BC337-40 A1G
BC337-40 A1G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO92-3
    TRANSISTOR, NPN, 45V, 0.8A, 250A
BC337-40 A1G 数据手册
BC337-16/25/40 thru BC338-16/25/40 Taiwan Semiconductor Small Signal Product NPN Transistor FEATURES - For switching and AF amplifier applications - These types are subdivided into three groups -16, -25 and -40, according to their current gain - Moisture sensitivity level 1 - Driver transistor - Pb free and RoHS complian - Green compound (Halogen free) with suffix "G" on packing code and prefix "G" on date code MECHANICAL DATA - Case: TO-92 small outline plastic package - Terminal: Matte tin plated, lead free, solderable per MIL-STD-202, Method 208 guaranteed - High temperature soldering guaranteed: 260°C/10s TO-92 - Weight: 190 mg (approximately) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25℃ unless otherwise noted) PARAMETER Total Power dissipation BC337 Collector-Base Voltage BC337 UNIT PTOT 625 50 mW BC337 45 V 25 5 VEBO BC338 V 30 VCEO BC338 Emitter-Base Voltage VALUE VCBO BC338 Collector-Emitter Voltage SYMBOL V 5 Collector Current IC 800 mA Peak Collector Current ICM 1000 mA TJ , TSTG -55 to +150 °C Junction and Storage Temperature Range PARAMETER BC337 Collector-Base Breakdown Voltage BC338 Collector-Emitter Breakdown Voltage Emitter-Base Breakdown Voltage Collector Base Cutoff Current SYMBOL BC337 BC338 BC337 BC338 IC= 100μA V(BR)CBO IC= 2mA V(BR)CEO IE= 100μA V(BR)EBO BC337 VCB=50V BC338 VCB=30V ICBO MIN 50 30 45 25 5 5 MAX UNIT - V - V - V - 100 - 100 nA Collector Emitter Saturation Voltage IC=500mA, IB=50mA VCE(sat) - 0.7 V Base Emitter On Voltage VCE=1V, IC=300mA VBE(on) - 1.2 V Transition Frequency VCE=5V, IC=10mA, f=50MHz fT 100 - MHz Output Capacitance VCB=10V, f=1MHz Cob 12 - pF 100 250 160 400 250 630 60 - Current Gain Group: -16 DC Current Gain VCE= 5V, -25 IC= 100mA -40 VCE= 5V, IC= 300mA Document Number: DS_S1407004 hFE V Version: B14 BC337-16/25/40 thru BC338-16/25/40 Taiwan Semiconductor Small Signal Product RATINGS AND CHARACTERISTICS CURVES (TA=25℃ unless otherwise noted) FIG.1 STATIC CHARACTERSTIC FIG.2 STATIC CHARACTERSTIC 1000 10 800 9 8 COMMON EMITTER Ta=25℃ 7 6 5 600 Ic(mA), COLLECTOR CURRENT Ic(mA), COLLECTOR CURRENT 1000 4 3 400 2 IB=1mA 200 0 0 0 10 20 30 COMMON EMITTER Ta=25℃ 800 600 400 VCE=1V 200 0 40 0.8 0.6 0.4 VCE(V), COLLECTOR EMITTER VOLTAGE FIG. 4 hFE - IC 1000 0 COMMON EMITTER VCE=1V COMMON EMITTER Ta=25℃ 0.2 Ta= 100℃ DC CURRENT GAIN hFE BASE-EMITTER VOLTAGE VBE(V) 0 BASE CURRENT IB(mA) FIG.3 STATIC CHARACTERSTIC 0.4 0.6 VCE=1V 0.8 1 0.8 0.6 0.4 0.2 100 Ta= 25℃ Ta= -25℃ 10 0 1 10 100 1000 Ic(mA), COLLECTOR CURRENT BASE CURRENT IB(mA) FIG. 6 VCE(sat) - IC FIG.5 IC - VCE(LOW VOLTAGE REGION) 1 COMMON EMITTER VCE=1V 1000 6 7 800 8 5 4 3 600 400 2 200 IB=1mA 0 0 0 1 2 3 4 VCE(V), COLLECTOR EMITTER VOLTAGE Document Number: DS_S1407004 5 6 COLLECTOR-EMITTER SATURATION VOLTAGE VCE(sat) (V) 1200 Ic(mA), COLLECTOR CURRENT 0.2 COMMON EMITTER IC / IB = 25 Ta= 100℃ Ta= -25℃ Ta= 25℃ 0.1 Ta= 100℃ 0.01 1 10 100 1000 Ic(mA), COLLECTOR CURRENT Version: B14 BC337-16/25/40 thru BC338-16/25/40 Taiwan Semiconductor Small Signal Product ORDERING INFORMATION PART NO. MANUFACTURE CODE (Note1) PACKING CODE GREEN COMPOUND CODE PACKAGE PACKING MARKING BC33x-16 (Note2) A1 G TO-92 4K / Ammo BC33x-16 (Note2) BC33x-25 (Note2) A1 G TO-92 4K / Ammo BC33x-25 (Note2) BC33x-40 (Note2) A1 G TO-92 4K / Ammo BC33x-40 (Note2) BC33x-16 (Note2) B1 G TO-92 5K / Bulk BC33x-16 (Note2) BC33x-25 (Note2) B1 G TO-92 5K / Bulk BC33x-25 (Note2) BC33x-40 (Note2) B1 G TO-92 5K / Bulk BC33x-40 (Note2) Note1: Indicator of manufacturing site for manufacture special control, if empty means no special control requirement. Note2: "x" is Device Code from "7" through "8", and "MARKING" should follow the "PART NO." EXAMPLE MANUFACTURE PART NO. BC337-16 A1G BC337-16 A1 G Green compound BC337-16 B1G BC337-16 B1 G Green compound BC337-16-B0 A1G BC337-16 B0 A1 G Green compound BC337-16-B0 B1G BC337-16 B0 B1 G Green compound Document Number: DS_S1407004 CODE PACKING CODE GREEN COMPOUND PREFERRED P/N CODE DESCRIPTION Version: B14 BC337-16/25/40 thru BC338-16/25/40 Taiwan Semiconductor Small Signal Product PACKAGE OUTLINE DIMENSIONS TO-92 Bulk DIM. Unit (mm) Unit (inch) Min Max Min Max A 4.30 5.10 0.169 0.201 B 4.30 4.70 0.169 0.185 C 12.50 14.50 0.492 - D 1.17 1.37 0.046 0.054 E 0.35 0.55 0.014 0.022 F 1.17 1.37 0.046 0.054 G 0.59 1.40 0.023 0.055 H 0.29 0.51 0.011 0.020 I 3.30 4.10 0.130 0.161 TO-92 Ammo A F B C E D G DIM. Unit (mm) Unit (inch) Min Max Min Max A 4.30 5.10 0.169 0.201 B 4.30 4.70 0.169 0.185 C 12.50 - 0.492 - D 2.20 2.80 0.087 0.110 E 0.35 0.55 0.014 0.022 F 0.59 1.40 0.023 0.055 G 0.29 0.51 0.011 0.020 H 3.30 4.10 0.130 0.161 SUGGEST PAD LAYOUT H Document Number: DS_S1407004 Version: B14 BC337-16/25/40 thru BC338-16/25/40 Taiwan Semiconductor Small Signal Product Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or seling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Document Number: DS_S1407004 Version: B14
BC337-40 A1G
PDF文档中包含的物料型号为:SN65HVD230。
器件简介为:这是一个用于汽车网络的高速CAN收发器,具有3.3V供电电压和高速差分收发能力。
引脚分配如下:TXD和RXD为高速差分信号输入输出,VCC和GND为供电和地,CANH和CANL为CAN总线差分信号线。
参数特性包括:工作温度范围为-40°C至+125°C,最大数据传输速率为1Mbps。
功能详解:该器件支持CAN协议,具有自动唤醒和睡眠模式,以及增强的电磁兼容性能。
应用信息:适用于汽车电子系统中的数据通信,如车载网络、传感器数据传输等。
封装信息:采用SOIC-8封装。
BC337-40 A1G 价格&库存
很抱歉,暂时无法提供与“BC337-40 A1G”相匹配的价格&库存,您可以联系我们找货
