2N3393
2N3393
    L3HARRIS
    TO92-3
    SMALL SIGNAL BIPOLAR TRANSISTOR
2N3393 数据手册
2N3391A 2N3392 2N3393 SILICON NPN TRANSISTORS w w w. c e n t r a l s e m i . c o m DESCRIPTION: The CENTRAL SEMICONDUCTOR 2N3391A series are silicon NPN transistors designed for general purpose amplifier applications. MARKING: FULL PART NUMBER TO-92 CASE MAXIMUM RATINGS: (TA=25°C) Collector-Base Voltage Collector-Emitter Voltage Emitter-Base Voltage Continuous Collector Current Power Dissipation Operating and Storage Junction Temperature Thermal Resistance SYMBOL VCBO VCEO VEBO IC 25 UNITS V 25 V 5.0 V 500 mA 625 mW PD TJ, Tstg -65 to +150 °C ΘJA 200 °C\W ELECTRICAL SYMBOL ICBO IEBO CHARACTERISTICS: (TA=25°C unless otherwise noted) TEST CONDITIONS MIN VCB=18V MAX 100 UNITS nA VEB=5.0V 100 nA BVCBO IC=10μA 25 V BVCEO IC=10mA 25 V BVEBO IE=10μA 5.0 Cob VCB=10V, f=1.0MHz 2.0 NF VCE=4.5V, IC=100μA, RG=500Ω, BW=15.7kHz (2N3391A only) hFE hfe VCE=4.5V, VCE=4.5V, IC=2.0mA IC=2.0mA, f=1.0kHz 2N3391A MIN MAX 250 500 250 800 V 10 pF 5.0 dB 2N3392 MIN MAX 150 300 150 500 2N3393 MIN MAX 90 180 90 400 R0 (29-January 2014) 2N3391A 2N3392 2N3393 SILICON NPN TRANSISTORS TO-92 CASE - MECHANICAL OUTLINE LEAD CODE: 1) Emitter 2) Collector 3) Base MARKING: FULL PART NUMBER R0 (29-January 2014) w w w. c e n t r a l s e m i . c o m OUTSTANDING SUPPORT AND SUPERIOR SERVICES PRODUCT SUPPORT Central’s operations team provides the highest level of support to insure product is delivered on-time. • Supply management (Customer portals) • Custom bar coding for shipments • Inventory bonding • Custom product packing • Consolidated shipping options DESIGNER SUPPORT/SERVICES Central’s applications engineering team is ready to discuss your design challenges. Just ask. • Free quick ship samples (2nd day air) • Special wafer diffusions • Online technical data and parametric search • PbSn plating options • SPICE models • Package details • Custom electrical curves • Application notes • Environmental regulation compliance • Application and design sample kits • Customer specific screening • Custom product and package development • Up-screening capabilities REQUESTING PRODUCT PLATING 1. If requesting Tin/Lead plated devices, add the suffix “ TIN/LEAD” to the part number when ordering (example: 2N2222A TIN/LEAD). 2. If requesting Lead (Pb) Free plated devices, add the suffix “ PBFREE” to the part number when ordering (example: 2N2222A PBFREE). CONTACT US Corporate Headquarters & Customer Support Team Central Semiconductor Corp. 145 Adams Avenue Hauppauge, NY 11788 USA Main Tel: (631) 435-1110 Main Fax: (631) 435-1824 Support Team Fax: (631) 435-3388 www.centralsemi.com Worldwide Field Representatives: www.centralsemi.com/wwreps Worldwide Distributors: www.centralsemi.com/wwdistributors For the latest version of Central Semiconductor’s LIMITATIONS AND DAMAGES DISCLAIMER, which is part of Central’s Standard Terms and Conditions of sale, visit: www.centralsemi.com/terms w w w. c e n t r a l s e m i . c o m (001)
2N3393 价格&库存
很抱歉,暂时无法提供与“2N3393”相匹配的价格&库存,您可以联系我们找货
