1N3996R
1N3996R
    SOLIDSTATE
    DO-203AA(DO-5)
    1N3996R
1N3996R 数据手册
S O L I D S TAT E INC. 1N3993 – 1N4000 Your TOTAL solutions source! 10 WATTS ZENER DIODES DO4 ZENER DIODES Low-voltage, alloy-junction zener diodes in hermetically sealed package with cathode connected to case. Polarity: Cathode-to-case (reverse polarity units are available and designed by an "R"suffix. MAXIMUM RATINGS: Junction and Storage Temperature: -65°C to + 175°C DC Power Dissipation: 10 Watts (Derate 83.3 mW/°C above 55°C) The type numbers shown in the table have a standard tolerance on the nominal zener voltage of + 10%. A standard tolerance of +5% on individual units is also available and is indicated by suffixing "A" to the standard type number. S O LID S T A T E 46 Farrand Street, Bloomfield, NJ 07003 • 800.631.2075 Your TOTAL solutions source! INC. In NJ: 973.429.8700 • Fax: 973.429.8683 • www.solidstateinc.com S O L I D S TAT E 1N3993 – 1N4000 INC. Your TOTAL solutions source! 10 WATTS ZENER DIODES ELECTRICAL CHARACTERISTICS (TB = 30°C ±3, VF = 1.5 V max @ IF = 2 amp for all units) Type Number 1N3993 1N3994 1N3995 1N3996 1N3997 1N3998 1N3999 1N4000 S O LID Nominal Zener Voltage VZ @ IZT Volts Test Current (IZT) mA Max Zener Impedance ZZT @ IZT Ohms ZZK @ IZT=1.0mA Ohms Max DC Zener Current (IZM)mA 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 640 580 530 490 445 405 370 335 2.0 1.5 1.2 1.1 1.0 1.1 1.2 1.3 400 400 500 550 600 750 500 250 2380 2130 1940 1780 1620 1460 1330 1210 Reverse Leakage Current IR µA VR Volts 100 100 50 10 10 10 10 10 0.5 0.5 1.0 1.0 1.0 2.0 2.0 3.0 S T A T E 46 Farrand Street, Bloomfield, NJ 07003 • 800.631.2075 Your TOTAL solutions source! INC. In NJ: 973.429.8700 • Fax: 973.429.8683 • www.solidstateinc.com
1N3996R 价格&库存
很抱歉,暂时无法提供与“1N3996R”相匹配的价格&库存,您可以联系我们找货
