BC856A SERIES
Taiwan Semiconductor
Small Signal Product
200mW, PNP Small Signal Transistor
FEATURES
- Epitaxial planar die construction
- Surface device type mounting
- Moisture sensitivity level 1
- Matte Tin(Sn) lead finish with Nickel(Ni) underplate
- Pb free and RoHS compliant
- Green compound (Halogen free) with suffix "G" on
packing code and prefix "G" on date code
MECHANICAL DATA
- Case : SOT- 23 small outline plastic package
- Terminal : Matte tin plated, lead free, solderable
per MIL-STD-202, method 208 guaranteed
- High temperature soldering guaranteed : 260°C/10s
SOT-23
- Weight : 0.008 grams (approximately)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted)
PARAMETER
Power Dissipation
SYMBOL
VALUE
UNIT
PD
200
mW
BC856
Collector-Base Voltage
-80
VCBO
BC857
-50
BC858
-30
BC856
Collector-Emitter Voltage
-65
VCEO
BC857
-45
BC858
Collector Current
Junction and Storage Temperature Range
PARAMETER
VEBO
-5
V
IC
-0.1
A
TJ , TSTG
-55 to + 150
°C
SYMBOL
BC856
BC857
IC= -10μA
IE = 0
V(BR)CBO
BC858
BC856
Collector-Emitter Breakdown
Voltage
BC857
IC= -10mA
IB = 0
V(BR)CEO
BC858
IE= -1μA
Emitter-Base Breakdown Voltage
Collector Cut-off Current
BC856
VCB= -70V
BC857
VCB= -45V
BC858
VCB= -25V
VEB= -5V
Emitter Cut-off Current
IC= 0
IE = 0
IC=0
V(BR)EBO
ICBO
IEBO
BC856A, BC857A, BC858A
DC Current Gain
BC856B, BC857B, BC858B
VCE= -5V
V
-30
Emitter-Base Voltage
Collector-Base Breakdown
Voltage
V
IC= -2mA
hFE
BC857C, BC858C
MIN
MAX
-80
-50
-30
UNIT
V
-65
-45
-30
-5
-100
-100
-100
V
V
-0.1
125
250
220
475
420
800
nA
μA
Collector-Emitter Saturation Voltage
IC= -100mA
IB= -5mA
VCE(sat)
-0.65
Base-Emitter Saturation Voltage
IC= -100mA
IB= -5mA
VBE(sat)
-1.1
V
IC= -10mA
f= 100MHz
fT
100
MHz
Transition Frequency
VCE= -5V
V
Version : H1606
BC856A SERIES
RATINGS AND CHARACTERISTIC CURVES
Fig. 2 DC Current Gain
Fig. 1 Static Characteristic
1000
50
45
IB = -400μA
IB = -300μA
35
30
IB = -250μA
25
IB =- 200μA
hFE, DC Current Gain
IC[mA], Collector Current
VCE = - 5V
IB = -350μA
40
IB = -150μA
15
IB = -100μA
10
5
IB = -50μA
4
6
8
10
12
14
16
100
10
18
-0.1
Fig.3 Base-Emitter Saturation Voltage
VS.Collector-Emitter Saturation
3
-100.
4
IC = 10 IB
VCE = - 5V
VBE(sat)
1
VCE(sat)
0.1
5
-10.
1
-1.
-0.
0.01
0.1
1
10
-0.0
100
-0.2
-0.4
-0.6
-0.8
-1.0
-1.2
VBE[V], Base-Emitter Voltage
Fig. 6 Current Gain Bandwidth Product
Fig.5 Collector Output Capacitance
f=1MHz IE=0
10
1
-1.
-10.
-100.
-1000.
fT[MHz], Current Gain-Bandwidth Product
1000
100
1
2
Fig. 4 Base-Emitter On Voltage
10
VBE(sat), VCE(sat)[V], Saturation Voltage
-100.0
VCE[V], Collector-Emitter Voltage
Cob[pF], Capacitance
-10.0
f=1MHz IE=0
100
10
1
-0.
-1.
-10.
-100.
VCB[V], Collector-Base Voltage
Version : H1606
BC856A SERIES
Fig. 7 DC Current Gain as a Function of
Collector Current; Typical Values
Fig. 8 Base-Emitter Voltage as a Function of
hFE - IC
500
VBE - IC
1200
hFE 450
BC857A: VCE=5V
400
350
BC857A: VCE=-5V
1000
Ta=55OC
800
Ta=150OC
300
VBE
250
600
Ta=25OC
200
150
100
200
50
Ta=25OC
400
Ta=55OC
2
Ta=150OC
0.1
1
10
100
1000
-IC(mA)
0.01
0.1
1
10
100
1000
3
-IC(mA)
4
5
1
Version : H1606
BC856A SERIES
Ordering information
Part No.
Packing
Packing code
code
suffix(*)
BC85xx
RF
(Note 1)
Note 1 : "xx" is Device Code from "6A" thru "8C".
G
Package
Packing
SOT-23
3K / 7 " Reel
*: optional available
Example
Preferred
Part No.
BC856A RFG
Part No.
BC856A
Packing
Packing code
code
suffix
RF
G
Description
Green compound
Version : H1606
BC856A SERIES
Dimensions
DIM.
Unit(mm)
Unit(inch)
Min
Max
Min
Max
A
2.70
3.10
0.106
0.122
B
1.10
1.50
0.043
0.059
C
0.30
0.51
0.012
0.020
D
1.78
2.04
0.070
0.080
E
2.20
2.60
0.087
0.102
F
G
0.90
1.30
0.550 REF
0.035
0.051
0.022 REF
H
0.1 REF
0.004 REF
Unit(mm)
Unit(inch)
Suggested PAD Layout
DIM.
Typ.
Typ.
A
0.95
0.037
B
2.0
0.079
C
0.9
0.035
D
0.8
0.031
Marking
Part No.
Marking
BC856A
3A
BC856B
BC857A
3B
3E
BC857B
3F
BC857C
3G
BC858A
3J
BC858B
3K
BC858C
3L
Version : H1606
BC856A SERIES
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied,to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or seling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version : H1606
很抱歉,暂时无法提供与“BC857A RFG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1.508621+0.19528
- 10+0.9383410+0.12146
- 100+0.57606100+0.07457
- 500+0.41799500+0.05411
- 1000+0.366671000+0.04747
- 国内价格 香港价格
- 3000+0.301073000+0.03897
- 6000+0.267936000+0.03468
- 9000+0.250999000+0.03249
- 15000+0.2319415000+0.03003
- 21000+0.2206421000+0.02856
- 30000+0.2096530000+0.02714
