150
MCQ1V3216-R820-R
±10
0.82
30
0.6
25
50
100
150
MCQ1V3216-1R0-R
±10
1.0
35
0.3
10
50
75
100
MCQ1V3216-1R2-R
±10
1.2
35
0.4
10
50
65
100
MCQ1V3216-1R5-R
±10
1.5
35
0.4
10
50
60
50
MCQ1V3216-1R8-R
±10
1.8
35
0.4
10
50
55
50
MCQ1V3216-2R2-R
±10
2.2
35
0.5
10
50
50
50
MCQ1V3216-2R7-R
±10
2.7
35
0.5
10
50
45
50
MCQ1V3216-3R3-R
±10
3.3
35
0.5
10
50
41
50
MCQ1V3216-3R9-R
±10
3.9
35
0.6
10
50
38
50
MCQ1V3216-4R7-R
±10
4.7
35
0.65
10
50
35
25
Part number
4
1. Ls = Inductance
2. Ls and Q test voltage and frequency
3. Rated I: Current rating for an approximate self-temperature rise of 40 °C or less.
2
www.eaton.com/electronics
4. Part Number Definition: MCQ1V3216-xxx-R
MCQ1V3216 = Product code and size
xxx= inductance value in µH, R= decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
MCQ1V3216
Effective June 2020
Mechanical parameters, schematic, pad layout (mm)
Recommended pad layout
Schematic
Part Number
L
W
T
a
F
G
H
MCQ1V3216-xxx-R
3.20 ±0.20
1.60 ±0.20
0.90 ±0.20
0.50 ±0.30
2.00 ref
1.40 ref
1.20 ref
Part marking: No marking
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.1 millimeters unless stated otherwise
Pad layout dimensions are reference only
Traces or vias underneath the inductor is not recommended
Packaging information (mm)
Drawing not to scale
Supplied in tape and reel packaging, 4000 parts per 7” diameter reel
W±0.2
8.00
F±0.1
3.50
E1±0.2
1.75
E2 Min
na
P0±0.2
4.00
P1±0.2
4.00
P2±0.1
2.00
D0±0.1
1.55
A0
1.9±0.2
B0
3.5±0.2
T
0.95±0.1
T1 Max
na
3
MCQ1V3216
Effective June 2020
Qualification testing
No.
Test item
Sample size (pcs)
1
External visual
72
2
Physical dimension
72
Specification
Specification
3
Initial electrical test
72
Specification
User spec
4
Solderability
6
+245 °C ±5 °C, dipping 5 ±1 s
>95% solder coverage
5
Resistance to soldering heat
6
+260 ±5 °C for 10±1 s
1. ΔL/L
很抱歉,暂时无法提供与“MCQ1V3216-R120-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4000+0.271024000+0.03497
