TIP47
TIP47
    L3HARRIS
    TO-220-3
    POWER BIPOLAR TRANSISTOR
TIP47 数据手册
TIP47 / TIP48 / TIP49 / TIP50 NPN Silicon Transistor Features • High-Voltage and Switching Applications • High Sustaining Voltage: VCEO(sus) = 250 V, 300 V, 350 V, 400 V • 1 A Rated Collector Current TO-220 1 1.Base 2.Collector 3.Emitter Ordering Information Part Number Top Mark Package Packing Method TIP47 TIP47 TO-220 3L (Single Gauge) Bulk TIP47TU TIP47 TO-220 3L (Single Gauge) Rail Bulk TIP48 TIP48 TO-220 3L (Single Gauge) TIP48TU TIP48 TO-220 3L (Single Gauge) Rail TIP49 TIP49 TO-220 3L (Single Gauge) Bulk TIP50 TIP50 TO-220 3L (Single Gauge) Bulk TIP50TU TIP50 TO-220 3L (Single Gauge) Rail Absolute Maximum Ratings Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be operable above the recommended operating conditions and stressing the parts to these levels is not recommended. In addition, extended exposure to stresses above the recommended operating conditions may affect device reliability. The absolute maximum ratings are stress ratings only. Values are at TC = 25°C unless otherwise noted. Symbol VCBO Parameter Collector-Base Voltage VCEO Collector-Emitter Voltage VEBO Emitter-Base Voltage Value TIP47 350 TIP48 400 TIP49 450 TIP50 500 TIP47 250 TIP48 300 TIP49 350 TIP50 400 5 Unit V V V IC Collector Current (DC) 1 A ICP Collector Current (Pulse) 2 A IB Base Current 0.6 A TJ Junction Temperature 150 °C - 65 to 150 °C TSTG Storage Temperature Range © 2000 Fairchild Semiconductor Corporation TIP47 / TIP48 / TIP49 / TIP50 Rev. 1.1.0 www.fairchildsemi.com TIP47 / TIP48 / TIP49 / TIP50 — NPN Silicon Transistor November 2014 Values are at TC = 25°C unless otherwise noted. Symbol PC Parameter Value Collector Dissipation (TC = 25°C) 40 Collector Dissipation (TA = 25°C) 2 Unit W Electrical Characteristics Values are at TC = 25°C unless otherwise noted. Symbol Parameter Conditions Collector-Emitter Sustaining Voltage(1) TIP48 IC = 30 mA, IB = 0 TIP49 TIP50 ICEO ICES IEBO hFE Collector Cut-Off Current Collector Cut-Off Current Typ. Max. Unit 250 TIP47 VCEO(sus) Min. 300 V 350 400 TIP47 VCE = 150 V, IB = 0 1 TIP48 VCE = 200 V, IB = 0 1 TIP49 VCE = 250 V, IB = 0 1 TIP50 VCE = 300 V, IB = 0 1 TIP47 VCE = 350 V, VEB = 0 1 TIP48 VCE = 400 V, VEB = 0 1 TIP49 VCE = 450 V, VEB = 0 1 TIP50 VCE = 500 V, VEB = 0 1 Emitter Cut-Off Current VBE = 5 V, IC = 0 DC Current Gain(1) (1) 1 VCE = 10 V, IC = 0.3 A 30 VCE = 10 V, IC = 1 A 10 mA mA mA 150 VCE(sat) Collector-Emitter Saturation Voltage IC = 1 A, IB = 0.2 A 1 V VBE(on) Base-Emitter On Voltage(1) VCE = 10 V, IC = 1 A 1.5 V Current Gain Bandwidth Product VCE = 10 V, IC = 0.2 A, f = 1 MHz fT 10 MHz Note: 1. Pulse test: pw ≤ 300 μs, duty cycle ≤ 2%. © 2000 Fairchild Semiconductor Corporation TIP47 / TIP48 / TIP49 / TIP50 Rev. 1.1.0 www.fairchildsemi.com 2 TIP47 / TIP48 / TIP49 / TIP50 — NPN Silicon Transistor Thermal Characteristics VBE(sat), VCE(sat)[V], SATURATION VOLTAGE 1000 hFE, DC CURRENT GAIN VCE = 10V 100 10 1 0.01 0.1 1 4 10 I C = 5 IB VBE(sat) 1 VCE(sat) 0.1 0.01 0.01 0.1 Figure 1. DC Current Gain 4 Figure 2. Collector-Emitter Saturation Voltage and Base-Emitter Saturation Voltage 50 s 1m s 0μ 10 μs 500 1 PC[W], POWER DISSIPATION 10 C D. IC[A], COLLECTOR CURRENT 1 IC[A], COLLECTOR CURRENT IC[A], COLLECTOR CURRENT 0.1 TIP47 TIP48 TIP49 TIP50 10 100 20 10 0 1000 VCE[V], COLLECTOR-EMITTER VOLTAGE 25 50 75 100 125 150 175 o TC[ C], CASE TEMPERATURE Figure 3. Safe Operating Area © 2000 Fairchild Semiconductor Corporation TIP47 / TIP48 / TIP49 / TIP50 Rev. 1.1.0 30 0 0.01 1 40 Figure 4. Power Derating www.fairchildsemi.com 3 TIP47 / TIP48 / TIP49 / TIP50 — NPN Silicon Transistor Typical Performance Characteristics TIP47 / TIP48 / TIP49 / TIP50 — NPN Silicon Transistor Physical Dimensions Figure 5. TO-220, MOLDED, 3LEAD, JEDEC VARIATION AB © 2000 Fairchild Semiconductor Corporation TIP47 / TIP48 / TIP49 / TIP50 Rev. 1.1.0 www.fairchildsemi.com 4 TRADEMARKS The following includes registered and unregistered trademarks and service marks, owned by Fairchild Semiconductor and/or its global subsidiaries, and is not intended to be an exhaustive list of all such trademarks. F-PFS¥ FRFET® SM Global Power Resource GreenBridge¥ Green FPS¥ Green FPS¥ e-Series¥ Gmax¥ GTO¥ IntelliMAX¥ ISOPLANAR¥ Making Small Speakers Sound Louder and Better™ MegaBuck¥ MICROCOUPLER¥ MicroFET¥ MicroPak¥ MicroPak2¥ MillerDrive¥ MotionMax¥ MotionGrid® MTi® MTx® MVN® mWSaver® OptoHiT¥ OPTOLOGIC® AccuPower¥ Awinda® AX-CAP®* BitSiC¥ Build it Now¥ CorePLUS¥ CorePOWER¥ CROSSVOLT¥ CTL¥ Current Transfer Logic¥ DEUXPEED® Dual Cool™ EcoSPARK® EfficientMax¥ ESBC¥ ® Fairchild® Fairchild Semiconductor® FACT Quiet Series¥ FACT® FAST® FastvCore¥ FETBench¥ FPS¥ OPTOPLANAR® ® PowerTrench® PowerXS™ Programmable Active Droop¥ QFET® QS¥ Quiet Series¥ RapidConfigure¥ ¥ Saving our world, 1mW/W/kW at a time™ SignalWise¥ SmartMax¥ SMART START¥ Solutions for Your Success¥ SPM® STEALTH¥ SuperFET® SuperSOT¥-3 SuperSOT¥-6 SuperSOT¥-8 SupreMOS® SyncFET¥ Sync-Lock™ ®* ® TinyBoost TinyBuck® TinyCalc¥ TinyLogic® TINYOPTO¥ TinyPower¥ TinyPWM¥ TinyWire¥ TranSiC¥ TriFault Detect¥ TRUECURRENT®* μSerDes¥ UHC® Ultra FRFET¥ UniFET¥ VCX¥ VisualMax¥ VoltagePlus¥ XS™ Xsens™ ௝❺™ * Trademarks of System General Corporation, used under license by Fairchild Semiconductor. DISCLAIMER FAIRCHILD SEMICONDUCTOR RESERVES THE RIGHT TO MAKE CHANGES WITHOUT FURTHER NOTICE TO ANY PRODUCTS HEREIN TO IMPROVE RELIABILITY, FUNCTION, OR DESIGN. TO OBTAIN THE LATEST, MOST UP-TO-DATE DATASHEET AND PRODUCT INFORMATION, VISIT OUR WEBSITE AT HTTP://WWW.FAIRCHILDSEMI.COM. FAIRCHILD DOES NOT ASSUME ANY LIABILITY ARISING OUT OF THE APPLICATION OR USE OF ANY PRODUCT OR CIRCUIT DESCRIBED HEREIN; NEITHER DOES IT CONVEY ANY LICENSE UNDER ITS PATENT RIGHTS, NOR THE RIGHTS OF OTHERS. THESE SPECIFICATIONS DO NOT EXPAND THE TERMS OF FAIRCHILD’S WORLDWIDE TERMS AND CONDITIONS, SPECIFICALLY THE WARRANTY THEREIN, WHICH COVERS THESE PRODUCTS. LIFE SUPPORT POLICY FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF FAIRCHILD SEMICONDUCTOR CORPORATION. As used herein: 1. Life support devices or systems are devices or systems which, (a) are 2. A critical component in any component of a life support, device, or system whose failure to perform can be reasonably expected to intended for surgical implant into the body or (b) support or sustain life, and (c) whose failure to perform when properly used in cause the failure of the life support device or system, or to affect its accordance with instructions for use provided in the labeling, can be safety or effectiveness. reasonably expected to result in a significant injury of the user. ANTI-COUNTERFEITING POLICY Fairchild Semiconductor Corporation's Anti-Counterfeiting Policy. Fairchild's Anti-Counterfeiting Policy is also stated on our external website, www.fairchildsemi.com, under Sales Support. Counterfeiting of semiconductor parts is a growing problem in the industry. All manufacturers of semiconductor products are experiencing counterfeiting of their parts. Customers who inadvertently purchase counterfeit parts experience many problems such as loss of brand reputation, substandard performance, failed applications, and increased cost of production and manufacturing delays. Fairchild is taking strong measures to protect ourselves and our customers from the proliferation of counterfeit parts. Fairchild strongly encourages customers to purchase Fairchild parts either directly from Fairchild or from Authorized Fairchild Distributors who are listed by country on our web page cited above. Products customers buy either from Fairchild directly or from Authorized Fairchild Distributors are genuine parts, have full traceability, meet Fairchild's quality standards for handling and storage and provide access to Fairchild's full range of up-to-date technical and product information. Fairchild and our Authorized Distributors will stand behind all warranties and will appropriately address any warranty issues that may arise. Fairchild will not provide any warranty coverage or other assistance for parts bought from Unauthorized Sources. Fairchild is committed to combat this global problem and encourage our customers to do their part in stopping this practice by buying direct or from authorized distributors. PRODUCT STATUS DEFINITIONS Definition of Terms Datasheet Identification Product Status Advance Information Formative / In Design Preliminary First Production No Identification Needed Full Production Obsolete Not In Production Definition Datasheet contains the design specifications for product development. Specifications may change in any manner without notice. Datasheet contains preliminary data; supplementary data will be published at a later date. Fairchild Semiconductor reserves the right to make changes at any time without notice to improve design. Datasheet contains final specifications. Fairchild Semiconductor reserves the right to make changes at any time without notice to improve the design. Datasheet contains specifications on a product that is discontinued by Fairchild Semiconductor. The datasheet is for reference information only. Rev. I72 © Fairchild Semiconductor Corporation www.fairchildsemi.com
TIP47
物料型号: - TIP47, TIP47TU - TIP48, TIP48TU - TIP49 - TIP50, TIP50TU
器件简介: - 这些是NPN硅晶体管,适用于高电压和开关应用。
引脚分配: - 1. Base - 2. Collector - 3. Emitter
参数特性: - 绝对最大额定值包括集电极-基极电压(VCBO)、集电极-发射极电压(VCEO)、发射极-基极电压(VEBO)、直流集电极电流(Ic)、脉冲集电极电流(IcP)、基极电流(IB)、结温(TJ)和存储温度范围(TSTG)。
功能详解: - 热特性包括集电极耗散(Pc)。 - 电气特性包括集电极-发射极维持电压(VCEo(Sus))、集电极截止电流(ICEO)、发射极截止电流(EBO)、直流电流增益(hFE)、集电极-发射极饱和电压(Vce(sat))、基极-发射极导通电压(VBE(on))和电流增益-带宽积(fT)。
应用信息: - 这些晶体管适用于高电压和开关应用。
封装信息: - TO-220 3L(Single Gauge),提供散装(Bulk)和托盘(Rail)包装方式。
TIP47 价格&库存
很抱歉,暂时无法提供与“TIP47”相匹配的价格&库存,您可以联系我们找货
