WCLA1005V1-101-R
WCLA1005V1-101-R
    EATON(伊顿)
    固定电感器 ±5% 0402 100nH 1.16GHz 1.19 x 0.66mm 30mA
WCLA1005V1-101-R 数据手册
Technical Data 10981 Effective November 2019 WCLA1005V1 Automotive grade wire wound chip inductor Applications • ADAS • Infotainment • Wireless communications • Wifi, bluetooth, satellite • Antenna tuning • On board computer • Industrial connectivity (IoT) Product features • AEC-Q200 qualified • 0402 (1005 metric) package • High Q value • Tight inductance tolerance • Inductance range from 1.0 nH to 120 nH • Moisture sensitivity level (MSL): 1 Environmental data • Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise HALOGEN Pb HF FREE WCLA1005V1 Automotive grade wire wound chip inductor  Technical Data 10981 Effective November 2019 Product specifications Part number OCL Tolerance (%) OCL (nH) OCL Test frequency (MHz) Q minimum Q Test frequency (MHz) DCR@ (Ω) @ +25 °C maximum Test voltage (mV) SRF (MHz) minimum I Rated (mA) WCLA1005V1-1R0-R ±10 1.0 250 13 250 0.045 500 10000 1360 WLCA1005V1-1R2-R ±10 1.2 250 8 250 0.135 500 10000 640 WCLA1005V1-1R8-R ±10 1.8 250 16 250 0.070 500 6000 1040 WCLA1005V1-1R9-R ±10 1.9 250 16 250 0.070 500 6000 1040 WCLA1005V1-2R0-R ±10 2.0 250 18 250 0.070 500 6000 1040 WCLA1005V1-2R2-R ±10 2.2 250 18 250 0.070 500 6000 960 WCLA1005V1-2R4-R ±10 2.4 250 16 250 0.080 500 6000 790 WCLA1005V1-2R5-R ±10 2.5 250 15 250 0.120 500 6000 640 WCLA1005V1-2R7-R ±10 2.7 250 15 250 0.120 500 6000 640 WCLA1005V1-2R9-R ±10 2.9 250 8 250 0.300 500 6000 400 WCLA1005V1-3R3-R ±5 3.3 250 20 250 0.066 500 6000 840 WCLA1005V1-3R6-R ±5 3.6 250 20 250 0.066 500 6000 840 WCLA1005V1-3R9-R ±5 3.9 250 20 250 0.066 500 6000 840 WCLA1005V1-4R3-R ±5 4.3 250 20 250 0.091 500 6000 700 WCLA1005V1-4R7-R ±5 4.7 250 18 250 0.200 500 4500 640 WCLA1005V1-5R1-R ±5 5.1 250 18 250 0.083 500 4800 800 WCLA1005V1-5R6-R ±5 5.6 250 20 250 0.083 500 4800 760 WCLA1005V1-6R2-R ±5 6.2 250 23 250 0.083 500 4800 760 WCLA1005V1-6R8-R ±5 6.8 250 23 250 0.260 500 4800 680 WCLA1005V1-7R5-R ±5 7.5 250 23 250 0.100 500 4800 680 WCLA1005V1-8R2-R ±5 8.2 250 25 250 0.100 500 4400 680 WCLA1005V1-8R7-R ±5 8.7 250 25 250 0.200 500 4100 480 WCLA1005V1-9R0-R ±5 9.0 250 25 250 0.100 500 4160 680 WCLA1005V1-9R5-R ±5 9.5 250 25 250 0.200 500 4000 480 WCLA1005V1-100-R ±5 10 250 25 250 0.20 500 3900 480 WCLA1005V1-110-R ±5 11 250 25 250 0.120 500 3680 640 WCLA1005V1-120-R ±5 12 250 25 250 0.120 500 3600 640 WCLA1005V1-130-R ±5 13 250 25 250 0.210 500 3450 440 WCLA1005V1-150-R ±5 15 250 25 250 0.300 500 3280 560 WCLA1005V1-160-R ±5 16 250 25 250 0.220 500 3100 560 WCLA1005V1-180-R ±5 18 250 25 250 0.230 500 3100 420 WCLA1005V1-190-R ±5 19 250 25 250 0.200 500 3040 480 WCLA1005V1-200-R ±5 20 250 25 250 0.250 500 3000 420 WCLA1005V1-220-R ±5 22 250 25 250 0.300 500 2800 400 WCLA1005V1-230-R ±5 23 250 22 250 0.380 500 2720 310 WCLA1005V1-240-R ±5 24 250 25 250 0.300 500 2700 400 WCLA1005V1-270-R ±5 27 250 25 250 0.520 500 2480 280 WCLA1005V1-300-R ±5 30 250 24 250 0.500 500 2350 400 WCLA1005V1-330-R ±5 33 250 24 250 0.650 500 2350 350 1. Test voltage is for open circuit inductance (OCL) and Q at +25 °C 2. Rated I: When rated I is applied to the product, self-temperature rise will be 20 °C or less. 2 www.eaton.com/electronics 3. Part Number Definition: WCLA1005V1-xxx-R WCLA1005V1 = Product code and size xxx= inductance value in nH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant Technical Data 10981 WCLA1005V1  Automotive grade wire wound chip inductor Effective November 2019  Product specifications Part number OCL Tolerance (%) OCL (nH) OCL Test frequency (MHz) Q minimum Q Test frequency (MHz) DCR@ (Ω) @ +25 °C maximum Test voltage (mV) SRF (MHz) minimum I Rated (mA) WCLA1005V1-360-R ±5 36 250 25 250 0.600 500 2320 250 WCLA1005V1-390-R ±5 39 250 25 250 0.750 500 2100 200 WCLA1005V1-400-R ±5 40 250 25 250 0.600 500 2240 220 WCLA1005V1-430-R ±5 43 250 25 250 0.810 500 2030 100 WCLA1005V1-470-R ±5 47 250 25 250 0.830 500 2100 150 WCLA1005V1-510-R ±5 51 250 25 250 0.820 500 1750 100 WCLA1005V1-560-R ±5 56 250 25 250 0.97 500 1760 100 WCLA1005V1-620-R ±5 62 250 25 250 1.120 500 1620 100 WCLA1005V1-680-R ±5 68 250 25 250 1.12 500 1620 100 WCLA1005V1-750-R ±5 75 250 25 250 1.630 500 1400 50 WCLA1005V1-820-R ±5 82 250 25 250 1.70 500 1260 50 WCLA1005V1-101-R ±5 100 250 25 250 2.00 500 1160 30 WCLA1005V1-121-R ±5 120 250 25 250 2.20 500 1100 30 1. Test voltage is for open circuit inductance (OCL) and Q at +25 °C 2. Rated I: When rated I is applied to the product, self-temperature rise will be 20 °C or less. 3. Part Number Definition: WCLA1005V1-xxx-R WCLA1005V1 = Product code and size xxx= inductance value in nH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant Dimensions (mm) Recommended pad layout Schematic Part Number A B C D E F G H WCLA1005V1-xxx-R 1.19 max 0.66 max 0.60 max 0.23 ref 0.50 ref 0.66 ref 0.46 ref 0.36 ref Park marking: No marking All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.1 millimeters unless stated otherwise Pad layout dimensions are reference only Traces or vias underneath the inductor is not recommended www.eaton.com/electronics 3 WCLA1005V1 Automotive grade wire wound chip inductor  Technical Data 10981 Effective November 2019 Packaging information (mm) Drawing not to scale Supplied in tape and reel packaging, 5000 parts per 7” diameter reel Boom cover tape Top cover tape Direcon of feed Center lines of cavity Boom cover tape Top cover tape 4 www.eaton.com/electronics W±0.3 8.00 F±0.05 3.50 E1±0.1 1.75 E2 Min na P0±0.1 4.00 P1±0.05 2.00 P2±0.05 2.00 D0+0.1-0.0 1.55 A0 0.74 B0 1.23 T 0.68 T1 na Technical Data 10981 WCLA1005V1  Automotive grade wire wound chip inductor Effective November 2019  Inductance vs frequency WCLA1005V1-1R0-R 5 Inductance (nH) 4 3 2 1 0 1 10 100 1000 10000 1000 10000 Frequency (MHz) WCLA1005V1-121-R Inductance (nH) 500 400 300 200 100 0 1 10 100 Frequency (MHz) Q vs frequency WCLA1005V1-1R0-R 250 200 Q 150 100 50 0 1 10 100 Frequency (MHz) 1000 10000 WCLA1005V1-121-R 100 80 Q 60 40 20 0 1 10 100 Frequency (MHz) 1000 10000 www.eaton.com/electronics 5 Technical Data 10981 WCLA1005V1 Automotive grade wire wound chip inductor  Effective November 2019 Solder reflow profile Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2019 Eaton All Rights Reserved Printed in USA Publication No. 10981 BU-MC19109 November 2019 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
WCLA1005V1-101-R 价格&库存
很抱歉,暂时无法提供与“WCLA1005V1-101-R”相匹配的价格&库存,您可以联系我们找货
