BZT52C2V4 - BZT52C75
Taiwan Semiconductor
500mW, 5% Tolerance SMD Zener Diodes
FEATURES
KEY PARAMETERS
Wide zener voltage range selection: 2.4V to 75V
VZ tolerance selection of ± 5%
Surface mounting device (SMD) type
Moisture sensitivity level: level 1, per J-STD-020
Compliant to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VZ
2.4-75
V
Test current IZT
5
mA
PD
500
mW
VF at IF=10mA
1
V
TJ Max.
150
°C
Package
SOD-123F
Configuration
Single die
APPLICATIONS
● Low voltage stabilizers or voltage references
● Adapters
● On-board DC/DC converter
MECHANICAL DATA
Case: SOD-123F
Molding compound meets UL 94 V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Polarity: Indicated by cathode band
Weight: 8.85 ± 0.5mg (approximately)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage @ IF=10mA
SYMBOL
VALUE
UNIT
VF
1
V
Power dissipation
PD
500
mW
Junction temperature range
TJ
-65 to +150
°C
Storage temperature range
TSTG
-65 to +150
°C
SYMBOL
TYP
UNIT
RӨJA
350
°C/W
THERMAL PERFORMANCE
PARAMETER
Junction-to-ambient thermal resistance
1
Version: G1804
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
ZENER VOLTAGE
PART
MARKING
NUMBER
CODE
TEST
REGULAR
TEST
LEAKAGE
CURRENT
IMPEDANCE
CURRENT
CURRENT
IR @ V R
VZ @ IZT
IZT
ZZT @ IZT
ZZK @ IZK
IZK
V
mA
Ω
Ω
mA
µA
V
Min.
Nom.
Max.
Max.
Max.
BZT52C2V4
2V4Z
2.28
2.40
2.52
5
100
564
1
45
1.0
BZT52C2V7
2V7Z
2.57
2.70
2.84
5
100
564
1
18
1.0
BZT52C3V0
3V0Z
2.85
3.00
3.15
5
100
564
1
9
1.0
BZT52C3V3
3V3Z
3.14
3.30
3.47
5
95
564
1
4.5
1.0
BZT52C3V6
3V6Z
3.42
3.60
3.78
5
90
564
1
4.5
1.0
BZT52C3V9
3V9Z
3.71
3.90
4.10
5
90
564
1
2.7
1.0
BZT52C4V3
4V3Z
4.09
4.30
4.52
5
90
564
1
2.7
1.0
BZT52C4V7
4V7Z
4.47
4.70
4.94
5
80
470
1
2.7
2.0
BZT52C5V1
5V1Z
4.85
5.10
5.36
5
60
451
1
1.8
2.0
BZT52C5V6
5V6Z
5.32
5.60
5.88
5
40
376
1
0.9
2.0
BZT52C6V2
6V2Z
5.89
6.20
6.51
5
10
141
1
2.7
4.0
BZT52C6V8
6V8Z
6.46
6.80
7.14
5
15
75
1
1.8
4.0
BZT52C7V5
7V5Z
7.11
7.50
7.86
5
15
75
1
0.9
5.0
BZT52C8V2
8V2Z
7.79
8.20
8.61
5
15
75
1
0.63
5.0
BZT52C9V1
9V1Z
8.65
9.10
9.56
5
15
94
1
0.45
6.0
BZT52C10
10VZ
9.50
10.00
10.50
5
1
0.18
7.0
BZT52C11
11VZ
10.45
11.00
11.55
5
1
0.09
8.0
BZT52C12
12VZ
11.40
12.00
12.60
5
25
141
1
0.09
8.0
BZT52C13
13VZ
12.35
13.00
13.65
5
30
160
1
0.09
8.0
BZT52C15
15VZ
14.25
15.00
15.75
5
30
188
1
0.045
10.5
BZT52C16
16VZ
15.20
16.00
16.80
5
40
188
1
0.045
11.2
BZT52C18
18VZ
17.10
18.00
18.90
5
45
212
1
0.045
12.6
BZT52C20
20VZ
19.00
20.00
21.00
5
55
212
1
0.045
14.0
BZT52C22
22VZ
20.90
22.00
23.10
5
55
235
1
0.045
15.4
BZT52C24
24VZ
22.80
24.00
25.20
5
70
235
1
0.045
16.8
BZT52C27
27VZ
25.65
27.00
28.35
2
80
282
0.5
0.045
18.9
BZT52C30
30VZ
28.50
30.00
31.50
2
80
282
0.5
0.045
21.0
BZT52C33
33VZ
31.35
33.00
34.65
2
80
306
0.5
0.045
23.0
BZT52C36
36VZ
34.20
36.00
37.80
2
90
329
0.5
0.045
25.2
BZT52C39
39VZ
37.05
39.00
40.95
2
130
329
0.5
0.045
27.3
BZT52C43
43VZ
40.85
43.00
45.15
2
150
353
0.5
0.045
30.1
BZT52C47
47VZ
44.65
47.00
49.35
2
170
353
0.5
0.045
33.0
BZT52C51
51VZ
48.45
51.00
53.55
2
180
376
0.5
0.045
35.7
BZT52C56
56VZ
53.20
56.00
58.80
2
200
400
0.5
0.045
39.2
BZT52C62
62VZ
58.90
62.00
65.10
2
215
423
0.5
0.045
43.4
BZT52C68
68VZ
64.60
68.00
71.40
2
240
447
0.5
0.045
47.6
BZT52C75
75VZ
71.25
75.00
78.75
2
255
470
0.5
0.045
52.5
2
Max.
Version: G1804
Notes:
1. The zener voltage (VZ) is tested under pulse condition of 30ms.
2. The device numbers listed have a standard tolerance on the normal zener voltage of ±5%.
3. For detailed information on price, availability and delivery of normal zener voltages between the voltages
shown and tighter voltage tolerances, contact your nearest Taiwan Semiconductor representative.
4. The zener impedance is derived from the 60-cycle ac voltage, which results when an ac current
having a rms value equal to 10% of the DC zener current(IZT or IZK) is superimposed to IZT or IZK.
ORDERING INFORMATION
PART NO.
(Note 1)
PACKAGE
PACKING
BZT52Cxxx RHG
SOD-123F
3K / 7" Reel
BZT52Cxxx RH
SOD-123F
3K / 7" Reel
Note:
1. "xxx" defines voltage from 2.4V (BZT52C2V4) to 75V (BZT52C75)
3
Version: G1804
CHARACTERISTICS CURVES
Fig.1 Typical Forward Characteristics
Fig. 2 Zener Breakdown Characteristics
100
TA=25oC
100
10
TA=25oC
10
Zener Current (mA)
Forward Current (mA)
1000
1
0.1
0.01
1
0.4
0.5
0.6
0.7
0.8
0.9
1.0
1.1
1
2
3
4
5
6
7
8
9
10 11 12
Zener Voltage (V)
Forward Voltage (V)
Fig. 3 Zener Breakdown Characteristics
Fig.4 Power Dissipation Curve
100
700
Power Dissipation (mW)
Zener Current (mA)
600
10
1
0.1
500
400
300
200
100
0.01
25
35
45
55
65
75
50
100
150
200
o
Ambient Temperature ( C)
Zener Voltage (V)
4
Version: G1804
Fig.5 Typical Capacitance
Fig.6 Effect of Zener Voltage on Impedence
1000
1000
Dynamic Impedence(Ohm)
Capacitance (pF)
IZ=1mA
1V Bias
100
Bias at 50% of
VZ (Nom)
10
IZ=5mA
100
IZ=20mA
10
1
1
1
10
Zener Voltage (V)
1
100
10
100
Zener Voltage (V)
5
Version: G1804
PACKAGE OUTLINE DIMENSION
SOD-123F
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
1.50
1.70
0.059
0.067
B
3.30
3.90
0.130
0.154
C
0.50
0.70
0.020
0.028
D
2.50
2.70
0.098
0.106
E
0.80
1.15
0.031
0.045
F
0.05
0.20
0.002
0.008
SUGGEST PAD LAYOUT
Unit (mm)
Unit (inch)
Min
Min
C
2.86
0.113
G
1.52
0.060
X
1.34
0.053
X1
4.20
0.165
Y
1.80
0.071
DIM.
6
Version: G1804
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: G1804
很抱歉,暂时无法提供与“BZT52C33 RHG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1.942911+0.25238
- 10+1.1742910+0.15254
- 50+0.8350350+0.10847
- 100+0.72475100+0.09414
- 500+0.52792500+0.06858
- 国内价格 香港价格
- 10+0.4784710+0.06215
- 100+0.35059100+0.04554
- 250+0.31231250+0.04057
- 国内价格
- 10+0.44678
- 100+0.32544
- 250+0.28891
- 国内价格 香港价格
- 3000+0.360783000+0.04687
- 9000+0.302029000+0.03923
