Technical Data 10930
Effective July 2019
WCL2520
Wire wound chip inductor
Applications
Product features
Industrial connectivity (IoT)
Computing/gaming consoles
Smart meters
Industrial equipment
Machine-to-machine (M2M)
Mobile phones
Wearable devices
Wireless LAN
Wireless communiations
1008 (2520 metric) package
Bluetooth
High Q value
WiFi
Tight inductance tolerance
Antenna
Inductance range from 0.12 uH to 220 uH
Moisture sensitivity level (MSL): 1
RF transciever modules
Environmental data
Operating temperature range: -40 °C to +85 °C
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
WCL2520
Effective July 2019
Product specifications
Part number
OCL
(uH) ±5%
I Rated
(mA)
maximum
OCL
Test frequency
(MHz)
Test
voltage
(mV)
DCR (Ω)
maximum
@ +25°C
SRF
(MHz)
minimum
Q
minimum
Q
Test frequency
(MHz)
WCL2520-R120-R
0.12
800
25.2
500
0.15
850
12
25.2
WCL2520-R390-R
0.39
600
25.2
500
0.29
480
12
25.2
WCL2520-R560-R
0.56
600
25.2
500
0.42
330
12
25.2
WCL2520-R680-R
0.68
600
25.2
500
0.45
330
12
25.2
WCL2520-R820-R
0.82
600
25.2
500
0.62
300
12
25.2
WCL2520-1R0-R
1.0
580
25.2
500
0.55
300
12
25.2
WCL2520-1R2-R
1.2
550
7.96
500
0.75
250
12
7.96
WCL2520-1R5-R
1.5
400
7.96
500
0.85
230
12
7.96
WCL2520-1R8-R
1.8
320
7.96
500
0.95
168
12
7.96
WCL2520-2R2-R
2.2
315
7.96
500
1.3
150
12
7.96
WCL2520-2R7-R
2.7
300
7.96
500
1.4
100
12
7.96
WCL2520-3R3-R
3.3
280
7.96
500
1.5
80
12
7.96
WCL2520-3R9-R
3.9
250
7.96
500
1.55
60
12
7.96
WCL2520-4R7-R
4.7
210
7.96
500
1.72
50
12
7.96
WCL2520-5R6-R
5.6
190
7.96
500
1.9
40
12
7.96
WCL2520-6R8-R
6.8
175
7.96
500
2.0
35
12
7.96
WCL2520-8R2-R
8.2
160
7.96
500
2.2
25
12
7.96
WCL2520-100-R
10
155
2.52
500
2.5
25
10
2.52
WCL2520-120-R
12
145
2.52
500
2.6
2.52
WCL2520-150-R
15
130
2.52
500
3.0
2.52
WCL2520-180-R
18
130
2.52
500
3.0
2.52
WCL2520-220-R
22
105
2.52
500
3.9
18
10
2.52
WCL2520-270-R
27
100
2.52
500
4.0
10
10
2.52
WCL2520-330-R
33
85
2.52
500
4.8
8
10
2.52
WCL2520-390-R
39
80
2.52
500
5.0
7
10
2.52
WCL2520-470-R
47
60
2.52
500
5.7
7
10
2.52
WCL2520-560-R
56
55
2.52
500
6.0
6.5
10
2.52
WCL2520-680-R
68
50
2.52
500
6.7
6.5
10
2.52
WCL2520-820-R
82
45
2.52
500
7.5
6.5
10
2.52
WCL2520-101-R
100
40
0.796
500
11
4.5
8
0.796
WCL2520-121-R
120
30
0.796
500
13
3
8
0.796
WCL2520-151-R
150
25
0.796
500
15
3
8
0.796
WCL2520-221-R
220
500
18
2.5
8
0.796
1. Test frequency and voltage at +25 °C. Test voltage is for both OCL and Q.
2. Resistance to soldering heat: +260 ±5 °C for 10 ± 1 second
3. At low temperature resistance (-40 ±2°C) the inductance change is within ±5% and the Q within ±10%
4. At high temperature resistance (+85 ±5°C) the inductance change is within ±5% and the Q within ±10%
5. At high temperature load (+85 ±2°C) the inductance change is within ±5% and the Q within ±10%
2
www.eaton.com/electronics
6. Insulation Resistance: ≥ 500 MΩ with an input voltage of 100 V ±15 Vdc
7. Temperature Characteristics: From -40 °C to +85 °C the inductance is within ±5%
8. Rated I: When rated I is applied to the product, self-temperature rise will be 20 °C or less.
9. Part Number Definition: WCL2520-xxx-R
WCL2520 = Product code and size
xxx= inductance value in uH, R= decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
WCL2520
Effective July 2019
Dimensions (mm)
Recommended pad layout
F
Schematic
G
H
H
C
A
D
E
Part Number
A
B
C
D
E
F
G
H
WCL2520-xxx-R
2.92 max
2.79 max
2.10 max
0.50 ref
2.0 ref
2.54
1.27
1.02
Part marking: xxx= =Inductance value in uH, R=decimal point. If no R is present then last character equals number of zeros
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.2 millimeters unless stated otherwise
Pad layout tolerances are ±0.1 millimeters unless stated otherwise
Do not route traces or vias underneath the inductor
Packaging information (mm)
Drawing not to scale
Supplied in tape and reel packaging, 2000 parts per 7” diameter reel
W ±0.30
F±0.05
E1±0.10
E2 Min
P0±0.10
P1±0.10
P2±0.05
D0+0.10/-0
D1+0.10/-0
A0
B0
K0
T Max
8.00
3.50
1.75
6.25
4.00
4.00
2.00
1.50
0.65
2.73±0.05
2.9±0.10
2.34 ±0.10
0.25
3
WCL2520
Effective July 2019
Inductance vs frequency
Inductance˄uH˅
WCL2520-150-R
15
10
WCL2520-4R7-R
5
WCL2520-1R5-R
10
100
1000
10000
Frequency [MHz]
Q vs frequency
50
Q
40
WCL2520-1R5-R
30
WCL2520-150-R
10
10
Frequency [MHz}
4
WCL2520-4R7-R
100
WCL2520
Effective June 2019
Solder reflow profile
TP
TC -5 °C
tP
Max. ramp up rate = 3° C/s
Max. ramp down rate = 6 °C/s
Temperature
TL
Preheat
A
T smax
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“WCL2520-R560-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 2000+0.68919
- 20000+0.64083
- 80000+0.60455
