SZMM3Z11VT1GX
SZMM3Z11VT1GX
    NEXPERIA(安世)
    SOD-323
    SZMM3Z11VT1G/SOD323/SOD2
SZMM3Z11VT1GX 数据手册
SZMM3Z series Voltage regulator diodes Rev. 2 — 30 March 2021 Product data sheet 1. General description General-purpose Zener diodes in a very small SOD323 (SC-76) Surface-Mounted Device (SMD) plastic package. 2. Features and benefits • • • • • • Non-repetitive peak reverse power disspation: ≤ 40 W Total power dissipation: ≤ 300 mW Tolerance series: ± 5 % Wide working voltage range: nominal 2.4 V to 75 V Low differential resistance AEC-Q101 qualified 3. Applications • General regulation functions 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions VF forward voltage IF = 100 mA PZSM non-repetitive peak reverse power dissipation [1] [2] Min Typ Max Unit [1] - - 1.1 V [2] - - 40 W Pulse test: tp ≤ 300 μs; δ ≤ 0.02 tp = 100 µs; square wave; Tj = 25 °C before surge 5. Pinning information Table 2. Pinning Pin Symbol Description 1 K cathode[1] 2 A anode Simplified outline 1 2 Graphic symbol K A 006aaa152 [1] The marking bar indicates the cathode. SZMM3Z series Nexperia Voltage regulator diodes 6. Ordering information Table 3. Ordering information Type number Package SZMM3Z2V4T1G to SZMM3Z75VT1G[1] [1] Name Description Version SC-76 plastic surface-mounted package; 2 leads SOD323 The series consists of 37 types with nominal working voltages from 2.4 V to 75 V. 7. Marking Table 4. Marking Codes Type number Marking Code Type number Marking Code SZMM3Z2V4T1G X8 SZMM3Z15VT1G VV SZMM3Z2V7T1G X9 SZMM3Z16VT1G VZ SZMM3Z3V0T1G XT SZMM3Z18VT1G X4 SZMM3Z3V3T1G XW SZMM3Z20VT1G XC SZMM3Z3V6T1G XZ SZMM3Z22VT1G XG SZMM3Z3V9T1G ME SZMM3Z24VT1G XM SZMM3Z4V3T1G MM SZMM3Z27VT1G DK SZMM3Z4V7T1G MS SZMM3Z30VT1G DL SZMM3Z5V1T1G MW SZMM3Z33VT1G DM SZMM3Z5V6T1G LF SZMM3Z36VT1G DN SZMM3Z6V2T1G LL SZMM3Z39VT1G DP SZMM3Z6V8T1G LR SZMM3Z43VT1G DR SZMM3Z7V5T1G LV SZMM3Z47VT1G DS SZMM3Z8V2T1G LZ SZMM3Z51VT1G DT SZMM3Z9V1T1G CU SZMM3Z56VT1G DU SZMM3Z10VT1G VA SZMM3Z62VT1G DV SZMM3Z11VT1G VE SZMM3Z68VT1G DW SZMM3Z12VT1G VK SZMM3Z75VT1G DX SZMM3Z13VT1G VP - - SZMM3Z_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 March 2021 © Nexperia B.V. 2021. All rights reserved 2 / 12 SZMM3Z series Nexperia Voltage regulator diodes 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Min Max Unit IF forward current - 200 mA PZSM non-repetitive peak reverse power dissipation tp = 100 µs; square wave; Tamb = 25 °C; prior to surge - - 40 W Ptot total power dissipation Tamb = 25 °C [1] - 300 mW Tj junction temperature - 150 °C Tamb ambient temperature −55 +150 °C Tstg storage temperature −65 +150 °C [1] Conditions Device mounted on an FR4 Printed-Circuit Board (PCB) , single-sided copper, tin-plated and standard footprint. 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air Rth(j-sp) thermal resistance from junction to solder point [1] [2] Min Typ Max Unit [1] - - 415 K/W [2] - - 110 K/W Device mounted on an FR4 Printed-Circuit Board (PCB) , single-sided copper, tin-plated and standard footprint. Soldering point of cathode tab 10. Characteristics Table 7. Electrical characteristics Tj = 25 °C unless otherwise specified. Symbol Parameter Conditions VF forward voltage IF = 10 mA IF = 100 mA [1] Max Unit [1] 0.9 V [1] 1.1 V Pulse test: tp ≤ 300 μs; δ ≤ 0.02 SZMM3Z_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 March 2021 © Nexperia B.V. 2021. All rights reserved 3 / 12 SZMM3Z series Nexperia Voltage regulator diodes Table 8. Electrical characteristics per type: SZMM3Z2V4T1G to SZMM3Z24VT1G Tj = 25 °C unless otherwise specified. SZMM3ZxxxT1G Working voltage Reverse current VZ (V) IR (µA) IZ = 5 mA Differential resistance rdiff (Ω) IZ = 0.5 IZ = 5 mA mA Temperature coefficient SZ (mV/K) IZ = 5 mA Diode capacitance Cd (pF)[1] Min Max Max Max Min Max Max 2.30 2.60 50.0 VR (V) 1.0 Max 2V4 1000 100 -3.5 0 450 2V7 2.50 2.90 20.0 1.0 1000 100 -3.5 0 440 3V0 2.80 3.20 10.0 1.0 1000 95 -3.5 0 425 3V3 3.10 3.50 5.0 1.0 1000 95 -3.5 0 410 3V6 3.40 3.80 5.0 1.0 1000 90 -3.5 0 390 3V9 3.70 4.10 3.0 1.0 1000 90 -3.5 0 370 4V3 4.01 4.48 3.0 1.0 1000 90 -3.5 0 350 4V7 4.42 4.90 2.0 1.0 800 80 -3.5 0.2 325 5V1 4.84 5.37 2.0 1.5 250 60 -2.7 1.2 300 5V6 5.31 5.92 1.0 2.5 100 40 -2.0 2.5 275 6V2 5.86 6.53 0.5 3.0 80 30 0.4 3.7 250 6V8 6.47 7.14 0.5 3.5 60 20 1.2 4.5 215 7V5 7.06 7.84 0.5 4.0 60 10 2.5 5.3 170 8V2 7.76 8.64 0.5 5.0 60 10 3.2 6.2 150 9V1 8.56 9.55 0.5 6.0 60 10 3.8 7.0 120 10V 9.45 10.55 0.1 7.0 60 10 4.5 8.0 110 11V 10.44 11.56 0.1 8.0 60 10 5.4 9.0 108 12V 11.42 12.60 0.1 9.0 80 10 6.0 10.0 105 13V 12.47 13.96 0.1 10.0 80 10 7.0 11.0 103 15V 13.84 15.52 0.05 11.0 80 15 9.2 13.0 99 16V 15.37 17.09 0.05 12.0 80 20 10.4 14.0 97 18V 16.94 19.03 0.05 13.0 80 20 12.4 16.0 93 20V 18.86 21.08 0.05 15.0 100 20 14.4 18.0 88 22V 20.88 23.17 0.05 17.0 100 25 16.4 20.0 84 24V 22.93 25.57 0.05 19.0 120 30 18.4 22.0 80 [1] f = 1 MHz; VR = 0 V SZMM3Z_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 March 2021 © Nexperia B.V. 2021. All rights reserved 4 / 12 SZMM3Z series Nexperia Voltage regulator diodes Table 9. Electrical characteristics per type: SZMM3Z27VT1G to SZMM3Z75VT1G Tj = 25 °C unless otherwise specified. SZMM3ZxxxT1G Working voltage Reverse current VZ (V) IR (µA) IZ = 2 mA Differential resistance rdiff (Ω) IZ = 0.5 IZ = 2 mA mA Temperature coefficient SZ (mV/K) IZ = 2 mA Diode capacitance Cd (pF)[1] Min Max Max Max Min Max Max 25.10 28.90 0.05 VR (V) 18.9 Max 27V 300 80 21.4 25.3 50 30V 28.00 32.00 0.05 21.0 300 80 24.4 29.4 50 33V 31.00 35.00 0.05 23.1 325 80 27.4 33.4 45 36V 34.00 38.00 0.05 25.2 350 90 30.4 37.4 45 39V 37.00 41.00 0.05 27.3 350 130 33.4 41.2 45 43V 40.00 46.00 0.05 30.1 375 150 37.6 46.6 40 47V 44.00 50.00 0.05 32.9 375 170 42.0 51.8 40 51V 48.00 54.00 0.05 35.7 400 180 46.6 57.2 40 56V 52.00 60.00 0.05 39.2 425 200 52.2 63.8 40 62V 58.00 66.00 0.05 43.4 450 215 58.8 71.6 35 68V 64.00 72.00 0.05 47.6 475 240 65.6 79.8 35 75V 70.00 79.00 0.05 52.5 500 255 73.4 88.6 35 [1] f = 1 MHz; VR = 0 V SZMM3Z_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 March 2021 © Nexperia B.V. 2021. All rights reserved 5 / 12 SZMM3Z series Nexperia Voltage regulator diodes aaa-032515 103 IF (mA) 102 10 10 1 1 10-1 10-1 10-2 10-2 10-3 0.4 0.6 0.8 VF (V) 1.0 10-3 0.4 Tj = 25 ° C Fig. 1. aaa-032517 103 IF (mA) 102 Fig. 2. 1 1 10-1 10-1 10-2 10-2 0.6 0.8 VF (V) 1.0 10-3 0.4 Tj = 25 ° C 1.0 aaa-028553 0.6 0.8 VF (V) 1.0 Tj = 25 ° C Forward current as a function of forward voltage; typical values (SZMM3Z7V5T1G) Product data sheet VF (V) 103 IF (mA) 102 10 SZMM3Z_SER 0.8 Forward current as a function of forward voltage; typical values (SZMM3Z6V8T1G) 10 Fig. 3. 0.6 Tj = 25 ° C Forward current as a function of forward voltage; typical values (SZMM3Z2V4T1G) 10-3 0.4 aaa-032516 103 IF (mA) 102 Fig. 4. Forward current as a function of forward voltage; typical values (SZMM3Z75VT1G) All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 March 2021 © Nexperia B.V. 2021. All rights reserved 6 / 12 SZMM3Z series Nexperia Voltage regulator diodes mgl273 0 SZ (mV/K) 12 SZ (mV/K) 4.3 -1 mgl274 10 11 10 9.1 8.2 7.5 6.8 5 3.9 3.6 -2 3.3 6.2 5.6 5.1 0 4.7 3.0 2.4 2.7 -3 0 20 40 IZ (mA) -5 60 Tj = 25 °C to 150 °C VZ = 2.4 V to 4.3 V Fig. 5. 0 4 8 12 IZ (mA) 20 Tj = 25 °C to 150 °C VZ = 4.7 V to 12 V Temperature coefficient as a function of working current; typical values (SZMM3Z2V4T1G to 4V3T1G) Fig. 6. aaa-032523 10-1 IR (A) Temperature coefficient as a function of working current; typical values (SZMM3Z4V7T1G to 12VT1G) aaa-032524 10-1 IR (A) 2.4 2.7 10-2 3.0 3.6 3.3 3.9 4.3 10-2 4.7 5.6 6.8 6.2 10-3 10-3 10-4 10-4 10-5 10-5 10-6 0 1 2 3 4 VR (V) 5 10-6 Tj = 25 °C Fig. 7. 16 Product data sheet 0 2 4 6 8.2 7.5 8 11 10 10 12 12 14 VR (V) Tj = 25 °C Reverse current as a function of reverse voltage; typical values (SZMM3Z2V4T1G to 4V3T1G) SZMM3Z_SER 5.1 9.1 Fig. 8. Reverse current as a function of reverse voltage; typical values (SZMM3Z4V7T1G to 12VT1G) All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 March 2021 © Nexperia B.V. 2021. All rights reserved 7 / 12 SZMM3Z series Nexperia Voltage regulator diodes aaa-032251 10-1 IR (A) IR (A) 10-2 aaa-006667 10-1 30 36 10-2 27 33 43 39 51 47 62 56 75 68 10-3 13 10-3 15 16 18 20 22 24 10-4 10-5 10-4 10-6 10-7 10-5 10-8 10-6 10 13 16 19 22 VR (V) 10-9 25 Tj = 25 °C Fig. 9. 20 40 60 VR (V) 80 Tj = 25 °C Reverse current as a function of reverse voltage; typical values (SZMM3Z13VT1G to 24VT1G) Fig. 10. Reverse current as a function of reverse voltage; typical values (SZMM3Z27VT1G to 75VT1G) 11. Test information Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 12. Package outline 1.35 1.15 1.1 0.8 0.45 0.15 1 2.7 2.3 1.8 1.6 2 0.40 0.25 0.25 0.10 Dimensions in mm 03-12-17 Fig. 11. Package outline SOD323 (SC-76) SZMM3Z_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 March 2021 © Nexperia B.V. 2021. All rights reserved 8 / 12 SZMM3Z series Nexperia Voltage regulator diodes 13. Soldering 3.05 2.1 solder lands solder resist 1.65 0.95 0.5 (2×) 0.6 (2×) solder paste occupied area 2.2 Dimensions in mm 0.5 (2×) 0.6 (2×) sod323_fr Fig. 12. Reflow soldering footprint SOD323 (SC-76) 5 2.9 1.5 (2×) solder lands solder resist occupied area 2.75 1.2 (2×) Dimensions in mm preferred transport direction during soldering sod323_fw Fig. 13. Wave soldering footprint SOD323 (SC-76) SZMM3Z_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 March 2021 © Nexperia B.V. 2021. All rights reserved 9 / 12 SZMM3Z series Nexperia Voltage regulator diodes 14. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes SZMM3Z_SER v.2 20210330 Product data sheet - SZMM3Z_SER v.1 Modifications: • SZMM3Z_SER v.1 20201210 - - SZMM3Z_SER Product data sheet Ordering information corrected Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 March 2021 © Nexperia B.V. 2021. All rights reserved 10 / 12 SZMM3Z series Nexperia Voltage regulator diodes equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 15. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or SZMM3Z_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 March 2021 © Nexperia B.V. 2021. All rights reserved 11 / 12 SZMM3Z series Nexperia Voltage regulator diodes Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................1 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 3 10. Characteristics............................................................ 3 11. Test information.......................................................... 8 12. Package outline.......................................................... 8 13. Soldering..................................................................... 9 14. Revision history........................................................10 15. Legal information......................................................11 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 30 March 2021 SZMM3Z_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 March 2021 © Nexperia B.V. 2021. All rights reserved 12 / 12
SZMM3Z11VT1GX
物料型号:SZMM3Z系列,包含37种型号,工作电压从2.4V至75V。
器件简介:这是一系列通用的Zener二极管,采用非常小型的SOD323 (SC-76)表面贴装设备(SMD)塑料封装。
引脚分配:有两个引脚,1号引脚标有K表示阴极,2号引脚为阳极。
参数特性: - 非重复峰值反向功率耗散:≤ 40 W - 总功率耗散:≤ 300 mW - 容差系列:± 5 % - 宽工作电压范围:标称2.4 V至75 V - 低微分电阻 - AEC-Q101认证
功能详解:适用于一般调节功能。
应用信息:文档中提到了一般调节功能的应用。
封装信息:SC-76塑料表面贴装封装,2个引脚。
SZMM3Z11VT1GX 价格&库存
很抱歉,暂时无法提供与“SZMM3Z11VT1GX”相匹配的价格&库存,您可以联系我们找货
SZMM3Z11VT1GX
  • 5+1.36448
  • 10+0.83055
  • 100+0.51139
  • 500+0.37612
  • 1000+0.32985
  • 5000+0.27646
库存:735
SZMM3Z11VT1GX
    • 1+1.40400
    • 200+1.32550
    库存:100
    SZMM3Z11VT1GX
    • 3000+0.441433000+0.05703
    • 6000+0.395186000+0.05106
    • 9000+0.371569000+0.04801
    • 15000+0.3450115000+0.04458
    • 21000+0.3292721000+0.04254
    • 30000+0.3139730000+0.04057
    库存:26970
    SZMM3Z11VT1GX
    • 5+1.36448
    • 10+0.83055
    • 100+0.51139
    • 500+0.37612
    • 1000+0.32985
    • 5000+0.27646
    库存:735
    SZMM3Z11VT1GX
    • 1+2.204411+0.28480
    • 10+1.3301010+0.17184
    • 100+0.82607100+0.10673
    • 500+0.60484500+0.07814
    • 1000+0.532991000+0.06886
    库存:26970
