BC847B RFG
BC847B RFG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOT-23
    BC847B RFG
BC847B RFG 数据手册
BC846A/B, BC847A/B/C, BC848A/B/C Taiwan Semiconductor Small Signal Product 200mW, NPN Small Signal Transistor FEATURES - Epitaxial planar die construction - Surface mount device type - Moisture sensitivity level 1 - Matte Tin(Sn) lead finish with Nickel(Ni) under plate - Pb free and RoHS compliant - Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC - Halogen-free according to IEC 61249-2-21 SOT-23 MECHANICAL DATA - Case: SOT- 23 small outline plastic package - Terminal: Matte tin plated, lead free, solderable per MIL-STD-202, Method 208 guaranteed - High temperature soldering guaranteed: 260°C/10s - Weight: 8mg (approximately) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) PARAMETER Power dissipation SYMBOL PD VALUE 200 80 UNIT mW VCBO 50 V BC846 Collector-Base Voltage BC847 Collector-Emitter Voltage BC848 30 BC846 65 VCEO BC847 Emitter-Base Voltage BC848 30 BC846 6 VEBO BC847 V 45 V 6 BC848 5 Collector Current Junction and Storage Temperature Range IC 0.1 A TJ , TSTG -55 to +150 °C Notes: 1. Valid provided that electrodes are kept at ambient temperature PARAMETER SYMBOL Collector-Emitter Breakdown Voltage BC847 IC= 10μA IE= 0 V(BR)CBO 30 BC846 65 IC= 10mA IB = 0 V(BR)CEO - V 45 - V - V 6 BC846 BC847 UNIT 30 BC848 Emitter-Base Breakdown Voltage 50 BC848 BC847 MAX 80 BC846 Collector-Base Breakdown Voltage MIN IE= 1μA IC= 0 V(BR)EBO 6 5 BC848 Collector Cut-off Current VCB= 30V IE = 0 ICBO - 100 nA Emitter Cut-off Current VEB= 5 V IC=0 IEBO - 0.1 μA 110 220 200 450 420 800 BC846A, BC847A, BC848A DC Current Gain BC846B, BC847B, BC848B VCE= 5V IC= 2mA hFE BC847C, BC848C Collector-Emitter Saturation Voltage Base-Emitter Saturation Voltage Transition frequency Document Number: DS_S1404004 VCE= 5V IC= 100mA IB= 5mA VCE(sat) - 0.5 V IC= 100mA IB= 5mA VBE(sat) - 1.1 V fT 100 - MHz IC= 10 mA f= 100MHz Version: H15 BC846A/B, BC847A/B/C, BC848A/B/C Taiwan Semiconductor Small Signal Product RATINGS AND CHARACTERISTICS CURVES (TA=25°C unless otherwise noted) Fig.1 Static Characteristic Fig.2 DC Current Gain 400 100 IB = 400μA 80 IC[mA], Collector Current (1) IB = 350μA 300 IB = 300μA (2) IB = 250μA 60 hFE 200 IB = 200μA (3) IB = 150μA 40 100 IB = 100μA 20 0 IB = 50μA 0 0 0 4 8 12 16 1 10 100 1000 IC (mA) VCE = 5 V. (1) Tamb = 150 °C. (2) Tamb = 25 °C. (3) Tamb = -55 °C. 20 VCE[V], Collector-Emitter Voltage Fig. 4 Base-Emitter On Voltage Fig.3 Base-Emitter Saturation Voltage Collector-Emitter Saturation Voltage 100 1200 VCE = 2V 1000 IC[mA], Collector Current (1) VBE(mV) 800 600 (2) 400 (3) 200 10 1 0 0.1 1 10 100 1000 0.1 VCE = 5 V. (1) Tamb = -55 °C. (2) Tamb = 25 °C. (3) Tamb = 150 °C. 0 0.4 0.6 0.8 1 1.2 VBE[V], Base-Emitter Voltage Fig.5 Collector Output Capacitance Fig. 6 Current Gain Bandwidth Product 100 10 1 0.1 1 10 100 VCB[V], Collector-Base Voltage Document Number: DS_S1404004 1000 fT[MHz], Current Gain-Bandwidth Product 1000 f=1MHz Cob[pF], Capacitance 0.2 VCE=5V 100 10 1 0.1 1 10 100 IC[mA], Collector Current Version: H15 BC846A/B, BC847A/B/C, BC848A/B/C Taiwan Semiconductor Small Signal Product ORDERING INFORMATION PART NO. PACKING CODE BC84xx (Note 1) RF R5 PACKING CODE SUFFIX G PACKAGE PACKING SOT-23 3K / 7" Reel 10K / 13" Reel Note 1: "xx" is device code from "BC846A" ~ "BC848C", detail could follow the previous page EXAMPLE EXAMPLE P/N PART NO. PACKING CODE BC846A RFG BC846A RF PACKING CODE DESCRIPTION SUFFIX G Green compound DIMENSIONS SOT-23 DIM. Unit (mm) Unit (inch) Min Max Min Max A 2.70 3.10 0.106 0.122 B 1.10 1.50 0.043 0.059 C 0.30 0.51 0.012 0.020 D 1.78 2.04 0.070 0.080 E 2.10 2.64 0.083 0.104 F 0.89 1.30 0.035 0.051 G 0.55 REF 0.022 REF H 0.1 REF 0.004 REF Unit (mm) Unit (inch) Typ. Typ. SUGGEST PAD LAYOUT DIM. Z 2.90 0.114 X 0.80 0.031 Y 0.90 0.035 C 2.00 0.079 E 1.35 0.053 MARKING CODE PART NO. MARKING BC846A 1A BC846B 1B BC847A 1E BC847B 1F BC847C 1G BC848A 1J BC848B 1K BC848C 1L Document Number: DS_S1404004 Version: H15 BC846A/B, BC847A/B/C, BC848A/B/C Taiwan Semiconductor Small Signal Product Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Document Number: DS_S1404004 Version: H15
BC847B RFG 价格&库存
很抱歉,暂时无法提供与“BC847B RFG”相匹配的价格&库存,您可以联系我们找货
BC847B RFG
  • 3000+0.292813000+0.03793
  • 6000+0.260466000+0.03374
  • 9000+0.243939000+0.03160
  • 15000+0.2253315000+0.02919
  • 21000+0.2143221000+0.02776
  • 30000+0.2036030000+0.02638
库存:12766
BC847B RFG
  • 1+1.485301+0.19260
  • 10+0.9031010+0.11710
  • 100+0.56060100+0.07270
  • 500+0.41200500+0.05340
  • 1000+0.359301000+0.04660
  • 3000+0.289903000+0.03760
  • 6000+0.280306000+0.03640
  • 9000+0.245509000+0.03190
  • 24000+0.1928024000+0.02500
库存:14629
BC847B RFG
  • 1+0.32808
  • 10+0.24303
  • 100+0.19321
  • 500+0.18027
  • 1000+0.17380
  • 3000+0.15895
  • 6000+0.14972
  • 9000+0.14505
  • 21000+0.13499
  • 30000+0.13128
库存:1177
BC847B RFG
    BC847B RFG
    • 1+1.503911+0.19481
    • 10+0.9087510+0.11772
    • 100+0.56093100+0.07266
    • 500+0.40681500+0.05270
    • 1000+0.356791000+0.04622
    库存:12766
