WCLA1608V1-391-R
WCLA1608V1-391-R
    EATON(伊顿)
    固定电感器 ±5% 800MHz 390nH 0603 1.78 x 1.10mm 100mA
WCLA1608V1-391-R 数据手册
Technical Data 10982 Effective November 2019 WCLA1608V1 Automotive grade wire wound chip inductor Applications • ADAS • Infotainment • Wireless communications • Wifi, bluetooth, satellite • Antenna tuning • On board computer Product features • AEC-Q200 qualified • 0603 (1608 metric) package • High Q value • Tight inductance tolerance • Inductance range from 1.6 nH to 470 nH • Moisture sensitivity level (MSL): 1 Environmental data • Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) HALOGEN Pb HF FREE WCLA1608V1 Automotive grade wire wound chip inductor  Technical Data 10982 Effective November 2019 Product specifications Part number OCL Tolerance (%) OCL (nH) OCL Test frequency (MHz) Q minimum Q Test frequency (MHz) DCR@ (Ω) @ +25 °C maximum Test voltage (mV) SRF (MHz) minimum I Rated (mA) WCLA1608V1-1R6-R ±10 1.6 250 18 250 0.04 500 12500 700 WCLA1608V1-1R8-R ±10 1.8 250 16 250 0.045 500 12500 700 WCLA1608V1-2R2-R ±10 2.2 250 12 250 0.09 500 10000 700 WCLA1608V1-3R3-R ±10 3.3 250 20 250 0.075 500 5900 700 WCLA1608V1-3R9-R ±5 3.9 250 22 250 0.08 500 6900 700 WCLA1608V1-4R7-R ±5 4.7 250 20 250 0.116 500 5800 700 WCLA1608V1-5R6-R ±10 5.6 250 18 250 0.2 500 5700 700 WCLA1608V1-6R8-R ±5 6.8 250 27 250 0.11 500 5800 700 WCLA1608V1-7R5-R ±5 7.5 250 28 250 0.11 500 4800 700 WCLA1608V1-8R2-R ±5 8.2 250 28 250 0.12 500 4700 700 WCLA1608V1-100-R ±5 10 250 31 250 0.13 500 4800 700 WCLA1608V1-120-R ±5 12 250 35 250 0.13 500 4000 700 WCLA1608V1-150-R ±5 15 250 30 250 0.15 500 4000 700 WCLA1608V1-180-R ±5 18 250 35 250 0.17 500 3100 700 WCLA1608V1-220-R ±5 22 250 38 250 0.19 500 3000 700 WCLA1608V1-270-R ±5 27 250 36 250 0.22 500 2800 600 WCLA1608V1-330-R ±5 33 250 36 250 0.22 500 2300 600 WCLA1608V1-390-R ±5 39 250 40 250 0.25 500 2200 600 WCLA1608V1-470-R ±5 47 200 36 200 0.28 500 2000 600 WCLA1608V1-560-R ±5 56 200 38 200 0.28 500 1900 600 WCLA1608V1-680-R ±5 68 200 36 200 0.34 500 1700 600 WCLA1608V1-820-R ±5 82 150 34 150 0.55 500 1700 400 WCLA1608V1-101-R ±5 100 150 30 150 0.63 500 1400 400 WCLA1608V1-121-R ±5 120 150 32 150 0.73 500 1300 300 WCLA1608V1-151-R ±5 150 150 28 150 0.8 500 990 280 WCLA1608V1-181-R ±5 180 100 25 100 1.45 500 990 240 WCLA1608V1-221-R ±5 220 100 25 100 2.1 500 900 200 WCLA1608V1-271-R ±5 270 100 24 100 2.3 500 900 170 WCLA1608V1-331-R ±5 330 100 25 100 3.89 500 900 100 WCLA1608V1-391-R ±5 390 100 25 100 4.35 500 800 100 WCLA1608V1-471-R ±5 470 100 25 100 7 500 700 75 1. Test voltage is for open circuit inductance (OCL) and Q at +25 °C 2. Rated I: When rated I is applied to the product, self-temperature rise will be 20 °C or less. 2 www.eaton.com/electronics 3. Part Number Definition: WCLA1608V1-xxx-R WCLA1608V1 = Product code and size xxx= inductance value in nH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant Technical Data 10982 WCLA1608V1  Automotive grade wire wound chip inductor Effective November 2019  Dimensions (mm) Recommended pad layout Schematic Part Number A B C D E F G H WCLA1608V1-xxx-R 1.78 max 1.10 max 0.95 max 0.30 ref 0.76 ref 1.02 ref 0.64 ref 0.64 ref Park marking: No marking All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.1 millimeters unless stated otherwise Pad layout dimensions are reference only Traces or vias underneath the inductor is not recommended Packaging information (mm) Drawing not to scale Supplied in tape and reel packaging, 4000 parts per 7” diameter reel Boom cover tape Top cover tape Center lines of cavity Boom cover tape Top cover tape Direcon of feed W±0.3 8.00 F±0.05 3.50 E1±0.1 1.75 E2 Min na P0±0.1 4.00 P1±0.05 4.00 P2±0.05 2.00 D0+0.1-0.0 1.55 A0 1.20 B0 1.85 T 1.0 T1 na www.eaton.com/electronics 3 WCLA1608V1 Automotive grade wire wound chip inductor  Technical Data 10982 Effective November 2019 Inductance vs frequency WCLA1608V1-1R6-R 5 Inductance (nH) 4 3 2 1 0 1 10 100 Frequency (MHz) 1000 10000 1000 10000 WCLA1608V1-471-R Inductance (nH) 1500 1200 900 600 300 0 1 10 100 Frequency (MHz) Q vs frequency WCLA1608V1-1R6-R 300 240 Q 180 120 60 0 1 10 100 Frequency (MHz) 1000 10000 WCLA1608V1-471-R 60 Q 40 20 0 1 10 100 Frequency (MHz) 4 www.eaton.com/electronics 1000 10000 Technical Data 10982 WCLA1608V1  Automotive grade wire wound chip inductor Effective November 2019  Solder reflow profile Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2019 Eaton All Rights Reserved Printed in USA Publication No. 10982 BU-MC19110 November 2019 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
WCLA1608V1-391-R
物料型号:WCLA1608V1
器件简介:该电感器是汽车级产品,适用于ADAS、信息娱乐、无线通信、Wi-Fi、蓝牙、卫星、天线调谐和车载电脑等应用。
引脚分配:文档中未提供具体的引脚分配信息,但提供了推荐的焊盘布局。
参数特性: - 符合AEC-Q200标准 - 0603 (1608公制)封装 - 高Q值 - 工作温度范围:-40°C至+125°C - 紧密的电感公差 - 电感范围从1.6 nH到470 nH - 湿度敏感性等级 (MSL): 1 - 无卤素、符合RoHS标准
功能详解:文档提供了详细的产品规格,包括不同的电感值、品质因数(Q值)、自谐振频率(SRF)、额定电流等。
应用信息:适用于汽车行业的多种应用,如驾驶辅助系统、信息娱乐系统、无线通信等。
封装信息:提供了电感器的尺寸信息和推荐的焊盘布局,以及包装信息,说明电感器以卷带形式供应,每卷7英寸直径可包含4000个部件。
WCLA1608V1-391-R 价格&库存
很抱歉,暂时无法提供与“WCLA1608V1-391-R”相匹配的价格&库存,您可以联系我们找货
WCLA1608V1-391-R
WCLA1608V1-391-R
  • 4000+1.056014000+0.13243
WCLA1608V1-391-R
    • 1+0.79294
    • 200+0.30694
    • 500+0.29614
    • 1000+0.29074
