Technical Data 10983
Effective November 2019
WCLA2012V1
Automotive grade wire wound chip inductor
Applications
ADAS
Infotainment
Wireless communications
Wifi, bluetooth, satellite
Antenna tuning
On board computer
Product features
AEC-Q200 qualified
0805 (2012 metric) package
Environmental data
High Q value
Tight inductance tolerance
Inductance range from 2.2 nH to 2200 nH
Moisture sensitivity level (MSL): 1
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
HALOGEN
Pb HF
FREE
WCLA2012V1
Product specifications
Part number
OCL
Tolerance
OCL
(nH)
OCL Test
frequency
(MHz)
Q minimum
Q Test
frequency
(MHz)
DCR@ (Ω)
@ +25 °C
maximum
Test
voltage (mV)
SRF (MHz)
minimum
I Rated (mA)
WCLA2012V1-2R2-R
±10
2.2
250
50
1500
0.03
500
8500
800
WCLA2012V1-2R7-R
±5
2.7
250
50
1500
0.045
500
8000
800
WCLA2012V1-3R3-R
±10
3.3
250
35
1500
0.09
500
7900
600
WCLA2012V1-4R7-R
±10
4.7
250
40
1000
0.05
500
6000
600
WCLA2012V1-5R6-R
±5
5.6
250
50
1000
0.065
500
5500
600
WCLA2012V1-6R8-R
±5
6.8
250
50
1000
0.11
500
5500
600
WCLA2012V1-8R2-R
±5
8.2
250
35
1000
0.2
500
4700
600
WCLA2012V1-100-R
±5
10
250
50
500
0.15
500
4200
600
WCLA2012V1-120-R
±5
12
250
50
500
0.15
500
4000
600
WCLA2012V1-150-R
±5
15
250
45
500
0.17
500
3400
600
WCLA2012V1-180-R
±5
18
250
55
500
0.2
500
3300
600
WCLA2012V1-220-R
±5
22
250
55
500
0.22
500
2600
500
WCLA2012V1-270-R
±5
27
250
55
500
0.25
500
2500
500
WCLA2012V1-330-R
±5
33
250
55
500
0.27
500
2050
500
WCLA2012V1-390-R
±5
39
250
55
500
0.29
500
2000
500
WCLA2012V1-470-R
±5
47
200
55
500
0.31
500
1650
500
WCLA2012V1-560-R
±5
56
200
55
500
0.34
500
1550
500
WCLA2012V1-680-R
±5
68
200
55
500
0.38
500
1450
500
WCLA2012V1-820-R
±5
82
150
55
500
0.42
500
1300
400
WCLA2012V1-101-R
±5
100
150
50
500
0.46
500
1200
400
WCLA2012V1-121-R
±5
120
150
45
250
0.51
500
1100
400
WCLA2012V1-151-R
±5
150
100
45
250
0.56
500
920
400
WCLA2012V1-181-R
±5
180
100
45
250
0.64
500
870
400
WCLA2012V1-221-R
±5
220
100
40
250
1.05
500
850
400
WCLA2012V1-271-R
±5
270
100
40
250
1.1
500
650
350
WCLA2012V1-331-R
±5
330
100
40
250
1.4
500
600
310
WCLA2012V1-391-R
±5
390
100
40
250
1.5
500
560
290
WCLA2012V1-471-R
±5
470
50
33
100
2
500
375
250
WCLA2012V1-561-R
±5
560
25
23
50
1.9
500
340
230
WCLA2012V1-681-R
±5
680
25
23
50
2.1
500
300
190
WCLA2012V1-821-R
±5
820
25
23
50
2.14
500
250
180
WCLA2012V1-102-R
±5
1000
25
2.4
500
200
170
WCLA2012V1-122-R
±5
1200
7.9
18
50
2.55
500
180
170
WCLA2012V1-152-R
±5
1500
7.9
18
50
2.8
500
170
160
WCLA2012V1-182-R
±5
1800
7.9
18
50
3.8
500
140
150
WCLA2012V1-222-R
±5
2200
7.9
16
7.9
4.2
500
50
150
1. Test voltage is for open circuit inductance (OCL) and Q at +25 °C
2. Rated I: When rated I is applied to the product, self-temperature rise will be 20 °C or less.
2
www.eaton.com/electronics
3. Part Number Definition: WCLA2012V1-xxx-R
WCLA2012V1 = Product code and size
xxx= inductance value in nH, R= decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
WCLA2012V1
Dimensions (mm)
Recommended pad layout
Schematic
Part Number
A
B
C
D
E
F
G
H
WCLA2012V1-xxx-R
2.30 max
1.70 max
1.52 max
0.50 ref
1.27 ref
1.78 ref
0.76 ref
1.02 ref
Park marking: xxx= inductance value in nH, R= decimal point, if no R is present last character indicates the number of zeros
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.1 millimeters unless stated otherwise
Pad layout dimensions are reference only
Traces or vias underneath the inductor is not recommended
Packaging information (mm)
Drawing not to scale
Supplied in tape and reel packaging, 3000 parts per 7” diameter reel
W±0.3
8.00
F±0.05
3.50
E1±0.1
1.75
E2 Min
na
P0±0.1
4.00
P1±0.05
4.00
P2±0.05
2.00
D0+0.1-0.0
1.55
D1 min
0.65
A0
1.85
B0
2.45
K0
1.5
T
0.23
3
WCLA2012V1
Inductance vs frequency
WCLA2012V1-2R2-R
Inductance (nH)
5
4
3
2
1
10
100
1000
10000
Frequency (MHz)
WCLA2012V1-222-R
Inductance (uH)
8
6
4
2
10
100
Frequency (MHz)
1000
10000
Q vs frequency
WCLA2012V1-2R2-R
100
80
Q
60
40
10
100
1000
10000
Frequency (MHz)
WCLA2012V1-222-R
50
40
Q
30
10
100
Frequency (MHz)
4
1000
10000
WCLA2012V1
Solder reflow profile
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used
in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com/electronics
© 2019 Eaton
All Rights Reserved
Printed in USA
Publication No. 10983 BU-MC19111
November 2019
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“WCLA2012V1-221-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 3000+0.87056
- 30000+0.82219
