2N4123
2N4123
    L3HARRIS
    TO92-3
    SMALL SIGNAL BIPOLAR TRANSISTOR
2N4123 数据手册
Dat asheet Rochest erEl ect r oni cs Manuf act ur edComponent s Rochest er br anded component s ar e manuf act ur ed usi ng ei t herdi e/ waf er s pur chased f r om t he or i gi nalsuppl i er s or Rochest er waf er sr ecr eat ed f r om t he or i gi nal I P. Al lr ecr eat i ons ar e donewi t ht heappr ovaloft heOCM. Par t sar et est ed usi ngor i gi nalf act or y t estpr ogr amsorRochest erdevel oped t est sol ut i ons t o guar ant ee pr oduct meet sorexceedt heOCM dat asheet . Qual i t yOver vi ew •I SO9001 • AS9120cer t icat i on • Qual iedManuf act ur er sLi st( QML)MI LPRF35835 •Cl assQ Mi l i t ar y •Cl assVSpaceLevel • Qual iedSuppl i er sLi stofDi st r i but or s( QSLD) •Rochest eri sacr i t i calsuppl i ert oDLA and meet sal li ndust r yandDLA st andar ds. Rochest erEl ect r oni cs,LLC i scommi t t edt o suppl yi ngpr oduct st hatsat i sf ycust omerexpect at i onsf orqual i t yandar eequalt ot hoseor i gi nal l y suppl i edbyi ndust r ymanuf act ur er s. Theor i gi nalmanuf act ur er ’ sdat asheetaccompanyi ngt hi sdocumentr e ect st heper f or mance andspecicat i onsoft heRochest ermanuf act ur edver si onoft hi sdevi ce.Rochest erEl ect r oni csguar ant eest heper f or manceofi t ssemi conduct orpr oduct st ot heor i gi nalOEM specicat i ons.‘ Typi cal ’val uesar ef orr ef er encepur posesonl y.Cer t ai nmi ni mum ormaxi mum r at i ngs maybebasedonpr oductchar act er i zat i on,desi gn,si mul at i on,orsampl et est i ng. © 2013Roc hes t erEl ec t r oni c s ,LLC.Al lRi ght sRes er v ed07112013 Tol ear nmor e,pl eas ev i s i twww. r oc el ec . c om MOTOROLA SEMICONDUCTOR TECHNICAL DATA General Purpose Transistors 2N4123 2N4124 NPN Silicon COLLECTOR 3 2 BASE 1 EMITTER 1 2 3 MAXIMUM RATINGS Rating Symbol 2N4123 2N4124 Unit Collector – Emitter Voltage VCEO 30 25 Vdc Collector – Base Voltage VCBO 40 30 Vdc Emitter – Base Voltage VEBO 5.0 Vdc Collector Current — Continuous IC 200 mAdc Total Device Dissipation @ TA = 25°C Derate above 25°C PD 625 5.0 mW mW/°C Total Device Dissipation @ TC = 25°C Derate above 25°C PD 1.5 12 Watts mW/°C TJ, Tstg – 55 to +150 °C Symbol Max Unit Operating and Storage Junction Temperature Range CASE 29–04, STYLE 1 TO–92 (TO–226AA) THERMAL CHARACTERISTICS Characteristic Thermal Resistance, Junction to Ambient RqJA 200 °C/W Thermal Resistance, Junction to Case RqJC 83.3 °C/W ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise noted) Symbol Min Max 30 25 — — 40 30 — — V(BR)EBO 5.0 — Vdc Collector Cutoff Current (VCB = 20 Vdc, IE = 0) ICBO — 50 nAdc Emitter Cutoff Current (VEB = 3.0 Vdc, IC = 0) IEBO — 50 nAdc Characteristic Unit OFF CHARACTERISTICS Collector – Emitter Breakdown Voltage(1) (IC = 1.0 mAdc, IE = 0) Collector – Base Breakdown Voltage (IC = 10 mAdc, IE = 0) Emitter – Base Breakdown Voltage (IE = 10 mAdc, IC = 0) V(BR)CEO 2N4123 2N4124 Vdc V(BR)CBO 2N4123 2N4124 Vdc 1. Pulse Test: Pulse Width = 300 ms, Duty Cycle = 2.0%. 2–14 Motorola Small–Signal Transistors, FETs and Diodes Device Data 2N4123 2N4124 ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise noted) (Continued) Characteristic Symbol Min Max 2N4123 2N4124 50 120 150 360 2N4123 2N4124 25 60 — — Unit ON CHARACTERISTICS DC Current Gain(1) (IC = 2.0 mAdc, VCE = 1.0 Vdc) hFE (IC = 50 mAdc, VCE = 1.0 Vdc) — Collector – Emitter Saturation Voltage(1) (IC = 50 mAdc, IB = 5.0 mAdc) VCE(sat) — 0.3 Vdc Base – Emitter Saturation Voltage(1) (IC = 50 mAdc, IB = 5.0 mAdc) VBE(sat) — 0.95 Vdc 250 300 — — SMALL– SIGNAL CHARACTERISTICS Current – Gain — Bandwidth Product (IC = 10 mAdc, VCE = 20 Vdc, f = 100 MHz) fT MHz 2N4123 2N4124 Input Capacitance (VEB = 0.5 Vdc, IC = 0, f = 1.0 MHz) Cibo — 8.0 pF Collector–Base Capacitance (IE = 0, VCB = 5.0 V, f = 1.0 MHz) Ccb — 4.0 pF 50 120 200 480 2N4123 2N4124 2.5 3.0 — — 2N4123 2N4124 50 120 200 480 — — 6.0 5.0 Small–Signal Current Gain (IC = 2.0 mAdc, VCE = 10 Vdc, RS = 10 k ohm, f = 1.0 kHz) Current Gain — High Frequency (IC = 10 mAdc, VCE = 20 Vdc, f = 100 MHz) hfe 2N4123 2N4124 — |hfe| (IC = 2.0 mAdc, VCE = 10 V, f = 1.0 kHz) (IC = 2.0 mAdc, VCE = 10 V, f = 1.0 kHz) Noise Figure (IC = 100 µAdc, VCE = 5.0 Vdc, RS = 1.0 k ohm, f = 1.0 kHz) — NF dB 2N4123 2N4124 1. Pulse Test: Pulse Width = 300 ms, Duty Cycle = 2.0%. 200 10 100 5.0 TIME (ns) CAPACITANCE (pF) 7.0 Cibo 3.0 ts 70 50 td 30 tf Cobo 2.0 VCC = 3 V IC/IB = 10 VEB(off) = 0.5 V 10.0 7.0 1.0 0.1 tr 20 0.2 0.3 0.5 0.7 1.0 2.0 3.0 5.0 7.0 10 REVERSE BIAS VOLTAGE (VOLTS) 20 30 40 Figure 1. Capacitance Motorola Small–Signal Transistors, FETs and Diodes Device Data 5.0 1.0 2.0 3.0 5.0 7.0 10 20 30 50 70 100 IC, COLLECTOR CURRENT (mA) 200 Figure 2. Switching Times 2–15 2N4123 2N4124 AUDIO SMALL–SIGNAL CHARACTERISTICS NOISE FIGURE (VCE = 5 Vdc, TA = 25°C) Bandwidth = 1.0 Hz 12 f = 1 kHz SOURCE RESISTANCE = 200 W IC = 0.5 mA 8 6 SOURCE RESISTANCE = 1 kΩ IC = 50 mA 4 2 0 0.1 SOURCE RESISTANCE = 500 W IC = 100 mA 0.2 0.4 1 2 4 10 f, FREQUENCY (kHz) IC = 1 mA 12 NF, NOISE FIGURE (dB) 10 NF, NOISE FIGURE (dB) 14 SOURCE RESISTANCE = 200 W IC = 1 mA IC = 0.5 mA 10 IC = 50 mA 8 IC = 100 mA 6 4 2 20 40 0 0.1 100 0.2 0.4 Figure 3. Frequency Variations 40 1.0 2.0 4.0 10 20 RS, SOURCE RESISTANCE (kΩ) 100 Figure 4. Source Resistance h PARAMETERS (VCE = 10 V, f = 1 kHz, TA = 25°C) 100 hoe, OUTPUT ADMITTANCE (m mhos) hfe , CURRENT GAIN 300 200 100 70 50 50 20 10 5 2 1 30 0.1 0.2 0.5 1.0 2.0 IC, COLLECTOR CURRENT (mA) 5.0 10 0.1 0.2 Figure 5. Current Gain h re , VOLTAGE FEEDBACK RATIO (X 10 –4 ) hie , INPUT IMPEDANCE (kΩ ) 10 5.0 10 10 10 5.0 2.0 1.0 0.5 7.0 5.0 3.0 2.0 1.0 0.7 0.5 0.1 0.2 0.5 1.0 2.0 IC, COLLECTOR CURRENT (mA) Figure 7. Input Impedance 2–16 5.0 Figure 6. Output Admittance 20 0.2 0.5 1.0 2.0 IC, COLLECTOR CURRENT (mA) 5.0 10 0.1 0.2 0.5 1.0 2.0 IC, COLLECTOR CURRENT (mA) Figure 8. Voltage Feedback Ratio Motorola Small–Signal Transistors, FETs and Diodes Device Data 2N4123 2N4124 STATIC CHARACTERISTICS h FE, DC CURRENT GAIN (NORMALIZED) 2.0 TJ = +125°C 1.0 VCE = 1 V +25°C 0.7 – 55°C 0.5 0.3 0.2 0.1 0.1 0.2 0.3 0.5 0.7 1.0 2.0 3.0 5.0 7.0 10 IC, COLLECTOR CURRENT (mA) 20 30 50 70 100 200 VCE, COLLECTOR EMITTER VOLTAGE (VOLTS) Figure 9. DC Current Gain 1.0 TJ = 25°C 0.8 IC = 1 mA 10 mA 30 mA 100 mA 0.6 0.4 0.2 0 0.01 0.02 0.03 0.05 0.07 0.1 0.2 0.3 0.5 IB, BASE CURRENT (mA) 0.7 1.0 2.0 3.0 5.0 7.0 10 Figure 10. Collector Saturation Region θV, TEMPERATURE COEFFICIENTS (mV/°C) 1.2 TJ = 25°C VBE(sat) @ IC/IB = 10 V, VOLTAGE (VOLTS) 1.0 0.8 VBE @ VCE = 1 V 0.6 0.4 VCE(sat) @ IC/IB = 10 0.2 0 1.0 2.0 50 5.0 10 20 IC, COLLECTOR CURRENT (mA) 100 200 Figure 11. “On” Voltages Motorola Small–Signal Transistors, FETs and Diodes Device Data 1.0 0.5 +25°C to +125°C qVC for VCE(sat) 0 – 55°C to +25°C – 0.5 – 55°C to +25°C – 1.0 +25°C to +125°C qVB for VBE(sat) – 1.5 – 2.0 0 20 40 60 80 100 120 140 160 IC, COLLECTOR CURRENT (mA) 180 200 Figure 12. Temperature Coefficients 2–17 EMBOSSED TAPE AND REEL SOT-23, SC-59, SC-70/SOT-323, SC–90/SOT–416, SOT-223 and SO-16 packages are available only in Tape and Reel. Use the appropriate suffix indicated below to order any of the SOT-23, SC-59, SC-70/SOT-323, SOT-223 and SO-16 packages. (See Section 6 on Packaging for additional information). SOT-23: available in 8 mm Tape and Reel Use the device title (which already includes the “T1” suffix) to order the 7 inch/3000 unit reel. Replace the “T1” suffix in the device title with a “T3” suffix to order the 13 inch/10,000 unit reel. SC-59: available in 8 mm Tape and Reel Use the device title (which already includes the “T1” suffix) to order the 7 inch/3000 unit reel. Replace the “T1” suffix in the device title with a “T3” suffix to order the 13 inch/10,000 unit reel. SC-70/ SOT-323: available in 8 mm Tape and Reel Use the device title (which already includes the “T1” suffix) to order the 7 inch/3000 unit reel. Replace the “T1” suffix in the device title with a “T3” suffix to order the 13 inch/10,000 unit reel. SOT-223: available in 12 mm Tape and Reel Use the device title (which already includes the “T1” suffix) to order the 7 inch/1000 unit reel. Replace the “T1” suffix in the device title with a “T3” suffix to order the 13 inch/4000 unit reel. SO-16: available in 16 mm Tape and Reel Add an “R1” suffix to the device title to order the 7 inch/500 unit reel. Add an “R2” suffix to the device title to order the 13 inch/2500 unit reel. RADIAL TAPE IN FAN FOLD BOX OR REEL TO-92 packages are available in both bulk shipments and in Radial Tape in Fan Fold Boxes or Reels. Fan Fold Boxes and Radial Tape Reel are the best methods for capturing devices for automatic insertion in printed circuit boards. TO-92: available in Fan Fold Box Add an “RLR” suffix and the appropriate Style code* to the device title to order the Fan Fold box. available in 365 mm Radial Tape Reel Add an “RLR” suffix and the appropriate Style code* to the device title to order the Radial Tape Reel. *Refer to Section 6 on Packaging for Style code characters and additional information on ordering *requirements. DEVICE MARKINGS/DATE CODE CHARACTERS SOT-23, SC-59, SC-70/SOT-323, and the SC–90/SOT–416 packages have a device marking and a date code etched on the device. The generic example below depicts both the device marking and a representation of the date code that appears on the SC-70/SOT-323, SC-59 and SOT-23 packages. ABC D The “D” represents a smaller alpha digit Date Code. The Date Code indicates the actual month in which the part was manufactured. 2–2 Motorola Small–Signal Transistors, FETs and Diodes Device Data Tape and Reel Specifications and Packaging Specifications Embossed Tape and Reel is used to facilitate automatic pick and place equipment feed requirements. The tape is used as the shipping container for various products and requires a minimum of handling. The antistatic/conductive tape provides a secure cavity for the product when sealed with the “peel–back” cover tape. • • • • • SOD–123, SC–59, SC–70/SOT–323, SC–70ML/SOT–363, SOT–23, TSOP–6, in 8 mm Tape • SOT–223 in 12 mm Tape • SO–14, SO–16 in 16 mm Tape Two Reel Sizes Available (7″ and 13″) Used for Automatic Pick and Place Feed Systems Minimizes Product Handling EIA 481, –1, –2 Use the standard device title and add the required suffix as listed in the option table on the following page. Note that the individual reels have a finite number of devices depending on the type of product contained in the tape. Also note the minimum lot size is one full reel for each line item, and orders are required to be in increments of the single reel quantity. SOD–123 SC–59, SC–70/SOT–323, SOT–23 8 mm 8 mm SOT–223 SC–70ML/SOT–363, TSOP–6 T1 ORIENTATION 8 mm SO–14, 16 12 mm 16 mm SC–70ML/SOT–363 T2 ORIENTATION DIRECTION 8 mm OF FEED EMBOSSED TAPE AND REEL ORDERING INFORMATION Devices Per Reel and Minimum Order Quantity Device Suffix (7) 3,000 T1 178 330 (7) (13) 3,000 10,000 T1 T3 8.0 ± 0.1 (.315 ± .004) 178 330 (7) (13) 500 2,500 R1 R2 16 16 8.0 ± 0.1 (.315 ± .004) 178 330 (7) (13) 500 2,500 R1 R2 SOD–123 8 8 4.0 ± 0.1 (.157 ± .004) 178 330 (7) (13) 3,000 10,000 T1 T3 SOT–23 8 8 4.0 ± 0.1 (.157 ± .004) 178 330 (7) (13) 3,000 10,000 T1 T3 SOT–223 12 12 8.0 ± 0.1 (.315 ± .004) 178 330 (7) (13) 1,000 4,000 T1 T3 SC–70ML/SOT–363 8 8 4.0 ± 0.1 (.157 ± .004) 178 178 (7) (7) 3,000 3,000 T1 T2 TSOP–6 8 4.0 ± 0.1 (.157 ± .004) 178 (7) 3,000 T1 Package Tape Width (mm) Pitch mm (inch) SC–59 8 4.0 ± 0.1 (.157 ± .004) 178 SC–70/SOT–323 8 8 4.0 ± 0.1 (.157 ± .004) SO–14 16 16 SO–16 Tape and Reel Specifications 6–2 Reel Size mm (inch) Motorola Small–Signal Transistors, FETs and Diodes Device Data EMBOSSED TAPE AND REEL DATA FOR DISCRETES CARRIER TAPE SPECIFICATIONS P0 K P2 D t 10 Pitches Cumulative Tolerance on Tape ± 0.2 mm (± 0.008″) E Top Cover Tape A0 K0 B1 F W B0 See Note 1 P For Machine Reference Only Including Draft and RADII Concentric Around B0 D1 For Components 2.0 mm x 1.2 mm and Larger Center Lines of Cavity Embossment User Direction of Feed * Top Cover Tape Thickness (t1) 0.10 mm (.004″) Max. Bar Code Label R Min Tape and Components Shall Pass Around Radius “R” Without Damage Bending Radius 10° Embossed Carrier 100 mm (3.937″) Maximum Component Rotation Embossment 1 mm Max Typical Component Cavity Center Line Tape 1 mm (.039″) Max Typical Component Center Line 250 mm (9.843″) Camber (Top View) Allowable Camber To Be 1 mm/100 mm Nonaccumulative Over 250 mm DIMENSIONS Tape Size B1 Max D D1 E F K P0 P2 R Min T Max W Max 8 mm 4.55 mm (.179″) 1.0 Min (.039″) 1.75 ± 0.1 mm (.069 ± .004″) 3.5 ± 0.05 mm (.138 ± .002″) 2.4 mm Max (.094″) 4.0 ± 0.1 mm (.157 ± .004″) 2.0 ± 0.1 mm (.079 ± .002″) 25 mm (.98″) 0.6 mm (.024″) 8.3 mm (.327″) 12 mm 8.2 mm (.323″) 1.5 + 0.1 mm – 0.0 ( 0 9 + .004″ 004 (.059 – 0.0) 5.5 ± 0.05 mm (.217 ± .002″) 6.4 mm Max (.252″) 16 mm 12.1 mm (.476″) 7.5 ± 0.10 mm (.295 ± .004″) 7.9 mm Max (.311″) 16.3 mm (.642″) 24 mm 20.1 mm (.791″) 11.5 ± 0.1 mm (.453 ± .004″) 11.9 mm Max (.468″) 24.3 mm (.957″) 1.5 mm Min (.060″) 30 mm (1.18″) 12 ± .30 mm (.470 ± .012″) Metric dimensions govern — English are in parentheses for reference only. NOTE 1: A0, B0, and K0 are determined by component size. The clearance between the components and the cavity must be within .05 mm min. to .50 mm max., NOTE 1: the component cannot rotate more than 10° within the determined cavity. NOTE 2: If B1 exceeds 4.2 mm (.165) for 8 mm embossed tape, the tape may not feed through all tape feeders. NOTE 3: Pitch information is contained in the Embossed Tape and Reel Ordering Information on pg. 5.12–3. Motorola Small–Signal Transistors, FETs and Diodes Device Data Tape and Reel Specifications 6–3 EMBOSSED TAPE AND REEL DATA FOR DISCRETES T Max Outside Dimension Measured at Edge 1.5 mm Min (.06″) A 13.0 mm ± 0.5 mm (.512″ ± .002″) 20.2 mm Min (.795″) 50 mm Min (1.969″) Full Radius G Size A Max 8 mm 330 mm (12.992″) 8.4 mm + 1.5 mm, – 0.0 (.33″ + .059″, – 0.00) 14.4 mm (.56″) 12 mm 330 mm (12.992″) 12.4 mm + 2.0 mm, – 0.0 (.49″ + .079″, – 0.00) 18.4 mm (.72″) 16 mm 360 mm (14.173″) 16.4 mm + 2.0 mm, – 0.0 (.646″ + .078″, – 0.00) 22.4 mm (.882″) 24 mm 360 mm (14.173″) 24.4 mm + 2.0 mm, – 0.0 (.961″ + .070″, – 0.00) 30.4 mm (1.197″) G Inside Dimension Measured Near Hub T Max Reel Dimensions Metric Dimensions Govern — English are in parentheses for reference only Tape and Reel Specifications 6–4 Motorola Small–Signal Transistors, FETs and Diodes Device Data TO–92 EIA, IEC, EIAJ Radial Tape in Fan Fold Box or On Reel TO–92 RADIAL TAPE IN FAN FOLD BOX OR ON REEL Radial tape in fan fold box or on reel of the reliable TO–92 package are the best methods of capturing devices for automatic insertion in printed circuit boards. These methods of taping are compatible with various equipment for active and passive component insertion. • • • • • • Available in Fan Fold Box Available on 365 mm Reels Accommodates All Standard Inserters Allows Flexible Circuit Board Layout 2.5 mm Pin Spacing for Soldering EIA–468, IEC 286–2, EIAJ RC1008B Ordering Notes: When ordering radial tape in fan fold box or on reel, specify the style per Figures 3 through 8. Add the suffix “RLR” and “Style” to the device title, i.e. MPS3904RLRA. This will be a standard MPS3904 radial taped and supplied on a reel per Figure 9. Fan Fold Box Information — Order in increments of 2000. Reel Information — Order in increments of 2000. US/European Suffix Conversions US EUROPE RLRA RL RLRE RL1 RLRM ZL1 Motorola Small–Signal Transistors, FETs and Diodes Device Data Packaging Specifications 6–5 TO–92 EIA RADIAL TAPE IN FAN FOLD BOX OR ON REEL H2A H2A H2B H2B H W2 H4 H5 T1 L1 H1 W1 W L T T2 F1 F2 P2 P2 P1 D P Figure 1. Device Positioning on Tape Specification Inches Symbol Item Millimeter Min Max Min Max D Tape Feedhole Diameter 0.1496 0.1653 3.8 4.2 D2 Component Lead Thickness Dimension 0.015 0.020 0.38 0.51 Component Lead Pitch 0.0945 0.110 2.4 2.8 .059 .156 1.5 4.0 0.3346 0.3741 8.5 9.5 Deflection Left or Right 0 0.039 0 1.0 Deflection Front or Rear 0 0.051 0 1.0 Feedhole to Bottom of Component 0.7086 0.768 18 19.5 Feedhole to Seating Plane 0.610 0.649 15.5 16.5 F1, F2 H H1 H2A H2B H4 H5 L Bottom of Component to Seating Plane Feedhole Location Defective Unit Clipped Dimension 0.3346 0.433 8.5 11 L1 Lead Wire Enclosure 0.09842 — 2.5 — P Feedhole Pitch 0.4921 0.5079 12.5 12.9 P1 Feedhole Center to Center Lead 0.2342 0.2658 5.95 6.75 P2 First Lead Spacing Dimension 0.1397 0.1556 3.55 3.95 0.06 0.08 0.15 0.20 T Adhesive Tape Thickness T1 Overall Taped Package Thickness — 0.0567 — 1.44 T2 Carrier Strip Thickness 0.014 0.027 0.35 0.65 W Carrier Strip Width 0.6889 0.7481 17.5 19 W1 Adhesive Tape Width 0.2165 0.2841 5.5 6.3 W2 Adhesive Tape Position .0059 0.01968 .15 0.5 NOTES: 1. Maximum alignment deviation between leads not to be greater than 0.2 mm. 2. Defective components shall be clipped from the carrier tape such that the remaining protrusion (L) does not exceed a maximum of 11 mm. 3. Component lead to tape adhesion must meet the pull test requirements established in Figures 5, 6 and 7. 4. Maximum non–cumulative variation between tape feed holes shall not exceed 1 mm in 20 pitches. 5. Holddown tape not to extend beyond the edge(s) of carrier tape and there shall be no exposure of adhesive. 6. No more than 1 consecutive missing component is permitted. 7. A tape trailer and leader, having at least three feed holes is required before the first and after the last component. 8. Splices will not interfere with the sprocket feed holes. Packaging Specifications 6–6 Motorola Small–Signal Transistors, FETs and Diodes Device Data TO–92 EIA RADIAL TAPE IN FAN FOLD BOX OR ON REEL FAN FOLD BOX STYLES ÇÇÇÇÇÇÇ ÇÇÇÇÇÇÇ ÇÇÇÇÇÇÇ ÇÇÇÇÇÇÇ ADHESIVE TAPE ON TOP SIDE FLAT SIDE ADHESIVE TAPE ON TOP SIDE ROUNDED SIDE CARRIER STRIP CARRIER STRIP Figure 2. Style M 252 mm 9.92” FLAT SIDE OF TRANSISTOR AND ADHESIVE TAPE VISIBLE. Style M fan fold box is equivalent to styles E and F of reel pack dependent on feed orientation from box. 330 mm 13” MAX ROUNDED SIDE OF TRANSISTOR AND ADHESIVE TAPE VISIBLE. Style P fan fold box is equivalent to styles A and B of reel pack dependent on feed orientation from box. Figure 3. Style P MAX 58 mm 2.28” MAX Figure 4. Fan Fold Box Dimensions ADHESION PULL TESTS 500 GRAM PULL FORCE 70 GRAM PULL FORCE 100 GRAM PULL FORCE 16 mm 16 mm HOLDING FIXTURE The component shall not pull free with a 300 gram load applied to the leads for 3 ± 1 second. Figure 5. Test #1 HOLDING FIXTURE The component shall not pull free with a 70 gram load applied to the leads for 3 ± 1 second. Figure 6. Test #2 Motorola Small–Signal Transistors, FETs and Diodes Device Data HOLDING FIXTURE There shall be no deviation in the leads and no component leads shall be pulled free of the tape with a 500 gram load applied to the component body for 3 ± 1 second. Figure 7. Test #3 Packaging Specifications 6–7 TO–92 EIA RADIAL TAPE IN FAN FOLD BOX OR ON REEL REEL STYLES CORE DIA. 82mm ± 1mm ARBOR HOLE DIA. 30.5mm ± 0.25mm MARKING NOTE HUB RECESS 76.2mm ± 1mm RECESS DEPTH 9.5mm MIN 365mm + 3, – 0mm 38.1mm ± 1mm 48 mm MAX Material used must not cause deterioration of components or degrade lead solderability Figure 8. Reel Specifications ADHESIVE TAPE ON REVERSE SIDE CARRIER STRIP CARRIER STRIP ROUNDED SIDE FLAT SIDE ADHESIVE TAPE FEED FEED Rounded side of transistor and adhesive tape visible. Flat side of transistor and carrier strip visible (adhesive tape on reverse side). Figure 9. Style A Figure 10. Style B ADHESIVE TAPE ON REVERSE SIDE CARRIER STRIP CARRIER STRIP FLAT SIDE ROUNDED SIDE ADHESIVE TAPE FEED FEED Flat side of transistor and adhesive tape visible. Figure 11. Style E Packaging Specifications 6–8 Rounded side of transistor and carrier strip visible (adhesive tape on reverse side). Figure 12. Style F Motorola Small–Signal Transistors, FETs and Diodes Device Data INFORMATION FOR USING SURFACE MOUNT PACKAGES RECOMMENDED FOOTPRINTS FOR SURFACE MOUNTED APPLICATIONS Surface mount board layout is a critical portion of the total design. The footprint for the semiconductor packages must be the correct size to ensure proper solder connection inter- face between the board and the package. With the correct pad geometry, the packages will self align when subjected to a solder reflow process. POWER DISSIPATION FOR A SURFACE MOUNT DEVICE PD = TJ(max) – TA RθJA The values for the equation are found in the maximum ratings table on the data sheet. Substituting these values into the equation for an ambient temperature TA of 25°C, one can calculate the power dissipation of the device. For example, for a SOT–223 device, PD is calculated as follows. PD = 150°C – 25°C = 800 milliwatts 156°C/W The 156°C/W for the SOT–223 package assumes the use of the recommended footprint on a glass epoxy printed circuit board to achieve a power dissipation of 800 milliwatts. There are other alternatives to achieving higher power dissipation from the surface mount packages. One is to increase the area of the drain/collector pad. By increasing the area of the drain/collector pad, the power dissipation can be increased. Although the power dissipation can almost be doubled with this method, area is taken up on the printed circuit board which can defeat the purpose of using surface mount technology. For example, a graph of RθJA versus drain pad area is shown in Figure 1. Another alternative would be to use a ceramic substrate or an aluminum core board such as Thermal Clad. Using a board material such as Thermal Clad, an aluminum core board, the power dissipation can be doubled using the same footprint. RθJA , THERMAL RESISTANCE, JUNCTION TO AMBIENT (°C/W) The power dissipation for a surface mount device is a function of the drain/collector pad size. These can vary from the minimum pad size for soldering to a pad size given for maximum power dissipation. Power dissipation for a surface mount device is determined by TJ(max), the maximum rated junction temperature of the die, RθJA, the thermal resistance from the device junction to ambient, and the operating temperature, TA. Using the values provided on the data sheet, PD can be calculated as follows: 160 140 Board Material = 0.0625″ G–10/FR–4, 2 oz Copper TA = 25°C 0.8 Watts 120 1.25 Watts* 1.5 Watts 100 80 0.0 *Mounted on the DPAK footprint 0.2 0.4 0.6 A, AREA (SQUARE INCHES) 0.8 1.0 Figure 1. Thermal Resistance versus Drain Pad Area for the SOT–223 Package (Typical) SOLDER STENCIL GUIDELINES Prior to placing surface mount components onto a printed circuit board, solder paste must be applied to the pads. Solder stencils are used to screen the optimum amount. These stencils are typically 0.008 inches thick and may be made of brass or stainless steel. For packages such as the Surface Mount Information 7–10 SOT–23, SC–59, SC–70/SOT–323, SC–90/SOT–416, SOD–123, SOT–223, SOT–363, SO–14, SO–16, and TSOP–6 packages, the stencil opening should be the same as the pad size or a 1:1 registration. Motorola Small–Signal Transistors, FETs and Diodes Device Data SOLDERING PRECAUTIONS The melting temperature of solder is higher than the rated temperature of the device. When the entire device is heated to a high temperature, failure to complete soldering within a short time could result in device failure. Therefore, the following items should always be observed in order to minimize the thermal stress to which the devices are subjected. • Always preheat the device. • The delta temperature between the preheat and soldering should be 100°C or less.* • When preheating and soldering, the temperature of the leads and the case must not exceed the maximum temperature ratings as shown on the data sheet. When using infrared heating with the reflow soldering method, the difference should be a maximum of 10°C. • The soldering temperature and time should not exceed 260°C for more than 10 seconds. • When shifting from preheating to soldering, the maximum temperature gradient shall be 5°C or less. • After soldering has been completed, the device should be allowed to cool naturally for at least three minutes. Gradual cooling should be used since the use of forced cooling will increase the temperature gradient and will result in latent failure due to mechanical stress. • Mechanical stress or shock should not be applied during cooling. * Soldering a device without preheating can cause excessive thermal shock and stress which can result in damage to the device. TYPICAL SOLDER HEATING PROFILE For any given circuit board, there will be a group of control settings that will give the desired heat pattern. The operator must set temperatures for several heating zones and a figure for belt speed. Taken together, these control settings make up a heating “profile” for that particular circuit board. On machines controlled by a computer, the computer remembers these profiles from one operating session to the next. Figure 2 shows a typical heating profile for use when soldering a surface mount device to a printed circuit board. This profile will vary among soldering systems, but it is a good starting point. Factors that can affect the profile include the type of soldering system in use, density and types of components on the board, type of solder used, and the type of board or substrate material being used. This profile shows temperature versus time. The line on the graph shows the STEP 1 PREHEAT ZONE 1 “RAMP” 200°C STEP 2 STEP 3 VENT HEATING “SOAK” ZONES 2 & 5 “RAMP” DESIRED CURVE FOR HIGH MASS ASSEMBLIES actual temperature that might be experienced on the surface of a test board at or near a central solder joint. The two profiles are based on a high density and a low density board. The Vitronics SMD310 convection/infrared reflow soldering system was used to generate this profile. The type of solder used was 62/36/2 Tin Lead Silver with a melting point between 177 –189°C. When this type of furnace is used for solder reflow work, the circuit boards and solder joints tend to heat first. The components on the board are then heated by conduction. The circuit board, because it has a large surface area, absorbs the thermal energy more efficiently, then distributes this energy to the components. Because of this effect, the main body of a component may be up to 30 degrees cooler than the adjacent solder joints. STEP 4 HEATING ZONES 3 & 6 “SOAK” STEP 5 HEATING ZONES 4 & 7 “SPIKE” STEP 6 VENT STEP 7 COOLING 205° TO 219°C PEAK AT SOLDER JOINT 170°C 160°C 150°C 150°C 100°C 140°C 100°C SOLDER IS LIQUID FOR 40 TO 80 SECONDS (DEPENDING ON MASS OF ASSEMBLY) DESIRED CURVE FOR LOW MASS ASSEMBLIES 50°C TIME (3 TO 7 MINUTES TOTAL) TMAX Figure 2. Typical Solder Heating Profile Motorola Small–Signal Transistors, FETs and Diodes Device Data Surface Mount Information 7–11 Footprints for Soldering 0.037 0.95 0.037 0.95 0.037 0.95 0.037 0.95 0.094 2.4 0.079 2.0 0.039 1.0 0.035 0.9 inches 0.031 0.8 0.031 0.8 mm mm SOT–23 0.025 0.025 0.65 0.65 ÉÉÉ ÉÉÉ ÉÉÉ 0.075 0.5 min. (3x) 1.9 0.035 0.9 0.028 1.4 inches 0.7 ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ 0.5 0.5 min. (3x) 1 SC–59 inches mm SC–70/SOT–323 SOT 416/SC–90 0.15 3.8 0.060 1.52 0.079 2.0 0.091 2.3 0.248 6.3 0.091 2.3 0.079 2.0 0.275 7.0 0.155 4.0 0.024 0.6 0.059 1.5 0.059 1.5 0.059 1.5 0.050 1.270 inches inches mm mm SOT–223 Surface Mount Information 7–12 SO–14, SO–16 Motorola Small–Signal Transistors, FETs and Diodes Device Data ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ 2.36 0.093 4.19 0.165 1.22 0.048 0.4 mm (min) ÉÉÉÉ ÉÉÉÉ ÉÉÉÉ ÉÉÉÉ 0.91 0.036 mm inches ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ 0.65 mm 0.65 mm 0.5 mm (min) 1.9 mm SOD–123 SOT–363 (SC–70 6 LEAD) 0.094 2.4 0.037 0.95 0.074 1.9 0.037 0.95 0.028 0.7 0.039 1.0 inches mm TSOP–6 Motorola Small–Signal Transistors, FETs and Diodes Device Data Surface Mount Information 7–13 Package Outline Dimensions Dimensions are in inches unless otherwise noted. A NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: INCH. 3. CONTOUR OF PACKAGE BEYOND DIMENSION R IS UNCONTROLLED. 4. DIMENSION F APPLIES BETWEEN P AND L. DIMENSION D AND J APPLY BETWEEN L AND K MINIMUM. LEAD DIMENSION IS UNCONTROLLED IN P AND BEYOND DIMENSION K MINIMUM. B R P L F SEATING PLANE K DIM A B C D F G H J K L N P R V D X X G J H V C SECTION X–X 1 N N STYLE 1: PIN 1. EMITTER 2. BASE 3. COLLECTOR STYLE 14: PIN 1. EMITTER 2. COLLECTOR 3. BASE STYLE 2: PIN 1. BASE 2. EMITTER 3. COLLECTOR STYLE 15: PIN 1. ANODE 1 2. CATHODE 3. ANODE 2 STYLE 3: PIN 1. ANODE 2. ANODE 3. CATHODE STYLE 4: PIN 1. CATHODE 2. CATHODE 3. ANODE STYLE 17: PIN 1. COLLECTOR 2. BASE 3. EMITTER STYLE 21: PIN 1. COLLECTOR 2. EMITTER 3. BASE STYLE 5: PIN 1. DRAIN 2. SOURCE 3. GATE STYLE 22: PIN 1. SOURCE 2. GATE 3. DRAIN INCHES MIN MAX 0.175 0.205 0.170 0.210 0.125 0.165 0.016 0.022 0.016 0.019 0.045 0.055 0.095 0.105 0.015 0.020 0.500 ––– 0.250 ––– 0.080 0.105 ––– 0.100 0.115 ––– 0.135 ––– MILLIMETERS MIN MAX 4.45 5.20 4.32 5.33 3.18 4.19 0.41 0.55 0.41 0.48 1.15 1.39 2.42 2.66 0.39 0.50 12.70 ––– 6.35 ––– 2.04 2.66 ––– 2.54 2.93 ––– 3.43 ––– STYLE 7: PIN 1. SOURCE 2. DRAIN 3. GATE STYLE 30: PIN 1. DRAIN 2. GATE 3. SOURCE CASE 029–04 (TO–226AA) TO–92 PLASTIC A NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: INCH. 3. CONTOUR OF PACKAGE BEYOND DIMENSION R IS UNCONTROLLED. 4. DIMENSION F APPLIES BETWEEN P AND L. DIMENSIONS D AND J APPLY BETWEEN L AND K MIMIMUM. LEAD DIMENSION IS UNCONTROLLED IN P AND BEYOND DIMENSION K MINIMUM. B R SEATING PLANE P L F K X X DIM A B C D F G H J K L N P R V D G H J V 1 2 3 N C SECTION X–X N STYLE 1: PIN 1. EMITTER 2. BASE 3. COLLECTOR STYLE 14: PIN 1. EMITTER 2. COLLECTOR 3. BASE INCHES MIN MAX 0.175 0.205 0.290 0.310 0.125 0.165 0.018 0.022 0.016 0.019 0.045 0.055 0.095 0.105 0.018 0.024 0.500 ––– 0.250 ––– 0.080 0.105 ––– 0.100 0.135 ––– 0.135 ––– MILLIMETERS MIN MAX 4.44 5.21 7.37 7.87 3.18 4.19 0.46 0.56 0.41 0.48 1.15 1.39 2.42 2.66 0.46 0.61 12.70 ––– 6.35 ––– 2.04 2.66 ––– 2.54 3.43 ––– 3.43 ––– STYLE 22: PIN 1. SOURCE 2. GATE 3. DRAIN CASE 029–05 (TO–226AE) TO–92 1–WATT PLASTIC Package Outline Dimensions 8–2 Motorola Small–Signal Transistors, FETs and Diodes Device Data PACKAGE OUTLINE DIMENSIONS (continued) B NOTES: 1. PACKAGE CONTOUR OPTIONAL WITHIN DIA B AND LENGTH A. HEAT SLUGS, IF ANY, SHALL BE INCLUDED WITHIN THIS CYLINDER, BUT SHALL NOT BE SUBJECT TO THE MIN LIMIT OF DIA B. 2. LEAD DIA NOT CONTROLLED IN ZONES F, TO ALLOW FOR FLASH, LEAD FINISH BUILDUP, AND MINOR IRREGULARITIES OTHER THAN HEAT SLUGS. D K F A DIM A B D F K F K MILLIMETERS MIN MAX 5.84 7.62 2.16 2.72 0.46 0.56 ––– 1.27 25.40 38.10 INCHES MIN MAX 0.230 0.300 0.085 0.107 0.018 0.022 ––– 0.050 1.000 1.500 All JEDEC dimensions and notes apply. CASE 51–02 (DO–204AA) DO–7 A B R SEATING PLANE ÉÉ ÉÉ D P L F K J SECTION X–X X X D G H V 1 2 C N N NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: INCH. 3. CONTOUR OF PACKAGE BEYOND ZONE R IS UNCONTROLLED. 4. DIMENSION F APPLIES BETWEEN P AND L. DIMENSIONS D AND J APPLY BETWEEN L AND K MINIMUM. LEAD DIMENSION IS UNCONTROLLED IN P AND BEYOND DIM K MINIMUM. DIM A B C D F G H J K L N P R V INCHES MIN MAX 0.175 0.205 0.170 0.210 0.125 0.165 0.016 0.022 0.016 0.019 0.050 BSC 0.100 BSC 0.014 0.016 0.500 ––– 0.250 ––– 0.080 0.105 ––– 0.050 0.115 ––– 0.135 ––– MILLIMETERS MIN MAX 4.45 5.21 4.32 5.33 3.18 4.49 0.41 0.56 0.407 0.482 1.27 BSC 3.54 BSC 0.36 0.41 12.70 ––– 6.35 ––– 2.03 2.66 ––– 1.27 2.93 ––– 3.43 ––– STYLE 1: PIN 1. ANODE 2. CATHODE CASE 182–02 (T0–226AC) TO–92 PLASTIC Motorola Small–Signal Transistors, FETs and Diodes Device Data Package Outline Dimensions 8–3 PACKAGE OUTLINE DIMENSIONS (continued) NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: INCH. 3. MAXIUMUM LEAD THICKNESS INCLUDES LEAD FINISH THICKNESS. MINIMUM LEAD THICKNESS IS THE MINIMUM THICKNESS OF BASE MATERIAL. A L 3 B S 1 DIM A B C D G H J K L S V 2 V G C H D STYLE 6: PIN 1. BASE 2. EMITTER 3. COLLECTOR STYLE 8: PIN 1. ANODE 2. NO CONNECTION 3. CATHODE STYLE 12: PIN 1. CATHODE 2. CATHODE 3. ANODE J K STYLE 10: PIN 1. DRAIN 2. SOURCE 3. GATE STYLE 9: PIN 1. ANODE 2. ANODE 3. CATHODE STYLE 18: PIN 1. NO CONNECTION 2. CATHODE 3. ANODE INCHES MIN MAX 0.1102 0.1197 0.0472 0.0551 0.0350 0.0440 0.0150 0.0200 0.0701 0.0807 0.0005 0.0040 0.0034 0.0070 0.0140 0.0285 0.0350 0.0401 0.0830 0.1039 0.0177 0.0236 STYLE 19: PIN 1. CATHODE 2. ANODE 3. CATHODE–ANODE MILLIMETERS MIN MAX 2.80 3.04 1.20 1.40 0.89 1.11 0.37 0.50 1.78 2.04 0.013 0.100 0.085 0.177 0.35 0.69 0.89 1.02 2.10 2.64 0.45 0.60 STYLE 11: PIN 1. ANODE 2. CATHODE 3. CATHODE–ANODE STYLE 21: PIN 1. GATE 2. SOURCE 3. DRAIN CASE 318–08 (TO–236AB) SOT–23 PLASTIC A NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: MILLIMETER. L 3 S 2 DIM A B C D G H J K L S B 1 D G J C H STYLE 1: PIN 1. EMITTER 2. BASE 3. COLLECTOR MILLIMETERS MIN MAX 2.70 3.10 1.30 1.70 1.00 1.30 0.35 0.50 1.70 2.10 0.013 0.100 0.09 0.18 0.20 0.60 1.25 1.65 2.50 3.00 INCHES MIN MAX 0.1063 0.1220 0.0512 0.0669 0.0394 0.0511 0.0138 0.0196 0.0670 0.0826 0.0005 0.0040 0.0034 0.0070 0.0079 0.0236 0.0493 0.0649 0.0985 0.1181 K STYLE 2: PIN 1. N.C. 2. ANODE 3. CATHODE STYLE 3: PIN 1. ANODE 2. ANODE 3. CATHODE STYLE 4: PIN 1. N.C. 2. CATHODE 3. ANODE STYLE 5: PIN 1. CATHODE 2. CATHODE 3. ANODE CASE 318D–04 SC–59 Package Outline Dimensions 8–4 Motorola Small–Signal Transistors, FETs and Diodes Device Data PACKAGE OUTLINE DIMENSIONS (continued) A F NOTES: 3. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 4. CONTROLLING DIMENSION: INCH. 4 S INCHES DIM MIN MAX A 0.249 0.263 B 0.130 0.145 C 0.060 0.068 D 0.024 0.035 F 0.115 0.126 G 0.087 0.094 H 0.0008 0.0040 J 0.009 0.014 K 0.060 0.078 L 0.033 0.041 M 0_ 10 _ S 0.264 0.287 B 1 2 3 D L G J C 0.08 (0003) M H MILLIMETERS MIN MAX 6.30 6.70 3.30 3.70 1.50 1.75 0.60 0.89 2.90 3.20 2.20 2.40 0.020 0.100 0.24 0.35 1.50 2.00 0.85 1.05 0_ 10 _ 6.70 7.30 K STYLE 1: PIN 1. 2. 3. 4. BASE COLLECTOR EMITTER COLLECTOR STYLE 2: PIN 1. 2. 3. 4. ANODE CATHODE NC CATHODE STYLE 3: PIN 1. 2. 3. 4. GATE DRAIN SOURCE DRAIN CASE 318E–04 SOT–223 A NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: MILLIMETER. 3. MAXIMUM LEAD THICKNESS INCLUDES LEAD FINISH THICKNESS. MINIMUM LEAD THICKNESS IS THE MINIMUM THICKNESS OF BASE MATERIAL. L 6 5 4 2 3 B S 1 D G M J C 0.05 (0.002) H K DIM A B C D G H J K L M S MILLIMETERS MIN MAX 2.90 3.10 1.30 1.70 0.90 1.10 0.25 0.50 0.85 1.05 0.013 0.100 0.10 0.26 0.20 0.60 1.25 1.55 0_ 10 _ 2.50 3.00 STYLE 1: PIN 1. 2. 3. 4. 5. 6. INCHES MIN MAX 0.1142 0.1220 0.0512 0.0669 0.0354 0.0433 0.0098 0.0197 0.0335 0.0413 0.0005 0.0040 0.0040 0.0102 0.0079 0.0236 0.0493 0.0610 0_ 10 _ 0.0985 0.1181 DRAIN DRAIN GATE SOURCE DRAIN DRAIN CASE 318G–02 TSOP–6 PLASTIC Motorola Small–Signal Transistors, FETs and Diodes Device Data Package Outline Dimensions 8–5 PACKAGE OUTLINE DIMENSIONS (continued) A L NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: INCH. 3 B S 1 2 DIM A B C D G H J K L N R S V D V G R N C 0.05 (0.002) J K H STYLE 2: PIN 1. ANODE 2. N.C. 3. CATHODE STYLE 3: PIN 1. BASE 2. EMITTER 3. COLLECTOR STYLE 7: PIN 1. BASE 2. EMITTER 3. COLLECTOR STYLE 4: PIN 1. CATHODE 2. CATHODE 3. ANODE STYLE 9: PIN 1. ANODE 2. CATHODE 3. CATHODE–ANODE INCHES MIN MAX 0.071 0.087 0.045 0.053 0.035 0.049 0.012 0.016 0.047 0.055 0.000 0.004 0.004 0.010 0.017 REF 0.026 BSC 0.028 REF 0.031 0.039 0.079 0.087 0.012 0.016 MILLIMETERS MIN MAX 1.80 2.20 1.15 1.35 0.90 1.25 0.30 0.40 1.20 1.40 0.00 0.10 0.10 0.25 0.425 REF 0.650 BSC 0.700 REF 0.80 1.00 2.00 2.20 0.30 0.40 STYLE 5: PIN 1. ANODE 2. ANODE 3. CATHODE STYLE 10: PIN 1. CATHODE 2. ANODE 3. ANODE–CATHODE CASE 419–02 SC–70/SOT–323 A NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: INCH. G V 6 5 4 1 2 3 DIM A B C D G H J K N S V –B– S D 6 PL 0.2 (0.008) M B M N J C H K INCHES MIN MAX 0.071 0.087 0.045 0.053 0.031 0.043 0.004 0.012 0.026 BSC ––– 0.004 0.004 0.010 0.004 0.012 0.008 REF 0.079 0.087 0.012 0.016 STYLE 1: PIN 1. 2. 3. 4. 5. 6. EMITTER 2 BASE 2 COLLECTOR 1 EMITTER 1 BASE 1 COLLECTOR 2 STYLE 6: PIN 1. 2. 3. 4. 5. 6. ANODE 2 N/C CATHODE 1 ANODE 1 N/C CATHODE 2 MILLIMETERS MIN MAX 1.80 2.20 1.15 1.35 0.80 1.10 0.10 0.30 0.65 BSC ––– 0.10 0.10 0.25 0.10 0.30 0.20 REF 2.00 2.20 0.30 0.40 CASE 419B-01 SOT–363 Package Outline Dimensions 8–6 Motorola Small–Signal Transistors, FETs and Diodes Device Data PACKAGE OUTLINE DIMENSIONS (continued) A C ÂÂÂ ÂÂÂ ÂÂÂ NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: INCH. H 1 K DIM A B C D E H J K B INCHES MIN MAX 0.055 0.071 0.100 0.112 0.037 0.053 0.020 0.028 0.004 ––– 0.000 0.004 ––– 0.006 0.140 0.152 MILLIMETERS MIN MAX 1.40 1.80 2.55 2.85 0.95 1.35 0.50 0.70 0.25 ––– 0.00 0.10 ––– 0.15 3.55 3.85 E 2 STYLE 1: PIN 1. CATHODE 2. ANODE J D CASE 425–04 SOD–123 NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: MILLIMETER. –A– S 2 3 D 3 PL 0.20 (0.008) G –B– 1 M B K J 0.20 (0.008) A MILLIMETERS MIN MAX 0.70 0.80 1.40 1.80 0.60 0.90 0.15 0.30 1.00 BSC ––– 0.10 0.10 0.25 1.45 1.75 0.10 0.20 0.50 BSC INCHES MIN MAX 0.028 0.031 0.055 0.071 0.024 0.035 0.006 0.012 0.039 BSC ––– 0.004 0.004 0.010 0.057 0.069 0.004 0.008 0.020 BSC STYLE 1: PIN 1. BASE 2. EMITTER 3. COLLECTOR C L DIM A B C D G H J K L S STYLE 4: PIN 1. CATHODE 2. CATHODE 3. ANODE H CASE 463–01 SOT–416/SC–90 Motorola Small–Signal Transistors, FETs and Diodes Device Data Package Outline Dimensions 8–7 PACKAGE OUTLINE DIMENSIONS (continued) 14 NOTES: 1. LEADS WITHIN 0.13 (0.005) RADIUS OF TRUE POSITION AT SEATING PLANE AT MAXIMUM MATERIAL CONDITION. 2. DIMENSION L TO CENTER OF LEADS WHEN FORMED PARALLEL. 3. DIMENSION B DOES NOT INCLUDE MOLD FLASH. 4. ROUNDED CORNERS OPTIONAL. 8 B 1 7 A F DIM A B C D F G H J K L M N L C J N H G D SEATING PLANE K M INCHES MIN MAX 0.715 0.770 0.240 0.260 0.145 0.185 0.015 0.021 0.040 0.070 0.100 BSC 0.052 0.095 0.008 0.015 0.115 0.135 0.300 BSC 0_ 10_ 0.015 0.039 MILLIMETERS MIN MAX 18.16 19.56 6.10 6.60 3.69 4.69 0.38 0.53 1.02 1.78 2.54 BSC 1.32 2.41 0.20 0.38 2.92 3.43 7.62 BSC 0_ 10_ 0.39 1.01 CASE 646–06 14–PIN DIP PLASTIC NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: INCH. 3. DIMENSION L TO CENTER OF LEADS WHEN FORMED PARALLEL. 4. DIMENSION B DOES NOT INCLUDE MOLD FLASH. 5. ROUNDED CORNERS OPTIONAL. –A– 16 9 1 8 B F C L S –T– SEATING PLANE K H G D M J 16 PL 0.25 (0.010) M T A M DIM A B C D F G H J K L M S INCHES MIN MAX 0.740 0.770 0.250 0.270 0.145 0.175 0.015 0.021 0.040 0.70 0.100 BSC 0.050 BSC 0.008 0.015 0.110 0.130 0.295 0.305 0_ 10 _ 0.020 0.040 MILLIMETERS MIN MAX 18.80 19.55 6.35 6.85 3.69 4.44 0.39 0.53 1.02 1.77 2.54 BSC 1.27 BSC 0.21 0.38 2.80 3.30 7.50 7.74 0_ 10 _ 0.51 1.01 CASE 648–08 16–PIN DIP PLASTIC Package Outline Dimensions 8–8 Motorola Small–Signal Transistors, FETs and Diodes Device Data PACKAGE OUTLINE DIMENSIONS (continued) NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: MILLIMETER. 3. DIMENSIONS A AND B DO NOT INCLUDE MOLD PROTRUSION. 4. MAXIMUM MOLD PROTRUSION 0.15 (0.006) PER SIDE. 5. DIMENSION D DOES NOT INCLUDE DAMBAR PROTRUSION. ALLOWABLE DAMBAR PROTRUSION SHALL BE 0.127 (0.005) TOTAL IN EXCESS OF THE D DIMENSION AT MAXIMUM MATERIAL CONDITION. –A– 14 8 –B– 1 P 7 PL 0.25 (0.010) 7 G M B M R X 45 _ C F –T– 0.25 (0.010) M J M K D 14 PL SEATING PLANE T B A S S DIM A B C D F G J K M P R MILLIMETERS MIN MAX 8.55 8.75 3.80 4.00 1.35 1.75 0.35 0.49 0.40 1.25 1.27 BSC 0.19 0.25 0.10 0.25 0_ 7_ 5.80 6.20 0.25 0.50 INCHES MIN MAX 0.337 0.344 0.150 0.157 0.054 0.068 0.014 0.019 0.016 0.049 0.050 BSC 0.008 0.009 0.004 0.009 0_ 7_ 0.228 0.244 0.010 0.019 CASE 751A–03 SO–14 PLASTIC –A– 16 9 1 8 –B– P NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: MILLIMETER. 3. DIMENSIONS A AND B DO NOT INCLUDE MOLD PROTRUSION. 4. MAXIMUM MOLD PROTRUSION 0.15 (0.006) PER SIDE. 5. DIMENSION D DOES NOT INCLUDE DAMBAR PROTRUSION. ALLOWABLE DAMBAR PROTRUSION SHALL BE 0.127 (0.005) TOTAL IN EXCESS OF THE D DIMENSION AT MAXIMUM MATERIAL CONDITION. 8 PL 0.25 (0.010) B M S G R K F X 45 _ C –T– SEATING PLANE M D 16 PL 0.25 (0.010) M T B S A S J DIM A B C D F G J K M P R MILLIMETERS MIN MAX 9.80 10.00 3.80 4.00 1.35 1.75 0.35 0.49 0.40 1.25 1.27 BSC 0.19 0.25 0.10 0.25 0_ 7_ 5.80 6.20 0.25 0.50 INCHES MIN MAX 0.386 0.393 0.150 0.157 0.054 0.068 0.014 0.019 0.016 0.049 0.050 BSC 0.008 0.009 0.004 0.009 0_ 7_ 0.229 0.244 0.010 0.019 CASE 751B–05 SO–16 PLASTIC Motorola Small–Signal Transistors, FETs and Diodes Device Data Package Outline Dimensions 8–9
2N4123 价格&库存
很抱歉,暂时无法提供与“2N4123”相匹配的价格&库存,您可以联系我们找货
