2N3053
2N3053
    L3HARRIS
    TO-205AA
    NPN TRANSISTOR
2N3053 数据手册
2N3053 2N3053A SILICON NPN TRANSISTORS w w w. c e n t r a l s e m i . c o m DESCRIPTION: The CENTRAL SEMICONDUCTOR 2N3053, 2N3053A types are epitaxial planar NPN silicon transistors designed for general purpose applications. MARKING: FULL PART NUMBER TO-39 CASE MAXIMUM RATINGS: (TA=25°C) Collector-Base Voltage Collector-Emitter Voltage Emitter-Base Voltage Continuous Collector Current Power Dissipation (TC=25°C) Operating and Storage Junction Temperature Thermal Resistance SYMBOL VCBO VCEO VEBO IC PD TJ, Tstg ΘJC 2N3053 60 40 ELECTRICAL CHARACTERISTICS: (TA=25°C unless otherwise noted) 2N3053 SYMBOL TEST CONDITIONS MIN MAX ICEV VCE=30V, VEB=1.5V 250 ICEV VCE=60V, VEB=1.5V IEBO VEB=4.0V 250 BVCBO IC=100μA 60 BVCER IC=100mA, RBE=10Ω (Note 1) 50 BVCEO IC=100mA (Note 1) 40 BVEBO IE=100μA 5.0 VCE(SAT) IC=150mA, IB=15mA 1.4 VBE(SAT) IC=150mA, IB=15mA 1.7 VBE(ON) VCE=2.5V, IC=150mA 1.7 VCE=2.5V, IC=150mA 25 hFE hFE VCE=10V, IC=150mA 50 250 fT VCE=10V, IC=50mA, f=100MHz 100 Cob VCB=10V, IE=0, f=1.0MHz 15 Cib VBE=0.5V, IC=0, f=1.0MHz 80 2N3053A 80 60 5.0 0.7 5.0 -65 to +200 35 2N3053A MIN MAX 250 250 80 70 60 5.0 0.3 0.6 1.0 1.0 25 50 250 100 15 80 UNITS V V V A W °C °C/W UNITS nA nA nA V V V V V V V MHz pF pF Notes: (1) Pulse width < 300μs, duty cycle < 2%. R2 (13-December 2013) 2N3053 2N3053A SILICON NPN TRANSISTORS TO-39 CASE - MECHANICAL OUTLINE LEAD CODE: 1) Emitter 2) Base 3) Collector MARKING: FULL PART NUMBER R2 (13-December 2013) w w w. c e n t r a l s e m i . c o m OUTSTANDING SUPPORT AND SUPERIOR SERVICES PRODUCT SUPPORT Central’s operations team provides the highest level of support to insure product is delivered on-time. • Supply management (Customer portals) • Custom bar coding for shipments • Inventory bonding • Custom product packing • Consolidated shipping options DESIGNER SUPPORT/SERVICES Central’s applications engineering team is ready to discuss your design challenges. Just ask. • Free quick ship samples (2nd day air) • Special wafer diffusions • Online technical data and parametric search • PbSn plating options • SPICE models • Package details • Custom electrical curves • Application notes • Environmental regulation compliance • Application and design sample kits • Customer specific screening • Custom product and package development • Up-screening capabilities REQUESTING PRODUCT PLATING 1. If requesting Tin/Lead plated devices, add the suffix “ TIN/LEAD” to the part number when ordering (example: 2N2222A TIN/LEAD). 2. If requesting Lead (Pb) Free plated devices, add the suffix “ PBFREE” to the part number when ordering (example: 2N2222A PBFREE). CONTACT US Corporate Headquarters & Customer Support Team Central Semiconductor Corp. 145 Adams Avenue Hauppauge, NY 11788 USA Main Tel: (631) 435-1110 Main Fax: (631) 435-1824 Support Team Fax: (631) 435-3388 www.centralsemi.com Worldwide Field Representatives: www.centralsemi.com/wwreps Worldwide Distributors: www.centralsemi.com/wwdistributors For the latest version of Central Semiconductor’s LIMITATIONS AND DAMAGES DISCLAIMER, which is part of Central’s Standard Terms and Conditions of sale, visit: www.centralsemi.com/terms w w w. c e n t r a l s e m i . c o m (001)
2N3053 价格&库存
很抱歉,暂时无法提供与“2N3053”相匹配的价格&库存,您可以联系我们找货
