Technical Data 10981
Effective November 2019
WCLA1005V1
Automotive grade wire wound chip inductor
Applications
ADAS
Infotainment
Wireless communications
Wifi, bluetooth, satellite
Antenna tuning
On board computer
Industrial connectivity (IoT)
Product features
AEC-Q200 qualified
0402 (1005 metric) package
High Q value
Tight inductance tolerance
Inductance range from 1.0 nH to 120 nH
Moisture sensitivity level (MSL): 1
Environmental data
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise
HALOGEN
Pb HF
FREE
WCLA1005V1
Product specifications
Part number
OCL
Tolerance
OCL
(nH)
OCL Test
frequency
(MHz)
Q minimum
Q Test
frequency
(MHz)
DCR@ (Ω)
@ +25 °C
maximum
Test
voltage (mV)
SRF (MHz)
minimum
I Rated (mA)
WCLA1005V1-1R0-R
±10
1.0
250
13
250
0.045
500
10000
1360
WLCA1005V1-1R2-R
±10
1.2
250
8
250
0.135
500
10000
640
WCLA1005V1-1R8-R
±10
1.8
250
16
250
0.070
500
6000
1040
WCLA1005V1-1R9-R
±10
1.9
250
16
250
0.070
500
6000
1040
WCLA1005V1-2R0-R
±10
2.0
250
18
250
0.070
500
6000
1040
WCLA1005V1-2R2-R
±10
2.2
250
18
250
0.070
500
6000
960
WCLA1005V1-2R4-R
±10
2.4
250
16
250
0.080
500
6000
790
WCLA1005V1-2R5-R
±10
2.5
250
15
250
0.120
500
6000
640
WCLA1005V1-2R7-R
±10
2.7
250
15
250
0.120
500
6000
640
WCLA1005V1-2R9-R
±10
2.9
250
8
250
0.300
500
6000
400
WCLA1005V1-3R3-R
±5
3.3
250
0.066
500
6000
840
WCLA1005V1-3R6-R
±5
3.6
250
0.066
500
6000
840
WCLA1005V1-3R9-R
±5
3.9
250
0.066
500
6000
840
WCLA1005V1-4R3-R
±5
4.3
250
0.091
500
6000
700
WCLA1005V1-4R7-R
±5
4.7
250
18
250
0.200
500
4500
640
WCLA1005V1-5R1-R
±5
5.1
250
18
250
0.083
500
4800
800
WCLA1005V1-5R6-R
±5
5.6
250
0.083
500
4800
760
WCLA1005V1-6R2-R
±5
6.2
250
23
250
0.083
500
4800
760
WCLA1005V1-6R8-R
±5
6.8
250
23
250
0.260
500
4800
680
WCLA1005V1-7R5-R
±5
7.5
250
23
250
0.100
500
4800
680
WCLA1005V1-8R2-R
±5
8.2
250
25
250
0.100
500
4400
680
WCLA1005V1-8R7-R
±5
8.7
250
25
250
0.200
500
4100
480
WCLA1005V1-9R0-R
±5
9.0
250
25
250
0.100
500
4160
680
WCLA1005V1-9R5-R
±5
9.5
250
25
250
0.200
500
4000
480
WCLA1005V1-100-R
±5
10
250
25
250
0.20
500
3900
480
WCLA1005V1-110-R
±5
11
250
25
250
0.120
500
3680
640
WCLA1005V1-120-R
±5
12
250
25
250
0.120
500
3600
640
WCLA1005V1-130-R
±5
13
250
25
250
0.210
500
3450
440
WCLA1005V1-150-R
±5
15
250
25
250
0.300
500
3280
560
WCLA1005V1-160-R
±5
16
250
25
250
0.220
500
3100
560
WCLA1005V1-180-R
±5
18
250
25
250
0.230
500
3100
420
WCLA1005V1-190-R
±5
19
250
25
250
0.200
500
3040
480
WCLA1005V1-200-R
±5
25
250
0.250
500
3000
420
WCLA1005V1-220-R
±5
22
250
25
250
0.300
500
2800
400
WCLA1005V1-230-R
±5
23
250
22
250
0.380
500
2720
310
WCLA1005V1-240-R
±5
24
250
25
250
0.300
500
2700
400
WCLA1005V1-270-R
±5
27
250
25
250
0.520
500
2480
280
WCLA1005V1-300-R
±5
30
250
24
250
0.500
500
2350
400
WCLA1005V1-330-R
±5
33
250
24
250
0.650
500
2350
350
1. Test voltage is for open circuit inductance (OCL) and Q at +25 °C
2. Rated I: When rated I is applied to the product, self-temperature rise will be 20 °C or less.
2
www.eaton.com/electronics
3. Part Number Definition: WCLA1005V1-xxx-R
WCLA1005V1 = Product code and size
xxx= inductance value in nH, R= decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
WCLA1005V1
Part number
OCL Tolerance
OCL (nH)
OCL Test
frequency
(MHz)
Q minimum
Q Test
frequency
(MHz)
DCR@ (Ω)
@ +25 °C
maximum
Test
voltage (mV)
SRF (MHz)
minimum
I Rated
(mA)
WCLA1005V1-360-R
±5
36
250
25
250
0.600
500
2320
250
WCLA1005V1-390-R
±5
39
250
25
250
0.750
500
2100
200
WCLA1005V1-400-R
±5
40
250
25
250
0.600
500
2240
220
WCLA1005V1-430-R
±5
43
250
25
250
0.810
500
2030
100
WCLA1005V1-470-R
±5
47
250
25
250
0.830
500
2100
150
WCLA1005V1-510-R
±5
51
250
25
250
0.820
500
1750
100
WCLA1005V1-560-R
±5
56
250
25
250
0.97
500
1760
100
WCLA1005V1-620-R
±5
62
250
25
250
1.120
500
1620
100
WCLA1005V1-680-R
±5
68
250
25
250
1.12
500
1620
100
WCLA1005V1-750-R
±5
75
250
25
250
1.630
500
1400
50
WCLA1005V1-820-R
±5
82
250
25
250
1.70
500
1260
50
WCLA1005V1-101-R
±5
100
250
25
250
2.00
500
1160
30
WCLA1005V1-121-R
±5
120
250
25
250
2.20
500
1100
30
Dimensions (mm)
Recommended pad layout
Schematic
Part Number
A
B
C
D
E
F
G
H
WCLA1005V1-xxx-R
1.19 max
0.66 max
0.60 max
0.23 ref
0.50 ref
0.66 ref
0.46 ref
0.36 ref
Park marking: No marking
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.1 millimeters unless stated otherwise
Pad layout dimensions are reference only
Traces or vias underneath the inductor is not recommended
3
WCLA1005V1
Packaging information (mm)
Drawing not to scale
Supplied in tape and reel packaging, 5000 parts per 7” diameter reel
Boom cover tape
Top cover tape
Direcon of feed
Center lines of cavity
Boom cover tape
Top cover tape
4
W±0.3
8.00
F±0.05
3.50
E1±0.1
1.75
E2 Min
na
P0±0.1
4.00
P1±0.05
2.00
P2±0.05
2.00
D0+0.1-0.0
1.55
A0
0.74
B0
1.23
T
0.68
T1
na
WCLA1005V1
Inductance vs frequency
WCLA1005V1-1R0-R
5
Inductance (nH)
4
3
2
1
10
100
1000
10000
1000
10000
Frequency (MHz)
WCLA1005V1-121-R
Inductance (nH)
500
400
300
200
100
10
100
Frequency (MHz)
Q vs frequency
WCLA1005V1-1R0-R
250
200
Q
150
100
50
10
100
Frequency
(MHz)
1000
10000
WCLA1005V1-121-R
100
80
Q
60
40
10
100
Frequency (MHz)
1000
10000
5
WCLA1005V1
Solder reflow profile
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used
in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com/electronics
© 2019 Eaton
All Rights Reserved
Printed in USA
Publication No. 10981 BU-MC19109
November 2019
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“WCLA1005V1-150-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5000+1.101215000+0.13810
