BC856A RFG
BC856A RFG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOT-23
    BC856A RFG
BC856A RFG 数据手册
BC856A SERIES Taiwan Semiconductor Small Signal Product 200mW, PNP Small Signal Transistor FEATURES - Epitaxial planar die construction - Surface device type mounting - Moisture sensitivity level 1 - Matte Tin(Sn) lead finish with Nickel(Ni) underplate - Pb free and RoHS compliant - Green compound (Halogen free) with suffix "G" on packing code and prefix "G" on date code MECHANICAL DATA - Case : SOT- 23 small outline plastic package - Terminal : Matte tin plated, lead free, solderable per MIL-STD-202, method 208 guaranteed - High temperature soldering guaranteed : 260°C/10s SOT-23 - Weight : 0.008 grams (approximately) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) PARAMETER Power Dissipation SYMBOL VALUE UNIT PD 200 mW BC856 Collector-Base Voltage -80 VCBO BC857 -50 BC858 -30 BC856 Collector-Emitter Voltage -65 VCEO BC857 -45 BC858 Collector Current Junction and Storage Temperature Range PARAMETER VEBO -5 V IC -0.1 A TJ , TSTG -55 to + 150 °C SYMBOL BC856 BC857 IC= -10μA IE = 0 V(BR)CBO BC858 BC856 Collector-Emitter Breakdown Voltage BC857 IC= -10mA IB = 0 V(BR)CEO BC858 IE= -1μA Emitter-Base Breakdown Voltage Collector Cut-off Current BC856 VCB= -70V BC857 VCB= -45V BC858 VCB= -25V VEB= -5V Emitter Cut-off Current IC= 0 IE = 0 IC=0 V(BR)EBO ICBO IEBO BC856A, BC857A, BC858A DC Current Gain BC856B, BC857B, BC858B VCE= -5V V -30 Emitter-Base Voltage Collector-Base Breakdown Voltage V IC= -2mA hFE BC857C, BC858C MIN MAX -80 - -50 - -30 - UNIT V -65 - -45 - -30 - -5 - - -100 - -100 - -100 V V - -0.1 125 250 220 475 420 800 nA μA Collector-Emitter Saturation Voltage IC= -100mA IB= -5mA VCE(sat) - -0.65 Base-Emitter Saturation Voltage IC= -100mA IB= -5mA VBE(sat) - -1.1 V IC= -10mA f= 100MHz fT 100 - MHz Transition Frequency VCE= -5V V Version : H1606 BC856A SERIES Taiwan Semiconductor Small Signal Product RATINGS AND CHARACTERISTIC CURVES (TA=25°C unless otherwise noted) Fig. 2 DC Current Gain Fig. 1 Static Characteristic 1000 50 45 IB = -400μA IB = -300μA 35 30 IB = -250μA 25 IB =- 200μA 20 hFE, DC Current Gain IC[mA], Collector Current VCE = - 5V IB = -350μA 40 IB = -150μA 15 IB = -100μA 10 5 IB = -50μA 0 0 2 4 6 8 10 12 14 16 100 10 18 -0.1 20 -1.0 Fig.3 Base-Emitter Saturation Voltage VS.Collector-Emitter Saturation 3 -100. 4 IC = 10 IB IC[mA], Collector Current VCE = - 5V VBE(sat) 1 VCE(sat) 0.1 5 -10. 1 -1. -0. 0.01 0.1 1 10 -0.0 100 -0.2 -0.4 -0.6 -0.8 -1.0 -1.2 VBE[V], Base-Emitter Voltage IC[mA], Collector Current Fig. 6 Current Gain Bandwidth Product Fig.5 Collector Output Capacitance f=1MHz IE=0 10 1 -1. -10. -100. -1000. fT[MHz], Current Gain-Bandwidth Product 1000 100 1 2 Fig. 4 Base-Emitter On Voltage 10 VBE(sat), VCE(sat)[V], Saturation Voltage -100.0 IC[mA], Collector Current VCE[V], Collector-Emitter Voltage Cob[pF], Capacitance -10.0 f=1MHz IE=0 100 10 1 -0. -1. -10. -100. IC[mA], Collector Current VCB[V], Collector-Base Voltage Version : H1606 BC856A SERIES Taiwan Semiconductor Small Signal Product RATINGS AND CHARACTERISTIC CURVES (TA=25°C unless otherwise noted) Fig. 7 DC Current Gain as a Function of Collector Current; Typical Values Fig. 8 Base-Emitter Voltage as a Function of Collector Current; Typical Values hFE - IC 500 VBE - IC 1200 hFE 450 BC857A: VCE=5V 400 350 BC857A: VCE=-5V 1000 Ta=55OC 800 Ta=150OC 300 VBE 250 600 Ta=25OC 200 150 100 200 50 0 1 Ta=25OC 400 Ta=55OC 2 Ta=150OC 0 0.01 0.1 1 10 100 1000 -IC(mA) 0.01 0.1 1 10 100 1000 3 -IC(mA) 4 5 1 Version : H1606 BC856A SERIES Taiwan Semiconductor Small Signal Product Ordering information Part No. Packing Packing code code suffix(*) BC85xx RF (Note 1) Note 1 : "xx" is Device Code from "6A" thru "8C". G Package Packing SOT-23 3K / 7 " Reel *: optional available Example Preferred Part No. BC856A RFG Part No. BC856A Packing Packing code code suffix RF G Description Green compound Version : H1606 BC856A SERIES Taiwan Semiconductor Small Signal Product Dimensions DIM. Unit(mm) Unit(inch) Min Max Min Max A 2.70 3.10 0.106 0.122 B 1.10 1.50 0.043 0.059 C 0.30 0.51 0.012 0.020 D 1.78 2.04 0.070 0.080 E 2.20 2.60 0.087 0.102 F G 0.90 1.30 0.550 REF 0.035 0.051 0.022 REF H 0.1 REF 0.004 REF Unit(mm) Unit(inch) Suggested PAD Layout DIM. Typ. Typ. A 0.95 0.037 B 2.0 0.079 C 0.9 0.035 D 0.8 0.031 Marking Part No. Marking BC856A 3A BC856B BC857A 3B 3E BC857B 3F BC857C 3G BC858A 3J BC858B 3K BC858C 3L Version : H1606 BC856A SERIES Taiwan Semiconductor Small Signal Product Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied,to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or seling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Version : H1606
BC856A RFG 价格&库存
很抱歉,暂时无法提供与“BC856A RFG”相匹配的价格&库存,您可以联系我们找货
BC856A RFG
  • 1+1.502011+0.19469
  • 10+0.9342310+0.12110
  • 100+0.57354100+0.07434
  • 500+0.41616500+0.05395
  • 1000+0.365061000+0.04732
库存:6671
BC856A RFG
  • 3000+0.299763000+0.03886
  • 6000+0.266746000+0.03458
  • 9000+0.249889000+0.03239
  • 15000+0.2309115000+0.02993
  • 21000+0.2196621000+0.02848
  • 30000+0.2087230000+0.02706
库存:6671
