2N6387
2N6387
    L3HARRIS
    TO-220-3
    NPN POWER TRANSISTOR
2N6387 数据手册
2N6387, 2N6388 Plastic Medium-Power Silicon Transistors These devices are designed for general−purpose amplifier and low−speed switching applications. Features http://onsemi.com • High DC Current Gain − hFE = 2500 (Typ) @ IC = 4.0 Adc • Collector−Emitter Sustaining Voltage − @ 100 mAdc • • • • DARLINGTON NPN SILICON POWER TRANSISTORS 8 AND 10 AMPERES 65 WATTS, 60 − 80 VOLTS VCEO(sus) = 60 Vdc (Min) − 2N6387 = 80 Vdc (Min) − 2N6388 Low Collector−Emitter Saturation Voltage − VCE(sat) = 2.0 Vdc (Max) @ IC = 5.0 Adc − 2N6387, 2N6388 Monolithic Construction with Built−In Base−Emitter Shunt Resistors TO−220AB Compact Package Pb−Free Packages are Available* MARKING DIAGRAM 4 MAXIMUM RATINGS (Note 1) Rating Symbol Value Unit Collector−Emitter Voltage 2N6387 2N6388 VCEO 60 80 Vdc Collector−Base Voltage 2N6387 2N6388 VCB 60 80 Vdc VEB 5.0 Vdc IC 10 15 Adc Base Current IB 250 mAdc Total Power Dissipation @ TC = 25_C Derate above 25_C PD 65 0.52 W W/°C Total Power Dissipation @ TA = 25_C Derate above 25_C PD 2.0 0.016 W W/°C TJ, Tstg −65 to +150 °C Emitter−Base Voltage Collector Current − Continuous − Peak Operating and Storage Junction, Temperature Range Thermal Resistance, Junction−to−Case 1 2 Symbol Max Unit RqJC 1.92 _C/W Thermal Resistance, Junction−to−Ambient 62.5 RqJA _C/W Stresses exceeding Maximum Ratings may damage the device. Maximum Ratings are stress ratings only. Functional operation above the Recommended Operating Conditions is not implied. Extended exposure to stresses above the Recommended Operating Conditions may affect device reliability. 1. Indicates JEDEC Registered Data. 2N638xG AYWW 3 2N638x = Device Code x = 7 or 8 G = Pb−Free Package A = Assembly Location Y = Year WW = Work Week ORDERING INFORMATION Device THERMAL CHARACTERISTICS Characteristics TO−220AB CASE 221A STYLE 1 Package Shipping 2N6387 TO−220AB 50 Units / Rail 2N6387G TO−220AB (Pb−Free) 50 Units / Rail 2N6388 TO−220AB 50 Units / Rail 2N6388G TO−220AB (Pb−Free) 50 Units / Rail *For additional information on our Pb−Free strategy and soldering details, please download the ON Semiconductor Soldering and Mounting Techniques Reference Manual, SOLDERRM/D. © Semiconductor Components Industries, LLC, 2011 October, 2011 − Rev. 14 1 Publication Order Number: 2N6387/D PD, POWER DISSIPATION (WATTS) 2N6387, 2N6388 TA 4.0 TC 80 3.0 60 TC 2.0 40 1.0 20 TA 0 0 20 40 60 80 100 T, TEMPERATURE (°C) 120 140 160 Figure 1. Power Derating ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ELECTRICAL CHARACTERISTICS (TC = 25_C unless otherwise noted) (Note 2) Characteristic Symbol Min Max 60 80 − − − − 1.0 1.0 − − − − 300 300 3.0 3.0 − 5.0 1000 100 20,000 − − − 2.0 3.0 − − 2.8 4.5 Unit OFF CHARACTERISTICS Collector−Emitter Sustaining Voltage (Note 3) (IC = 200 mAdc, IB = 0) 2N6387 2N6388 Collector Cutoff Current (VCE = 60 Vdc, IB = 0) (VCE = 80 Vdc, IB = 0) 2N6387 2N6388 Collector Cutoff Current (VCE = 60 Vdc, VEB(off) = 1.5 Vdc) (VCE − 80 Vdc, VEB(off) = 1.5 Vdc) (VCE = 60 Vdc, VEB(off) = 1.5 Vdc, TC = 125_C) (VCE = 80 Vdc, VEB(off) = 1.5 Vdc, TC = 125_C) 2N6387 2N6388 2N6387 2N6388 Emitter Cutoff Current (VBE = 5.0 Vdc, IC = 0) VCEO(sus) ICEO ICEX IEBO Vdc mAdc mAdc mAdc mAdc ON CHARACTERISTICS (Note 3) DC Current Gain (IC = 5.0 Adc, VCE = 3.0 Vdc) (IC = 1 0 Adc, VCE = 3.0 Vdc) 2N6387, 2N6388 2N6387, 2N6388 Collector−Emitter Saturation Voltage (IC = 5.0 Adc, IB = 0.01 Adc) (IC = 10 Adc, IB = 0.1 Adc) 2N6387, 2N6388 2N6387, 2N6388 Base−Emitter On Voltage (IC = 5.0 Adc, VCE = 3.0 Vdc) (IC = 10 Adc, VCE = 3.0 Vdc) 2N6387, 2N6388 2N6387, 2N6388 hFE VCE(sat) VBE(on) − Vdc Vdc DYNAMIC CHARACTERISTICS Small−Signal Current Gain (IC = 1.0 Adc, VCE = 5.0 Vdc, ftest = 1.0 MHz) |hfe| 20 − − Output Capacitance (VCB = 10 Vdc, IE = 0, f = 1.0 MHz) Cob − 200 pF Small−Signal Current Gain (IC = 1.0 Adc, VCE = 5.0 Vdc, f = 1.0 kHz) hfe 1000 − − 2. Indicates JEDEC Registered Data. 3. Pulse Test: Pulse Width v 300 ms, Duty Cycle v 2.0%. http://onsemi.com 2 2N6387, 2N6388 VCC + 30 V RB AND RC VARIED TO OBTAIN DESIRED CURRENT LEVELS D1 MUST BE FAST RECOVERY TYPES, e.g., 1N5825 USED ABOVE IB [ 100 mA MSD6100 USED BELOW IB [ 100 mA RC SCOPE TUT RB V1 APPROX + 12 V 0 51 V2 -8V [ 8.0 k [ 120 - 4.0 V FOR td AND tr, D1 IS DISCONNECTED AND V2 = 0 25 ms APPROX D1 tr, tf v 10 ns DUTY CYCLE = 1.0% Figure 2. Switching Times Test Circuit 7.0 5.0 3.0 ts t, TIME (s) μ tf 1.0 0.7 0.3 0.2 0.1 0.07 0.1 tr VCC = 30 V IC/IB = 250 IB1 = IB2 TJ = 25°C 0.2 td 0.5 2.0 1.0 IC, COLLECTOR CURRENT (AMPS) 5.0 10 r(t), TRANSIENT THERMAL RESISTANCE (NORMALIZED) Figure 3. Switching Times 1.0 0.7 0.5 0.3 D = 0.5 0.2 0.2 0.1 0.1 0.07 0.05 P(pk) ZqJC (t) = r(t) RqJC RqJC = 1.92°C/W MAX D CURVES APPLY FOR POWER PULSE TRAIN SHOWN READ TIME AT t1 TJ(pk) - TC = P(pk) ZqJC(t) 0.05 0.02 0.03 0.02 0.01 0.01 0.01 0.02 SINGLE PULSE 0.05 0.1 0.2 0.5 1.0 2.0 5.0 t, TIME (ms) 10 Figure 4. Thermal Response http://onsemi.com 3 20 50 t1 t2 DUTY CYCLE, D = t1/t2 100 200 500 1.0 k 2N6387, 2N6388 There are two limitations on the power handling ability of a transistor: average junction temperature and second breakdown. Safe operating area curves indicate IC − VCE limits of the transistor that must be observed for reliable operation; i.e., the transistor must not be subjected to greater dissipation than the curves indicate. The data of Figure 5 is based on TJ(pk) = 150_C; TC is variable depending on conditions. Second breakdown pulse limits are valid for duty cycles to 10% provided TJ(pk) < 150_C. TJ(pk) may be calculated from the data in Figure 4. At high case temperatures, thermal limitations will reduce the power that can be handled to values less than the limitations imposed by second breakdown 20 10 IC, COLLECTOR CURRENT (AMPS) 10 ms 5.0 50 ms 1 ms dc 2.0 50 ms 5 ms 1.0 TJ = 150°C 0.5 BONDING WIRE LIMITED THERMALLY LIMITED @ TC = 100°C SECOND BREAKDOWN LIMITED 0.2 0.1 CURVES APPLY BELOW RATED VCEO 0.03 1.0 2N6387 2N6388 40 10 20 2.0 4.0 6.0 60 VCE, COLLECTOR-EMITTER VOLTAGE (VOLTS) 80 Figure 5. Active-Region Safe Operating Area 300 TJ = 25°C 5000 3000 2000 200 C, CAPACITANCE (pF) hFE, SMALL-SIGNAL CURRENT GAIN 10,000 1000 500 300 200 TC = 25°C VCE = 4.0 Vdc IC = 3.0 Adc 100 50 30 20 10 Cob 100 Cib 70 50 1.0 2.0 5.0 10 20 50 100 f, FREQUENCY (kHz) 200 30 0.1 500 1000 0.2 0.5 1.0 2.0 5.0 10 20 VR, REVERSE VOLTAGE (VOLTS) VCE , COLLECTOR-EMITTER VOLTAGE (VOLTS) 20,000 VCE = 4.0 V hFE, DC CURRENT GAIN 10,000 TJ = 150°C 3000 2000 25°C 1000 -55°C 500 300 200 0.1 0.2 0.3 0.5 0.7 1.0 2.0 3.0 IC, COLLECTOR CURRENT (AMP) 100 Figure 7. Capacitance Figure 6. Small−Signal Current Gain 5000 50 5.0 7.0 10 3.0 TJ = 25°C 2.6 IC = 2.0 A 4.0 A 6.0 A 2.2 1.8 1.4 1.0 0.3 Figure 8. DC Current Gain 0.5 0.7 1.0 2.0 3.0 5.0 7.0 IB, BASE CURRENT (mA) 10 Figure 9. Collector Saturation Region http://onsemi.com 4 20 30 2N6387, 2N6388 θV, TEMPERATURE COEFFICIENTS (mV/°C) 3.0 V, VOLTAGE (VOLTS) TJ = 25°C 2.5 2.0 1.5 1.0 0.5 0.1 VBE(sat) @ IC/IB = 250 VBE @ VCE = 4.0 V VCE(sat) @ IC/IB = 250 0.2 0.3 0.5 0.7 1.0 2.0 3.0 + 5.0 + 4.0 + 3.0 hFE@VCE + 4.0V 3 25°C to 150°C + 2.0 + 1.0 *qVC for VCE(sat) -55°C to 25°C 0 - 1.0 - 2.0 - 3.0 qVB for VBE 25°C to 150°C -55°C to 25°C - 4.0 - 5.0 0.1 5.0 7.0 10 *IC/IB ≤ 0.2 0.3 0.5 0.7 1.0 2.0 3.0 5.0 7.0 10 IC, COLLECTOR CURRENT (AMP) IC, COLLECTOR CURRENT (AMP) Figure 10. “On” Voltages Figure 11. Temperature Coefficients 105 IC, COLLECTOR CURRENT (A) μ REVERSE FORWARD COLLECTOR 104 103 VCE = 30 V 102 BASE TJ = 150°C 101 100 [ 8.0 k [ 120 100°C 25°C 10-1 -0.6 -0.4 -0.2 0 +0.2 +0.4 +0.6 +0.8 EMITTER +1.0 +1.2 + 1.4 VBE, BASE-EMITTER VOLTAGE (VOLTS) Figure 12. Collector Cut−Off Region Figure 13. Darlington Schematic http://onsemi.com 5 2N6387, 2N6388 PACKAGE DIMENSIONS TO−220 CASE 221A−09 ISSUE AG −T− B F SEATING PLANE C T S 4 DIM A B C D F G H J K L N Q R S T U V Z A Q U 1 2 3 H K Z L R V J NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: INCH. 3. DIMENSION Z DEFINES A ZONE WHERE ALL BODY AND LEAD IRREGULARITIES ARE ALLOWED. G D N INCHES MIN MAX 0.570 0.620 0.380 0.405 0.160 0.190 0.025 0.036 0.142 0.161 0.095 0.105 0.110 0.161 0.014 0.025 0.500 0.562 0.045 0.060 0.190 0.210 0.100 0.120 0.080 0.110 0.045 0.055 0.235 0.255 0.000 0.050 0.045 ----0.080 STYLE 1: PIN 1. 2. 3. 4. MILLIMETERS MIN MAX 14.48 15.75 9.66 10.28 4.07 4.82 0.64 0.91 3.61 4.09 2.42 2.66 2.80 4.10 0.36 0.64 12.70 14.27 1.15 1.52 4.83 5.33 2.54 3.04 2.04 2.79 1.15 1.39 5.97 6.47 0.00 1.27 1.15 ----2.04 BASE COLLECTOR EMITTER COLLECTOR ON Semiconductor and are registered trademarks of Semiconductor Components Industries, LLC (SCILLC). SCILLC reserves the right to make changes without further notice to any products herein. SCILLC makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does SCILLC assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in SCILLC data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. SCILLC does not convey any license under its patent rights nor the rights of others. SCILLC products are not designed, intended, or authorized for use as components in systems intended for surgical implant into the body, or other applications intended to support or sustain life, or for any other application in which the failure of the SCILLC product could create a situation where personal injury or death may occur. Should Buyer purchase or use SCILLC products for any such unintended or unauthorized application, Buyer shall indemnify and hold SCILLC and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that SCILLC was negligent regarding the design or manufacture of the part. SCILLC is an Equal Opportunity/Affirmative Action Employer. This literature is subject to all applicable copyright laws and is not for resale in any manner. PUBLICATION ORDERING INFORMATION LITERATURE FULFILLMENT: Literature Distribution Center for ON Semiconductor P.O. Box 5163, Denver, Colorado 80217 USA Phone: 303−675−2175 or 800−344−3860 Toll Free USA/Canada Fax: 303−675−2176 or 800−344−3867 Toll Free USA/Canada Email: orderlit@onsemi.com N. American Technical Support: 800−282−9855 Toll Free USA/Canada Europe, Middle East and Africa Technical Support: Phone: 421 33 790 2910 Japan Customer Focus Center Phone: 81−3−5817−1050 http://onsemi.com 6 ON Semiconductor Website: www.onsemi.com Order Literature: http://www.onsemi.com/orderlit For additional information, please contact your local Sales Representative 2N6387/D
2N6387 价格&库存
很抱歉,暂时无法提供与“2N6387”相匹配的价格&库存,您可以联系我们找货
