KTC3198-O/Y/GR/BL
Taiwan Semiconductor
Small Signal Product
TO-92 NPN Bipolar Transistor
FEATURES
- The transistor is subdivided into four groups according to
its DC current gain: O, Y, GR, BL
- Pb free and RoHS compliant
MECHANICAL DATA
- Case: TO-92 small outline plastic package
- High temperature soldering guaranteed: 260°C/10s
1. Emitter
- Weight: 195mg (approximately)
2. Collector
3. Base
APPLICATION
TO-92
- General purpose switching and AF amplifier application
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25℃ unless otherwise noted)
PARAMETER
SYMBOL
VALUE
UNIT
Collector Power Dissipation
Collector-Base Voltage
PC
VCBO
0.5
60
W
V
Collector-Emitter Voltage
VCEO
50
V
Emitter-Base Voltage
VEBO
5
V
IC
0.15
A
RθJA
250
℃/W
TJ , TSTG
-55 to + 150
°C
Collector Current
Thermal Resistance From Junction to Ambient
Junction and Storage Temperature Range
SYMBOL
MIN
Collector Cut-off Current
VCB= 60V, IE= 0
ICBO
Emitter Cut-off Current
VEB= 5V, IC= 0
IEBO
VCE= 6V, IC= 2mA
MAX
UNIT
0.1
μA
0.1
μA
hFE(1)
70
700
VCE= 6V, IC= 150mA
hFE(2)
25
Collector-Emitter Saturation Voltage
IC= 100mA, IB=10mA
VCE(sat)
0.25
V
Base-Emitter Saturation Voltage
IC= 100mA, IB=10mA
VBE(sat)
1
V
Transition Frequency
VCE= 10V, IC=1mA
Collector Output Capacitance
VCB= 10V, IE=0, f=1MHz
PARAMETER
DC Current Gain
fT
80
MHz
Cob
3.5
pF
CLASSIFIACTION OF hFE
RANK
O
Y
GR
BL
RANGE
70-140
120-240
200-400
300-700
Document Number: DS_S1405004
Version: A14
KTC3198-O/Y/GR/BL
RATINGS AND CHARACTERISTICS CURVES
FIG.1 Static Characteristic
FIG.3 VCE(sat) vs. IC
FIG.5 Cob / CIb vs. VCB / VEb
FIG.2 hFE vs. IC
FIG.4 VBBE(sat) vs. IC
FIG.6 fT vs. IC
Version: A14
KTC3198-O/Y/GR/BL
ORDERING INFORMATION
MANUFACTURE
GREEN COMPOUND
PACKING CODE
PART NO.
CODE
KTC3198-xx
(Note2)
PACKAGE
PACKING
MARKING
4K / Ammo
KTC
3198
xx021
(Note3)
CODE
(Note1)
A1
G
B1
G
A2
G
B2
G
TO-92
TO-92
TO-92
TO-92
5K / Bulk
2K / Ammo
10K / Bulk
KTC3198-xx
(Note2)
B0
A1
G
TO-92
4K / Ammo
KTC3198-xx
(Note2)
B0
B1
G
TO-92
5K / Bulk
KTC3198-xx
(Note2)
M0
A2
G
TO-92
2K / Ammo
KTC3198-xx
(Note2)
M0
B2
G
TO-92
10K / Bulk
KTC
3198
xx021
(Note3)
Note1: Indicator of manufacturing site for manufacture special control, if empty means no special control requirement
Note2: "xx" means device code of "O", "Y", "GR", "BL"
Note3: "MARKING" should follow the "PART NO.", for example, if "PART NO." is KTC3198-O, which
"MARKING" is KTC
3198
O021
EXAMPLE
MANUFACTURE
PREFERRED P/N
GREEN COMPOUND
PACKING CODE
PART NO.
CODE
KTC3198-O A1G
KTC3198-O
KTC3198-O-B0 A1G
KTC3198-O
KTC3198-O-B0 B1G
DESCRIPTION
CODE
A1
G
Green compound
B0
A1
G
Green compound
KTC3198-O
B0
B1
G
Green compound
KTC3198-O-M0 A2G
KTC3198-O
M0
A2
G
Green compound
KTC3198-O-M0 B2G
KTC3198-O
M0
B2
G
Green compound
Version: A14
KTC3198-O/Y/GR/BL
PACKAGE OUTLINE DIMENSIONS
TO-92 Bulk
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
4.30
4.70
0.169
0.185
B
4.30
4.70
0.169
0.185
C
12.50
14.50
0.492
0.571
D
1.17
1.37
0.046
0.054
E
0.35
0.55
0.014
0.022
F
1.17
1.37
0.046
0.054
G
0.59
1.20
0.023
0.047
H
0.29
0.51
0.011
0.020
I
3.30
3.70
0.130
0.146
TO-92 Ammo
A
G
B
C
E
H
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
4.30
4.70
0.169
0.185
B
4.30
4.70
0.169
0.185
C
12.50
0.492
D
2.20
2.80
0.087
0.110
E
0.35
0.55
0.014
0.022
G
0.59
1.20
0.023
0.047
H
0.29
0.51
0.011
0.020
I
3.30
3.70
0.130
0.146
D
SUGGEST PAD LAYOUT
I
Version: A14
KTC3198-O/Y/GR/BL
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no
responsibility or liability for any errors inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property
rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability
whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties
relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or seling these
products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such
improper use or sale.
Version: A14
很抱歉,暂时无法提供与“KTC3198-GR B1G”相匹配的价格&库存,您可以联系我们找货
