1SMC5352 M6G
1SMC5352 M6G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO214AB
    DIODE ZENER 15V 5W DO214AB
1SMC5352 M6G 数据手册
1SMC5352 Taiwan Semiconductor 5W, 15V Surface Mount Zener Diode FEATURES ● ● ● ● ● KEY PARAMETERS Ideal for automated placement Glass passivated chip junction Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● For general purpose regulation and protection applications PARAMETER VALUE UNIT VZ 15 V PD 5 W TJ MAX 150 °C Package DO-214AB (SMC) Configuration Single die MECHANICAL DATA ● ● ● ● ● ● Case:DO-214AB (SMC) Molding compound meets UL 94V-0 flammability rating Terminal:Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity:Indicated by cathode band Weight:0.260g (approximately) DO-214AB (SMC) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL VALUE UNIT Steady state power dissipation at TL = 75°C PD 5 W Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C Maximum ratings are those values beyond which device damage can occur. Maximum ratings applied to the device are individual stress limit values (not normal operating conditions) and are not valid simultaneously. If these limits are exceeded, device functional operation is not implied, damage may occur and reliability may be attached. THERMAL PERFORMANCE PARAMETER Junction-to-ambient thermal resistance 1 SYMBOL TYP UNIT RӨJA 55 °C/W Version: G2102 1SMC5352 Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) Part number (Note 1) 1SMC5352 Marking code 352B Regulator Voltage (Note 2) Test Current VZ@IZ IZ ZZ IR VR IZM Maximum Dynamic Knee Impedance ZZK@1mA V mA Ω μA V mA Ω 15 75 2.5 1.0 11.5 315 75 Maximum Maximum I Test Dynamic Reverse R Voltage Impedance Current Maximum Regulator Current Notes: 1. Tolerance and voltage regulation designation. The type number listed indicates a tolerance of 5%. 2. Zener voltage (VZ) measurement Nominal Zener voltage is measured with the device junction in thermal equilibrium with ambient temperature 25°C ORDERING INFORMATION ORDERING CODE PACKAGE PACKING 1SMC5352 DO-214AB (SMC) 3,000 / Tape & Reel 2 Version: G2102 1SMC5352 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Effect Of Zener Current Fig.2 Steady State Power Derating PD, MAXIMUM POWER DISSIPATION (W) 100 10 1 1 10 7 6 5 4 3 2 1 0 0 100 IZ. ZENER TEST CURRENT (mA) 25 50 75 100 125 150 LEAD TEMPERATURE (°C) Fig.3 Typical Junction Capacitance 1000 CJ, CAPACITANCE (pF) Zz, DYNAMIC IMPEDANCE (Ω) 1000 100 0 1 10 100 BREAKDOWN VOLTAGE (V) 3 Version: G2102 1SMC5352 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AB (SMC) SUGGESTED PAD LAYOUT MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: G2102 1SMC5352 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: G2102
1SMC5352 M6G 价格&库存
很抱歉,暂时无法提供与“1SMC5352 M6G”相匹配的价格&库存,您可以联系我们找货
