MTZJ15SC R0G
MTZJ15SC R0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-204AG
    DIODE ZENER 14.72V 500MW DO34
MTZJ15SC R0G 数据手册
MTZJ2V0SA - MTZJ56S Taiwan Semiconductor 500mW, 2V-56V Zener Diodes FEATURES KEY PARAMETERS ● Wide zener voltage range selection: 2.0V to 56V ● Hermetically sealed glasss ● Compliant to RoHS directive 2011/65/EU and in accordance to WEEE 2002/96/EC PARAMETER VALUE UNIT VZ 2.0 - 56 V Test current IZT 5 mA PD 500 mW TJ MAX 175 °C APPLICATIONS ● ● ● ● Low voltage stabilizers or voltage references Adapters Lighting application On-board DC/DC converter Package DO-34 Configuration Single die MECHANICAL DATA ● ● ● ● Case: DO-34 Terminal: Matte tin plated leads, solderable per J-STD-002 Polarity: Indicated by cathode band Weight: 92 mg (approximately) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Power dissipation Junction temperature range Storage temperature SYMBOL PD TJ TSTG 1 VALUE 500 -55 to +175 -55 to +175 UNIT mW °C °C Version: C1804 MTZJ2V0SA - MTZJ56S Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) ZENER VOLTAGE MARKING PART NUMBER MTZJ2V0S MTZJ2V2S MTZJ2V4S MTZJ2V7S MTZJ3V0S MTZJ3V3S MTZJ3V6S MTZJ3V9S MTZJ4V3S MTZJ4V7S MTZJ5V1S MTZJ5V6S MTZJ6V2S MTZJ6V8S MTZJ7V5S MTZJ8V2S MTZJ9V1S MTZJ10S MTZJ11S MTZJ12S MTZJ13S MTZJ15S MTZJ16S A B A B A B A B A B A B A B A B A B C A B C A B C A B C A B C A B C A B C A B C A B C A B C D A B C A B C A B C A B C A B C CODE 2V0A 2V0B 2V2A 2V2B 2V4A 2V4B 2V7A 2V7B 3V0A 3V0B 3V3A 3V3B 3V6A 3V6B 3V9A 3V9B 4V3A 4V3B 4V3C 4V7A 4V7B 4V7C 5V1A 5V1B 5V1C 5V6A 5V6B 5V6C 6V2A 6V2B 6V2C 6V8A 6V8B 6V8C 7V5A 7V5B 7V5C 8V2A 8V2B 8V2C 9V1A 9V1B 9V1C 10A 10B 10C 10D 11A 11B 11C 12A 12B 12C 13A 13B 13C 15A 15B 15C 16A 16B 16C Min. 1.88 2.02 2.12 2.22 2.33 2.43 2.54 2.69 2.85 3.01 3.16 3.32 3.45 3.60 3.74 3.89 4.04 4.17 4.30 4.44 4.55 4.68 4.81 4.94 5.09 5.28 5.45 5.61 5.78 5.96 6.12 6.29 6.49 6.66 6.85 7.07 7.29 7.53 7.78 8.03 8.29 8.57 8.83 9.12 9.41 9.70 9.97 10.18 10.50 10.82 11.13 11.44 11.74 12.11 12.55 12.99 13.44 13.89 14.35 14.80 15.25 15.69 TEST REGULAR TEST CURRENT IMPEDANCE CURRENT LEAKAGE CURRENT IZK IR @ V R VZ @ IZT IZT V mA Nom. 1.99 2.11 2.21 2.32 2.43 2.53 2.65 2.80 2.96 3.12 3.27 3.43 3.58 3.72 3.88 4.03 4.17 4.30 4.44 4.56 4.68 4.81 4.94 5.07 5.23 5.42 5.59 5.76 5.94 6.12 6.28 6.46 6.66 6.84 7.04 7.26 7.48 7.73 7.99 8.24 8.51 8.79 9.07 9.36 9.66 9.95 10.21 10.45 10.78 11.10 11.42 11.74 12.05 12.43 12.88 13.33 13.79 14.26 14.72 15.19 15.65 16.10 Max. 2.10 2.20 2.30 2.41 2.52 2.63 2.75 2.91 3.07 3.22 3.38 3.53 3.695 3.845 4.01 4.16 4.29 4.43 4.57 4.68 4.80 4.93 5.07 5.20 5.37 5.55 5.73 5.91 6.09 6.27 6.44 6.63 6.83 7.01 7.22 7.45 7.67 7.92 8.19 8.45 8.73 9.01 9.30 9.59 9.90 10.20 10.44 10.71 11.05 11.38 11.71 12.03 12.35 12.75 13.21 13.66 14.13 14.62 15.09 15.57 16.04 16.51 ZZT @ IZT ZZK @ IZK Ω Ω Max. Max. mA μA V Max. 5 100 1000 0.5 120 0.5 5 100 1000 0.5 120 0.7 5 100 1000 0.5 120 1.0 5 110 1000 0.5 100 1.0 5 120 1000 0.5 50 1.0 5 120 1000 0.5 20 1.0 5 100 1000 1.0 10 1.0 5 100 1000 1.0 5 1.0 5 100 1000 1.0 5 1.0 5 80 900 0.5 5 1.0 5 80 1200 0.5 5 1.5 5 60 900 0.5 5 2.5 5 60 500 0.5 5 3.0 5 20 150 0.5 2 3.5 5 20 120 0.5 0.5 4.0 5 20 120 0.5 0.5 5.0 5 25 120 0.5 0.5 6.0 5 30 120 0.5 0.2 7 5 30 120 0.5 0.2 8 5 30 110 0.5 0.2 9 5 35 110 0.5 0.2 10 5 40 110 0.5 0.2 11 5 40 150 0.5 0.2 12 2 Version: C1804 MTZJ2V0SA - MTZJ56S Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) MTZJ18S MTZJ20S MTZJ22S MTZJ24S MTZJ27S MTZJ30S MTZJ33S MTZJ36S MTZJ39S MTZJ43S MTZJ47S MTZJ51S MTZJ56S A B C A B C D A B C D A B C D A B C D A B C D A B C D A B C D A B C D E F G CODE 18A 18B 18C 20A 20B 20C 20D 22A 22B 22C 22D 24A 24B 24C 24D 27A 27B 27C 27D 30A 30B 30C 30D 33A 33B 33C 33D 36A 36B 36C 36D 39A 39B 39C 39D 39E 39F 39G 43S 47S 51S 56S Min. 16.22 16.82 17.42 18.02 18.63 19.23 19.72 20.15 20.64 21.08 21.52 22.05 22.61 23.12 23.63 24.26 24.97 25.63 26.29 26.99 27.70 28.36 29.02 29.68 30.32 30.90 31.49 32.14 32.79 33.40 34.01 34.68 35.36 36.00 36.63 37.36 38.14 38.94 40.00 44.00 48.00 53.00 REGULAR TEST IMPEDANCE CURRENT VZ @ IZT IZT ZZT @ IZT ZZK @ IZK IZK IR @ V R V mA Ω Ω mA Max. Max. 5 45 150 0.5 0.2 13 5 55 200 0.5 0.2 15 5 30 200 0.5 0.2 17 5 35 200 0.5 0.2 19 5 45 250 0.5 0.2 21 5 55 250 0.5 0.2 23 5 65 250 0.5 0.2 25 5 75 250 0.5 0.2 27 5 85 250 0.5 0.2 30 5 90 90 110 110 250 250 250 250 0.5 0.5 0.5 0.5 0.2 0.2 0.2 0.2 33 36 39 43 CURRENT MARKING PART NUMBER TEST LEAKAGE CURRENT ZENER VOLTAGE Nom. 16.64 17.26 17.88 18.49 19.11 19.73 20.22 20.68 21.18 21.63 22.08 22.62 23.19 23.72 24.24 24.89 25.62 26.29 26.97 27.69 28.42 29.09 29.77 30.45 31.10 31.70 32.30 32.97 33.64 34.27 34.89 35.58 36.28 36.93 37.58 38.33 39.13 39.87 42.50 46.50 51.00 56.50 Max. 17.06 17.70 18.33 18.96 19.59 20.22 20.72 21.2 21.71 22.17 22.63 23.18 23.77 24.31 24.85 25.52 26.26 26.95 27.64 28.39 29.13 29.82 30.51 31.22 31.88 32.50 33.11 33.79 34.49 35.13 35.77 36.47 37.19 37.85 38.52 39.29 40.11 40.80 45.00 49.00 54.00 60.00 μA V Max. Notes: 1. The zener voltage subdivision (VZ) is measured 30ms after diode is powered up 2. The operating resistance (ZZT or ZZK) is measured by superimposing a minute alternation current in the regulated current (IZ) 3. When ordering, please specify tolerance A, B, C, D, E, F, G 3 Version: C1804 MTZJ2V0SA - MTZJ56S Taiwan Semiconductor ORDERING INFORMATION ORDERING CODE (Note 1, 2) PACKAGE PACKING MTZJxxxSx R0 DO-34 10K / 14" Reel MTZJxxxSx R0G DO-34 10K / 14" Reel MTZJxxxSx A0 DO-34 5K / Box (Ammo) MTZJxxxSx A0G DO-34 5K / Box (Ammo) Note: 1. "xxx" defines voltage from 2.0V (MTZJ2V0SA) to 56V (MTZJ56S) 2. “G” means green compound (Halogen free) 4 Version: C1804 MTZJ2V0SA - MTZJ56S Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig. 1 VZ - IZ Characteristics 10 8.2 7.5 6.8 1 22 24 30 27 36 33 39 Zener Current, IZ (mA) 6.2 20 18 16 15 13 12 11 10 9.1 5.6 0.1 5.1 4.7 4.3 0.01 3.9 3.6 0.001 0 2 4 6 8 10 12 14 16 18 20 22 24 Zener Voltage, VZ (V) 28 30 32 34 36 38 40 Fig. 3 rz - VZ Characteristics Fig. 2 PD - TA Characteristics 0.10 Temp. Coefficient : rz (%/ oC) 600 Power Dissipation : PD (mW) 26 500 400 300 200 Iz = 5 mA 0.08 Iz = 10 mA 0.06 0.04 0.02 0.00 -0.02 Iz = 10 mA -0.04 100 Iz = 5 mA -0.06 0 0 25 50 75 100 125 150 175 -0.08 200 0 Ambient Temperature : TA (oC) 10 20 30 40 50 Zener Voltage (V) 5 Version: C1804 MTZJ2V0SA - MTZJ56S Taiwan Semiconductor PACKAGE OUTLINE DIMENSION DO-34 DIM A B C D Unit (mm) Min Max 0.30 0.55 2.16 3.04 25.40 38.10 1.27 2.00 Unit (inch) Min Max 0.012 0.022 0.085 0.120 1.000 1.500 0.050 0.079 MARKING DIAGRAM xxx = Marking code 6 Version: C1804 MTZJ2V0SA - MTZJ56S Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7 Version: C1804
MTZJ15SC R0G
物料型号:MTZJ2V0SA - MTZJ56S,由台湾半导体公司生产。
器件简介:这些是500mW,2V至56V的齐纳二极管,具有以下特点: - 齐纳电压范围宽:2.0V至56V - 采用密封玻璃封装 - 符合RoHS指令2011/65/EU和WEEE 2002/96/EC
引脚分配:文档中未明确指出具体的引脚分配,但通常齐纳二极管有阳极和阴极两个引脚。
参数特性: - 齐纳电压(Vz):2.0V至56V - 测试电流(lzr):5mA - 功率消耗(Po):500mW - 最大结温(T MAX):175°C - 封装类型:DO-34 - 配置:单片
功能详解:文档中未提供详细的功能解释,但齐纳二极管通常用于电压稳定和过压保护。
应用信息: - 低电压稳定器或电压参考 - 适配器 - 照明应用 - 板上DC/DC转换器
封装信息: - 封装类型:DO-34 - 端头:镀锡的引线,可按J-STD-002进行焊接 - 极性:通过阴极带表示 - 重量:大约92毫克
绝对最大额定值: - 功率消耗:500mW - 结温范围:-55至+175°C - 存储温度:-55至+175°C
电气规格:文档提供了不同型号的齐纳二极管在5mA测试电流下的最小值、标称值和最大值,包括齐纳电压、正向电压、反向电流等参数。
订购信息:提供了不同电压等级的订购代码、封装类型和包装方式。
特性曲线:文档包含了齐纳电压与电流、功率耗散与环境温度、以及温度系数与齐纳电压的关系图。
封装尺寸:提供了DO-34封装的详细尺寸。
MTZJ15SC R0G 价格&库存
很抱歉,暂时无法提供与“MTZJ15SC R0G”相匹配的价格&库存,您可以联系我们找货
MTZJ15SC R0G
  • 10000+0.3029610000+0.03886
  • 20000+0.2119820000+0.02719
  • 30000+0.2103230000+0.02698
  • 50000+0.1902750000+0.02441
