TIP115
TIP115
    L3HARRIS
    TO-220-3
    PNP DARLINGTON TRANSISTOR
TIP115 数据手册
TIP115 / TIP117 PNP Epitaxial Silicon Darlington Transistor Features Equivalent Circuit • Monolithic Construction with Built-in Base-Emitter Shunt Resistors • High DC Current Gain: hFE = 1000 @ VCE = -4 V, IC = -1 A (Minimum) • Low Collector-Emitter Saturation Voltage • Industrial Use • Complementary to TIP110 / TIP111 / TIP112 C B 1 TO-220 R1 1.Base 2.Collector 3.Emitter R2 R1 ≅ 10kΩ R2 ≅ 0.6kΩ E Ordering Information Part Number Top Mark Package Packing Method TIP115 TIP115 TO-220 3L (Single Gauge) Bulk TIP117TU TIP117 TO-220 3L (Single Gauge) Rail Absolute Maximum Ratings Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be operable above the recommended operating conditions and stressing the parts to these levels is not recommended. In addition, extended exposure to stresses above the recommended operating conditions may affect device reliability. The absolute maximum ratings are stress ratings only. Values are at TC = 25°C unless otherwise noted. Symbol Parameter Value TIP115 -60 TIP117 -100 TIP115 -60 TIP117 -100 Unit VCBO Collector-Base Voltage VCEO Collector-Emitter Voltage VEBO Emitter-Base Voltage -5 V IC Collector Current (DC) -2 A ICP Collector Current (Pulse) -4 A IB Base Current (DC) -50 mA TJ Junction Temperature 150 °C -65 to 150 °C TSTG Storage Temperature Range © 2001 Fairchild Semiconductor Corporation TIP115 / TIP117 Rev. 1.1.0 V V www.fairchildsemi.com TIP115 / TIP117 — PNP Epitaxial Silicon Darlington Transistor November 2014 Values are at TC = 25°C unless otherwise noted. Symbol PC Parameter Value Collector Dissipation (TA = 25°C) 2 Collector Dissipation (TC = 25°C) 50 Unit W Electrical Characteristics(1) Values are at TC = 25°C unless otherwise noted. Symbol VCEO(sus) Parameter Collector-Emitter Sustaining Voltage ICEO Collector Cut-Off Current ICBO Collector Cut-Off Current IEBO Emitter Cut-Off Current hFE DC Current Gain Conditions TIP115 IC = -30 mA, IB = 0 TIP117 Min. Max. -60 Unit V -100 TIP115 VCE = -30 V, IB = 0 -2 TIP117 VCE = -50 V, IB = 0 -2 TIP115 VCB = -60 V, IE = 0 -1 TIP117 VCB = -100 V, IE = 0 -1 VEB = -5 V, IC = 0 -2 mA IC = -2 A, IB = -8 mA -2.5 V VCE = -4 V, IC = -1 A 1000 VCE = -4 V, IC =- 2 A 500 mA mA VCE(sat) Collector-Emitter Saturation Voltage VBE(on) Base-Emitter On Voltage VCE = -4 V, IC = -2 A -2.8 V Output Capacitance VCB = -10 V, IE = 0, f = 0.1 MHz 200 pF Cob Note: 1. Pulse test: pw ≤ 300 μs, duty cycle ≤ 2%. © 2001 Fairchild Semiconductor Corporation TIP115 / TIP117 Rev. 1.1.0 www.fairchildsemi.com 2 TIP115 / TIP117 — PNP Epitaxial Silicon Darlington Transistor Thermal Characteristics 10k -5 IB = -1000μA VCE = -4V IB = -800μA -4 IB IB = -700μA IB = -600μA IB = -300μA IB = -500μA -3 0μA = -40 hFE, DC CURRENT GAIN IC[A], COLLECTOR CURRENT IB = -900μA IB = -200μA -2 IB = -100μA -1 -1 -2 -3 -4 100 10 -0.01 -0 -0 1k -5 -0.1 -10 IC[A], COLLECTOR CURRENT VCE[V], COLLECTOR-EMITTER VOLTAGE Figure 1. Static Characteristic VBE(sat), VCE(sat)[V], SATURATION VOLTAGE -1 Figure 2. DC Current Gain -100 1000 IC = 500 IB Cob[pF], CAPACITANCE f = 0.1 MHz -10 VBE(sat) -1 VCE(sat) -0.1 -0.01 -0.1 -1 100 10 1 -0.01 -10 IC[A], COLLECTOR CURRENT -0.1 -1 -10 -100 VCB[V], COLLECTOR-BASE VOLTAGE Figure 3. Collector-Emitter Saturation Voltage and Base-Emitter Saturation Voltage Figure 4. Collector Output Capacitance -10 80 PC[W], POWER DISSIPATION s s 5m 1m IC[A], COLLECTOR CURRENT 70 DC -1 TIP 115 TIP 116 TIP 117 -0.1 -1 -10 50 40 30 20 10 0 -100 0 25 50 75 100 125 150 175 o VCE[V], COLLECTOR-EMITTER VOLTAGE TC[ C], CASE TEMPERATURE Figure 5. Safe Operating Area © 2001 Fairchild Semiconductor Corporation TIP115 / TIP117 Rev. 1.1.0 60 Figure 6. Power Derating www.fairchildsemi.com 3 TIP115 / TIP117 — PNP Epitaxial Silicon Darlington Transistor Typical Performance Characteristics TIP115 / TIP117 — PNP Epitaxial Silicon Darlington Transistor Physical Dimensions Figure 7. TO-220, MOLDED, 3LEAD, JEDEC VARIATION AB © 2001 Fairchild Semiconductor Corporation TIP115 / TIP117 Rev. 1.1.0 www.fairchildsemi.com 4 TRADEMARKS The following includes registered and unregistered trademarks and service marks, owned by Fairchild Semiconductor and/or its global subsidiaries, and is not intended to be an exhaustive list of all such trademarks. F-PFS¥ FRFET® SM Global Power Resource GreenBridge¥ Green FPS¥ Green FPS¥ e-Series¥ Gmax¥ GTO¥ IntelliMAX¥ ISOPLANAR¥ Making Small Speakers Sound Louder and Better™ MegaBuck¥ MICROCOUPLER¥ MicroFET¥ MicroPak¥ MicroPak2¥ MillerDrive¥ MotionMax¥ MotionGrid® MTi® MTx® MVN® mWSaver® OptoHiT¥ OPTOLOGIC® AccuPower¥ Awinda® AX-CAP®* BitSiC¥ Build it Now¥ CorePLUS¥ CorePOWER¥ CROSSVOLT¥ CTL¥ Current Transfer Logic¥ DEUXPEED® Dual Cool™ EcoSPARK® EfficientMax¥ ESBC¥ ® Fairchild® Fairchild Semiconductor® FACT Quiet Series¥ FACT® FAST® FastvCore¥ FETBench¥ FPS¥ OPTOPLANAR® ® PowerTrench® PowerXS™ Programmable Active Droop¥ QFET® QS¥ Quiet Series¥ RapidConfigure¥ ¥ Saving our world, 1mW/W/kW at a time™ SignalWise¥ SmartMax¥ SMART START¥ Solutions for Your Success¥ SPM® STEALTH¥ SuperFET® SuperSOT¥-3 SuperSOT¥-6 SuperSOT¥-8 SupreMOS® SyncFET¥ Sync-Lock™ ®* ® TinyBoost TinyBuck® TinyCalc¥ TinyLogic® TINYOPTO¥ TinyPower¥ TinyPWM¥ TinyWire¥ TranSiC¥ TriFault Detect¥ TRUECURRENT®* μSerDes¥ UHC® Ultra FRFET¥ UniFET¥ VCX¥ VisualMax¥ VoltagePlus¥ XS™ Xsens™ ௝❺™ * Trademarks of System General Corporation, used under license by Fairchild Semiconductor. DISCLAIMER FAIRCHILD SEMICONDUCTOR RESERVES THE RIGHT TO MAKE CHANGES WITHOUT FURTHER NOTICE TO ANY PRODUCTS HEREIN TO IMPROVE RELIABILITY, FUNCTION, OR DESIGN. TO OBTAIN THE LATEST, MOST UP-TO-DATE DATASHEET AND PRODUCT INFORMATION, VISIT OUR WEBSITE AT HTTP://WWW.FAIRCHILDSEMI.COM. FAIRCHILD DOES NOT ASSUME ANY LIABILITY ARISING OUT OF THE APPLICATION OR USE OF ANY PRODUCT OR CIRCUIT DESCRIBED HEREIN; NEITHER DOES IT CONVEY ANY LICENSE UNDER ITS PATENT RIGHTS, NOR THE RIGHTS OF OTHERS. THESE SPECIFICATIONS DO NOT EXPAND THE TERMS OF FAIRCHILD’S WORLDWIDE TERMS AND CONDITIONS, SPECIFICALLY THE WARRANTY THEREIN, WHICH COVERS THESE PRODUCTS. LIFE SUPPORT POLICY FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF FAIRCHILD SEMICONDUCTOR CORPORATION. As used herein: 1. Life support devices or systems are devices or systems which, (a) are 2. A critical component in any component of a life support, device, or system whose failure to perform can be reasonably expected to intended for surgical implant into the body or (b) support or sustain life, and (c) whose failure to perform when properly used in cause the failure of the life support device or system, or to affect its accordance with instructions for use provided in the labeling, can be safety or effectiveness. reasonably expected to result in a significant injury of the user. ANTI-COUNTERFEITING POLICY Fairchild Semiconductor Corporation's Anti-Counterfeiting Policy. Fairchild's Anti-Counterfeiting Policy is also stated on our external website, www.fairchildsemi.com, under Sales Support. Counterfeiting of semiconductor parts is a growing problem in the industry. All manufacturers of semiconductor products are experiencing counterfeiting of their parts. Customers who inadvertently purchase counterfeit parts experience many problems such as loss of brand reputation, substandard performance, failed applications, and increased cost of production and manufacturing delays. Fairchild is taking strong measures to protect ourselves and our customers from the proliferation of counterfeit parts. Fairchild strongly encourages customers to purchase Fairchild parts either directly from Fairchild or from Authorized Fairchild Distributors who are listed by country on our web page cited above. Products customers buy either from Fairchild directly or from Authorized Fairchild Distributors are genuine parts, have full traceability, meet Fairchild's quality standards for handling and storage and provide access to Fairchild's full range of up-to-date technical and product information. Fairchild and our Authorized Distributors will stand behind all warranties and will appropriately address any warranty issues that may arise. Fairchild will not provide any warranty coverage or other assistance for parts bought from Unauthorized Sources. Fairchild is committed to combat this global problem and encourage our customers to do their part in stopping this practice by buying direct or from authorized distributors. PRODUCT STATUS DEFINITIONS Definition of Terms Datasheet Identification Product Status Advance Information Formative / In Design Preliminary First Production No Identification Needed Full Production Obsolete Not In Production Definition Datasheet contains the design specifications for product development. Specifications may change in any manner without notice. Datasheet contains preliminary data; supplementary data will be published at a later date. Fairchild Semiconductor reserves the right to make changes at any time without notice to improve design. Datasheet contains final specifications. Fairchild Semiconductor reserves the right to make changes at any time without notice to improve the design. Datasheet contains specifications on a product that is discontinued by Fairchild Semiconductor. The datasheet is for reference information only. Rev. I72 © Fairchild Semiconductor Corporation www.fairchildsemi.com
TIP115 价格&库存
很抱歉,暂时无法提供与“TIP115”相匹配的价格&库存,您可以联系我们找货
