BC337-16/25/40 thru BC338-16/25/40
Taiwan Semiconductor
Small Signal Product
NPN Transistor
FEATURES
- For switching and AF amplifier applications
- These types are subdivided into three groups -16, -25 and -40, according to their current gain
- Moisture sensitivity level 1
- Driver transistor
- Pb free and RoHS complian
- Green compound (Halogen free) with suffix "G" on
packing code and prefix "G" on date code
MECHANICAL DATA
- Case: TO-92 small outline plastic package
- Terminal: Matte tin plated, lead free,
solderable per MIL-STD-202, Method 208 guaranteed
- High temperature soldering guaranteed: 260°C/10s
TO-92
- Weight: 190 mg (approximately)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25℃ unless otherwise noted)
PARAMETER
Total Power dissipation
BC337
Collector-Base Voltage
BC337
UNIT
PTOT
625
50
mW
BC337
45
V
25
5
VEBO
BC338
V
30
VCEO
BC338
Emitter-Base Voltage
VALUE
VCBO
BC338
Collector-Emitter Voltage
SYMBOL
V
5
Collector Current
IC
800
mA
Peak Collector Current
ICM
1000
mA
TJ , TSTG
-55 to +150
°C
Junction and Storage Temperature Range
PARAMETER
BC337
Collector-Base Breakdown Voltage
BC338
Collector-Emitter Breakdown Voltage
Emitter-Base Breakdown Voltage
Collector Base Cutoff Current
SYMBOL
BC337
BC338
BC337
BC338
IC= 100μA
V(BR)CBO
IC= 2mA
V(BR)CEO
IE= 100μA
V(BR)EBO
BC337
VCB=50V
BC338
VCB=30V
ICBO
MIN
50
30
45
25
5
5
MAX
UNIT
V
V
V
100
100
nA
Collector Emitter Saturation Voltage
IC=500mA, IB=50mA
VCE(sat)
0.7
V
Base Emitter On Voltage
VCE=1V, IC=300mA
VBE(on)
1.2
V
Transition Frequency
VCE=5V, IC=10mA,
f=50MHz
fT
100
MHz
Output Capacitance
VCB=10V, f=1MHz
Cob
12
pF
100
250
160
400
250
630
60
Current Gain Group: -16
DC Current Gain
VCE= 5V,
-25
IC= 100mA
-40
VCE= 5V,
IC= 300mA
Document Number: DS_S1407004
hFE
V
Version: B14
RATINGS AND CHARACTERISTICS CURVES
FIG.1 STATIC CHARACTERSTIC
FIG.2 STATIC CHARACTERSTIC
1000
10
800
9
8
COMMON EMITTER
Ta=25℃
7
6
5
600
Ic(mA), COLLECTOR CURRENT
1000
4
3
400
2
IB=1mA
200
COMMON EMITTER
Ta=25℃
800
600
400
VCE=1V
200
0.8
0.6
0.4
VCE(V), COLLECTOR EMITTER VOLTAGE
FIG. 4 hFE - IC
1000
COMMON EMITTER
VCE=1V
COMMON EMITTER
Ta=25℃
0.2
Ta= 100℃
DC CURRENT GAIN hFE
BASE-EMITTER VOLTAGE VBE(V)
BASE CURRENT IB(mA)
FIG.3 STATIC CHARACTERSTIC
0.4
0.6
VCE=1V
0.8
1
0.8
0.6
0.4
0.2
100
Ta= 25℃
Ta= -25℃
10
10
100
1000
BASE CURRENT IB(mA)
FIG. 6 VCE(sat) - IC
FIG.5 IC - VCE(LOW VOLTAGE REGION)
1
COMMON EMITTER
VCE=1V
1000
6
7
800
8
5
4
3
600
400
2
200
IB=1mA
2
3
4
5
6
COLLECTOR-EMITTER SATURATION
VOLTAGE VCE(sat) (V)
1200
0.2
COMMON EMITTER
IC / IB = 25
Ta= 100℃
Ta= -25℃
Ta= 25℃
0.1
Ta= 100℃
0.01
1
10
100
1000
Version: B14
ORDERING INFORMATION
PART NO.
MANUFACTURE
CODE (Note1)
PACKING CODE
GREEN COMPOUND
CODE
PACKAGE
PACKING
MARKING
BC33x-16
(Note2)
A1
G
TO-92
4K / Ammo
BC33x-16
(Note2)
BC33x-25
(Note2)
A1
G
TO-92
4K / Ammo
BC33x-25
(Note2)
BC33x-40
(Note2)
A1
G
TO-92
4K / Ammo
BC33x-40
(Note2)
BC33x-16
(Note2)
B1
G
TO-92
5K / Bulk
BC33x-16
(Note2)
BC33x-25
(Note2)
B1
G
TO-92
5K / Bulk
BC33x-25
(Note2)
BC33x-40
(Note2)
B1
G
TO-92
5K / Bulk
BC33x-40
(Note2)
Note1: Indicator of manufacturing site for manufacture special control, if empty means no special control requirement.
Note2: "x" is Device Code from "7" through "8", and "MARKING" should follow the "PART NO."
EXAMPLE
MANUFACTURE
PART NO.
BC337-16 A1G
BC337-16
A1
G
Green compound
BC337-16 B1G
BC337-16
B1
G
Green compound
BC337-16-B0 A1G
BC337-16
B0
A1
G
Green compound
BC337-16-B0 B1G
BC337-16
B0
B1
G
Green compound
CODE
PACKING CODE
GREEN COMPOUND
PREFERRED P/N
CODE
DESCRIPTION
Version: B14
PACKAGE OUTLINE DIMENSIONS
TO-92 Bulk
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
4.30
5.10
0.169
0.201
B
4.30
4.70
0.169
0.185
C
12.50
14.50
0.492
D
1.17
1.37
0.046
0.054
E
0.35
0.55
0.014
0.022
F
1.17
1.37
0.046
0.054
G
0.59
1.40
0.023
0.055
H
0.29
0.51
0.011
0.020
I
3.30
4.10
0.130
0.161
TO-92 Ammo
A
F
B
C
E
D
G
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
4.30
5.10
0.169
0.201
B
4.30
4.70
0.169
0.185
C
12.50
0.492
D
2.20
2.80
0.087
0.110
E
0.35
0.55
0.014
0.022
F
0.59
1.40
0.023
0.055
G
0.29
0.51
0.011
0.020
H
3.30
4.10
0.130
0.161
SUGGEST PAD LAYOUT
H
Version: B14
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility
or liability for any errors inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property
rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability
whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties
relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or seling these
products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper
use or sale.
Version: B14
很抱歉,暂时无法提供与“BC337-40 B1G”相匹配的价格&库存,您可以联系我们找货
