2N5323
2N5323
    L3HARRIS
    TO-205AA
    SMALL SIGNAL PNP TRANSISTOR
2N5323 数据手册
2N5320 2N5321 2N5322 2N5323 NPN PNP COMPLEMENTARY SILICON SWITCHING TRANSISTORS w w w. c e n t r a l s e m i . c o m DESCRIPTION: The CENTRAL SEMICONDUCTOR 2N5320, 2N5322 series types are complementary silicon power transistors manufactured by the epitaxial planar process, designed for amplifier and switching applications. MARKING: FULL PART NUMBER TO-39 CASE MAXIMUM RATINGS: (TC=25°C) Collector-Base Voltage Collector-Emitter Voltage Collector-Emitter Voltage Emitter-Base Voltage Continuous Collector Current Continuous Base Current Power Dissipation Operating and Storage Junction Temperature Thermal Resistance Thermal Resistance SYMBOL VCBO VCEV VCEO VEBO IC IB PD TJ, Tstg ΘJA ΘJC 2N5320 2N5322 100 100 75 6.0 ELECTRICAL CHARACTERISTICS: (TC=25°C unless otherwise noted) 2N5320 2N5322 SYMBOL TEST CONDITIONS MIN MAX ICBO VCB=80V 0.5 ICBO VCB=60V IEBO VEB=5.0V 0.1 IEBO VEB=4.0V BVCEV IC=100μA, VBE=1.5V 100 BVCEO IC=10mA 75 BVEBO IE=100μA 6.0 VCE(SAT) IC=500mA, IB=50mA (2N5320) 0.5 VCE(SAT) IC=500mA, IB=50mA (2N5321) VCE(SAT) IC=500mA, IB=50mA (2N5322) 0.7 VCE(SAT) IC=500mA, IB=50mA (2N5323) VBE(ON) VCE=4.0V, IC=500mA 1.1 hFE VCE=4.0V, IC=500mA 30 175 hFE VCE=2.0V, IC=1.0A 10 fT VCE=4.0V, IC=50mA, f=10MHz 50 - 2N5321 2N5323 75 75 50 5.0 2.0 1.0 10 -65 to +200 175 17.5 2N5321 2N5323 MIN MAX 5.0 0.5 75 50 5.0 0.8 40 50 1.2 1.4 250 - UNITS V V V V A A W °C °C/W °C/W UNITS μA μA μA μA V V V V V V V V MHz R5 (11-May 2017) 2N5320 2N5321 2N5322 2N5323 NPN PNP COMPLEMENTARY SILICON SWITCHING TRANSISTORS ELECTRICAL SYMBOL ton ton toff toff CHARACTERISTICS TEST CONDITIONS VCC=30V, IC=500mA, VCC=30V, IC=500mA, VCC=30V, IC=500mA, VCC=30V, IC=500mA, Continued: (TC=25°C unless otherwise noted) IB1=50mA (2N5320, 2N5321) IB1=50mA (2N5322, 2N5323) IB1=IB2=50mA (2N5320, 2N5321) IB1=IB2=50mA (2N5322, 2N5323) MAX 80 100 800 1.0 UNITS ns ns ns μs TO-39 CASE - MECHANICAL OUTLINE LEAD CODE: 1) Emitter 2) Base 3) Collector MARKING: FULL PART NUMBER R5 (11-May 2017) w w w. c e n t r a l s e m i . c o m OUTSTANDING SUPPORT AND SUPERIOR SERVICES PRODUCT SUPPORT Central’s operations team provides the highest level of support to insure product is delivered on-time. • Supply management (Customer portals) • Custom bar coding for shipments • Inventory bonding • Custom product packing • Consolidated shipping options DESIGNER SUPPORT/SERVICES Central’s applications engineering team is ready to discuss your design challenges. Just ask. • Free quick ship samples (2nd day air) • Special wafer diffusions • Online technical data and parametric search • PbSn plating options • SPICE models • Package details • Custom electrical curves • Application notes • Environmental regulation compliance • Application and design sample kits • Customer specific screening • Custom product and package development • Up-screening capabilities REQUESTING PRODUCT PLATING 1. If requesting Tin/Lead plated devices, add the suffix “ TIN/LEAD” to the part number when ordering (example: 2N2222A TIN/LEAD). 2. If requesting Lead (Pb) Free plated devices, add the suffix “ PBFREE” to the part number when ordering (example: 2N2222A PBFREE). CONTACT US Corporate Headquarters & Customer Support Team Central Semiconductor Corp. 145 Adams Avenue Hauppauge, NY 11788 USA Main Tel: (631) 435-1110 Main Fax: (631) 435-1824 Support Team Fax: (631) 435-3388 www.centralsemi.com Worldwide Field Representatives: www.centralsemi.com/wwreps Worldwide Distributors: www.centralsemi.com/wwdistributors For the latest version of Central Semiconductor’s LIMITATIONS AND DAMAGES DISCLAIMER, which is part of Central’s Standard Terms and Conditions of sale, visit: www.centralsemi.com/terms w w w. c e n t r a l s e m i . c o m (001)
2N5323 价格&库存
很抱歉,暂时无法提供与“2N5323”相匹配的价格&库存,您可以联系我们找货
