1PGSMA4740 – 1PGSMA200Z
Taiwan Semiconductor
1W, 10V - 200V Surface Mount Zener Diode
FEATURES
KEY PARAMETERS
Photo Glass passivated chip junction
Ideal for automated placement
Low inductance
Typical IR less than 1μA above 11V
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
VZ
10 - 200
V
Test current IZT
1.2 - 25
mA
Ptot
1
W
TJ MAX
175
°C
Package
DO-214AC (SMA)
Configuration
Single die
● For general purpose regulation and protection applications
MECHANICAL DATA
Case: DO-214AC (SMA)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.060g (approximately)
DO-214AC (SMA)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
VALUE
UNIT
VF
1.2
V
Ptot
1.25
W
Total power dissipation at TA = 75°C
Ptot
1
W
Junction temperature
TJ
-55 to +175
°C
TSTG
-55 to +175
°C
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
29
°C/W
Junction-to-ambient thermal resistance
RӨJA
120
°C/W
Junction-to-case thermal resistance
RӨJC
31
°C/W
Forward voltage @ IF = 200mA
Total power dissipation at TA = 50°C, derate above 50°C
(1)
Storage temperature
Notes:
1. Mounted on 5mm x 5mm Cu pad test board
THERMAL PERFORMANCE
PARAMETER
Thermal Performance Note: Units mounted on PCB (5mm x 5mm Cu pad test board)
1
Version: B2102
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
Part number
(Note 1)
Marking
code
1PGSMA4740
1PGSMA4741
1PGSMA4742
1PGSMA4743
1PGSMA4744
1PGSMA4745
1PGSMA4746
1PGSMA4747
1PGSMA4748
1PGSMA4749
1PGSMA4750
1PGSMA4751
1PGSMA4752
1PGSMA4753
1PGSMA4754
1PGSMA4755
1PGSMA4756
1PGSMA4757
1PGSMA4758
1PGSMA4759
1PGSMA4760
1PGSMA4761
1PGSMA4762
1PGSMA4763
1PGSMA4764
1PGSMA110Z
1PGSMA120Z
1PGSMA130Z
1PGSMA150Z
1PGSMA160Z
1PGSMA180Z
1PGSMA200Z
P740A
P741A
P742A
P743A
P744A
P745A
P746A
P747A
P748A
P749A
P750A
P751A
P752A
P753A
P754A
P755A
P756A
P757A
P758A
P759A
P760A
P761A
P762A
P763A
P764A
P110A
P120A
P130A
P150A
P160A
P180A
P200A
Zener voltage
VZ @ IZ
V
Min Nom Max
9.5
10
10.5
10.5
11
11.6
11.4
12
12.6
12.4
13
13.7
14.3
15
15.8
15.2
16
16.8
17.1
18
18.9
19
20.9
22
23.1
22.8
24
25.2
25.7
27
28.4
28.5
30
31.5
31.4
33
34.7
34.2
36
37.8
37.1
39
41
40.9
43
45.2
44.7
47
49.4
48.5
51
53.6
53.2
56
58.8
58.9
62
65.1
64.6
68
71.4
71.3
75
78.8
77.9
82
86.1
86.5
91
95.6
95
100 105
104.5 110 115.5
114 120 126
123.5 130 136.5
142.5 150 157.5
152 160 168
171 180 189
190 200 210
Test
current
Regulator
impedance
Test
current
Leakage
current
Maximum DC
Zener Current
IZT
mA
ZZT @ IZT ZZK @ IZK
Ω
Ω
Max
Max
7
700
8
700
9
700
10
700
14
700
16
700
22
750
23
750
25
750
35
750
40
1000
45
1000
50
1000
60
1000
70
1500
80
1500
95
1500
110
2000
125
2000
150
2000
175
2000
200
3000
250
3000
350
3000
450
4000
550
4500
700
5000
1000
6000
1100
6500
1200
7000
1500
8000
IZK
mA
IR @ V R
µA
V
Max
5
7.6
1
8.4
1
9.1
1
9.9
1
11.4
1
12.2
1
13.7
1
15.2
1
16.7
1
18.2
1
20.6
1
22.8
1
25.1
1
27.4
1
29.7
1
32.7
1
35.8
1
38.8
1
42.6
1
47.1
1
51.7
1
56.0
1
62.2
1
69.2
1
76.0
1
83.6
1
91.2
1
98.8
1
114.0
1
121.6
1
136.8
1
152.0
IZM
mA
Max
91
83
76
69
61
57
50
45
41
38
34
30
27
25
23
22
19
18
16
14
13
12
11
10
9
8.9
8.3
7.7
6.7
6.3
5.6
5.0
25
23
21
19
17
15.5
14.0
12.5
11.5
10.5
9.5
8.5
7.5
7.0
6.5
6.0
5.5
5.0
4.5
4.0
3.7
3.3
3.0
2.8
2.5
2.3
2.0
1.9
1.7
1.6
1.4
1.2
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
Note:
1. Tolerance and Voltage Regulation Designation. The type number listed indicates a tolerance of ±5%.
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
1PGSMAx
DO-214AC (SMA)
7,500 / Tape & Reel
Notes:
1. “x” defines voltage from 10V(1PGSMA4740) to 200V(1PGSMA200Z)
2
Version: B2102
CHARACTERISTICS CURVES
Fig.2 Typical Junction Capacitance
1.5
1000
1
100
CAPACITANCE (pF)
Ptot - Total Power Dissipation (W)
Fig.1 Steady State Power Derating
0.5
50
75
100
125
150
1PGSMA4742
1PGSMA4756
10
1PGSMA200Z
f=1.0MHz
Vsig=50mVp-p
1
175
1
AMBIENT TEMPERATURE (°C)
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Zener Impedance
Zz - DYNAMIC IMPEDANCE (Ω)
10000
1000
1PGSMA4742
100
1PGSMA4756
10
1PGSMA200Z
1
0.1
1
10
100
Iz - ZENER TEST CURRENT (mA)
3
Version: B2102
PACKAGE OUTLINE DIMENSIONS
DO-214AC (SMA)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: B2102
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to any
intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for
such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale
and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability,
or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: B2102
很抱歉,暂时无法提供与“1PGSMA150ZHR3G”相匹配的价格&库存,您可以联系我们找货
