1PGSMB5926 – 1PGSMB5956
Taiwan Semiconductor
3W, 11V - 200V Surface Mount Zener Diode
FEATURES
KEY PARAMETERS
Photo Glass passivated chip junction
Ideal for automated placement
Low inductance
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VZ
11 - 200
V
Test current IZT
1.9 - 34.1
mA
Ptot
3
W
TJ MAX
175
°C
Package
DO-214AA (SMB)
Configuration
Single die
APPLICATIONS
Switching mode power supply (SMPS)
Adapters
Lighting application
On-board DC/DC converter
MECHANICAL DATA
Case: DO-214AA (SMB)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.100g (approximately)
DO-214AA (SMB)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
DC power dissipation at TL=75°C, measure at
zero lead length (Note 1) derate above 75°C
SYMBOL
VALUE
UNIT
Ptot
3
W
TJ
-55 to +175
°C
TSTG
-55 to +175
°C
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
21
°C/W
Junction-to-ambient thermal resistance
RӨJA
59
°C/W
Junction-to-case thermal resistance
RӨJC
23
°C/W
Junction temperature
Storage temperature
Notes:
1. Mounted on Cu-Pad size 10mm x 10mm on PCB
THERMAL PERFORMANCE
PARAMETER
Thermal Performance Note: Units mounted on PCB (10mm x 10mm Cu pad test board)
1
Version: C2102
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
Device
(Note 1)
Device
Marking
Code
Nominal Zener
Voltage
Min
Test Zener Impedance
(Note 3)
current
Vz@Iz
IZT
ZZT @ IZT
V
Nom
(Note 2)
mA
Ω
ZZK@IZK
Ω
mA
Leakage
Current
Maximum
DC
Zener
Current
IR@VR
IZM
μA
V
mA(DC)
Max
1PGSMB5926 P926B
10.45
11
11.55
34.1
5.5
550 0.25
1
8.4
136
1PGSMB5927 P927B
11.40
12
12.60
31.2
6.5
550 0.25
1
9.1
125
1PGSMB5928 P928B
12.35
13
13.65
28.8
7.0
550 0.25
1
9.9
115
1PGSMB5929 P929B
14.25
15
15.75
25.0
9.0
600 0.25
1
11.4
100
1PGSMB5930 P930B
15.20
16
16.80
23.4
10.0
600 0.25
1
12.2
94
1PGSMB5931 P931B
17.10
18
18.90
20.8
12.0
650 0.25
1
13.7
83
1PGSMB5932 P932B
19.00
18.7
14.0
650 0.25
1
15.2
75
1PGSMB5933 P933B
20.90
22
23.10
17.0
17.5
650 0.25
1
16.7
68
1PGSMB5934 P934B
22.80
24
25.20
15.6
19
700 0.25
1
18.2
63
1PGSMB5935 P935B
25.65
27
28.35
13.9
23
700 0.25
1
20.6
56
1PGSMB5936 P936B
28.50
30
31.50
12.5
26
750 0.25
1
22.8
50
1PGSMB5937 P937B
31.35
33
34.65
11.4
33
800 0.25
1
25.1
45
1PGSMB5938 P938B
34.20
36
37.80
10.4
38
850 0.25
1
27.4
42
1PGSMB5939 P939B
37.05
39
40.95
9.6
45
900 0.25
1
29.7
38
1PGSMB5940 P940B
40.85
43
45.15
8.7
53
950 0.25
1
32.7
35
1PGSMB5941 P941B
44.65
47
49.35
8.0
67
1000 0.25
1
35.8
32
1PGSMB5942 P942B
48.45
51
53.55
7.3
70
1100 0.25
1
38.8
29
1PGSMB5943 P943B
53.20
56
58.80
6.7
86
1300 0.25
1
42.6
27
1PGSMB5944 P944B
58.90
62
65.10
6.0
100
1500 0.25
1
47.1
24
1PGSMB5945 P945B
64.60
68
71.40
5.5
120
1700 0.25
1
51.7
22
1PGSMB5946 P946B
71.25
75
78.75
5.0
140
2000 0.25
1
56.0
1PGSMB5947 P947B
77.90
82
86.10
4.6
160
2500 0.25
1
62.2
18
1PGSMB5948 P948B
86.45
91
95.55
4.1
200
3000 0.25
1
69.2
16
1PGSMB5949 P949B
95.00
100 105.00
3.7
250
3100 0.25
1
76.0
15
1PGSMB5950 P950B 104.50 110 115.50
3.4
300
4000 0.25
1
83.6
13
1PGSMB5951 P951B 114.00 120 126.00
3.1
360
4500 0.25
1
91.2
12
1PGSMB5952 P952B 123.50 130 136.50
2.9
450
5000 0.25
1
98.8
11
1PGSMB5953 P953B 142.50 150 157.50
2.5
600
6000 0.25
1
114.0
10
1PGSMB5954 P954B 152.00 160 168.00
2.3
700
6500 0.25
1
121.6
9
1PGSMB5955 P955B 171.00 180 189.00
2.1
900
7000 0.25
1
136.8
8
1PGSMB5956 P956B 190.00 200 210.00
1.9
1200 8000 0.25
1
152.0
7
Notes:
1. Tolerance and type number designation the type numbers listed indicate a tolerance of 5%
2. Zener voltage (Vz) measurement Nominal Zener voltage is measured with the device junction in thermal
equilibrium with ambient temperature 25°C
3. Zener impedance (Zz) derivation : ZZT and ZZK are measured by dividing the AC voltage drop across the device
by the AC current applied.
4. The specified limits are for Iz (AC) = 0.1 Iz (DC) with the AC frequency = 60Hz
2
Version: C2102
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
1PGSMB59x
DO-214AA (SMB)
3,000 / Tape & Reel
Notes:
1. "x" defines voltage from 11V(1PGSMB5926) to 200V(1PGSMB5956)
3
Version: C2102
CHARACTERISTICS CURVES
Fig.1 Steady State Power Derating
Fig.2 Typical Junction Capacitance
1000
1PGSMB5927
3
CAPACITANCE (pF)
TOTAL POWER DISSIPATION (W)
4
2
1
100
1PGSMB5939
1PGSMB5945
10
f=1.0MHz
Vsig=50mVp-p
25
50
75
100
125
150
175
1
10
100
REVERSE VOLTAGE (V)
LEAD TEMPERATURE (°C)
Fig.3 Typical Zener Impedance
Zz - DYNAMIC IMPEDANCE (Ω)
10000
1000
100
1PGSMB5945
10
1PGSMB5939
1PGSMB5927
1
0.1
1
10
100
Iz - ZENER TEST CURRENT (mA)
4
Version: C2102
PACKAGE OUTLINE DIMENSIONS
DO-214AA (SMB)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: C2102
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for
application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to any
intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for
such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale
and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability,
or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers
using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for
any damages resulting from such improper use or sale.
6
Version: C2102
很抱歉,暂时无法提供与“1PGSMB5929HR5G”相匹配的价格&库存,您可以联系我们找货
