BZT52C4V7-G RHG
BZT52C4V7-G RHG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOD-123
    BZT52C4V7-G RHG
BZT52C4V7-G RHG 数据手册
BZT52C2V4-G - BZT52C43-G Taiwan Semiconductor Small Signal Product 5% Zener Voltage Tolerance Zener Diode FEATURES - Wide zener voltage range selection: 2.4V to 43V - Surface Mount Device Type - Moisture sensitivity level (MSL): 1 - Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC - Halogen-free according to IEC 61249-2-21 SOD-123 MECHANICAL DATA - Case: Bend lead SOD-123 small outline plastic package - Terminal: Matte tin plated, lead free, solderable per MIL-STD-202, Method 208 guaranteed - High temperature soldering guaranteed: 260°C/10s - Polarity: Indicated by cathode band MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) PARAMETER Forward Voltage (Note2) @ IF = 10mA Power Dissipation (Note1) Thermal Resistance from Junction to Ambient SYMBOL VALUE UNIT VF 0.9 V PD 350 mW RθJA 357 °C/W °C Junction Temperature TJ 150 Storage Temperature TSTG - 55 to +150 °C 2 Notes: 1. Device mounted on ceramic PCB: 7.6mm X 9.4mm X 0.87mm with pad areas 25mm 2. Short duration test pulse used to minimize self-heating effect Version: B1601 BZT52C2V4-G - BZT52C43-G Taiwan Semiconductor Small Signal Product ELECTRICAL CHARACTERISTICS (Ratings at TA=25°C ambient temperature unless otherwise specified) Zener Voltage Range Device Type Maximum Zener Impedance Marking code VZ @ IZT IZT Nom(V) Min(V) Max(V) mA ZZT @ IZT ZZk @ Izk Ohm Maximum Reverse Current Typical Temperature Coefficient @ IZTC Test Current mV/°C IZTC IZT IR VR mA μA V Min Max mA BZT52C2V4-G WX 2.4 2.2 2.6 5 100 600 1.0 50 1.0 -3.5 0 5 BZT52C2V7-G W1 2.7 2.5 2.9 5 100 600 1.0 20 1.0 -3.5 0 5 BZT52C3V0-G W2 3.0 2.8 3.2 5 95 600 1.0 10 1.0 -3.5 0 5 BZT52C3V3-G W3 3.3 3.1 3.5 5 95 600 1.0 5 1.0 -3.5 0 5 BZT52C3V6-G W4 3.6 3.4 3.8 5 90 600 1.0 5 1.0 -3.5 0 5 BZT52C3V9-G W5 3.9 3.7 4.1 5 90 600 1.0 3 1.0 -3.5 0 5 BZT52C4V3-G W6 4.3 4 4.6 5 90 600 1.0 3 1.0 -3.5 0 5 BZT52C4V7-G W7 4.7 4.4 5.0 5 80 500 1.0 3 2.0 -3.5 0.2 5 BZT52C5V1-G W8 5.1 4.8 5.4 5 60 480 1.0 2 2.0 -2.7 1.2 5 BZT52C5V6-G W9 5.6 5.2 6.0 5 40 400 1.0 1 2.0 -2.0 2.5 5 BZT52C6V2-G WA 6.2 5.8 6.6 5 10 150 1.0 3 4.0 0.4 3.7 5 BZT52C6V8-G WB 6.8 6.4 7.2 5 15 80 1.0 2 4.0 1.2 4.5 5 BZT52C7V5-G WC 7.5 7.0 7.9 5 15 80 1.0 1 5.0 2.5 5.3 5 BZT52C8V2-G WD 8.2 7.7 8.7 5 15 80 1.0 0.7 5.0 3.2 6.2 5 BZT52C9V1-G WE 9.1 8.5 9.6 5 15 100 1.0 0.5 6.0 3.8 7.0 5 BZT52C10-G WF 10 9.4 10.6 5 20 150 1.0 0.2 7.0 4.5 8.0 5 BZT52C11-G WG 11 10.4 11.6 5 20 150 1.0 0.1 8.0 5.4 9.0 5 BZT52C12-G WH 12 11.4 12.7 5 25 150 1.0 0.1 8.0 6.0 10.0 5 BZT52C13-G WI 13 12.4 14.1 5 30 170 1.0 0.1 8.0 7.0 11.0 5 BZT52C15-G WJ 15 13.8 15.6 5 30 200 1.0 0.1 10.5 9.2 13.0 5 BZT52C16-G WK 16 15.3 17.1 5 40 200 1.0 0.1 11.2 10.4 14.0 5 BZT52C18-G WL 18 16.8 19.1 5 45 225 1.0 0.1 12.6 12.4 16.0 5 BZT52C20-G WM 20 18.8 21.2 5 55 225 1.0 0.1 14.0 14.4 18.0 5 BZT52C22-G WN 22 20.8 23.3 5 55 250 1.0 0.1 15.4 16.4 20.0 5 BZT52C24-G WO 24 22.8 25.6 5 70 250 1.0 0.1 16.8 18.4 22.0 5 BZT52C27-G WP 27 25.1 28.9 2 80 300 0.5 0.1 18.9 21.4 25.3 2 BZT52C30-G WQ 30 28.0 32.0 2 80 300 0.5 0.1 21.0 24.4 29.4 2 BZT52C33-G WR 33 31.0 35.0 2 80 325 0.5 0.1 23.1 27.4 33.4 2 BZT52C36-G WS 36 34.0 38.0 2 90 350 0.5 0.1 25.2 30.4 37.4 2 BZT52C39-G WT 39 37.0 41.0 2 130 350 0.5 0.1 27.3 33.4 41.2 2 BZT52C43-G WU 43 40.0 46.0 5 100 700 1.0 0.1 32.0 10.0 12.0 5 Version: B1601 BZT52C2V4-G - BZT52C43-G Taiwan Semiconductor Small Signal Product ORDERING INFORMATION PART NO. PACKING CODE BZT52Cxxx-G (Note 1, 2) RH PACKING CODE SUFFIX G PACKAGE PACKING SOD-123 3K / 7" Reel Note 1: "xxx" is device code from "2V4" - "43" Note 2: Whole series with green compound EXAMPLE EXAMPLE P/N PART NO. BZT52C2V4-G RHG BZT52C2V4-G PACKING PACKING CODE CODE SUFFIX RH G DESCRIPTION Green compound Version: B1601 BZT52C2V4-G - BZT52C43-G Taiwan Semiconductor Small Signal Product PACKAGE OUTLINE DIMENSIONS SOD-123 DIM. Unit (mm) Unit (inch) Min Max Min Max A 1.40 1.80 0.055 0.071 B 3.55 3.85 0.140 0.152 C 0.45 0.70 0.018 0.028 D 2.55 2.85 0.100 0.112 E 0.95 1.35 0.037 0.053 F 0.05 0.15 0.002 0.006 0.50 REF G H - 0.10 0.02 REF - 0.004 SUGGEST PAD LAYOUT DIM. Unit (mm) Unit (inch) Min Min G 2.25 0.089 X 0.90 0.035 X1 4.05 0.159 Y 0.95 0.037 Version: B1601 BZT52C2V4-G - BZT52C43-G Taiwan Semiconductor Small Signal Product CREAT BY ART Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Version: B1601
BZT52C4V7-G RHG 价格&库存
很抱歉,暂时无法提供与“BZT52C4V7-G RHG”相匹配的价格&库存,您可以联系我们找货
BZT52C4V7-G RHG
  • 1+2.209791+0.28704
  • 10+1.3333510+0.17320
  • 50+0.9481850+0.12317
  • 100+0.82360100+0.10699
  • 500+0.60190500+0.07819
库存:5940
BZT52C4V7-G RHG
  • 3000+0.438233000+0.05693
  • 9000+0.368179000+0.04783
库存:5940
